ilium007
Audience mesh on RouterOS 7
Tue May 07, 2024 3:04 am
Hi - I recall reading through a forum post some time ago re. mesh not working on the Audience under RouterOS 7. Is this the case? I have one Audience running 7.14.3 and look gin at purchasing another to use the 160MHz mesh channel but not sure if it works.
Nullcaller
Re: Audience mesh on RouterOS 7
Tue May 07, 2024 6:18 pm
It depends on what exactly you have in mind. If you want true mesh with 3+ Audiences, I don't know. If you just want to connect 1+ Audience to a master Audience wirelessly, there's this topic.
vingjfg
Tue May 07, 2024 9:35 pm
My experience with ROs 6 is that trying to set up the mesh can be a lot of trouble. With 2 devices, consider one as AP, the other one as STATION-BRIDGE. That works rather well.
My setup has 3 Audience and they are plowing along without a hitch.
ilium007
Wed May 08, 2024 10:49 am
Thanks for the replies. I will give AP / STATION-BRIDGE a go.
Simonej
Thu May 09, 2024 9:58 pm
Hi, I just managed to have 2x Audience with Caps man enabled, working better than expected!
Use wifi1&2 as standard AP mode (till 2 Wi-Fi networks you can have roaming enabled as CAPs and VLAN), wifi3 as AP + bridge.
If you need help I can share my config.
pajapatak
Mon May 13, 2024 11:48 am
Hello @Simonej,
can you please share (the relevant part of) the configuration? I am thinking of a similar setup (not with Audiences though), so a configuration which works would be very helpful!
Users browsing this forum: No registered users and 15 guests
