I have setup a router according to my best knowledge. There are a number of separate internal LANs connected to the router. There are 3 services reachable from the internet, SMTP (25) on one public IP address, and HTTP (80) / HTTPS (443) on another public IP. The web server is also accessible internally using it's internet name. This works.
To reach certain services like SMTP (587), printers, RDP across different LANs, I have configured simple forwarding rules to allow traffic from one LAN to another. Those rules work, except for one specific instance.
There is for example the following forwarding rule that works without problem.
Code: Select all
add action=accept chain=forward dst-address=192.168.0.0/23 in-interface-list=LAN src-address=172.16.10.0/24
Code: Select all
add action=accept chain=forward dst-address=172.16.10.93 in-interface=mainnet out-interface=konnet src-address=192.168.0.0/23
Code: Select all
add action=masquerade chain=srcnat dst-address=172.16.10.93 src-address=192.168.0.0/23
Best regards,
Peter
Code: Select all
add frame-types=admit-only-vlan-tagged name=bridge pvid=40 vlan-filtering=yes
set [ find default-name=combo1 ] combo-mode=sfp
/interface vlan
add interface=bridge name=admnet vlan-id=190
add interface=bridge name=guestnet vlan-id=60
add interface=bridge name=konnet vlan-id=10
add interface=bridge name=mainnet vlan-id=1
add interface=bridge name=mgmtnet vlan-id=40
add interface=bridge name=persnet vlan-id=110
add interface=bridge name=proxynet vlan-id=150
add interface=bridge name=testnet vlan-id=220
add name=WAN
add name=LAN
add name=MGMT
add name=DHCP-LAN
add name=USERLAN
add name=konpool ranges=172.16.10.128-172.16.10.254
add name=guestpool ranges=192.168.6.128-192.168.6.254
add name=testpool ranges=192.168.22.201-192.168.22.254
add address-pool=konpool interface=konnet lease-time=12h name=kondhcp
add address-pool=guestpool interface=guestnet name=guestdhcp
add address-pool=testpool interface=testnet lease-time=1d name=testdhcp
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1 pvid=\
974
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether6
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=ether7 pvid=40
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1 \
pvid=975
set loose-tcp-tracking=no
set discover-interface-list=MGMT
/ip settings
set tcp-syncookies=yes
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 vlan-ids=1
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 vlan-ids=10
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 untagged=ether7 vlan-ids=\
40
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 vlan-ids=60
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 vlan-ids=110
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 vlan-ids=150
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 vlan-ids=190
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1 vlan-ids=220
add interface=combo1 list=WAN
add interface=mainnet list=LAN
add interface=konnet list=LAN
add interface=mgmtnet list=LAN
add interface=guestnet list=LAN
add interface=persnet list=LAN
add interface=proxynet list=LAN
add interface=admnet list=LAN
add interface=testnet list=LAN
add interface=mgmtnet list=MGMT
add interface=konnet list=DHCP-LAN
add interface=guestnet list=DHCP-LAN
add interface=testnet list=DHCP-LAN
add interface=mainnet list=USERLAN
add interface=konnet list=USERLAN
add interface=guestnet list=USERLAN
add interface=testnet list=USERLAN
add address=192.168.4.100/24 interface=mgmtnet network=192.168.4.0
add address=aaa.aaa.aaa.aaa/29 interface=combo1 network=aaa.aaa.aaa.xxx
add address=192.168.6.100/24 interface=guestnet network=192.168.6.0
add address=172.16.10.100/24 interface=konnet network=172.16.10.0
add address=192.168.11.100/24 interface=persnet network=192.168.11.0
add address=192.168.15.100/24 interface=proxynet network=192.168.15.0
add address=192.168.19.100/24 interface=admnet network=192.168.19.0
add address=192.168.22.100/24 interface=testnet network=192.168.22.0
add address=192.168.0.101/23 interface=mainnet network=192.168.0.0
add address=bbb.bbb.bbb.1/29 interface=combo1 network=bbb.bbb.bbb.yyy
add address=bbb.bbb.bbb.2/29 interface=combo1 network=bbb.bbb.bbb.yyy
add address=bbb.bbb.bbb.3/29 interface=combo1 network=bbb.bbb.bbb.yyy
add address=172.16.10.0/24 dns-server=172.16.10.11,172.16.10.10 domain=\
kon.talps gateway=172.16.10.100 ntp-server=172.16.10.98
add address=192.168.6.0/24 dns-server=192.168.6.100 gateway=192.168.6.100
add address=192.168.22.0/24 dns-server=192.168.22.10 domain=testdom.talps \
gateway=192.168.22.100 ntp-server=192.168.22.98
set allow-remote-requests=yes servers=123.45.67.8,123.45.67.9
/ip firewall address-list
add address=192.168.4.0/24 list=isolatedLAN
add address=192.168.6.0/24 list=isolatedLAN
add address=192.168.11.0/24 list=isolatedLAN
add address=192.168.15.0/24 list=isolatedLAN
add address=192.168.19.0/24 list=isolatedLAN
add address=192.168.22.0/24 list=isolatedLAN
add address=192.168.0.101 list=routerAddresses
add address=192.168.4.100 list=routerAddresses
add address=192.168.6.100 list=routerAddresses
add address=192.168.11.100 list=routerAddresses
add address=192.168.15.100 list=routerAddresses
add address=192.168.19.100 list=routerAddresses
add address=192.168.22.100 list=routerAddresses
add address=172.16.10.100 list=routerAddresses
# Some incoming packets are first filtered by the RAW table
# Classic start of the rule set from Mikrotik wiki
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
# Allow input from local LAN interfaces that were not dropped by the RAW filter
add action=accept chain=input in-interface-list=LAN
add action=accept chain=input in-interface=mgmtnet
# Drop the rest
# Forward packets not dropped by the RAW table
add action=fasttrack-connection chain=forward connection-state=\
established,related hw-offload=yes
add action=accept chain=forward connection-state=\
# Forward packets that are routed elswhere
add action=accept chain=forward dst-address=10.0.10.0/23 in-interface-list=LAN
add action=accept chain=forward dst-address=10.0.14.0/24 in-interface-list=LAN
# Forward packets from/to limited hosts (SMTP server, RDP)
add action=accept chain=forward dst-address=192.168.0.111 dst-port=587 \
in-interface=guestnet out-interface=mainnet protocol=tcp src-address=\
192.168.6.13
add action=accept chain=forward dst-address=192.168.0.51 dst-port=3389 \
in-interface=guestnet out-interface=mainnet protocol=udp src-address=\
192.168.6.13
192.168.6.13
add action=accept chain=forward dst-address=192.168.6.13 dst-port=23389 \
in-interface=mainnet out-interface=guestnet protocol=udp src-address=\
192.168.0.51
in-interface=mainnet out-interface=guestnet protocol=tcp src-address=\
192.168.0.51
# !!! This is problematic, does not work without masquerade!
add action=accept chain=forward dst-address=172.16.10.93 in-interface=mainnet \
# Forward packets to webserver
add action=accept chain=forward dst-address=192.168.15.0/24 \
in-interface-list=LAN src-address=192.168.0.0/23
# Forward packets from network A to network B, traffic from B to A is prohibited
add action=accept chain=forward dst-address=192.168.0.0/23 in-interface-list=\
# Allow all hosts on 2 different networks to use SMTP server
in-interface=admnet out-interface=mainnet protocol=tcp src-address=\
192.168.19.0/24
in-interface=persnet out-interface=mainnet protocol=tcp src-address=\
192.168.11.0/24
# Allow RDP to one specific host from a single PC
add action=accept chain=forward dst-address=192.168.11.231 dst-port=3389 \
in-interface=mainnet out-interface=persnet protocol=tcp src-address=\
192.168.0.58
# Drop invalid packets
# Allow from LAN to WAN
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN
# Allow dst-nated packages to servers behind the router (SMTP, http, etc.)
add action=accept chain=forward connection-nat-state=dstnat \
in-interface-list=WAN
# Drop everything else
add action=drop chain=forward
# NAT rules, specific rules are on top
# !!! I had to resort to this "trick" to be able to reach the device 172.16.10.9
# from the network 192.168.0.0/23, see forward rule above
# This is strange, as the forward rule from the network 172.16.10.0/24 to 192.168.0.0/23
# does not need masquerading. There are other equivalent rules in the forward chain also
# that do not need masquerading.
add action=masquerade chain=srcnat dst-address=172.16.10.93 \
# All outgoing traffic to the internet from the internal networks through aaa.aaa.aaa.aaa
add action=src-nat chain=srcnat out-interface-list=WAN to-addresses=\
aaa.aaa.aaa.aaa
# dstnat rules to reach internal servers
add action=dst-nat chain=dstnat dst-address=aaa.aaa.aaa.aaa dst-port=25 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.0.112 to-ports=25
add action=dst-nat chain=dstnat dst-address=aaa.aaa.aaa.aaa dst-port=80 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.0.112 to-ports=80
add action=dst-nat chain=dstnat dst-address=aaa.aaa.aaa.aaa dst-port=443 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.0.112 to-ports=\
443
add action=dst-nat chain=dstnat dst-address=bbb.bbb.bbb.3 dst-port=80 \
protocol=tcp to-addresses=192.168.15.99 to-ports=80
add action=dst-nat chain=dstnat dst-address=bbb.bbb.bbb.3 dst-port=443 \
protocol=tcp to-addresses=192.168.15.99 to-ports=443
/ip firewall raw
# Classic RAW icmp filter from Mikrotik wiki
add action=jump chain=prerouting jump-target=icmp4 protocol=icmp
add action=accept chain=icmp4 icmp-options=0:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 icmp-options=3:0 protocol=icmp
add action=accept chain=icmp4 icmp-options=3:1 protocol=icmp
add action=accept chain=icmp4 icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 icmp-options=8:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 icmp-options=11:0-255 protocol=icmp
add action=drop chain=icmp4 protocol=icmp
# Allow public web server also from 2 internal networks
add action=accept chain=prerouting dst-address=192.168.15.99 src-address=\
192.168.0.0/23
172.16.10.0/24
# Drop packets from some internal networks destined to router's WebFig
add action=drop chain=prerouting dst-address-list=routerAddresses dst-port=80 \
log=yes log-prefix=RACC protocol=tcp
# Allow DNS requests from addresses isolatedLAN list, but not from 192.168.4.0/24
add action=accept chain=prerouting dst-port=53 protocol=udp src-address=\
!192.168.4.0/24 src-address-list=isolatedLAN
add action=accept chain=prerouting dst-port=53 protocol=tcp src-address=\
# Allow DHCP requests from hosts in the interface list DHCP-LAN
add action=accept chain=prerouting dst-address=255.255.255.255 dst-port=67 \
in-interface-list=DHCP-LAN protocol=udp src-address=0.0.0.0 src-port=68
# Drop traffic between addresses in isolatedLAN list
add action=drop chain=prerouting dst-address-list=isolatedLAN src-address=\
# Route away packets that should be handled elsewhere
add disabled=no dst-address=10.0.10.0/24 gateway=192.168.0.216 routing-table=\
main suppress-hw-offload=no
add disabled=no dst-address=10.0.11.0/24 gateway=192.168.0.216 routing-table=\
add disabled=no dst-address=10.0.14.0/24 gateway=172.16.10.97 routing-table=\
