sakhawath066
Required Dude server package
Wed May 15, 2024 2:33 pm
I would like to install Dude server package
My router model is CCR2116-12G-4S+, Architecture is arm64 and Version is 7.14.3 (stable).
but which options i need to install? Can anyone suggest me please?
holvoetn
Re: Required Dude server package  [SOLVED]
Wed May 15, 2024 4:00 pm
Download extra packages for arm64.
Within it you will find dude.
Amm0
Wed May 15, 2024 5:31 pm
And... then copy the dude.npk to the root of the Files & reboot. You need to enable it Dude > Settings and pick a path to store the database. You'd need the Dude client for Windows to then manage it, using same RouterOS login in Dude app.
sakhawath066
Thu May 16, 2024 6:41 am
Many thanks for your great support. it solves my issue.
sakhawath066
Thu May 16, 2024 6:42 am
Thanks for your guidance. I appreciate !
Users browsing this forum: No registered users and 5 guests
