normis
Newsletter #118 | May 2024
Wed May 15, 2024 2:26 pm
Read our latest newsletter and learn more about:
- NetMetal ax
- L23UGSR-5HaxD2HaxD
- wAP ac LTE kit (refresh)
- LHGG LTE6 kit
- XS+85LC01D 25G modules
- MikroTik Brandbook
- CRS510-8XS-2XQ-IN Review by STH
- Community Success stories: DIN-Rail Mount
https://mt.lv/news118
Rox169
Re: Newsletter #118 | May 2024
Wed May 15, 2024 2:35 pm
please produce proper outdoor antennas. Those are ridiculos...wind kill them in one week....
normis
Wed May 15, 2024 2:40 pm
Which ones? The only antenna in the is the LHG, which is not a new design. Has worked for many years in high winds across the globe
Rox169
Wed May 15, 2024 2:59 pm
The anntenas with the NetMetal AX. Im looking for small omnidirectional and small directional anntenas.
normis
Wed May 15, 2024 3:01 pm
Quoting the text: " If necessary, you can adapt the NetMetal ax for lower range use with such antennas as our HGO-antenna-OUT", that is not the normal use case. This is a long range outdoor product, you attach a dish to it. The small antennas are only for testing it or some special use case.
Rox169
Wed May 15, 2024 3:08 pm
ok, but why you do not offer any small omnidirectional and small directional anntenas?
normis
Wed May 15, 2024 3:13 pm
Antennas is not the main business of MikroTik. There are many 3rd party antennas on the market that work with our devices.
Rox169
Wed May 15, 2024 3:17 pm
no, there are very few antenas on the market. I would by NetBox 5 AX if there was small 20cm omnidirectional anntena
normis
Wed May 15, 2024 3:24 pm
Go check our distributor list, at least in Europe all major distributors carry many WiFi antennas: https://mikrotik.com/buy
sirbryan
Long time Member
Long time Member
Wed May 15, 2024 5:36 pm
That's a pretty uninformed statement. What kind of antenna do you want?
(The following is just from one distributor.)
syadnom
Forum Veteran
Forum Veteran
Wed May 15, 2024 6:51 pm
Really looking forward to some wifi6 CPE. SXT wifi6 etc.
pe1chl
Wed May 15, 2024 9:10 pm
It appears the mt.lv server hosting the newsletter is down at the moment...
Paternot
Wed May 15, 2024 9:27 pm
Looks like it. I'm trying to get it and... timeout is all I get.
Benzebub
Yeah, managed to find it using this link: https://mikrotik.com/mt_redirect.php?code=news118
honzam
Wed May 15, 2024 9:55 pm
Where is 5Ghz AX client? For example DiscAX ? Still waiting...
Amm0
Wed May 15, 2024 9:57 pm
LOL re official font, manrope ... at least it's description matches the product ;)
This font is a crossover of different font types: it is semi-condensed, semi-rounded, semi-geometric, semi-din, semi-grotesque. It employs minimal stoke thickness variations and a semi-closed aperture.
Paternot
Wed May 15, 2024 10:00 pm
It works! Thanks. :D
GolemPL
Wed May 15, 2024 10:20 pm
I have a question about the NetMetal AX: Does it support WiFi seamless roaming? I read somewhere that it requires 1GB of RAM. Is it still necessary to have 1GB of RAM? I'm interested in roaming between CAP AX and NetMetal AX. Will it work?
gosha
Wed May 15, 2024 11:16 pm
When we could wait any new CCR? I'm waiting the model like CCR1036 / CCR1072 with hotswap PSUs and lot of S+ interfaces
sinisa
Wed May 15, 2024 11:52 pm
Why? Where is wAP AX?
Btw. I think that description of NetMetal AX is misleading:
Two RP-SMA connectors allow adding an antenna of your choice
I understood this to mean: there is already an integrated antenna, but you can add an external one.
Of course, integrated antennae in a metal case would not do any good, but I think that description should clarify that you HAVE to add an antenna (or two)...
troffasky
Thu May 16, 2024 12:30 am
s/allow/require/
normis
Thu May 16, 2024 8:11 am
Does the mt.lv link work for everyone now?
BartoszP
Thu May 16, 2024 8:15 am
Works for me :)
pe1chl
Thu May 16, 2024 12:23 pm
Works for me too.
pe1chl
Thu May 16, 2024 12:30 pm
Please consider to make a 5G product similar to what is now on offer for LTE6.
(a separate (semi-)outdoor PoE-powered device that can be connected to an existing PoE-providing router to have a 5G link and can be located at a place with good coverage, i.e. outside of the server-room 19" rack where the router is)
In my case no need for a LHG-type dish, just a good compact antenna in a form factor like SXT or wAP is OK.
bratislav
Thu May 16, 2024 12:37 pm
You mean small outdoor omnidirectional antennas like the HGO-antenna-OUT literally offered with NetMetal ax...
Rox169
Thu May 16, 2024 12:51 pm
yes, imagine..what would do very high wind to this stick... fanny
bratislav
Tue May 21, 2024 9:57 pm
Basically the same thing as it would do to your car antenna, you should try and understand that larger antennas give more resistance to air flow and are therefore more likely to fly away...
BartoszP
Sat May 25, 2024 5:43 pm
kubla36
Sat Jun 22, 2024 3:25 am
Does the L23UGSR-5HaxD2HaxD have support for any 802.11ad/ay/wigig 60GHz minipcie cards?
antonsb
Thu Jun 27, 2024 4:18 pm
No, we have separate 60GHz product line.
