seb101
Access to Webfig/SSH from Mgmt VLAN
Thu May 02, 2024 5:15 pm
Hi all,
I've just got a SXT LTE Modem kit, this is my first Mikrotik Router device and boy is the interface a steep learning curve!
What I want to acheive is very simple at the end of the day, I want the LTE modem in passthrough mode to ether1, I know how to do this part. Then I want to be able to access the management interface of the SXT device (RouterOS) also over ether1 on VLAN100, this VLAN is already active as the mangement VLAN in my network and has a DHCP server.
So my steps so far:
1. Create an Interface->VLAN with VLAN tag 100 - Success I can see traffic on the interface
2. Add a IP->DHCP client to interface VLAN100 - Success I can see an IP is assigned from the DHCP server
3. Remove ether1 from the defconf bridge - Success (but is this really needed?)
3. Connect to management interface from a host on VLAN 100 - Fail, management interface is not available/does not respond.
How do I get the RouterOS to accept HTTP/SSH from the new VLAN100 interface?
Thank you!
TheCat12
Re: Access to Webfig/SSH from Mgmt VLAN
Sun May 05, 2024 12:08 pm
An exported config is highly advisable to be able to diagnose the problem
/export file=anynameyouwish (minus sensitive information)
Users browsing this forum: mnkt, svant and 39 guests
