ShanerWarnerX
Route a Static IP through Wireguard Tunnel
Tue May 07, 2024 12:10 pm
Hey All,
I have configured a Wireguard Tunnel to a VPS with a Successful Handshake and Can also PING the IP.
The Internet Connection is a PPPoE Dialup with a Dynamic IP (CG-NAT).
I've been trying to create a static route for a Specific IP 192.168.1.43 to go over the WG-Cloud Interface, But it breaks the Connection.
Have even tried to route all traffic over over the WG-Cloud Interface.
Am I missing out on something?
rplant
Re: Route a Static IP through Wireguard Tunnel
Tue May 07, 2024 1:21 pm
One solution
Set up a route table to go via wireguard, and route entry to go via the wireguard interface.
/route table add disabled=no fib name=ViaWG-Cloud
add disabled=no dst-address=0.0.0.0/0 gateway=WG-Cloud routing-table=ViaWG-Cloud
Then for setting up the routing of specified IP Addresses to go via wireguard there are at least a couple of options.
Route Marking packets (possibly more flexible) and Routing Rules (a lot easier for simple cases).
A simple Routing Rule Example
/routing rule
add action=lookup comment="min-prefix=0 all known local routes go via main" disabled=no min-prefix=0 table=main
add action=lookup src-address=192.168.1.43/32 dst-address=0.0.0.0/0 table=ViaWG-Cloud
Very likely you will likely also need to set up a NAT rule on the wireguard tunnel.
(As the other end of the tunnel is unlikely to know what to do with 192.168.1.43)
Likely best option is to add the wireguard tunnel to the WAN interface list, which sets up masquerade and also adds firewalling.
(Assuming near default config)
add interface=WG-Cloud list=WAN
anav
Tue May 07, 2024 4:27 pm
Best to provide config after giving it a go.
ShanerWarnerX
Wed May 08, 2024 10:13 am
I have configured a NAT rule on the CHR (VPS) and tried the configuration last night, It worked. , And decided to go ahead with a fresh configuration once again as I am still learning and wanted to know what I'm exactly doing, But this time it didn't go as planned, I may have missed out on something again.
Could establish a successful Ping to 10.0.1.1 and a Handshake.
Below Is the configuration:
CHR Configuration
/interface wireguard
add listen-port=13231 mtu=1420 name=WG-Server-BLR
add name=WAN
/port
set 0 name=serial0
add interface=ether1 list=WAN
add interface=WG-Server-BLR list=WAN
/interface wireguard peers
add allowed-address=10.0.1.2/32 interface=WG-Server-BLR name=RB5009-Home public-key="ABCDEFGHIJKLMNOPQ123456789"
add address=10.0.1.1/24 interface=WG-Server-BLR network=10.0.1.0
/ip dhcp-client
add action=accept chain=input connection-state=established,related,untracked \
    connection-type=""
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
    WAN
/system note
set show-at-login=no
RB5009 Configuration
add admin-mac=48:A9:8A:9F:B1:C0 auto-mac=no name=bridge
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no mac-address=\
    5C:96:66:50:83:FA name=SFP-ODI-WAN rx-flow-control=auto \
    sfp-shutdown-temperature=70C speed=1Gbps tx-flow-control=auto
set [ find default-name=ether1 ] mac-address=5C:96:66:50:83:FA
add listen-port=13231 mtu=1420 name=WG-Cloud-BLR
/interface vlan
add interface=SFP-ODI-WAN name=VL10-Broadband vlan-id=10
/interface pppoe-client
add add-default-route=yes disabled=no interface=VL10-Broadband name=\
    Instanet-PPPoE-01 use-peer-dns=yes user=ISPUsername
/disk
set usb1 type=hardware
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
    "15 664 676 352" type=partition
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/routing table
add disabled=no fib name=ViaWG-Cloud-BLR
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge disabled=yes interface=ether1
/interface detect-internet
set detect-interface-list=all
add interface=Instanet-PPPoE-01 list=WAN
add interface=SFP-ODI-WAN list=WAN
add allowed-address=0.0.0.0/0 endpoint-address=129.XXX.XX.XX2 endpoint-port=\
    13231 interface=WG-Cloud-BLR public-key=\
add address=192.168.1.10/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=192.168.2.10/24 interface=SFP-ODI-WAN network=192.168.2.0
add address=10.0.1.2/24 interface=WG-Cloud-BLR network=10.0.1.0
/ip arp
add address=192.168.2.1 interface=SFP-ODI-WAN
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.1.43 client-id=1:5c:96:66:50:83:fa mac-address=\
    5C:96:66:50:83:FA server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.10 gateway=\
    192.168.1.10 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.10 comment=defconf name=router.lan
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add disabled=no dst-address=129.XXX.XXX.XX0/32 gateway=Instanet-PPPoE-01 \
    routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Instanet-PPPoE-01 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10 vrf-interface=Instanet-PPPoE-01
add disabled=no dst-address=0.0.0.0/0 gateway=WG-Cloud-BLR routing-table=\
    ViaWG-Cloud-BLR
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup comment="min-prefix=0 all known local routes go via main" \
add action=lookup dst-address=0.0.0.0/0 src-address=192.168.1.43/32 table=\
    ViaWG-Cloud-BLR
/system note
/tool mac-server
/tool mac-server mac-winbox
rplant
Wed May 08, 2024 1:27 pm
add interface=WG-Cloud-BLR list=WAN
Possibly also
Change the wireguard MTU on the 5009 to 1412 (because its inside pppoe)
Add a persistent keep alive on the 5009 (somewhere 25-60 seconds is likely good)
Users browsing this forum: ale2co, ckonsultor, gabeluci, ursaca, zahgl and 37 guests
