Hi all.
I fear something is being filtered out by my ISP as I cannot connect to BTH VPN via wireguard app.
The Android APP says (translate from Italian) that "VPN cannot be activated: VPN service not authorized by the user".
On my Android device there is no such an authorization to be granted to the app itself, so I suspect it is something on my RB5009.
Which protocols do I need to be available onto my home RB5009 WAN to make sure BTH VPN Wireguard works?
This is my environment.
Device: RB5009
RouterOS: 7.14.3
Android: 14
Mikrotik BTH app version: 0.24
Wireguard Android app version: 1.0.20231018
I used Winbox to:
1. Enable IP/Cloud/BTH VPN
2. I created a user in IP/Cloud/Back To Home Users
3. I got the QR code from that user config into Mikrotik BTH app: no way to connect as the power button doesn't react.
4. I got the QR code from IP/Cloud/BTH VPN Wireguard int oWireguard VPN app: "VPN cannot be activated: VPN service not authorized by the user".
I cannot use WiFi in this very case.
