predel
iPhone lock update.
Tue May 07, 2024 10:03 am
I have an RB760iGS router. I'm just starting out and getting to know the device.
I have a problem with my iphone 12. The Internet works on it via WiFi without any problem, but the problem is with updating the software.
Unfortunately it doesn't want to update. I don't see the drop in the logs, or I don't know how to look for it yet.
Other Android phones or Windows computers do not have such problems. I haven't noticed them yet.
Can you help me how to search for such problems?
Thank you Piter
Kanzler
Re: iPhone lock update.
Tue May 07, 2024 10:07 am
I very much doubt that the reason is in the router, but anyway, please show me your config
Kanzler
Tue May 07, 2024 10:09 am
Does the update work if you are connected to a different router?
predel
Tue May 07, 2024 4:31 pm
It works when I turn on Wi-Fi and use LTE.
I don't have much in the configuration because I'm just starting out. Are firewall rules enough for you?
Kanzler
Tue May 07, 2024 4:38 pm
It's best to see the full configuration
predel
Tue May 07, 2024 4:49 pm
is there any command for this?
Kanzler
Tue May 07, 2024 5:10 pm
/export file=config
jaclaz
Tue May 07, 2024 5:33 pm
Follow this:
viewtopic.php?t=203686#p1051720
predel
Tue May 07, 2024 5:36 pm
# may/07/2024 16:23:33 by RouterOS 6.49.15
# software id = NXXXX
# model = RB760iGS
# serial number = XXXXX
add arp=reply-only name=BR-LAN
set [ find default-name=ether1 ] name=ether1_LAN
set [ find default-name=ether2 ] name=ether2_LAN
set [ find default-name=ether3 ] name=ether3_LAN
set [ find default-name=ether4 ] name=ether4_LAN
set [ find default-name=ether5 ] name=ether5_LAN
set [ find default-name=sfp1 ] name=sfp1_WAN
add name=LAN
add name=WAN
/ip firewall layer7-protocol
add name=block_site regexp=facebook.com
/ip kid-control
add fri=7h-23h59m mon=7h-20h30m name=MATI sat=7h-23h59m sun=7h-20h30m thu=\
7h-20h30m tue=7h-20h30m wed=7h-20h30m
add mon=7h-16h30m,19h-20h30m name=ALA sat=7h-22h sun=7h-21h thu=\
7h-16h30m,19h-20h30m tue=7h-16h30m,19h-20h30m wed=7h-17h30m,19h-20h30m
add disabled=yes fri=9h-10h,18h50m-23h59m mon=9h-10h,18h50m-23h59m name=\
chromecast-tv sat=6h-23h59m sun=6h-23h59m thu=9h-10h,18h50m-23h59m tue=\
9h-10h,18h50m-23h59m wed=9h-10h,18h50m-23h59m
add disabled=yes fri=0s-15h30m mon=0s-15h30m name=NIEZNANI sat=0s-15h30m sun=\
0s-15h30m thu=0s-15h30m tue=0s-15h30m wed=0s-15h30m
add name=dhcp_pool1 ranges=10.10.0.10-10.10.0.200
add name=dhcp_trap ranges=10.10.0.200-10.10.0.220
add name=dhcp_static ranges=10.10.0.5-10.10.0.49
add name=dhcp_pool2 next-pool=dhcp_static ranges=10.10.0.50-10.10.0.200
add add-arp=yes address-pool=dhcp_pool2 disabled=no interface=BR-LAN \
lease-time=1d name=dhcp1
/queue simple
add max-limit=50M/165M name="All LAN" target=10.10.0.0/24
add max-limit=50M/50M name=VENOM parent="All LAN" target=10.10.0.198/32
add max-limit=10M/120M name="Piotrek Firmowy" parent="All LAN" target=\
10.10.0.199/32
add bridge=BR-LAN interface=ether1_LAN
add bridge=BR-LAN interface=ether2_LAN
add bridge=BR-LAN interface=ether3_LAN
add bridge=BR-LAN interface=ether4_LAN
add bridge=BR-LAN interface=ether5_LAN
add interface=sfp1_WAN list=WAN
add interface=BR-LAN list=LAN
add address=10.10.0.1/24 interface=BR-LAN network=10.10.0.0
/ip dhcp-client
add disabled=no interface=sfp1_WAN
/ip dhcp-server alert
add disabled=no interface=BR-LAN on-alert="pojawi\B3 si\EA nieznany host"
/ip dhcp-server lease
add address=10.10.0.199 client-id=1:74:78:27:77:40:37 comment=\
Piotrek-laptop-firmowy mac-address=74:78:27:77:40:37 server=dhcp1
add address=10.10.0.198 client-id=1:d8:50:e6:3f:ba:5f comment=\
Piotrek-stacjonarny mac-address=D8:50:E6:3F:BA:5F server=dhcp1
add address=10.10.0.191 client-id=1:0:31:92:c5:f2:a0 comment=AC-deco-dol \
mac-address=00:31:92:C5:F2:A0 server=dhcp1
add address=10.10.0.115 client-id=1:f8:25:51:36:cd:6d comment=Drukarka \
mac-address=F8:25:51:36:CD:6D server=dhcp1
add address=10.10.0.190 client-id=1:64:6e:e0:4a:d0:a3 mac-address=\
64:6E:E0:4A:D0:A3 server=dhcp1
add address=10.10.0.183 client-id=1:84:e3:42:7d:eb:e5 comment=TUYA-GATEWAY \
mac-address=84:E3:42:7D:EB:E5 server=dhcp1
add address=10.10.0.181 client-id=1:8:1c:6e:b2:b3:a0 comment=Piotrek-Telefon \
mac-address=08:1C:6E:B2:B3:A0 server=dhcp1
add address=10.10.0.180 client-id=1:16:54:db:3:1d:8e comment=\
MATI-Telefon-POCO mac-address=16:54:DB:03:1D:8E server=dhcp1
add address=10.10.0.179 client-id=1:d8:fc:93:8a:d6:8f comment=MATI-Laptop \
mac-address=D8:FC:93:8A:D6:8F server=dhcp1
add address=10.10.0.178 client-id=1:62:fe:6b:b3:2d:af comment=\
MATI-Telefon-Redmi mac-address=62:FE:6B:B3:2D:AF server=dhcp1
add address=10.10.0.176 client-id=1:0:31:92:c6:36:10 comment=AC-deco-gora \
mac-address=00:31:92:C6:36:10 server=dhcp1
add address=10.10.0.175 client-id=1:40:fa:fe:89:10:f5 comment=\
ANIA-Moto-firmowy mac-address=40:FA:FE:89:10:F5 server=dhcp1
add address=10.10.0.174 client-id=1:1c:53:f9:b:26:6c comment=Chromecast-salon \
mac-address=1C:53:F9:0B:26:6C server=dhcp1
add address=10.10.0.173 client-id=1:f4:c8:8a:7d:f1:bd comment=ALA-Laptop-WiFi \
mac-address=F4:C8:8A:7D:F1:BD server=dhcp1
add address=10.10.0.172 client-id=1:68:a8:6d:9:69:70 comment=ANIA-MacBook \
mac-address=68:A8:6D:09:69:70 server=dhcp1
add address=10.10.0.171 client-id=1:a8:4a:28:77:f6:80 comment=ANIA-iPhone \
mac-address=A8:4A:28:77:F6:80 server=dhcp1
add address=10.10.0.170 client-id=1:48:4b:aa:91:57:da comment=ALA-Telefon \
mac-address=48:4B:AA:91:57:DA server=dhcp1
add address=10.10.0.182 client-id=1:50:e5:49:5c:9b:b1 comment=\
MATI-Desktop-str mac-address=50:E5:49:5C:9B:B1 server=dhcp1
add address=10.10.0.113 client-id=1:1c:99:57:7c:f5:b comment=\
ANIA-laptop-firmowy mac-address=1C:99:57:7C:F5:0B server=dhcp1
add address=10.10.0.112 comment=MATI-CHROMECAST mac-address=B0:2A:43:36:43:B3 \
server=dhcp1
add address=10.10.0.104 always-broadcast=yes comment="Server Lenovo SRV01" \
lease-time=52w1d mac-address=6C:4B:90:79:B6:68 server=dhcp1
add address=10.10.0.88 client-id=\
ff:0:4c:cf:36:0:1:0:1:2d:7c:9d:ad:52:54:0:4c:cf:36 comment=\
KVM-bacula-server mac-address=52:54:00:4C:CF:36 server=dhcp1
add address=10.10.0.87 client-id=1:30:83:d2:fc:31:a4 comment=Piotrek-Motorola \
mac-address=30:83:D2:FC:31:A4 server=dhcp1
add address=10.10.0.85 client-id=1:0:f7:6f:a9:6a:33 comment=\
ALA-Telefon-Zastepczy mac-address=00:F7:6F:A9:6A:33 server=dhcp1
add address=10.10.0.98 client-id=1:6c:4b:90:79:b6:68 lease-time=52w1d \
add address=10.10.0.201 mac-address=C0:A5:E8:11:72:77
add address=10.10.0.84 client-id=1:3e:81:1e:f5:3d:10 comment=\
ALA-Samsung-GalaxyA25 mac-address=3E:81:1E:F5:3D:10 server=dhcp1
add address=10.10.0.80 client-id=1:52:54:0:cc:b0:26 comment=\
Piotrek-KVM-Windows10 mac-address=52:54:00:CC:B0:26 server=dhcp1
add address=10.10.0.195 client-id=1:52:54:0:89:9b:49 comment=\
Piotrek-KVM-Debian mac-address=52:54:00:89:9B:49 server=dhcp1
add address=10.10.0.0/24 comment="DHCP LAN" dns-server=8.8.8.8,8.8.4.4 \
domain=maj.ovh gateway=10.10.0.1 netmask=24 ntp-server=\
194.146.251.100,194.146.251.101
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 disabled=yes list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 disabled=yes list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 disabled=yes list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 disabled=yes list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 disabled=yes list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 disabled=yes list=not_in_internet
add address=224.0.0.0/4 comment=Multicast disabled=yes list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 disabled=yes list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 disabled=yes list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 disabled=yes list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 disabled=yes list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 disabled=yes list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 disabled=yes list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 disabled=yes list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" disabled=\
add address=10.10.0.198 list=tiktok-ALLOW
add action=fasttrack-connection chain=forward disabled=yes
add action=accept chain=input dst-port=8291 protocol=tcp src-address=\
10.10.0.0/24
add action=accept chain=input dst-port=22 protocol=tcp src-address=\
10.10.0.0/24
add action=accept chain=input dst-port=8080 protocol=tcp src-address=\
10.10.0.0/24
add action=accept chain=input protocol=icmp src-address=10.10.0.0/24
add action=accept chain=input dst-port=53 protocol=udp src-port=53
add action=accept chain=input in-interface-list=LAN
add action=accept chain=input comment=defconf connection-state=\
established,related,new
add action=accept chain=input comment="Allow from LAN" in-interface-list=LAN
add action=drop chain=forward comment="Block Sites" disabled=yes dst-port=\
80,443 layer7-protocol=block_site log=yes log-prefix=block_sites \
protocol=tcp
add action=add-dst-to-address-list address-list=wp address-list-timeout=\
none-dynamic chain=forward comment="container wp" content=wp.pl \
add action=add-dst-to-address-list address-list=snapchat \
address-list-timeout=none-dynamic chain=forward comment=\
"counter snapchat" content=snapchat.com src-address=10.10.0.0/24
add action=add-dst-to-address-list address-list=instagram \
"counter instagram" content=instagram.com src-address=10.10.0.0/24
add action=add-dst-to-address-list address-list=tiktok address-list-timeout=\
none-dynamic chain=forward comment="container tiktok" content=tiktok.com \
add action=add-dst-to-address-list address-list=onet address-list-timeout=\
none-dynamic chain=forward comment=container.onet.pl content=onet.pl \
add action=add-dst-to-address-list address-list=facebook \
"container facebook" content=facebook.com src-address=10.10.0.0/24
add action=add-dst-to-address-list address-list=yotube address-list-timeout=\
none-dynamic chain=forward comment="container youtube" content=\
youtube.com src-address=10.10.0.0/24
none-dynamic chain=forward comment="container youtube PL" content=\
youtube.pl src-address=10.10.0.0/24
add action=add-dst-to-address-list address-list=netflix address-list-timeout=\
none-dynamic chain=forward comment="container netflix" content=\
netflix.com src-address=10.10.0.0/24
add action=add-dst-to-address-list address-list=player address-list-timeout=\
none-dynamic chain=forward comment="container TVN Player" content=\
player.pl src-address=10.10.0.0/24
add action=drop chain=forward comment="block site youtube" disabled=yes \
dst-address-list=yotube src-address=10.10.0.191
add action=drop chain=input comment="Drop all INPUT"
add action=drop chain=forward comment=NIEZNANI disabled=yes log=yes \
log-prefix=NIEZNANI src-mac-address=40:A3:CC:93:06:E3
add action=drop chain=forward comment="defconf drop forward invalid" \
connection-state=invalid
add action=drop chain=forward comment="Block Tiktock" dst-address-list=tiktok \
add action=drop chain=forward comment="Block snapchat" dst-address-list=\
snapchat src-address=10.10.0.0/24
add action=drop chain=forward comment="Block instagram" disabled=yes \
dst-address-list=instagram fragment=no hotspot="" src-address=\
10.10.0.0/24
add action=masquerade chain=srcnat log=yes log-prefix=mask-port \
out-interface=sfp1_WAN src-address=10.10.0.0/24
add action=redirect chain=dstnat disabled=yes dst-port=80 protocol=tcp \
to-ports=8080
add action=redirect chain=dstnat disabled=yes dst-port=443 protocol=tcp \
to-ports=8080
/ip kid-control device
add mac-address=52:54:00:56:D3:A8 name=Debian-desktop user=MATI
add mac-address=F4:C8:8A:7D:F1:BD name=ZBYCHU user=ALA
add mac-address=D8:FC:93:8A:D6:8F name=MATI-Laptop user=MATI
add mac-address=16:54:DB:03:1D:8E name=MATI-POCO user=MATI
add mac-address=30:83:D2:FC:31:A4 name=motorola user=NIEZNANI
add mac-address=50:E5:49:5C:9B:B1 name=MATI-Desktop user=MATI
add mac-address=B0:2A:43:36:43:B3 name=Chromecast-tv user=chromecast-tv
add mac-address=1C:53:F9:0B:26:6C name=Chromecast-TV-Mati user=chromecast-tv
add mac-address=3E:81:1E:F5:3D:10 name=ALA-Samsung-GalaxyA25 user=ALA
/ip proxy
set anonymous=yes cache-administrator=piotr@XXX cache-path=\
disk1/lost+found
/ip proxy access
add action=deny
add action=deny dst-host=*wp.pl*
/ip service
set telnet address=10.10.0.0/24
set ftp disabled=yes
set www address=10.10.0.0/24
set ssh address=10.10.0.0/24
set winbox address=10.10.0.0/24
set api-ssl address=10.10.0.0/24
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=router
/system logging
set 0 action=disk
set 1 action=disk
set 2 action=disk
set 3 action=disk
/system note
set note="Hello welcome router Mikrotik"
/system ntp client
set enabled=yes primary-ntp=194.146.251.100 secondary-ntp=194.146.251.101
/tool e-mail
set address=mailXX.XXXX.net from=router.XXXX@XXXX.pl password=\
"LXXXXXX" port=587 start-tls=tls-only user=\
router.XXXX@XXXX.pl
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool traffic-monitor
add interface=sfp1_WAN name=tmon1
Amm0
Tue May 07, 2024 5:58 pm
That's kinda far away from the defaults...
You do have some blocking rules... So if some update on iPhone uses same CDN/cloud/etc as something that's blocked... That be one reason it wouldn't work.
If you add a firewall rule BEFORE the drops that just accept all traffic from the IP of the iPhone with update troubles, does that allow an update?
predel
Tue May 07, 2024 6:08 pm
I try to put what I want to play before the drop. I know it's crap right now, but I don't have time to sit down
