Fri May 24, 2024 4:25 pm
Rate-Select is set to high on all devices (FEC-Mode is set to auto)
It's the same on all interfaces - and no matter what I do....
- CRS326 here: 6GBit/s with the bandwidth Tester
- CRS518 there: 100MBit/s
awful.
I have to append that we're using single mode SFPs for the 100G (we have single mode cabling). I have not seen any package drops...
status: link-ok
auto-negotiation: disabled
rate: 100Gbps
full-duplex: yes
tx-flow-control: yes
rx-flow-control: yes
fec: off
supported: 10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,
1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR,40G-baseSR4-LR4,
40G-baseCR4,25G-baseSR-LR,25G-baseCR,50G-baseSR2-LR2,50G-baseCR2,100G-baseSR4-LR4,
100G-baseCR4
sfp-supported: 1G-baseX,10G-baseSR-LR,25G-baseSR-LR,100G-baseSR4-LR4
sfp-module-present: yes
sfp-type: QSFP28/QSFP56
sfp-connector-type: LC
sfp-link-length-sm: 10km
sfp-vendor-name: FS
sfp-vendor-part-number: QSFP28-LR4-100G
sfp-vendor-revision: 01
sfp-vendor-serial: G2311058537
sfp-manufacturing-date: 20231123
sfp-wavelength: 1310nm
sfp-temperature: 44C
sfp-supply-voltage: 3.272V
sfp-tx-bias-current: 56mA
sfp-tx-power: 0.614dBm
sfp-rx-power: 0.768dBm
eeprom-checksum: good
eeprom: 0000: 11 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0010: 00 00 00 00 00 00 2c 9d 00 00 7f d0 00 00 00 00 ......,. ........
0020: 00 00 2e a1 2d 89 2b 02 2a f7 6e 19 6b 9d 6e 89 ....-.+. *.n.k.n.
0030: 6e 7e 2d 00 36 91 2f a6 32 8b 00 00 00 00 00 00 n~-.6./. 2.......
0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0060: 00 00 ff 00 00 00 00 00 00 00 1f 00 00 00 00 00 ........ ........
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0080: 11 ce 07 80 00 00 00 00 00 00 00 03 ff 02 0a 00 ........ ........
0090: 00 00 00 64 46 53 20 20 20 20 20 20 20 20 20 20 ...dFS
The 25GB DA Cables look like this:
status: link-ok
rate: 25Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
fec: off
1G-baseT-full,1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,
10G-baseCR,25G-baseSR-LR,25G-baseCR
sfp-supported: 1G-baseT-full,1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseCR,25G-baseCR
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP/SFP+/SFP28/SFP56
sfp-connector-type: copper-pigtail
sfp-link-length-copper-active-om4: 1m
sfp-vendor-name: FS
sfp-vendor-part-number: S28-PC01
sfp-vendor-revision: A
sfp-vendor-serial: F2230383968-2
sfp-manufacturing-date: 24-01-25
sfp-dwdm-channel-spacing: 13Ghz
eeprom: 0000: 03 04 21 00 00 00 00 00 04 00 00 00 ff 00 00 00 ..!..... ........
0010: 00 00 01 00 46 53 20 20 20 20 20 20 20 20 20 20 ....FS
0020: 20 20 20 20 0d 78 a7 14 53 32 38 2d 50 43 30 31 .x.. S28-PC01
0030: 20 20 20 20 20 20 20 20 41 20 20 20 00 00 00 44 A ...D
0040: 00 00 68 00 46 32 32 33 30 33 38 33 39 36 38 2d ..h.F223 0383968-
0050: 32 20 20 20 32 34 30 31 32 35 20 20 00 00 00 e7 2 2401 25 ....
0060: 80 00 1b 82 86 c2 8a 85 9b c4 bf 45 13 73 85 f1 ........ ...E.s..
0070: 7f a5 d2 00 00 00 00 00 00 00 00 00 93 34 e9 f3 ........ .....4..
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
EDIT:
> are the low bandwidths on the SFP+ ports or on the QSFP (100G) ports? because on the 100G links there might be an improvement if you configure
> FEC on the CRS and the other switch (FEC must be the same on both link ends!)
No, they are not. But I'm anyways not talking about 10 or 15GBit - I am talking about MEGABITS. We currently have 300 MBit/sec throughput. Not even one Gigabit.
Something is completely off - and I have no clue what it is at the moment. No matter what ports I use... 25GBit/s DAC, 10Gbit/s SFPs, 10GBit/s DAC or 100GBit/s QSFP25 - the CPU load goes up like crazy (and yes, the system shows the HW Offload is on) but it's like having a 20 year old cablemodem wedged in between (probably even worse).
Tobias
