Aesposito
is there a chance to downgrade routerOS?
Thu May 23, 2024 5:57 pm
hi guys
i was wondering, is there a possibility to downgrade a firmware? in my example i would like to downgrade from 7.14 to 6.49. i tried the same procedure as upgrading (uploading the nbk file, reboot) but it did not work. is it possible? if yes how?
Kanzler
Re: is there a chance to downgrade routerOS?  [SOLVED]
Thu May 23, 2024 5:58 pm
anovojr
Thu May 23, 2024 8:08 pm
Yep, you can downgrade firmware, but it can be tricky. Make sure you have the right file.
holvoetn
Thu May 23, 2024 8:23 pm
OP: what device are we talking about ? What was the installed version when you got it ?
Yet you can not go lower then factory version.
Sometimes it's even impossible (e.g. on AX devices, forget about ROS6).
Users browsing this forum: Bing [Bot] and 27 guests
