Even pinging lo fails, which works on all physical routers:
Code: Select all
[admin@foo-gw] > /ping ::1 count=2
Columns: SEQ, STATUS
SEQ STATUS
0 packet rejected
1 packet rejected
Settings:
Code: Select all
[admin@foo-gw] > /ipv6/settings/print
disable-ipv6: no
forward: yes
accept-redirects: yes-if-forwarding-disabled
accept-router-advertisements: yes
max-neighbor-entries: 16384
Any ideas what exactly is failing if /ping ::1 does not work?
