kleshki
hap ax3 random wireless disconnects
Thu Jun 06, 2024 12:12 am
Hi everyone.
I've recently changed my tp-link archer ax50 for hap ax3. Now I have some problems with 5GHz wireless. The firmware version is 7.15 Here's my config
 1 M BR default-name="wifi1" name="wifi-5ghz" l2mtu=1560 mac-address=D4:01:C3:9D:86:32 arp-timeout=auto radio-mac=D4:01:C3:9D:86:32 configuration=home-private-cfg
        configuration.mode=ap .ssid="MikroTik-Home" .country=United States .antenna-gain=0
        security=home-private
        security.authentication-types=wpa2-psk .passphrase="_removed_" .ft=yes .ft-over-ds=yes
        channel=5ghz
        channel.frequency=5180-5320,5660-5845 .band=5ghz-ax .width=20/40/80mhz
The problems are:
1. MSI laptop ax-capable states that it connects using 802.11ac (was ax with archer).
2. Random disconnects mostly under load. Windows shows full or 2/3 points signal and around 500Mbps transmit bandwidth.
Here's log with debug enabled:
 06-06 01:39:49 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -81
 06-06 01:39:49 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -81
 06-06 01:39:55 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 20
 06-06 01:39:55 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 20
 06-06 01:39:58 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -76
 06-06 01:39:58 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -76
 06-06 01:40:00 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 20
 06-06 01:40:00 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 20
 06-06 01:40:03 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -75
 06-06 01:40:03 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -75
 06-06 01:40:05 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 21
 06-06 01:40:05 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength -73
Here I can clearly see that MikroTik "thinks" there's bad signal, but it was ok with archer and Windows also think so, and the laptop is literally in the next room to the router without significant obstacles (i.e. there's even no door between rooms).
I've started my config without country, antenna gain and "ft" parameters and with wpa3 enabled, going step by step with disabling wpa3, setting country, setting antenna gain, enabling ft - nothing solved the problem. Both Samsung android phones doesn't seem to have this problem, however I didn't pushed any significant network load on them, like YT or something.
Do I miss something?
tangent
Re: hap ax3 random wireless disconnects
Thu Jun 06, 2024 5:18 am
Here's my config
It would be clearer if you posted the sanitized output of "/interface/wifi/export", not "print" because that includes sub-items like the configuration and security sections.
One thing this can show more clearly is when you have redundant or conflicting items in the "configuration" and "interface" sections, for example. The "configuration" should abstract as much as possible that is the same between the 2.4 and 5GHz radios, leaving the "interface" element to override only the unique parts.
A clean implementation of that will look something like this:
/interface wifi configuration add country="United States" mode=ap name=homecfg security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes .passphrase="nunyaBinness" ssid="Home WiFi"
/interface wifi set [ find default-name=wifi2 ] channel.band=2ghz-ax .width=20/40mhz configuration=homecfg
/interface wifi set [ find default-name=wifi1 ] channel.band=5ghz-ax .width=20/40/80mhz configuration=homecfg
The point is, there is only one "configuration" for both radios, and they differ only in the frequencies and such.
Then there is an incompatibility. It may be enough to explain everything else you're seeing. Your task is to find out what the laptop wants that the MT isn't providing. The fix may be a settings change away, or it may be a hard limit on one end or the other.
This isn't necessarily a problem. It is possible that all you're getting here is additional visibility into what's going on that your old router didn't tell you.
A common reason for this type of behavior is bouncing between the 2.4 and 5GHz sides of the network.
That said, I don't see a reconnection event immediately afterward on the other network, so… 🤷‍♂️
WiFi doesn't use airborne transmission. 😛
The wall between the two rooms is likely more relevant to the router's operating conditions than the human-sized door frame and hallway between them.
RouterOS has defaulted to "Latvia" for the last few releases, so unless that's where you live, you should always set the country.
antenna gain
Unless you're doing something advanced, you should leave this unset. Being the lowest legal value, "0" is likely wrong even if you do have good cause to be setting it.
kleshki
Thu Jun 06, 2024 11:49 am
Hi @tangent and thanks for your detailed answer!
Here's export of wifi section
int wifi export
# 2024-06-06 13:21:28 by RouterOS 7.15
# software id = **ELIDED**
# model = C53UiG+5HPaxD2HPaxD
# serial number = **ELIDED**
/interface wifi channel
add band=5ghz-ax disabled=no frequency=5180,5220 name=5ghz skip-dfs-channels=all width=20/40/80mhz
add antenna-gain=0 country="United States" disabled=no name=home-private-cfg security.authentication-types="" .ft=no .ft-over-ds=no ssid=MikroTik-Home
/interface wifi security
add authentication-types=wpa2-psk disable-pmkid=yes disabled=no name=home-private
/interface wifi
set [ find default-name=wifi2 ] configuration=home-private-cfg configuration.mode=ap name=wifi-2.4ghz security=home-private security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel=5ghz configuration=home-private-cfg configuration.mode=ap disabled=no name=wifi-5ghz security=home-private security.authentication-types=wpa2-psk
I have my 2.4G interface completely disabled for now, since I don't have any IoT yet, and that was the same on previous router. I don't need this band for now, so there's no switching between, old router is powered off. I did exactly as you described - everything in config is separated from the physical interface (except for authentication types - they seem to be ignored from security config, leaving my network "open", and only setting them to the physical interface did the job. This seems like a new bug for me, bcz it worked in ROS6).
And about provided logs - at first, I just did configuration and started using network. However, I noticed frequent disconnects on the laptop, lasting for like 5-20 seconds or so to reconnect automatically. That's why I'd opened logs, and this is the events that are logged when disconnect occurs. Also, when disconnect happens, laptop shows 1/3 SSID signal strength and tries to reconnect, and when reconnect happens it becomes 3/3 again. Laptop is literally used as desktop now, with same positioning for itself and old router/new ax3. With old router I played online games no problems or disconnects.
Also have to notice that wireless quality itself is perfect until it disconnects, i.e. surfing is omega-fast and smooth, no lags for youtube or twitch (or both at once).
Things that I've also read from this forum or reddit before posting:
1. Possible antenna damage - I had my antennas attached before power on
2. Possible ROS7.15 wireless bugs - signal strength sometimes shows above zero, can firmware version be the cause of the problems?
This is the log of one of disconnect events, showing this
 13:39:32 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -75
 13:39:32 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -75
 13:39:34 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 21
 13:39:35 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 21
 13:46:40 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -76
 13:46:40 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -76
 13:46:43 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 17
 13:46:43 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 17
 13:46:49 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -71
 13:46:49 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -71
 13:46:51 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 21
 13:46:51 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 21
 13:46:53 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength 21
 13:46:53 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength 21
 13:46:55 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 17
 13:46:56 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 17
 13:46:58 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -74
 13:46:58 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -74
 13:46:59 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 20
 13:46:59 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 20
 13:47:01 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -74
 13:47:01 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -74
 13:47:03 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 20
 13:47:03 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 20
3. Wireless interfaces are bridged but should not be - they are, but doubt it affects wireless connectivity, since I did same config in ROS6.
4. Tried to play with frequencies - leaving it blank sets channel to 5500, and SSID becomes invisible to Samsung S21
Reason: elided PII
erlinden
Thu Jun 06, 2024 12:09 pm
The antenna gain is incorrect, it should be 5 or 6 (in the manual it shows 5.5). Don't know what the default is, at least it is not 0.
kleshki
Thu Jun 06, 2024 12:24 pm
Can't set it to decimal value, gonna try with 5 and respond back with results.
Any ideas on why laptop is not recognizing ax protocol tho? Because Samsung shows "6" on the wireless icon, not sure if it's using ax but I think it is, while laptop is always at .11ac no matter what configs I did before
erlinden
Thu Jun 06, 2024 12:41 pm
What exact wireless card is in the laptop?
kleshki
Thu Jun 06, 2024 12:48 pm
Intel(R) Wi-Fi 6 AX201 160MHz
erlinden
Thu Jun 06, 2024 1:27 pm
Strange, as the MikroTik is supplying and the laptop is capable. Have you checked with an app like Wifi Analyzer?
I also notice you use "disable-pmkid=yes", can you start again from the basic configuration (disable current /interface wifi configuration and add a new one)?
tangent
Thu Jun 06, 2024 2:01 pm
This is the kind of thing I meant in my first reply: you're setting it from two different places, creating a conflict:
Note that "security.authentication" is set as blank on the first line and to "wpa2-psk" on the second. This is the same setting!
Which one takes precedence? I dunno, but there's no reason to press your luck. If you're going to have an "/interface wifi security" entry, you shouldn't be including "security.ANYTHING" in your "/interface/wifi/configuration" entry. You can do it either way, however it makes sense to you, but don't try to do it from both directions.
(There's a third potential method, doing it from the top "/interface/wifi" level, too.)
holvoetn
Thu Jun 06, 2024 2:38 pm
Which one takes precedence? I dunno, but there's no reason to press your luck. ...
When looking at Winbox, left to right on the tabs, that should be descending preference (so leftmost option where you can set it, has highest priority).
Directly on interface is highest.
Then configuration
Then Security
I (try to) make it a habit to never set anything on interface. Only apply configuration.
And in configuration I only apply earlier made channels, security, ...
But obviously when doing something QnD for testing, it can happen I set it all directly on interface :lol:
kleshki
Thu Jun 06, 2024 2:59 pm
WiFi Analyzer tells this:
Channel 136 5680 GHz (I've added some channels after another connection drop)
Channel width 20 MHz
Protocol 802.11ax (metro UI still shows 802.11ac, was also ax with tp-link) Dunno what to trust there now, reverting to old router shows ax proto in metro UI again
After setting antenna gain to 5, I had another disconnect with laptop. Tried to forget the SSID and reconnect, gonna see what happens.
On auth-types - since I did configuration with Winbox, the problem was that in /wifi/configuration I left auth types open, which produced the auth-types="" config and left the network open. Closing the auth types tab fixed this, so now it's set directly in security profile and working. A bit inconvenient but can move on with this. So the only thing that worry me now is constant disconnects.
The config is now only different from stock with disabled pmkid and static 5ghz channels (auto sets channel 5500 which is invisible to my phones). Can try re-enable pmkid, or should I anyway create a new config?
Can I also somehow see in winbox or terminal which 802.11 protocol clients are using?
erlinden
Thu Jun 06, 2024 4:04 pm
Winbox (and terminal) will show with what rates devices are connected. That will indicate the protocol used (866 for ac, 1200 for ax).
Adding a new config is not much of work (you can disable current if you want). Then you can be sure all settings are correct. But setting it to default manually will give the same result.
kleshki
Thu Jun 06, 2024 5:32 pm
Here's my current configuration, now looks pretty simple.
add band=5ghz-ax disabled=no frequency=5180,5220,5640-5730 name=5ghz skip-dfs-channels=all width=20/40/80mhz
add antenna-gain=5 country="United States" disabled=no name=home-private-cfg ssid=MikroTik-Home
add authentication-types=wpa2-psk disabled=no name=home-private
/interface wifi
Winbox shows variable rates from 300 to 700 Mbps (sometimes dropping to 6 Mbps tho) at ~5m range. Signal is around -67..-77 for all devices. Can this be damaged hardware somehow? Since I got a decent discount from the shop for the device and now scared about it
kleshki
Thu Jun 06, 2024 6:04 pm
And got another disconnect with above config.
 20:01:47 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -75
 20:01:47 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -75
 20:02:15 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength 24
 20:02:15 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength 24
kleshki
Thu Jun 06, 2024 10:42 pm
An optimistic update on the topic: I decided to rollback from 7.15 to factory firmware which is 7.14.1 and it seems to be no disconnects for some hours already. The bandwidth is still bad so there is a place for tweaks still. But at least it's stable now.
Jef61
Fri Jun 07, 2024 1:37 pm
I also had many disconnects after upgrading my ax2 from 7.14.3 to 7.15.0
For example, the music stream from the Google home-speakers was full of interruptions.
After downgrading to 7.14.3 the disconnects are gone.
kleshki
Tue Jun 25, 2024 2:28 pm
After contacting MikroTik support, they told me there's a bunch of feedback about 7.15 fw having disconnects, but they also told me there's some kind of problems reproducing this bug in their lab. So current solution for home devices is to revert back to latest 7.14.x, since in 7.15 there's qcom-driver update, and 7.15.1 doesn't fix that either. I also don't see anything related in beta branch, so it seems that this bug will stay for a while. It would be a good move from MT to make a separate branch with latest firmware and old stable driver until the problem is resolved.
Ruza
Sun Jul 07, 2024 10:15 pm
I have the same problem. With support, I have already reset the router to factory settings 4 times and tried to select the configuration, but all to no avail. The only option is to roll back to 7.14.3.
kleshki
Mon Jul 08, 2024 8:02 pm
7.15.2 out, seems still no fix. As I understand from reading through the pinned topic of 7.15 update, the issue is mostly related to ax devices. Has anyone tried beta branch, are there any changes?
Kanzler
Mon Jul 08, 2024 8:53 pm
Yes, this problem applies to AX devices. As far as I understand, there are several problems there. For some users, the problem was resolved when updating to 7.16beta
S8T8
Mon Jul 08, 2024 9:47 pm
After many weeks of testing with different wireless devices and reading (+ testing) all the 7.15.X changelog, v7.14.3 was promoted as very stable for me, despite some "nice to have" features and no relevant fixes (for my use case) of latest release, I suggest to skip.
v7.16beta seems nice to try. Good luck!
Ruza
Sun Jul 14, 2024 10:05 pm
Latest 7.16beta4 does not solve the problem.
VadiKO
Tue Jul 16, 2024 12:02 am
I'm also having wifi issues on my mikrotik ax3. Unfortunately 7.15.2 doesn't solve this problem... I'm still waiting for a solution from Mikrotik developers.
Before the update to 7.15, everything worked fine and there were no such problems. I have already tried different settings, they do not solve the problem in any way.
I would also like to point out that the programs (winbox, webfig, mobile application for iOS) for configuration have a different interface for the "Reselect Interval" parameter, which also complicates the configuration of the router and can even create random errors in the configuration.
dang21000
Tue Jul 16, 2024 1:46 pm
Hi, same behavior about reselect interval
manigk
Tue Jul 16, 2024 2:05 pm
Did you try changing security to WPA2-PSK only and Management Protection to disabled?
I have had similar issues/inconsistencies and this seems to have helped (although it is certainly not an ideal solution). I am currently at 7.15.2, so I have yet to do more testing with newer ROS versions.
VadiKO
Fri Jul 19, 2024 6:26 pm
No, I didn't try. I have devices that do not support wpa3 and there are devices that support it, I want those devices that support wpa3 to work through wpa3, and those that do not also have the ability to connect to Wi-Fi. That's why I have wpa2 and 3 enabled. Control protection cannot be turned off if wpa 2 and 3 are used.
sLgFiRE
Sat Jul 20, 2024 2:06 am
i have same problems with all of my cap ac xl with capsman, i have 4 ssids and see, that capsman made new wifi slave interfaces with same mac as the main wifi interface, other wifi slaves have not the same mac, i think there is a problem with mac adresses for the slaves. i hope mirkotik will fix this
jfim88
Sat Jul 20, 2024 11:59 am
Same here on my hAP ax2 (7.15.2)
infabo
Sat Jul 20, 2024 12:22 pm
Can you enable logging on your device 9D:08? maybe you see a reason there why it disconnects.
jfim88
Sat Jul 20, 2024 4:08 pm
How I can enable logging for a device?
sindy
Sat Jul 20, 2024 5:41 pm
Although "Can you do xxxx?" is frequently used as a polite form of "Do xxxx!", the same wording may surprisingly mean an actual question :) Some devices support logging and some don't, and since the MAC address of your device in question is private, it is not possible to find out the vendor, so it is not possible for anyone but you to know whether it is a computer, a mobile phone, or an IoT device, and hence whether logging is supported.
Other than that, is only that single MAC address affected in your case?
anav
Sat Jul 20, 2024 6:14 pm
NO he is not doing anything wrong
WHY, because there is no PROPER process, nor guidance.
Setting up wifi on AX is shit show of inconsistency.
So please do not blame the poor user, thrown into the meat grinder of completely useless MMI performance.
infabo
Sat Jul 20, 2024 8:34 pm
Depends on the device. If it is a PC or alike it may be easier to access log files than on an iphone (still possible IIRC). But to avoid confusion: I mean logging on the affected device itself. You see a regular disconnect in your AP logs. But you don't know why the client disconnected. That information is not available - except on the client itself.
kleshki
Sun Jul 21, 2024 12:52 am
This was one of suggestions of MikroTik support guy. I can tell that this didn't solve disconnect problem neither on 7.15 nor on 7.15.1 on hap ax3 device (haven't tried 7.15.2 yet, but since there are no changes to wifi-qcom driver, I don't see a reason to give it a shot). I did try a bunch of configurations starting from the one after reset button, ending with a bunch of tweaks and sending around 10-15 supout files - no luck. It now became inconvenient for me to reboot the router here and there to upgrade to 7.15 and rollback again to working firmware after another tweak didn't do the trick, so I gave up on this and now use 7.14.1 until some information on disconnects show up. The only consistent thing I've noticed is that the more load on the network was done, the more chances to disconnect occur. So the connection could be "stable" for hours if I just leave device working, and could drop each 15 minutes while e.g. watching YouTube.
Ruza
Fri Jul 26, 2024 10:34 am
Update 7.15.3 does not solve the problem
kleshki
Fri Jul 26, 2024 10:54 am
This seems to not happen until "wifi-qcom" note appears in a patch-note (which is not the case for 7.15.3 nor beta branch)
BrateloSlava
Tue Aug 06, 2024 12:52 pm
Greetings!
Here is my configuration. I haven't noticed any problems with it on either 7.15.x or 7.16.x versions of ROS. I use the same configuration with CAPsMAN.
Laptop - Acer with Intel(R) Wi-Fi 6 AX201 160MHz network card.
Drivers for the network card are the latest from Intel's site.
# 2024-08-05 16:52:47 by RouterOS 7.16beta7
# software id =
# serial number =
/interface wifi channel add band=2ghz-ax disabled=no name=Home-2.4GHz-auto-AX reselect-interval=1h..1h30m width=20/40mhz
/interface wifi channel add band=5ghz-ax disabled=no name=Home-5GHz-auto-AX reselect-interval=1h..2h skip-dfs-channels=10min-cac width=20/40/80mhz
/interface wifi datapath add bridge=bridge-LAN disabled=no name=datapath-loc
/interface wifi security add authentication-types=wpa2-psk,wpa3-psk connect-priority=0/1 disable-pmkid=yes disabled=no encryption=ccmp ft=yes ft-over-ds=yes group-key-update=1h management-protection=allowed name=secur-Home passphrase=xxxXXXxxx wps=disable
/interface wifi steering add disabled=no name=steering-Home neighbor-group=NG-Home rrm=yes wnm=yes
/interface wifi configuration add chains=0,1 channel=Home-2.4GHz-auto-AX country=Ukraine datapath=datapath-loc disabled=no mode=ap multicast-enhance=enabled name=Home-2ghz-AX qos-classifier=dscp-high-3-bits security=secur-Home ssid=MikroAP-Loc steering=steering-Home tx-chains=0,1
/interface wifi configuration add chains=0,1 channel=Home-5GHz-auto-AX country="United States" datapath=datapath-loc disabled=no dtim-period=3 mode=ap multicast-enhance=enabled name=Home-5ghz-AX qos-classifier=dscp-high-3-bits security=secur-Home ssid=MikroAP-Loc steering=steering-Home tx-chains=0,1
/interface wifi set [ find default-name=wifi1 ] configuration=Home-5ghz-AX configuration.manager=capsman-or-local .mode=ap disabled=no
/interface wifi set [ find default-name=wifi2 ] configuration=Home-2ghz-AX configuration.manager=capsman-or-local .mode=ap disabled=no
By the way.
For other WiFi points at home I use this configuration (for cAP ac)
# 2024-08-05 16:52:46 by RouterOS 7.16beta7
# software id =
# model = RBcAPGi-5acD2nD
# serial number =
/interface wifi channel add band=2ghz-n disabled=no frequency=2412,2437,2462 name=Home-2.4GHz-1-6-11 width=20mhz
/interface wifi channel add band=5ghz-ac disabled=no frequency=5180,5260,5500,5580,5745 name=Home-5GHz-MAX reselect-interval=30m..1h skip-dfs-channels=10min-cac width=20/40/80mhz
/interface wifi datapath add bridge=bridge1 disabled=no name=datapath-loc
/interface wifi security add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes management-protection=allowed name=sec-home passphrase=xxxXXXxxx wps=disable
/interface wifi steering add disabled=no name=steering-LAN neighbor-group=NBG-Group-LAN rrm=yes wnm=yes
/interface wifi configuration add chains=0,1 channel=Home-2.4GHz-1-6-11 country=Ukraine datapath=datapath-loc disabled=no mode=ap name=cfg-Home-2 qos-classifier=priority security=sec-home ssid=MikroAP-Loc steering=steering-LAN tx-chains=0,1
/interface wifi configuration add chains=0,1 channel=Home-5GHz-MAX country="United States" datapath=datapath-loc disabled=no mode=ap name=cfg-Home-5 qos-classifier=priority security=sec-home ssid=MikroAP-Loc steering=steering-LAN tx-chains=0,1
/interface wifi set [ find default-name=wifi1 ] configuration=cfg-Home-2 configuration.manager=capsman .mode=ap disabled=no
/interface wifi set [ find default-name=wifi2 ] configuration=cfg-Home-5 configuration.manager=capsman .mode=ap disabled=no
killersoft
Wed Aug 07, 2024 1:34 am
There is a linux kernel driver issue with intel ax201/ax210 cards..
https://bugzilla.kernel.org/show_bug.cgi?id=203709
victorbayas
Wed Aug 07, 2024 2:03 pm
What I did to “fix” disconnections on my hAP AX3 was increasing the DHCP lease time from 30 minutes to 1 day on all the interfaces. My iPhone was disconnecting all the time before doing this change.
dang21000
Wed Aug 07, 2024 9:17 pm
I only use my HAPax3 device as AP, not router.
Since 2/3 weeks, i've removed wpa3 (before wap2 and wp3 were allowed) from security profiles, no more problems.
kleshki
Wed Aug 07, 2024 10:23 pm
I've also tried this, (un)fortunately I'm not an Apple user, so all my devices work regardless of DHCP lease time being 30 minutes or more/less
Since 2/3 weeks, I've removed wpa3 (before wap2 and wp3 were allowed) from security profiles, no more problems.
There's no WPA3 in my configuration, so sadly this also doesn't solve problems for me. However, WPA3 works good for my devices, so maybe I'll bring it back when the main issue is resolved.
intweed
Thu Aug 15, 2024 11:49 am
I have exactly the same problem after upgrading to 7.15 (7.15.2 at the moment). At first I thought someone was doing a deauthentication attack to speed up the handshake capture, but then I came across this thread.
loxmaty
Mon Aug 19, 2024 1:51 pm
I have exactly the same problem on my hAP ax2 at 7.15.3 and 7.16rc2. Laptop with Intel Wireless-AC 9461. Driver version 23.60.0 (i try the many oldest driver too). Random disconnects mostly under load.
Changing security to WPA2-PSK only and Management Protection to disabled not resolve the issue.
vmsh0
Mon Aug 19, 2024 4:26 pm
Same issues here on 7.15->7.15.3. Downgrade to 7.14.3 fixes the issue.
It's maybe also worth noting that I've noticed some specific patterns. Namely, streaming video seems to be a big one: whenever I start a video call on Teams, or watch a movie on Plex on my Google Chromecast, the issue presents itself much more frequently.
The worst case I have observed is the Chromecast being barely able to stream just a few seconds of video in between reconnects.
It would be nice to have an official acknowledgement from MikroTik, documenting the temporary workaround of downgrading to 7.14.3 and the next steps the company is taking to fix this. (Maybe I have missed it -- in that case, could I kindly be pointed to it?)
loxmaty
Mon Aug 19, 2024 7:38 pm
Confirm this. Downgrade to 7.14.3 is the only one work solution for me. At 7.14.3 all works perfect! Mikrotik when you fix this?
VadiKO
Sat Aug 24, 2024 9:58 am
Tired of waiting for a solution to the problem from the manufacturer, I also reverted to 7.14.3 and everything works fine.
Marvitex
Sat Aug 31, 2024 2:04 pm
Just to add additional feedback, I have a hEX S updated to 7.15.3 which works perfectly and a hAP ax3 stuck on 7.14.3 because it's the last version with which WiFi works well.
Plugpulled
Sat Aug 31, 2024 3:45 pm
TL:DR; 7.16rc4 fixes all wifi related issues.
I recently was trying to stream a remux to LG C2 via Plex and found out i was also running into the same problem. The Plex log was showing as device(WebOS tv) was constantly getting disconnected and reconnected which then continued the stream on tv. After upgrading to testing channel or beta 7.16rc4 it seems to have fixed the issues.
ivicask
Sat Aug 31, 2024 4:57 pm
I have exactly the same TV and HAP AX3 is 1m away from it, and also getting random dcs while watching plex, or router makes TV + multiple other devices roam from 5ghz to 2ghz exactly the same time for no reason which also interrupts my plex stream.
All was on fine 7.14.3.
kleshki
Sat Aug 31, 2024 5:12 pm
I recently gave a shot for rc3 too. At first, it seemed to be that it fixes a problem, it was stable for like 2 days or so, so I decided to give a try for WPA2/3 also. And within an hour I got a bunch of problems with every single device on wireless network, related to SA Query timeouts and reauthenticating. Reverting WPA2/3 back to WPA2 only, however, brought wireless network to a more stable state, while Intel AX201 device returned to its "disconnect each 5 minutes" state. So, I decided to give up at this point and revert back to 7.14.3, reporting each stage of testing to my opened support ticket.
Since they've pinged me with a bunch of questions in this ticket after a month of silence and me gave up at this point, I think they're doing a great job to investigate this issue, so I really hope for a real fix in 7.17beta (or at least, a temporary revert to a wifi driver).
loxmaty
Mon Sep 02, 2024 10:01 am
Can anyone else confirm that 7.16rc4 resolve issue with wi-fi 5Ghz random disconnects ?
Ruza
Mon Sep 02, 2024 8:12 pm
7.16rc4 does not solve the problem! 2 hours of work without failures, then the same problems appeared. Rolling back to 7.14.3 is the only solution so far.
erlinden
Mon Sep 02, 2024 10:01 pm
Would be beneficial if all people with problems share their config (at least the /interface/wifi part) to validate settings.
Additional tip: when going up and down in versions you might run into some strange problems. Actually, I did...hence some steps that might be of use.
I would advise (in case you want to give it another try) to:
Create a config (using export)
Reset the device, no default settings
Restore the config (using import)
Be aware that some settings aren't part of the export (i.e. users).
My ax's and ac's are all working perfectly fine with 7.16 rc4
At least, send supout.rif file to support.
infabo
Mon Sep 02, 2024 10:05 pm
7.15+ wifi-qcom drivers are instable with Intel clients. That is already known and confirmed even by Mikrotik
erlinden
Mon Sep 02, 2024 10:13 pm
Yes, I know. And I'll tell my corporate laptop it should disconnect more often :D
kleshki
Mon Sep 02, 2024 10:48 pm
I've sent a bunch of supouts already, the last advice is to set channel width to 20 Mhz which is kinda weird for a 5Ghz network. They also stated that the issue only reproduces with windows version of Intel drivers (Linux clients are stable) dunno if it is the case.
It's also worth noting that windows begins producing eventID 6062 - Lso was triggered, if it means something. There's not much information I've found about this event on the Internet.
infabo
Tue Sep 03, 2024 1:17 am
https://answers.microsoft.com/en-us/win ... c9c40f7491
No help at all. Classic Microsoft Forum topic.
Even if not related to wifi-qcom:
On wifi-qcom-ac my Linux Notebook with AX200 very often refused to connect to 2.4ghz when channel was 40mhz or was not even able to connect. Can't remember exactly. It basically connected to 5ghz most of the time and I did not notice this issue for a long time. I may changed device orientation or something and the signal dropped a little, and notebook tried to roam to 2.4. But it resulted in no wifi connection, because of iwlwifi flooding the log with DEAUTH CLIENT LEAVING messages (don't remember exact wording). After switching to 20mhz channel on 2.4ghz the notebook now can connect to 2.4ghz as well. Really astonishing. But maybe some Bluetooth interference or something.
loxmaty
Tue Sep 03, 2024 10:05 am
Everything happens exactly as you described. Laptop with Intel Wireless-AC 9461, Windows 11. Warning in the event log ID 6062 - Lso was triggered after which the disconnection occurs. This situation usually occurs under network load,such as streaming video, downloading large files.
kleshki
Tue Sep 03, 2024 11:27 am
I'm not sure, does it make sense to share my ticket here? Can other people see my supouts and so on?
ToTheFull
Tue Sep 03, 2024 12:36 pm
Have you both installed the latest drivers from Intel?
https://www.intel.com/content/www/us/en ... =[Wireless]
WiFi Date: 08/20/2024 Version: 23.70.2
Bluetooth Date: 08/20/2024Version: 23.70.3
Advice is to use the .exe Don't just install the driver using device manager, if you did just run the .exe files from above.
Search CMD right click Run as adminitrator using the following command.....
netsh wlan show wlanreport
It will build a report @ C:\ProgramData\Microsoft\Windows\WlanReport\wlan-report-latest.html
Got 3 Machines that will stay connected all day here on the qcom driver!
p.s Don't forget to run the command to build a report each time!
kleshki
Tue Sep 03, 2024 1:36 pm
I've updated the driver with MT support from Intel site, at the moment of ticket opening it was v. 23.30.something release date 01.24 latest driver and there was no success.
I've downloaded the one from your link and it shows v. 23.70.2.3 release date 24.07.2024 (AX201). It seems releases occur less frequently for this series of adapters, according to release date you provided. Will give it a shot once again, probably today
ToTheFull
Tue Sep 03, 2024 1:41 pm
infabo
Tue Sep 03, 2024 2:35 pm
I get Intel AX200 driver updates by Windows Update. Why the heck are you downloading drivers manually from Intel's website????
Ruza
Tue Sep 03, 2024 2:51 pm
I have a problem not only with Intel drivers. I have problems with AMlogic TV-box (BeeLink s912) on Android 9 and Lenovo tab on Android 13 when watching videos from MeGoGo or YouTube
ToTheFull
Tue Sep 03, 2024 3:01 pm
Why would I get the latest updates/security updates, Really!
infabo
Tue Sep 03, 2024 3:08 pm
Driver/Firmware/Bios updates are optionally. You can install these via WU without installing regular updates AFAIK.
holvoetn
Tue Sep 03, 2024 3:42 pm
On more then one occasion I noticed Intel drivers where NOT updated by Windows Update. So don't count on it.
I also have been chasing wifi issues not too long ago in the past only to find out a new driver was available directly on the supplier website which after installation fixed the issues I was having (not only with MT APs, also Symbol, Netgear, ...).
I currently have AX211 in my laptop BTW. Zero problems.
ToTheFull
Tue Sep 03, 2024 3:49 pm
Depends what channel you are in on Windows, IE your drivers will auto downgrade as well on some. Thats why i have Auto udates turned off on my PC's.
infabo
Tue Sep 03, 2024 3:58 pm
Turning of Auto-Updates is not the same as not updating your system at all. All these decades and Windows still hasn't managed to supply device drivers in a proper and easy way for users.
holvoetn
Tue Sep 03, 2024 4:14 pm
And where is the surprise ... ?
After all, it's Microsoft we're referring to here :lol:
Ruza
Thu Sep 05, 2024 10:16 am
7.16rc4 and reducing the 5 GHz channel width to 20 MHz solves the problem, there are no WiFi breaks.
infabo
Thu Sep 05, 2024 10:54 am
Maybe 20mhz channel width also resolves it on 7.15?
ToTheFull
Thu Sep 05, 2024 11:00 am
It would be nice to see what Signal ranges we are talking about here ?
-70's/-80's or just any Signal range.
kleshki
Thu Sep 05, 2024 11:58 am
This is not a (permanent) solution since reducing channel width also lowers throughput.
Ruza
Thu Sep 05, 2024 1:28 pm
I agree. It's stupid to buy an expensive router and cut the data transfer speed... But nevertheless, it works.
I checked 20/40 MHz - it doesn't work.
infabo
Thu Sep 05, 2024 2:04 pm
Well, Mikrotik AX devices are all but expensive.
sajgan
Tue Sep 24, 2024 2:56 pm
Hi
has anyone tested 7.16?
Ruza
Wed Sep 25, 2024 11:20 pm
Hi
7.16 does not solve the problem
VadiKO
Sun Sep 29, 2024 7:29 pm
Hi
I have updated.
24 hours, everything is ok!
loxmaty
Sun Sep 29, 2024 7:50 pm
Hi
7.17beta2 does not solve the problem to. I am very disappointed, I really wanted to buy a Mikrotik router, because it provides great flexibility of settings, but now I see that Mikrotik engineers can not cope even with basic tasks. Why should I, like an idiot, go through the firmware in the hope that they fixed the banal problem of disconnecting wifi on AX devices, which everyone has known about for a long time. If you can not solve it yourself, roll back the Qualcom driver. I am very disappointed. I use more than 400 Mikrotik devices in my work as a system administrator, and I always recommended them to my clients, but apparently this has come to an end.
flynno
Sun Sep 29, 2024 8:49 pm
I have same issues
litvcom
Sun Sep 29, 2024 9:48 pm
I also notice this behavior, but mostly with only one device. In my case, with Chromecast with Google TV 4K.
VadiKO
Sun Sep 29, 2024 10:58 pm
I had the same problem on 7.15.3 and had to go back to 7.14.3 where everything worked fine.
Yesterday I still dared to try 7.16 and everything works fine for me.
itimo01
Sun Sep 29, 2024 11:57 pm
TLDR; The fix was to limit myself to only channels up to 124.
I got a hap ax3 and ax2 and have literally 0 issues with AX Clients
I'm currently running 7.17beta2, but always been running the latest version since December 2023.
Some of the issues here sound similar to mine when started deploying Intel AX210 and BE200 Cards.
Anything above 5ghz Channel 124 they only wanted to connect to with 20mhz channel width. (the issues sometimes were that it only connected at 802.11n speeds and sometimes it wouldnt connect at all)
Keeping in mind, I'm from Germany.
And that i also had this issue with AC only APs from competitors.
If anyone is interested in my findings with AX210 and BE200 cards regarding this issue, it's mostly on the Intel Forum:
https://community.intel.com/t5/Wireless ... -p/1550533
I don't have any AX210s anymore but I've attached a screenshot of my working FT, WPA3, AX, 80Mhz Setup:
For reference, I tried these network cards and they all work flawlessly:
Any Channel:
Realtek RTL8852AE
Mediatek MT7922 (aka AMD RZ6XX)
Below Channel 124:
Intel AX210
Intel BE200 (Windows + Linux)
Qualcomm WCN685x (not sure which exact version it is)
kleshki
Mon Sep 30, 2024 12:13 am
What's the ROS version you have where it works?
itimo01
Mon Sep 30, 2024 4:30 am
Currently, 7.17beta2.
But the last version I was able to test the AX210 with was 7.14.2 I think.
The BE200 I was able to test with all versions 7.13+ and it's been working perfectly fine (well, since working Linux drivers have been released :D)
Since i only ever had the issue with the Intel AX Cards, and it even occurred with an AC only router (ZTE MF281. Its an ISP LTE Router) i never even checked the mikrotik forums about it.
Coughy
Mon Sep 30, 2024 12:34 pm
is yours 2.4 or 5g??
as i was having same problems but i dont have hardly any anymore
im on the 7.17 beta but i had it working and roaming before this beta
i found it is the 2.4 that seem to be having all the issues
but i hardly get any now with my config changes
I have same issues
flynno
Mon Sep 30, 2024 12:46 pm
I have same issues
Seems to be with both 2.4G and 5G
Coughy
Mon Sep 30, 2024 2:41 pm
i have lots of screen shots to show you but i wont do it here on OP
m8 go to wifi config and put DTIM period up to 8 on the 2.4 and 3 on the 5g try it works for me i get hardly any disconects now
if not i will do a new post with my config so you can try my settings
flynno
Mon Sep 30, 2024 2:59 pm
Ok I will try this tonight, I'm limited on making changes because it's a live network and users will go ape.
infabo
Mon Sep 30, 2024 4:56 pm
dtim-period is "1" by default. Some have dedicated SSID for IoT devices - which are mostly battery powered. In such a case a DTIM period of 2 may improve batter life. Maybe it even helps with disconnects - but can't test as I do not have "flapping clients".
R1CH
Mon Sep 30, 2024 8:54 pm
Note that Apple recommends DTIM interval of 4.
tangent
Tue Oct 01, 2024 2:01 am
Where? Their current recommendations do not speak of DTIM at all.
For what it's worth, I've gone back and documented my hAP ax³ WiFi configuration in more detail than my post #2 above, which continues to work nicely with several Apple devices, and has done since 7.14rc2 back in February, when I installed it. I've installed many releases between, up to 7.17beta2 now, and I never noticed any serious regressions.
I really don't understand all this moaning. I suppose y'all are doing something quite different than I am, and these differences materially affect the symptom. My article may help here, if only by providing baseline known-working configuration.
kleshki
Tue Oct 01, 2024 2:28 am
It happens with any kind of configuration, whether it's defconf or not, and support guy told me they replicated the problem with Intel AX in their lab. I haven't noticed any issues with 7.14.3. But any 7.15 onwards the disconnects are just waaaay to often. All stuff that we tried with support worked anyway in 7.14 and did not in 7.15+ and yes I do upgrade routerboard etc etc.
I'm not sure if the problem is the same with other devices, since laptop with Intel AX is my main wireless device and all focus was to fix this. Other devices are rare to no disconnects, or I didn't notice them. It's even worse with WPA3 enabled.
If you don't have a problem, doesn't mean no one also have it nor it means they are just retards.
tangent
Tue Oct 01, 2024 2:45 am
…support guy told me they replicated the problem with Intel AX in their lab
I was speaking of Apple devices, which as far as I know, do not include the affected Intel AX chipsets. Regardless, I am not attempting to gainsay the MT engineers on this one; if they say the chipset has a bug that affects RouterOS compatibility, then I believe them.
What I object to is this "everything is terrible" attitude I'm seeing while it's been working here, steadily, since February. There's a mismatch somewhere, and I'd like to try and resolve it, not fall into an endless moan-fest.
I did not use that derogatory term, and as a moderator here, I caution you against using it again on this forum.
Rather than name-call the others, I prefer to contribute positively, as with this article I've just written, presenting a working configuration for at least one person, me. How much broader does that go? I don't know, but it's objectively the case that everything isn't terrible for everyone.
kleshki
Tue Oct 01, 2024 3:00 am
I didn't name-call others, I rather meant the opposite - pretty sure people do best effort to fix this, not just throw "everything is bad" messages. Same for me.
I appreciate your effort and took time to inspect your config. This is actually the same as I get right after /sys/reset. The only moment is that device auto-select 5GHz channel 5500 which doesn't work for half of my devices, so I have to specify channels manually. And yes, one step with support was: "reset your device to just wifi+default gateway and check if you have problems" which didn't succeed.
I've bought my device around week or two before 7.15 release, so all stuff was good until update. And as I said, every time support suggested me a config change, I did update to 7.15+, checked if it works or not and downgrade back (because of unusable device) leaving changed config. And whatever changes we did worked well in 7.14. And yes I update adapter drivers directly from Intel site, so they're latest. After all my attempts I gave up as one of latest firmwares introduced another bug for me which I've also reported to them, so it wasn't comfortable for me to upgrade back and forth as ax3 device is my only home router. Supports told me they'll notify on changes, so I'm confident I did what I could, and not just moan.
itimo01
Tue Oct 01, 2024 3:54 am
It used to be 3 quite a few years ago. But they have since updated their documents. Use DTIM that suits best for you.
I have to +1 this, since it's working perfectly fine for me with newest (and older) intel Wi-Fi drivers (as documented on the intel forum).
Also on the Intel Forums, there's also a lot of people having issues with Intel AX/BE Chips with non Mikrotik routers ^^
Since my wifi conf is extremely simple i'll just drop it here:
name="conf_5" ssid="SECRET" country=Germany multicast-enhance=enabled security=common-auth
     security.authentication-types=wpa2-psk,wpa3-psk .encryption="" .passphrase="SECRET" .wps=disable .ft=yes
     datapath=VLAN0
     datapath.bridge=bridge .vlan-id=1
     channel.frequency=5160-5640
name="conf_2.4" ssid="SECRET" country=Germany multicast-enhance=enabled security=common-auth
     datapath=VLAN0
     channel.frequency=2412-2472 .width=20mhz
Edit: as statet before i've been running this config since 7.13.X (dont remember exactly) and its been working perfectly ever since
kleshki
Tue Oct 01, 2024 4:49 pm
add band=5ghz-ax disabled=no frequency=5220,5180-5320,5660-5845 name=5ghz skip-dfs-channels=10min-cac width=20/40/80mhz
add authentication-types=wpa2-psk disabled=no management-protection=disabled name=home-private
/interface wifi
add country="United States" datapath=home-private-datapath disabled=no name=home-private-cfg security=home-private ssid=\
    xxx
add bridge=bridge disabled=no name=home-private-datapath vlan-id=100
This is my current running config for 5GHz. Nothing special. Works on 7.14.3. Doesn't work 7.15+. Driver ver. 23.70.2.3. Works on any other router I've interfered with (d-link, tp-link, mikrotik 6.xx firmwares ap, ubiquity, some public wifi stuff and so on).
jaclaz
Tue Oct 01, 2024 5:21 pm
@tangent
The origin is (probably) a (I believe now lost forever) twitter post, cited here (which explains some of the reasons to increase DTIM interval for Apple devices):
https://www.sniffwifi.com/2016/05/go-to ... sleep.html
The analysis seems to make sense, and this "set DTIM to 3" advice can be found in a lot of places, the DTIM 4 is new (at least to me).
flynno
Tue Oct 01, 2024 5:23 pm
/interface wifi
    xxx
You getting any issues with that setup?
Does your devices roam without ft=yes ft-over-ds=yes?
itimo01
Tue Oct 01, 2024 5:30 pm
Mikrotik V6 doesn't support AX.
You sure you were connected with AX for the others?
kleshki
Tue Oct 01, 2024 6:13 pm
Yes I had disconnects with Intel AX on that. Ax3 is a single stand-alone device, so there's nowhere to roam. Support told me that those options make no sense in my setup (but are enabled by default). In one of testing iterations I've disabled them.
rrataj
Tue Oct 01, 2024 9:49 pm
Hey all, I had the same issues with disconnects on my hap ax2 and ax3 (capsman with FT), and just wanted to share that enabling tkip cipher helped. I know, weird, but it's working for me. I tested a lot of methods, 20mhz channel width, management protection, ft disabled etc. But only enabling tkip cipher in security works and my chromecast and macbook can connect to wifi now.
tangent
Tue Oct 01, 2024 10:14 pm
Sure there is: from 5 GHz to 2.4 and back when both radios have the same SSID. FT does apply in this case!
kleshki
Tue Oct 01, 2024 10:24 pm
I have 5GHz and 2.4GHz SSIDs separate as 5GHz covers area well enough, so I wanna make sure all devices use 5GHz all time
Ruza
Sat Oct 05, 2024 3:41 pm
Today I got Wi-Fi disconnects on 7.16 with a channel width of 20 MHz.
I see everything is bad with the new drivers
Sent supout.rif to support
kleshki
Sat Oct 05, 2024 6:43 pm
I've recently heard an opinion that connected USB3 device may affect wireless (friends who have ax3 had problems with usb and didn't have without). I had problems before I attached USB disk, and now there isn't much transfers (only error logs by now). Maybe it will be useful if anyone who has problems would also note in their messages if they use USB or not.
jaclaz
Sat Oct 05, 2024 7:00 pm
There are know issues with USB 3.x devices, not only Mikrotik related, but they should be limited to the 2.4 GHz, because the frequencies are essentially the same and interferences happen, see:
viewtopic.php?t=203470
and official USB document.
https://www.usb.org/sites/default/files/327216.pdf
Coughy
Sun Oct 06, 2024 7:59 am
old post i no but get one of these in 32g works perfetly on 7/17beta2 running my containrers and no wofo issues
Model Number: SDCZ430-016G-Z35
SanDisk Ultra Fit USB 3.2 Flash Drive - 16GB
VadiKO
Mon Oct 07, 2024 10:43 am
My dear friends, I am finally back to 7.14.3 again
At first, 7.16 worked fine, but then problems with turning off Wi-Fi started again
I tried the test 7.17 beta 2, the situation is even worse there...
I'm back on 7.14.3
tlamik
Mon Oct 07, 2024 9:21 pm
Stupid me tried to install 7.16 and I could not work with putty anymore.
Downgrade to 7.15.3 works nicely for me.
SIgnal is slow, I frequently roamin from 5G to 2.4G and back, but no disconnection like with 7.16
entepcetfevo
Tue Oct 08, 2024 6:06 pm
Follow-up my hap ax3 / google chromecast gen3 / ROS > 7.14.3 problem. viewtopic.php?p=1078328#p1078328
I tried any other ROS version post 7.14.3 and any WiFi workaround posted here.
Unfortunately got the same behavior, in a few seconds after cast all the WiFi devices in the house get insta disconnected. Roll back to 7.14.3 every time.
Today I managed to fix the problem for me. :D
I bought an Ugreen 30985 external network card for Chromecast with micro USB / USB-A connectors, 100Mb/s, and now I use the chromecast wired.
No more disconnects, v 7.16 stable.
vic3apex
Mon Oct 14, 2024 8:47 pm
I have the same issue on my hap ax3 :( firmware is latest 7.16.1
v1597psh
Tue Oct 22, 2024 4:30 pm
Downgrading to 7.14.3 solved the problem for me
Ruza
Tue Oct 22, 2024 7:44 pm
7.17beta 4 no changes. 7 hours of work and wifi drops again
fafpak
Wed Oct 23, 2024 5:27 pm
Currently running ROS 7.16.1.
I was having issues with my "Intel(R) Wi-Fi 6 AX201 160MHz" card dropping connection since 7.15.
I applied a critical Dell driver update yesterday and the issue seems to be resolved:
  • Uptime 17.47:xx
  • Signal -65
Could it be an Intel driver issue and not a Mikrotik issue?
kleshki
Wed Oct 23, 2024 5:57 pm
I'm on 7.16.1 for now, intel driver v. 23.70.2.3. I don't have time now to play games and so on, so it's hard for me to notice disconnects that I had before. But logs are filled with this:
19:08:39 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -70
19:08:39 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -70
19:08:39 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength -66
19:08:39 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength -66
19:24:08 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -70
19:24:08 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -70
19:24:08 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength -71
19:24:08 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength -71
19:24:09 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -71
19:24:09 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -71
19:24:13 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength -70
19:24:13 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength -70
19:25:08 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz disconnected, connection lost, signal strength -73
19:25:08 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz disassociated, connection lost, signal strength -73
19:25:11 wireless,debug 0C:7A:15:F5:D2:AF@wifi-5ghz associated, signal strength -72
19:25:11 wireless,info 0C:7A:15:F5:D2:AF@wifi-5ghz connected, signal strength -71
Windows logs are filled with netwtw10 warning 6062 and info message 7021. And this is only reproducible on a MikroTik router with 7.15+ firmware.
eNET1
Fri Oct 25, 2024 5:01 pm
I have the very some problem, with many devices including my LG TV, NVIDIA Shield, my iPhone and iPad. I can’t watch movies from my Plex Media Server anymore because from time to time wifi keeps disconnecting on my ax3, I have to reconnect and restart the stream. Downgrading to 7.14.3 fixes everything, but it’s been months now and there’s no fix on newer firmware, what’s up with that, are we going to be stuck with 7.14.3?
klaproos
Sun Oct 27, 2024 12:32 pm
Still the same for me : hap ax3 icw chromecast. Is disappointing: I bought a brand new ax3 this year, and now i'm stuck with v7.14.3
When will this be solved ?
erlinden
Sun Oct 27, 2024 1:15 pm
What is in itself the problem of remaining at 7.14.3 (at least for the time being)?
Is there specific functionality missing that was introduced from 7.15 upwards?
kleshki
Sun Oct 27, 2024 2:19 pm
7.15 patch notes include wifi-qcom driver update.
jaclaz
Sun Oct 27, 2024 2:30 pm
I thought that the issues were caused mainly by that driver update :shock: , it doesn't sound like a desired new functionality ... :lol:
Ruza
Mon Oct 28, 2024 7:12 pm
  • Uptime 17.47:xx
  • Signal -65
No, I have tried many Intel drivers but the error is always the same.
JohnTRIVOLTA
Mon Oct 28, 2024 7:24 pm
Some horror here, every day several times, very unpleasant and only on 5GHz.
I have Intel(R) Wi-Fi 6 AX201 160MHz work on 2GHz - no problems!
vic3apex
Wed Oct 30, 2024 10:37 am
Is there a chance to escalate this issue? It seems that the developers of RouterOS 7.x do not know anything about this.
erlinden
Wed Oct 30, 2024 10:48 am
As you know, assumption is the mother...etc.
Just contact support to address your problem.
Ruza
Thu Oct 31, 2024 8:54 pm
I have contacted. No solution yet.
Your request status has been changed to Waiting for support.18/Sep/24 9:10 AM
loxmaty
Fri Nov 15, 2024 10:26 am
Looks like Intel new Wireless Bluetooth driver 23.90.0 and 7.17beta5 work fine for me. No more discconects under load. I'm testing about 3 hours. Can anybody else confirm that?
kleshki
Fri Nov 15, 2024 3:42 pm
What's the version is shown on WiFi dongle itself in the device manager?
VadiKO
Sat Nov 16, 2024 5:57 pm
3 hours is too little, I was fine for a day, then the falls started again...
wait 2-3 days, then say whether it's good or not.
loxmaty
Sun Nov 17, 2024 11:21 am
23.70.2.3
kleshki
Sun Nov 17, 2024 11:34 am
I'm at the same driver version but can't confirm this works on 7.16.x, not sure about beta
loxmaty
Thu Nov 21, 2024 12:09 pm
7.17beta6 broken again?
Im create ticket and send support.rif to mikrotik.
negavoid2
Thu Nov 21, 2024 3:55 pm
The issue is not only with intel adapters, some qualcomm xiaomi mobiles are disconnecting too. Also still sitting on 7.14.3 where everything works perfect. All the later firmware including 7.16.1 still cause disconnects.
sszbv
Trainer
Trainer
Fri Nov 22, 2024 9:57 am
This is slightly off topic, but can be interesting to read.
Looking at this forum thread, I recognize a lot off the issues.
But there is a difference in my experiences with AX.
When the devices were released, I replaced all APs in my home. Then I noticed that the range is not as good as from the AC devices. To I doubled the number of APs. Each room has it's own AP. And the living room has two. One cap AX at 2.4 and 5, and a hap ax3 at 5 on a high channel with low power output (this is only for the dinner table).
This setup works fine since the beginning, with all versions of routeros.
Note that we only use Apple devices and just a few windows laptops from Lenovo for school and work. (I have a large family)
I have 9 APs (5x cap ax, 1x wap ax, 3x hap ax3).
The router is a CCR2004-16G-2S+.
Current version is 7.16.1 on all devices.
There are 7 ssids on different vlans.
And on average 45 clients connected (including smart lights and sensors)
Wpa3, wpa2, 802.11r (FT + FT over DS), 802.11k (steering rrm) and 801.11v (steering wnm) are all enabled (except on the ssid for smart lights). Used channels are 1, 5, 9, 13, 36, 40, 44, 48, 149, 153, 157.
Vlan config, is tagged for all SSID's, but untagged for the capsman/management.
It works fine, so it CAN work!
But now comes the bad part...
Keeping in mind that my AX system works, and that large AC setups were never a problem, I rolled out three large locations with AX.
115x cap ax +- 400 clients
44x cap ax +- 300 clients
71x cap ax +- 500 clients
From the start I have many issues, like in this thread, disconnecting and reconnecting devices.
Can you imagine what it's like to work on your laptop, sitting on the exact same spot for all day, having your wifi drop every 5 minutes?
With the AP in sight?
That is exactly what is happening!
Many windows laptops just keep hanging on the worst AP they can find.
Keep connecting and disconnecting from the wifi.
While stationary!!!
Old phones too, they just don't work.
The range of the cap ax is less than the cap ac, maybe 6 meters at most.
With new devices, things work better, more range, less disconnects.
To make it at least usable, in the end I had to disable WPA3, FT, RRM and WNM. Also a good solution is to put an extra AP next to people with many complaints.
I think at the MikroTik support desk, they only have the working AX, like I have at home.
They can't imagine that their stuff doesn't work, but in some cases it doesn't.
And it can't all be blamed on bad AP placement, wrong settings...
Anyway, if you are out there having issues with your AX setup, keep in mind that it CAN work.
And in the meantime, let's hope updates in the future will remove all issues like magic.
infabo
Fri Nov 22, 2024 10:30 am
Thank you for this objective and informative insight. Things are not always black and white.
ToTheFull
Fri Nov 22, 2024 11:20 am
I have Zero issues with 7.17beta6 just WPA2 using capsman is very stable, I look forward to the release. it's far better than 7.16.1
Also using the latest 11.11.2024 Intel driver with no problems.
Interface name: WiFi
    Driver                    : Intel(R) Wi-Fi 6E AX210 160MHz
    Vendor                    : Intel Corporation
    Provider                  : Intel
    Date                      : 26/09/2024
    Version                   : 23.90.0.2
@sszbv I feel your pain brother, it's been a journey for sure!
holvoetn
Fri Nov 22, 2024 2:46 pm
FWIW I had AX3 and now wAP AX on my desk.
Since I have that wAP AX I use my laptop only via wifi. Zero disconnects. And using Azure Remote Desktop when working from home I would know immediately ... that environment is HIGHLY allergic to disconnects, even for a split second.
(Using AX3 I also have used that setup for testing, also there, no problems noticed)
I do see sporadic loggings indicating so but no disconnects on the client device itself.
loxmaty
Re: hap ax3 random wireless disconnects
Sat Nov 23, 2024 5:42 am
This is not a hardware problem, this is a software problem, on 7.14.3 everything works perfectly, for everyone. The problem started after 7.14.3, many on the forum think that it is related to the update of the Qualcomm driver.
blazer4493
Sun Dec 01, 2024 4:20 am
I've also been suffering these disconnects for a while on my hAP ax3 but only on the 5G radio, I've been updating to latest ROS releases as they come out since I got it about a year ago and it seems like the issue has been getting progressively worse as the versions progressed. Since I remember noticing a little bit of issues at first, growing in severity until I finally got fed up and looked into it yesterday.
Before yesterday I was on 7.16.3 and (without my chromecast connected) it would last for about a week tops and then start to get a bit unreliable. I also noticed that changing settings on the 5G interface would accelerate the degradation of its reliability. A reboot would fix it for a random amount of time. No different settings changed anything at all, I tried many variations of my own config, and also adopting configs that people have posted as "working configs", changing only the SSID, password and country. With my chromecast connected I noticed that if it was connected to 5G it would trigger the 5G radio to be rendered unusable (im talking repeating intervals of 15-45 seconds of it functioning followed by 30-120 seconds of being completely dysfunctional), even right after a reboot. With the chromecast connected to 2.4G, it was fine in that regard. However it would buffer alot and have quality reductions since my 20+ neighbours in wireless range have butchered the 2.4G band with overlapping and 80MHz wide channels, causing low speeds on 2.4G. I'm not attributing that to ROS issues since even with all that interference and noise the 2.4G interface doesn't drop out completely like 5G does, its just slow as hell.
Another interesting thing I observed is that while the chomecast was causing the 5G interface to have a fit and barely work, it would also cause the 2.4G interface to have less performance (but not completely drop out) than it normally does. I didn't do any in depth analysis on it, I just noticed that both my phone and laptop would load websites noticeably slower (since I was researching the issue) while the chromecast was connected to 5G than when it was not. I have no idea if this is simply due to a software bug maxing out the hAP's CPU causing the slow downs or something else going on in the airwaves.
Since I downgraded to 7.14.3 its been working perfectly fine even with my normal pre-debugging config with WPA2+3 and protected management frames enabled. The chromecast connects quickly (to 5G) when i turn it on unlike before where it took a long time. And both wifi bands function perfectly fine even after hours of watching stuff on the chromecast. I tried stress testing it to see if I could get it to break, by changing settings a bunch of times while saturating the connection with iperf and while reconnecting devices frequently, and I couldn't get it to fail on this version YET. It seems rock stable, but ive only had it running for 24 hours so far. I'll report back if time brings issues.
ddanaj
Mon Dec 02, 2024 2:23 pm
Some users which are testing 7.17rc version viewtopic.php?t=212754 are reporting, that on this version everything working ok and there are no disconnects.
Ruza
Sun Dec 08, 2024 4:35 pm
No. Unfortunately, updating to 7.17rc2 didn't help me.
Android devices started disconnecting 10 minutes after the update.
ozone1864
Tue Dec 10, 2024 5:26 pm
Hey guys, I just did an update to 7.16.2 after couple of months on 7.14.3
I am facing similar wifi disconnection on 5Ghz interface.
Can anyone recommend the latest stable version after 7.14.3 to keep the wifi stable
negavoid2
Wed Dec 11, 2024 3:58 pm
The issue still not fixed, we all sitting on downgraded to 7.14.3 firmware.
nbsdr
Fri Dec 20, 2024 2:04 pm
Thank God I found this thread because I was going crazy with the random disconnects.
2024-12-20 12:45:37	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -63
2024-12-20 12:45:38	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:45:42	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, SA Query timeout, signal strength -58
2024-12-20 12:45:50	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:45:52	memory	wireless, info	B0:3C:xx:xx:xx:xx@wifi1 disconnected, SA Query timeout, signal strength -59
2024-12-20 12:46:00	memory	wireless, info	B0:3C:xx:xx:xx:xx@wifi1 connected, signal strength -59
2024-12-20 12:51:01	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -58
2024-12-20 12:51:02	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:51:05	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -56
2024-12-20 12:51:09	memory	wireless, info	B0:3C:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -60
2024-12-20 12:51:11	memory	wireless, info	B0:3C:xx:xx:xx:xx@wifi1 connected, signal strength -68
2024-12-20 12:51:11	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:51:14	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -62
2024-12-20 12:51:15	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:51:18	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -57
2024-12-20 12:51:20	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:51:25	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, SA Query timeout, signal strength -59
2024-12-20 12:51:35	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -58
2024-12-20 12:51:38	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -59
2024-12-20 12:51:41	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:51:42	memory	wireless, info	B0:3C:xx:xx:xx:xx@wifi1 disconnected, SA Query timeout, signal strength -58
2024-12-20 12:51:44	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -60
2024-12-20 12:51:46	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 connected, signal strength -57
2024-12-20 12:51:47	memory	wireless, info	B0:3C:xx:xx:xx:xx@wifi1 connected, signal strength -66
2024-12-20 12:51:53	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi1 disconnected, connection lost, signal strength -57
2024-12-20 12:51:53	memory	wireless, info	78:2B:xx:xx:xx:xx@wifi2 connected, signal strength -37
This saddened me because I bought the router and I was happy for a while because of how stable wireless was and then all of a sudden it started doing this. I will downgrade to 7.14.3 and see if it helps! Thanks!
geku
Mon Dec 23, 2024 1:51 pm
Had same issues, changed DTIM values to 3 for 5GHz (it was 10 by default), the same was proposed upper in the thread, 2 days - no disconnects so far.
mkx
Mon Dec 23, 2024 2:23 pm
A random thread from quite some time ago ... which concluded that DTIM interval longer than around 3 can (and will) cause problems with certain station devices and in certain usage scenarios.
BTW, current WiFi manual says that default setting of dtim-period property is 1. So the value you saw might be older default which was kept on your device dince wifi-qcom(-ac) was first installed.
geku
Mon Dec 23, 2024 11:57 pm
That's actually stange as device was purchased by me less than month ago + my first action was to update it. But it could highlight some issues in dev/build/release process.
holvoetn
Tue Dec 24, 2024 12:08 am
Or a very recent change of default setting.
vic3apex
Tue Dec 24, 2024 2:48 am
I have never changed the dtim-period setting, and currently its value is 0 on both wireless interfaces. With this value, I have clients constantly disconnecting on router OS versions greater than 7.14.3.
erlinden
Tue Dec 24, 2024 8:19 am
That's strange as the range is from 1 to 255 (according to the documentation):
dtim-period (integer 1..255; default: 1)
vic3apex
Tue Dec 24, 2024 10:57 am
Mikrotik app for Android shows the following value of dtim-period setting:
erlinden
Tue Dec 24, 2024 11:02 am
The question is what the actual value is. I only trust the config (through cli export). Can you check what the value is through export?
By the way, I use dtim-period=3
mkx
Tue Dec 24, 2024 11:13 am
It might be artifact (by Tik app) for not having property set at all ... in which case default value (1) would be used.
When in doubt, always use CLI to verify ... and report a bug in UI to MT to get it fixed.
Marvitex
Wed Dec 25, 2024 1:25 pm
I have a hAP ax³ (now it only works as an AP) and although I set the dtim-period value to 1, some clients (in particular two Android smartphones) keep disconnecting.
Having reverted (for the umpteenth time) to 7.14.3, everything works perfectly.
Honestly, for WiFi I'm starting to evaluate something else.
erlinden
Wed Dec 25, 2024 2:09 pm
dtim-period=1 is the default, you could try a bit higher, like 3.
Why evaluate something else, if 7.14.3 is working for you. Why upgrade at all?
sajgan
Wed Dec 25, 2024 2:51 pm
Security reasons?
erlinden
Wed Dec 25, 2024 4:28 pm
Security reasons?
I can think of a thousand and more reasons...want to know from @Marvitex.
infabo
Wed Dec 25, 2024 4:37 pm
7.14.x is not known to have any security related issues. See for more info here: https://mikrotik.com/supportsec
On the other hand, there are vulnerabilities not mentioned in the "security blog" at all. Instead Mikrotik silently fixed them. e.g. https://www.enricobassetti.it/2023/11/c ... -rest-api/
dang21000
Wed Dec 25, 2024 10:00 pm
With lot of AX devices, i've found (capsman mode) a way to have a fully working without any random disconnect.
The way is simple, create a master hidden ssid with channel config and a long passkey and have all others ssid as slaves.
## CHANNEL CFG
add disabled=no name=master_channel width=20/40mhz-Ce
add disabled=no name=slave_channel width=20/40/80mhz
## MASTER SSID
add channel=master_channel country=France disabled=no hide-ssid=yes mode=ap \
    multicast-enhance=enabled name=master_config \
    security.authentication-types=wpa3-psk .passphrase=RRRRRRRRRRR \
    .wps=disable ssid=master
## SLAVE SSID
add channel=slave_channel country=France datapath=vlan1049_datapath disabled=\
    no hide-ssid=no mode=ap multicast-enhance=enabled name=vlan1049_config \
    security=vlan1049_auth ssid=ZZZZZZ
I have wireless cams and no disconnect and roaming is fine. At this time, still stable since 18 days. Before this main change, they lost signal many times.
Marvitex
Sat Dec 28, 2024 1:52 pm
First of all, it is psychologically degrading to think of having an up-to-date hEX S without any kind of problem and a hAP ax³ that, instead, has to stay with a version from almost the beginning of the year. For what reason then? We still don't understand where the problem lies, evidently.
Security reasons?
One of the most important reasons, regardless of whether there are security bugs or not.
Security reasons?
Exactly, the reasons are many and there is no need to list them.
But anyway, for example, I've been waiting for the PPSK for a while (since everything around WiFi features is slow, on MikroTik) and now that it arrives I can't try it out. :?
erlinden
Sat Dec 28, 2024 5:46 pm
Thanks @Marvitex, new functionality makes perfect sense.
Afaik MikroTik upgraded the Qualcom(?) driver, which seems to have influence for some users (for me only more logging is profided but no problems with stability).
Maximasus
Thu Jan 02, 2025 10:30 pm
Having the same issue on ax3, the latest version with stable wireless is 7.15beta8
BartoszP
Thu Jan 02, 2025 10:41 pm
I see kind of oxymoron: stable + 7.15beta8 despite the fact that production 7.15 is the older version.
Maximasus
Fri Jan 03, 2025 12:05 am
As mentioned, stable wireless, not build. The latest from the point of view security updates - 7.15b8 is later than 7.14.3
macgaiver
Fri Jan 03, 2025 9:28 am
So, before Christmas i upgraded Intel WiFi driver to 23.100.0 for my AX201... no disconnection problem since, ok i had only few days of test because of the holidays , but before it happened daily at least once. you guys might like to give it a try.
Marvitex
Fri Jan 03, 2025 10:02 am
The problem doesn't occur only with Intel network cards.
erlinden
Fri Jan 03, 2025 10:27 am
I think he didn't mention that, he just informed us about an updated Intel driver that seems to give him better stability.
Marvitex
Fri Jan 03, 2025 2:12 pm
Sure, useful for those with an Intel network card, although personally I wouldn't be comfortable with it anyway.
Ruza
Wed Jan 15, 2025 11:26 am
ROS - 7.16.2 and 7.17.RC7
Intel drivers 23.100.04
Wireless reconnections continue, problem not resolved
Poovard
Fri Jan 17, 2025 6:18 pm
7.17 Stable - Ax3
Intel AX200 160Mhz
Intel 23.160.1.2 Driver -
Problem persists.
WPA2 and WPA3 enabled. Connected to master interface. WPA3 Connection.
Win 11 Event Viewer shows "7021 - Connection telemetry fields and analysis usage" around the time of the disconnect.
Will try disabling WPA3 and report back...
vovik
Sat Jan 18, 2025 2:27 am
Problem still present in 7.17rc8, only using WPA2.
Disconnects on my Google chromecast tv, google mini speakers, Lenovo laptop. Laptop is using intel wifi chip, not sure about other devices.
Had to downgrade back to 7.14.3
eNET1
Sat Jan 18, 2025 8:11 pm
Still getting disconnected on latest 7.17 version, I am starting to doubt this issue is even looked at, it’s been over 6 months now, some of you trying upgrading intel drivers when issue is clearly on mikrotik’s side, come on, you shouldn’t even do anything at all for it to work normally as it gets disconnected on default settings with minimalistic setup…
elussivealex
Sun Jan 19, 2025 1:49 am
I have same WiFi disconnects issues, even 7.17 and 7.17RC8 not helps at all, and I can’t roll back to 7.14.3 because Factory firmware for my board is 7.15.2.
Why Mikrotik engineers can’t solve this mass problem for so long?
UDP: I finally downgraded it, but don’t want staying on 7.14.3 forever, because safety issues(
massinia
Sun Jan 19, 2025 11:19 am
@elussivealex @eNET1 @vovik
Did you generate and send the supout file to MikroTik support before downgrade?
It seems that it is not easy to understand the cause and it does not happen to everyone.
For example, I have no disconnections with hAP ax3 (CAPsMAN) + hAP ax2 (cAP) and about 50 clients using WPA2 / WPA3.
Maybe you're doing something wrong in your configuration?
t0mm13b
Sun Jan 19, 2025 12:19 pm
Support don't read the forum threads, (not that I can see or they are being selective)
Everyone seems to be complaining, and come on this thread to post about the issues, but is anyone actually sending the required supout.rif to support?
Ruza
Sun Jan 19, 2025 11:42 pm
I keep sending files to the ticket SUP-157262, which I opened.
https://help.mikrotik.com/servicedesk/s ... SUP-157262
No result yet.
It seems that support has reached a dead end and has no solution.
Because the proposed solutions are to update the drivers for Intel adapters. But my TV Boxes and Android phones are also disconnecting.
But if someone else opens similar tickets, it will give the developers more information to analyze the problem and solve it faster.
https://help.mikrotik.com/servicedesk/s ... 1/create/5
VadiKO
Mon Jan 20, 2025 11:05 pm
I sents.
Got various options for settings to fix the problem but it didn't help.
I continue to use 7.14.3 :?
MichalPospichal
Tue Jan 21, 2025 1:33 am
It is possible, I too have the random disconnects and SA query timeouts and I have tried a lot of different wifi settings. Would you care to share your wifi config so people can compare it with a tested working setup?
massinia
Tue Jan 21, 2025 9:33 am
Sure this is my configuration, very simple because at the moment I don't use VLAN at home.
# 2025-01-21 08:17:32 by RouterOS 7.17
# software id = BH9H-NUQS
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDG00000000
add band=5ghz-ax disabled=no frequency=5500 name=100 skip-dfs-channels=\
    10min-cac
add band=2ghz-ax disabled=no frequency=2412,2437 name=1-6 width=20/40mhz
add authentication-types=wpa2-psk,wpa3-psk connect-priority=0/1 \
    disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes name=SecWiFi-1 wps=\
    disable
add disabled=no name=steering1 neighbor-group=dynamic-MikroTik-b8e24291 rrm=\
    yes wnm=yes
add channel=1-6 country=Italy disabled=no mode=ap name="2.4 GHz" security=\
    SecWiFi-1 ssid=MikroTik steering=steering1
add channel=100 country=Italy disabled=no mode=ap name="5 GHz" security=\
/interface wifi
# operated by CAP 48:A9:8A:39:34:A4%bridge, traffic processing on CAP
add configuration="5 GHz" configuration.manager=local .mode=ap disabled=no \
    name=cap-wifi1 radio-mac=48:A9:8A:39:34:A8
add configuration="2.4 GHz" configuration.manager=local .mode=ap disabled=no \
    name=cap-wifi2 radio-mac=48:A9:8A:39:34:A9
set [ find default-name=wifi1 ] configuration="5 GHz" configuration.manager=\
set [ find default-name=wifi2 ] configuration="2.4 GHz" \
/interface wifi capsman
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no \
    upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration="2.4 GHz" \
    supported-bands=2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration="5 GHz" \
    supported-bands=5ghz-ax
add address-pool=default-dhcp interface=bridge lease-time=12h name=defconf
As you can see I added "connect-priority=0/1" because do some old Chinese smartphones when using WPA3 remain hooked to a cAP and do not roam, by activating I solved it.
Another change is the DHCP server lease which is 12 hours.
In another location I have a 5009 (CAPsMAN) with 4 wAPs AX (cAP), similar configuration but also with VLAN, here too no disconnections with about 60 wireless clients.
mndtrp
Tue Jan 21, 2025 11:45 am
I've been having these issues as well using my HAP ax2 running ROS > 7.14.3. Been through the hoops with MT support using minimum configuration and trying to identify what devices cause WIFI disconnects. What we have found is that my Google Nest Speakers (Audio and Mini) cause regular and temporary WIFI drop-out for most, if not all all connected WIFI devices. Removing the Google Nest Speakers (Audio and Mini) increases WIFI stability significantly.
Trying to re-configure ROS based on Mikrotik Support and forum recommended settings has been a rabbit hole for me with zero improvement to stability.
Instead of trying to change the ROS configuration. Try to identify what devices are causing the issue by temporality removing them. Like Android TV, Google Nests and other similar devices. It's tedious, but could be bring valuable information to MK support.
Since my issue cannot be reproduced on ROS <= 7.14.3, my conclusion is that this is a Mikrotik issue.
massinia
Tue Jan 21, 2025 12:09 pm
@mndtrp
Out of curiosity, how long is the lease time of the DHCP server? 10 minutes?
mndtrp
Tue Jan 21, 2025 12:26 pm
@mndtrp
I’ve tried 10 minutes, 1 hour and 24 hours. Lease time has no effect.
MichalPospichal
Wed Jan 22, 2025 12:49 am
As I have already mentioned in another thread here: viewtopic.php?p=1117893&sid=06afa00c0c7 ... c99f05563c
I am pretty certain my issues started after I introduced WiiM Streamer into my network. Before that, my phone was the only device permanently connected on 5Ghz with occasional temporary connections of laptops. No issues observed. After connecting WiiM on 5GHz, the phone, perfectly working up till then for almost a year, started giving me SA query timeouts at least once a day randomly.
And yes, most likely it is Mikrotik issue, since in 7.15 the Qualcomm Wifi driver was updated, so it is pretty clear what is behind all this mess. Just rollback of the driver should fix it, but Mikrotik does not wanna hear about it apparently. So we are stuck with broken Wifi.
MichalPospichal
Wed Jan 22, 2025 12:56 am
Thanks, I suppose you are using same SSID for 2 and 5GHz and use roaming between the 2, correct? Since I see you have FT enabled.
I have 2 and 5Ghz separated on different SSIDs, and connect devices directly where I want them to, and I have FT disabled, but otherwise basically the same setup (I even tried the connect priority setting with no impact), and with only 2 devices (my phone and WiiM Ultra), my phone gets SA query timeouts. Crazy to think you have no issues whatsoever with dozens of devices at the same time.
massinia
Wed Jan 22, 2025 9:24 am
Yes, it's correct.
Yes indeed it's curious... consider that I also have 3 Sonos One, 2 Chromecast and a Google Nest Audio and they never disconnect.
Ruza
Thu Jan 23, 2025 11:33 am
Today I tried to update to 7.17 and set up local WiFi interfaces via local CapsMan.
I understand that this is a hack and an excessive solution, but it works for Massinia.
The solution worked for 3 hours and my TV box started reconnecting to WiFi again
Florian
Thu Jan 23, 2025 4:02 pm
For the record, never had the problem here (around 10-11 devices, 2.4 anf 5ghz)...
dang21000
Thu Jan 23, 2025 10:13 pm
Since, i've fixed channel width AND create a "fake master hidden ssid"
I've no disconnect except roaming on a building with 4 floors and 12 hap ax3 running 7.17.
This my capsman cfg :
/interface wifi channel
add channel=master_channel country=France disabled=no hide-ssid=yes mode=ap multicast-enhance=enabled name=master_config \
    security.authentication-types=wpa3-psk ssid=master
/interface wifi datapath
add bridge=bridge1 bridge-cost=10 client-isolation=no disabled=no interface-list=guest name=vlan1049_datapath vlan-id=1049
add bridge=bridge1 bridge-cost=10 client-isolation=no disabled=no interface-list=lan name=vlan1050_datapath vlan-id=1050
add bridge=bridge1 bridge-cost=10 client-isolation=no disabled=no interface-list=guest name=vlan1069_datapath vlan-id=1069
add bridge=bridge1 bridge-cost=10 client-isolation=no disabled=no interface-list=lan name=vlan1070_datapath vlan-id=1070
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-mobility-domain=0x1049 ft-over-ds=yes name=vlan1049_auth wps=disable
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-mobility-domain=0x1050 ft-over-ds=yes name=vlan1050_auth wps=disable
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-mobility-domain=0x1069 ft-over-ds=yes name=vlan1069_auth wps=disable
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-mobility-domain=0x1070 ft-over-ds=yes name=vlan1070_auth wps=disable
/interface wifi configuration
add channel=slave_channel country=France datapath=vlan1049_datapath disabled=no hide-ssid=no mode=ap multicast-enhance=enabled name=\
    vlan1049_config security=vlan1049_auth ssid=1049
add channel=slave_channel country=France datapath=vlan1050_datapath disabled=no hide-ssid=no mode=ap multicast-enhance=enabled name=\
    vlan1050_config security=vlan1050_auth ssid=1050
add channel=slave_channel country=France datapath=vlan1069_datapath disabled=no hide-ssid=no mode=ap multicast-enhance=enabled name=\
    vlan1069_config security=vlan1069_auth ssid=1069
add channel=slave_channel country=France datapath=vlan1070_datapath disabled=no hide-ssid=no mode=ap multicast-enhance=enabled name=\
    vlan1070_config security=vlan1070_auth ssid=1070
set ca-certificate=auto certificate=auto enabled=yes interfaces=vlan1067 package-path="" require-peer-certificate=no upgrade-policy=none
add action=create-dynamic-enabled comment=wifi-5g disabled=no master-configuration=master_config name-format=wifi-5g-%I slave-configurations=\
    vlan1049_config,vlan1050_config,vlan1069_config,vlan1070_config slave-name-format=%m%v supported-bands=5ghz-a,5ghz-n,5ghz-ac,5ghz-ax
add action=create-dynamic-enabled comment=wifi-2g disabled=no master-configuration=master_config name-format=wifi-2g-%I slave-configurations=\
    vlan1049_config,vlan1050_config,vlan1069_config,vlan1070_config slave-name-format=%m%v supported-bands=2ghz-ax,2ghz-g,2ghz-n
blazer4493
Sun Jan 26, 2025 7:06 am
Tested 7.18beta2 today and the issue is still not completely fixed. Though it has been reduced a lot since the 7.16-7.17 builds I find. It's actually almost entirely usable now where as before I HAD to be on 7.14.3 to actually have a usable connection on the 5GHz interface. The two devices I have that trigger the problem do still cause the 5GHz interface to drop, but it's only when they first connect and its for a much shorter period of time.
massinia
Sun Jan 26, 2025 11:57 am
Which hack? It is the correct way.
On device with CAPsMAN active the cAPs interfaces are local managed, otherwise fast roaming can never work.
In the CAPs instead they are managed by CAPsMAN
Ruza
Sun Jan 26, 2025 12:57 pm
This is the right way if you have additional access points and need centralized network management.
But in my case there is only one hAP AX3 router and running CapsMan is a redundant solution. But this, unfortunately, does not work either.
Ruza
Sun Jan 26, 2025 1:04 pm
I agree with this. I also have fewer interruptions on this version, and on Windows computers, instead of interruptions, there are sometimes delays in data transfer. But unfortunately, watching YouTube or Netflix is ​​interrupted on TVBox and tablets.
ivicask
Sun Jan 26, 2025 4:46 pm
Still no improvements for me on 7.18, soundbar, tv, tablets, getting disconnected for no reason even next to router on desk under full signal...
Ruza
Fri Jan 31, 2025 7:51 pm
People, please, let's help the developers solve our common problem with WiFi.
Please open tickets on the support portal
https://help.mikrotik.com/servicedesk/s ... r/portal/1
describe the problem and attach the Supout.rif file.
This will help the developers collect more information and solve the problem faster.
Because more than half a year has passed, and the problem is not solved.
MichalPospichal
Sat Feb 01, 2025 2:35 am
Done that, SUP-177122 opened on 22/01, still in "waiting for support".
geku
Sun Feb 02, 2025 12:43 am
Here is what I see when trying to connect my old Wyze Cam v1. Camera continuously sends 'Probe Request' but router is silent.
I simplified configuration 2.4GHz to next:
1 M B  default-name="wifi2" name="wifi2" l2mtu=1560 mac-address=xxxx arp-timeout=auto radio-mac=xxxx
        configuration.mode=ap .ssid="ssid1" .dtim-period=3
        security.authentication-types=wpa2-psk .encryption=ccmp .passphrase="xxx"
        channel.frequency=2437 .secondary-frequency=disabled .band=2ghz-g .width=20mhz
 3   BI name="wifi4" l2mtu=1560 mac-address=xxxx arp-timeout=auto master-interface=wifi2
        configuration.mode=ap .ssid="ssid2" .dtim-period=3
        channel.frequency=2437 .band=2ghz-g
But still silence form router. In logs it looks like that (2nd image), but I cannot see those connections and associations in Wireshark. May be some packets are filtered and I need to buy USB WiFi module that can be put into monitor mode to properly log WiFi communication.. I don't know.
Ruza
Sun Feb 02, 2025 1:31 am
ROS 7.18.beta4 no changes
Android devices start disconnects after 15 minutes (((
MikrotikUser100
Fri Feb 07, 2025 1:13 am
sajgan
Wed Feb 19, 2025 10:22 am
maybe someone tested 7.18rc1 version?
jdub88
Fri Feb 21, 2025 3:48 pm
Yes - I gave it 48 hours, it was unusable for me - Same symptoms with the drops, SSIDs dissappear briefly from the network list...then come back and rejoin. Kicks me off Zoom calls,etc.
Theres never anything meaningful in the logs
Back down to 7.14.3 and all is well again - at this point I think I will just have to accept that there is no point trying the new versions and settle for the stability over the new features. It's for home use anyway, so not a huge issue, except for say some major as-yet-unknown security issue further down the line.
It is a shame that this has been going on for so long. My other Mikrotik buddies have mostly gone to TP-Link, but I am happy to stick with 7.14.3.
nonimuss
Sun Feb 23, 2025 8:43 am
Forget it! The developers have stopped support, they do not use cheap models and are not aware of the problem. They also don't want to believe that something might not work on their equipment! :(
darkstarpz
Sun Feb 23, 2025 11:03 am
Any response from MT support? That is not real - so many uses have this issue and no feedback???
Do we have support case number so we can push them?
inray
Sun Feb 23, 2025 1:20 pm
Today's practice among developers is not to enter into a discussion about an issue when they have nothing to say and no fix to offer.
I'm afraid we'll have to wait as long as it takes to get to the cause of the problem, or replace all Mikrotik WiFi devices with some other manufacturer's.
Personally although I love RouterOS and Mikrotik routers I have lost faith that one day they will be able to offer the stability and capabilities that other WiFi device manufacturers currently offer.
WiFi has never been Mikrotik's strong point and unfortunately it seems this is still true today.
mndtrp
Sun Feb 23, 2025 9:23 pm
Mine is SUP-172402. Not much happening. Support has run out of ideas and been quiet for 3-4 weeks now.
mchernyshev
Mon Feb 24, 2025 1:11 pm
Dear all.
I have tried upgrading to last beta one more time using hAP ax3
after that disabled "Detect interface list" on my wireless interfaces. Seems I don't have Wi-Fi disconnects anymore.
Hope it will help you as well.
BartoszP
Mon Feb 24, 2025 1:20 pm
pfyod
Mon Feb 24, 2025 1:37 pm
@mchernyshev Do you have any Chromecast devices in your network? Before upgrade, was your wireless only usable on ROS <=17.4.3?
mchernyshev
Mon Feb 24, 2025 2:05 pm
I don't have Chromecast devices. before I have used ROS 7.14.3 as last stable and didn't check stable branch version today.
Last check was made on development branch and I have posted here after I have good results with disabled internet check without any additional checks.
sajgan
Tue Feb 25, 2025 10:34 am
oooo 7.18rc2 good bye :)
channel: stable
installed-version: 7.14.3
latest-version: 7.18
mndtrp
Tue Feb 25, 2025 11:40 am
Just tested 7.18. No improvement.
Issues after less than 10 minutes (with Google Nest Hub/Audio/Mini Speakers connected) causing full outage for all connected devices on the same WIFI master interface. And no, it is not DHCP related. Lease time is 24 hours.
And as always. Removing the Google Nest devices. Stability returns.
SUP-172402 updated.
pfyod
Tue Feb 25, 2025 11:54 am
I find it quite disconcerting that it's been pinpointed that some change in 7.15beta9 is causing this (my gut feeling it's the "wifi-qcom - updated driver" part) and it's still not fixed / rolled back, almost a year later...
mikrotik4kvm3
Tue Feb 25, 2025 1:09 pm
SUP-172402 updated.
Exactly the same here - as soon as I connect my 2 x Google Nest Hubs and 2 x Google Nest Minis, then my devices start roaming like crazy between my 2 hAP ax2 devices (can easily roam a few hundred times in a day) and I also have loads of disconnects and reconnects as well. When I disconnect all the Nest devices then everything behaves really well on the network. I really don't want to downgrade to 7.14.3, so sticking to the latest (7.18 as I write this) and keep my Nest devices disconnected for now...
sajgan
Thu Feb 27, 2025 9:39 am
eh I jump to 7.18... when only my mbp connected all works fine (almost - I had to change the country and go back from the new to the old one because I couldn't connect to 5GHz). Today all pepople in home started working and... BUM. WIFI connected, but no traffic, can't reconnect.. I fast downgrade to 7.14.3...
As I now mikrotik guys enabled many options that are compliant with the 5GHz ax standard in version higher than 7.14.3 and question is "what we must turn off in configuration on 7.18?" - as I think one/more devices can brick 5GHz - why mikrotik don't make "fix" for handicapped devices?
jdub88
Fri Feb 28, 2025 1:31 pm
Well, that is the key question we're all trying to get answers on, but the onus seems to be on customers to prove the problem with laborious log gathering and support tickets, whereas you would have thought they could leverage the overwhelming (albeit perhaps anecdotal) evidence showing that everyone reports stability in 7.14.3 but not after and keep reverting back to it. Something must stand out to the devs. Alas, this has been going on for a long time, and my expectation now is to stick with 7.14.3. I value stability over a new UI that's for sure.
mikrotik4kvm3
Sun Mar 02, 2025 5:59 pm
SUP-172402 updated.
OK, have to report back again. With my Google Nest devices turned off, all was going well, until I started using my PS Portal (Android based). After playing for about an hour, devices started roaming and disconnecting like crazy. Tried again the next day, and after about 30-40 mins of using the PS Portal, same thing - devices roaming and disconnecting.
So, I have actually downgraded my 2 x hAP ax2 units to 7.14.3 and kept my RB5009 on 7.18. Been using it like this for a few days now (with all Google Nest devices and my PS Portal connected) and everything is behaving really well.
As I'm using different versions on my caps (2 x hAP ax2) and my capsman (RB5009), I just have to be aware that some WiFi features will be incompatible (e.g. setting the "reselect interval" on capsman will have no affect on the caps).
BitHaulers
Mon Mar 03, 2025 10:58 pm
As someone who manages a few hundred different sites that all use Mikrotik WiFi, I've noticed similar issues to what's mentioned on threads like this.
One thing I've noticed with all Mikrotiks, is the need for NetInstall when anything weird happens. However, nobody ever things or wants to NetInstall as a matter of course for troubleshooting. In my professional experience, factory resets do not fix the problem.
I have seen dozens of "bugs" that are mentioned in this forum and on Reddit, that have been fixed when I perform two NetInstalls, one to the factory firmware that the device shipped with, without a default config, and another one to the latest build, also without a default config, and then I build it with my own script from scratch.
This has fixed a disturbing number of problems, even with brand new, fresh out of the box, Mikrotiks. It doesn't matter if it's a WiFi issue, a routing issues, an NTP client issue, a mangle issue, an LTE issue, a ping watchdog issue, a DHCP server issue, DHCP client issue.
Something is wrong with RouterOS, that is fixed with multiple NetInstalls. I think the main problem is, last I checked, NetInstall did not write zeros to the flash memory. While I understand this is not good for the hardware, it's better than throwing it out and buying a new device.
So, everyone on here is talking about all these problems that aren't fixed by upgrading.
I can't really take any of these data points seriously until you guys start NetInstalling and building them from scratch without the default configs. If they still do it after that, then we have eliminated memory corruption from the problem.
There are no tools within RouterOS that have ever detected memory corruption for me. However, I have had all sorts of gremlins disappear over the years with this method.
As much as people will complain that what I'm saying shouldn't be relevant, I think you guys need to try it, and prove it's not relevant.
mndtrp
Tue Mar 04, 2025 10:49 am
Did like you suggested
Steps
1. Repartition (includes formating)
2. Netinstall Factory Firmware (7.6) - No default configuration
3. Netinstall Latest Firmware (7.19b2) + Configure with Script
and the problem persists.
ilium007
Tue Mar 04, 2025 12:07 pm
How do you "repartition" before a Netinstall? I just tried on an old RB device:
holvoetn
Tue Mar 04, 2025 12:19 pm
As message indicates: you first have to enable this in device mode.
ilium007
Tue Mar 04, 2025 12:45 pm
I can't imagine having to be in any other device mode other than "advanced" to allow something like a change to boot order:
[admin@MikroTik] /system/device-mode> print
                 mode: advanced
     allowed-versions: 7.13+,6.49.8+
              flagged: no
     flagging-enabled: yes
            scheduler: yes
                socks: yes
                fetch: yes
                 pptp: yes
                 l2tp: yes
       bandwidth-test: yes
          traffic-gen: no
              sniffer: yes
                ipsec: yes
                romon: yes
                proxy: yes
              hotspot: yes
                  smb: yes
                email: yes
             zerotier: yes
            container: no
  install-any-version: no
           partitions: no
          routerboard: no
        attempt-count: 0
[admin@MikroTik] /system/device-mode> /system/routerboard/settings/set boot-device=try-ethernet-once-then-nand
failure: not allowed by device-mode
Or... a repartition:
[admin@MikroTik] > /partitions/repartition partitions=1
Repartitioning requires reboot. Continue, yes? [y/N]:
y
[admin@MikroTik] >
sajgan
Tue Mar 04, 2025 1:02 pm
/system/device-mode/update partitions=yes
holvoetn
Tue Mar 04, 2025 1:07 pm
partitions: no
Should be yes if you want to repartition.
/partitions
does not allow to change count of partitions. If your router is unable to boot, it will still be able to boot into your other partitions. No restriction for crash recovery.
See Help pages:
https://help.mikrotik.com/docs/spaces/R ... evice-mode
mndtrp
Tue Mar 04, 2025 2:17 pm
Steps
Just want to say that Repartitioning is not required. I just did it because I could. Going from 2 to 1 partition.
This is what I had to do. Though I'd share to save other intermediate Mikrotik noobs like me some time.
0. Export of my current configuration.
export show-sensitive file=config_export
1-3. Described above.
4. Noticed that huge chunks of my exported configuration from Step 0 was not imported. Because Device Mode is reset during this process.
5. Reconfigured Device Mode.
system/device-mode/update mode=home partitions=yes zerotier=yes scheduler=yes
6. The following configuration was not imported during Netinstall.
/routing rule
/system scheduler
/system script
/tool/netwatch
/tool mac-server
/tool mac-server mac-winbox
/system ntp client
/system ntp client servers
/system package update
/system routerboard mode-button
/routing igmp-proxy interface
/system clock
/system identity
/ipv6 firewall address-list
/ipv6 firewall filter
Default firewall rules can be found here: viewtopic.php?p=1124805#p856824
7. Backups of this configuration is half of what is what before Netinstalling. Cached data?
8. Seemingly better stability. Only my Google Nest Audio device is causing havoc on my 5Ghz WIFI. Moving it to 2.4Ghz is showing promising stability for now. But is not a solution to the issue. It must work on any HAPax2 WIFI interface.
9. Spoke too soon. Stability is not improving. It just took a little longer than I expected to break.
I'll update the list if I learn more related to this procedure.
mikrotik4kvm3
Wed Mar 05, 2025 10:29 am
I originally did netinstall all my devices to the latest firmware (without applying a default config) and WiFi issues with Google Nest devices and my PS Portal were causing havoc. So, unfortunately, netinstall is not the solution in this case :(
As mentioned by some guys earlier, I think the issue is this change introduced in 7.15 -> "wifi-qcom - updated driver"
Nonetheless, I'm staying on 7.14.3 until the problem is resolved (like a lot of people in this forum are doing)...
mndtrp
Fri Mar 07, 2025 11:52 am
Testing 7.19beta4. No improvement.
Issues after less than 10 minutes.
marcin21
Sun Mar 09, 2025 4:30 pm
how did You downgraded board to lower than factory ros revision?
MichalPospichal
Tue Mar 11, 2025 6:43 pm
Exactly. I wish Mikrotik would release some test version of the latest ROS with the OLDER Wifi driver, just to prove the point. Sure, it could break some new features in 7.15+ versions, that were maybe implemented based on the updated Wifi drivers, but it would just be a testing version to confirm the problem IS the driver. This would help tremendously not to be chasing ghosts instead of really fixing the issue. Because this can drag for years seeing how Mikrotik actually gives a crap about it.
infabo
Tue Mar 11, 2025 7:29 pm
Good catch!
v1597psh
Thu Mar 13, 2025 10:02 am
What's new in 7.18.2 (2025-Mar-11 13:59):
*) wifi - improved stability for wifi interfaces
Anyone tested this?
mndtrp
Thu Mar 13, 2025 11:21 am
Anyone tested this?
Just tested 7.19beta5. And had high hopes, but I'm sorry to say. There is no improvement.
Within the first 10 minutes Google devices and iPhones lost connectivity simultaneously. Will keep it running an hour or two before I roll back.
What's new in 7.19beta5 (2025-Mar-12 12:42):
*) wifi - fixed incorrect attribution of 802.11be capability to 802.11ax APs in output of scan command (introduced in v7.19beta2);
*) wifi - fixed sending of reassociation response frames (introduced in v7.19beta2);
*) wifi - improved stability for wifi interfaces;
erlinden
Thu Mar 13, 2025 11:56 am
Have you considerd (or performed) a netinstall, @mndtrp?
https://help.mikrotik.com/docs/spaces/R ... Netinstall
sindy
Thu Mar 13, 2025 12:16 pm
I have netinstalled a hAP ac² for other reasons and recreated the configuration from the text exports (i.e. no "invisible" data), nevertheless:
  • the Intel 201ax gets thrown out from an AP no matter what (20 MHz channels, 40 MHz channels, 80 MHz channels tried, not using those "not recommended" ones, running the latest driver from Intel pages) and has to connect to the other AP after 2-3 days of continuous run,
  • the iPhone keeps disconnecting and reconnecting even with that Apple-optimized dtim-period=3 on the respective /interface/wifi/configuration row, however the latter is only visible on the /interface/wifi/registration-table/print stats output, the user does not complain. Even an incoming "WiFi calling" call makes the phone re-establish the connection, I haven't tried to isolate it from the mobile network yet.
Leaving aside that the above are just the commonly experienced issues; according to this thread, there are more scenarios where a particular station can break things for the other ones. So I would not expect too much from a netinstall.
aperture147
Fri Mar 14, 2025 1:48 pm
7.15+ wifi-qcom drivers are instable with Intel clients. That is already known and confirmed even by Mikrotik
I don't think it's just the intel client's problem. My Bosch dishwasher and Aqara IoT hub is also having the disconnecting problem and I doubt that it's using an intel wifi chip.
robmaltsystems
Forum Veteran
Forum Veteran
Fri Mar 14, 2025 2:07 pm
Pretty sure some of the Realtek chips are affected too. Often used in cheaper Lenovo laptops like mine.
itimo01
Fri Mar 14, 2025 2:27 pm
You mind telling me which one you got?
My RTL8852AE in a Thinkpad L14 is rock solid.
But i also dont have any of the issues people have in this topic here.
And that is with Intel AX210 and BE200 cards too.
The only thing I noticed is that my Intel 2XX cards have a much more limited 5ghz spectrum compared to any other Wi-Fi card I got.
Including older Intel ones like the AC9260
robmaltsystems
Forum Veteran
Forum Veteran
Fri Mar 14, 2025 2:52 pm
Realtek 7722CE. I also have a Realtek 8832CU Wi-Fi 6 USB adapter and that feels more stable and of course faster. My experience is with hAP ax2 so slightly different setup.
Ruza
Mon Mar 31, 2025 11:11 am
7.19beta6 didn't solve the problem. I even replaced AX200 with AX210, but nothing helps.
Android devices also lose network, especially on Android 9 or 10. Android 11 network just freezes for a while, but maybe they have a different Wi-Fi module than 9
Rolled back to 7.14.3
ivicask
Mon Mar 31, 2025 12:45 pm
For me 7.18.2 seam to solved the problem, for example my Samsung soundbar which behaved the worst before now has 19 days uptime which was not possible after 7.15 update, it would sometimes disconnect several times per day..
rralex89
Mon Mar 31, 2025 4:20 pm
I'm on 7.18.2 and the matter is not resolved for me. I still get disconnects. Only now the disconnection message is different "MACADDRESS"@5Ghz_BedroomAP- disconnected, not responding, signal strength -86"
Sirafim
Mon Mar 31, 2025 4:21 pm
Confirmed, the problem has not been solved.
I downgraded the RoS version again to 7.14.3
TomUrlings
Wed Apr 02, 2025 8:13 pm
Thanks for this, also reverted my hAP ax^3 to 7.14.3 and did not see any disconnects on both 2.4GHz and 5GHz.
Edit: hAP logging below (MAC/SSIDs etc masked)
Apr  1 18:51:12 gw-lan wireless,info  00:11:22:33:44:55@5GHz(ssid (5 GHz)) disconnected, connection lost, signal strength -55
Apr  1 18:51:12 gw-lan wireless,debug 00:11:22:33:44:55@5GHz(ssid (5 GHz)) disassociated, connection lost, signal strength -55
Apr  1 18:51:29 gw-lan wireless,debug 00:11:22:33:44:55@5GHz(ssid (5 GHz)) associated, signal strength -49
Apr  1 18:51:29 gw-lan wireless,info  00:11:22:33:44:55@5GHz(ssid (5 GHz)) connected, signal strength -49
Ubuntu 24.04.2 LTS logging below:
2025-04-01T18:51:12.711076-07:00 es wpa_supplicant[3158]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=99:99:99:99:99:99 reason=4 locally_generated=1
2025-04-01T18:51:29.021730-07:00 es wpa_supplicant[3158]: wlp0s20f3: Trying to associate with 99:99:99:99:99:99 (SSID='ssid (5 GHz)' freq=5745 MHz)
2025-04-01T18:51:29.023833-07:00 es kernel: wlp0s20f3: associate with 99:99:99:99:99:99 (try 1/3)
2025-04-01T18:51:29.038808-07:00 es kernel: wlp0s20f3: associated
2025-04-01T18:51:29.044390-07:00 es NetworkManager[3138]: <info>  [1743558689.0442] device (wlp0s20f3): supplicant interface state: associating -> associated
2025-04-01T18:51:29.044492-07:00 es NetworkManager[3138]: <info>  [1743558689.0443] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> associated
2025-04-01T18:51:29.139063-07:00 es NetworkManager[3138]: <info>  [1743558689.1389] device (wlp0s20f3): supplicant interface state: associated -> 4way_handshake
2025-04-01T18:51:29.139182-07:00 es NetworkManager[3138]: <info>  [1743558689.1389] device (p2p-dev-wlp0s20f3): supplicant management interface state: associated -> 4way_handshake
Note: reason=4 as mentioned by wpa_supplicant means "Disassociated due to inactivity". This happened randomly, sometimes multiple times in a short period of time (<30 minutes). Sometimes it took a while before it would disconnect in the same manner. Multiple devices affected, not just this laptop, also printer, chromecast, Android phones, etc.
After downgrade to 7.14.3 this has not happened since.
chechito
Thu Apr 03, 2025 5:39 pm
i am also returning to 7.14.3 on hap ax2 , thanks for sharing
13 hours of uptime and counting, what an achievement...
mituss
Sun Apr 06, 2025 7:09 pm
This router came from the factory with RouterOS 7.11.2, but with some really random setups — some units shipped with 7.16.0, and most of the drivers were flashed during production with 7.11.2 versions. Starting with 7.13.0, they completely messed up the Wi-Fi drivers by splitting the wave2 package into two separate ones. Ever since then, they’ve never quite managed to get the drivers working properly again.
Currently, I’m running the latest 7.19beta8, and I still get random disconnects. Honestly, I’m at the point where I’m ready to smash this router with a hammer. For a brand that has such a big name in networking, it's shocking how bad their Wi-Fi implementation is — especially when brands like Asus, TP-Link, Mercury, and D-Link have managed to do it better.
Back to the point — if you care about Wi-Fi stability, 7.11.2 (or even 7.11.3) gives you probably the most stable experience on this router. Keep in mind though, this is a half-baked Wi-Fi 6 home router. Wi-Fi 6 should support 160MHz channels, not just the low-end 80MHz ones. 🤦‍♂️
I even tried upgrading the antennas to some 20dBi 50ohm monsters — but yeah, with broken drivers, it made zero difference.
P.S. If anyone out there is a MikroTik OS fan like me (it is like a Swiss Army knife OS), and you're researching before buying this router or any other Wi-Fi-enabled MikroTik device… just don’t — unless you plan to disable the built-in Wi-Fi and use a separate access point. If that's your plan, sure, go for it.
But for me, switching from this to a Ubiquiti UDR7 or even an Asus Wi-Fi 7 router feels like it would’ve been a way better choice.
infabo
Sun Apr 06, 2025 7:42 pm
Is there a reason why you recommend 7.11 instead of 7.12? You said they messed starting with 7.13.
mituss
Sun Apr 06, 2025 8:27 pm
No particular reason, but I’d definitely recommend checking the changelog first. Personally, I just went with whatever version the factory flashed on the device — since, in theory, that’s what ships with it when you buy it. And realistically, as a retailer, you want a setup that actually works out of the box so customers don’t end up returning the device.
This is the change that really messed things up:
https://mikrotik.com/download/changelogs#c-stable-v7_13
That’s when they basically said goodbye to wifiwave2 😄 — and things went downhill from there.
Right now, I’m already looking around for another router, though I’ll probably keep this one around for a while longer — hoping maybe they’ll eventually fix it. But honestly, the difference was huge for me. I went from a commercial Wi-Fi 6 router that easily gave me ~600Mbps download speeds over Wi-Fi in an ~80m² apartment... to the hAP AX3, which struggles to keep a device connected for even 1 hour without a random disconnect. 😅
At the end of the day, despite loving the flexibility and features of MikroTik devices, I still feel like this was a downgrade — at least from a pure Wi-Fi performance perspective.
infabo
Sun Apr 06, 2025 9:24 pm
My wap ax has factory version 7.15. That is after 7.13. Should I now be concerned?
phascogale
Mon Apr 07, 2025 1:42 am
As an alternative data point, as I write my ax3 is providing 864 Mb/s through a wall with zero drop-outs observed, running 7.18.2 in a standard configuration for my country, no special tuning; over 1 Mb/s in the study where the ax3 sits high on top of a bookshelf. It is sufficient such that I dropped my original intention to extend the network downstairs with an ax2.
My ax3 is strong and stable, and all my routers (even mAP lite) have benefitted (or not acquired problems) all the way from 6.49 / 7.6 to 7.18.
I am not in any way denying people have problems yet I doubt this is an intrinsic one, but QC on a device or else the variables of the working environment for a configuration. In my case WiFi clients to MT are Apple to the ax3 and IoT to a couple of hAP ax lite, Linux boxes are wired. Other environments and software will be different which can be almost endlessly confusing..
mituss
Mon Apr 07, 2025 3:28 am
Mine came with 7.16.1 — at least that's the factory version shown on the RouterBoard. But in System > Resources, it showed 7.11.2 as the factory version. After a lot of troubleshooting and digging through the changelog, I found that the driver split happened in 7.13.0.
I've been dealing with range issues and random disconnects on my hAP AX3 right from the start. My router is about 13 meters away from my home office, placed in a hallway. I've tried every channel width combination, scanned and tested all available frequencies, swapped out the antennas for some really good ones, adjusted antenna gain ( there are some hardcoded limitations so that's useless) , basically tried everything I could think of. I even have a d-link extender placed in the middle, with clear line of sight, but still the connection randomly drops and switches between 5 GHz and 2.4 GHz and i get notifications from the extender that the 5g connection to the router dropped and the extender is 3m away.
This is my experience who knows maybe it's a faulty device, though if it was only me, there woudn't be a thread reserved to this issue here :). I have another friend with the same router and he's experiencing the same shinanigans.
massinia
Mon Apr 07, 2025 10:15 am
Are you using the DAP-X1860?
It was one of the worst extenders I tried, it had the same problem you described but it did it with all AX routers (tried with ASUS, TP-Link and Keenetic).
Mine too, I've been using it for about two years and I haven't had any problems with the wireless.
rralex89
Tue Apr 08, 2025 5:31 pm
After working with Mikrotik on a support case, they've managed to reproduce the issue and they said they will develop a fix in a future release. I did not get a timeframe from them but the good part is that at least someone is working on it.
infabo
Tue Apr 08, 2025 7:23 pm
Thank you, rralex89!
rralex89
Tue Apr 08, 2025 9:03 pm
no worries. SUP-184106 for future reference. just to be clear i did not get the issue with the WAP AX, when i tested with a WAP AX it worked seamless . Only with the hAP AX2 and CAP AX with any RouterOS version newer than 7.14.3. I did not have the ax3 to test with but it obviously has the same issue as it shares the wireless chipset with the CAP AX and HAP AX2
mndtrp
Fri Apr 11, 2025 11:14 am
SUP-172402 is also confirmed as a bug.
@Mikrotik support: "With having proof, the issue has been reported internally with access to the setup, and we are investigating it further."
Florian
Fri Apr 11, 2025 8:21 pm
Very good news :)
RedOnion
Fri Apr 11, 2025 10:02 pm
I had a similar response:
We could reproduce a similar behavior with "Chromecast" devices, when streaming from a PC (a YouTube video for example), to the "Chromecast" device (which basically connects to the TV/monitor via HDMI, is powered via USB, and can be controlled via phone APP or a stream can be pushed/"cast" to it via Google Chrome browser - in other words, it enables the TV with "smart-TV" functionality).
During such streaming, there could be times of ~10-20 seconds when SSID goes down.
So if you can confirm that the SSID goes down and all 5 GHz connected devices drop out (some can be more sticky and stay connected, but if the majority of WiFi clients gets disconnected within 15 seconds of each other/at the same time), it looks like the same issue we reproduced.
In that case, we are investigating it! The system will notify you when we find the fix.
VadiKO
Tue Apr 15, 2025 9:24 am
Hello friends!
I am also communicating with Mikrotik support.
Currently my ax3 is updated to ros 7.18.2, I want to note that it shows itself much better compared to ros 7.15, but it is still far from ideal, some devices continue to lose connection, but not all at once as before.
Mikrotik support is collecting data to fix the problem.
We expect improvements in the next releases of ros. :)
Liiina
Tue Apr 15, 2025 7:28 pm
they have been collecting data for a year now. i don't think this problem will be solved, moreover i would bet that this problem will not be solved at all.
infabo
Tue Apr 15, 2025 9:44 pm
Maybe another wireless driver update fixes it.
VadiKO
Tue Apr 15, 2025 11:52 pm
I agree, but there are already improvements, my PC no longer loses connection, I can safely play online games, a year ago this was impossible.
robmaltsystems
Forum Veteran
Forum Veteran
Wed Apr 16, 2025 11:53 am
I hope they get this resolved because this single flaw is preventing me installing any AX kit.
VadiKO
Wed Apr 23, 2025 2:06 pm
Hello friends!
I have some news from support:
We are still communicating with the Qualcomm (WiFi chip/driver) developers to figure it out. Rest assured, we will see it through and, hopefully, fix it soon.
I have "marked" this ticket and when we find the "fix" you should be notified via our ticket system that the fix is on the horizon.
As a potential workaround, I would advise switching the "streaming" device to 2.4 GHz network instead of 5 GHz. As it seems, it only affects 5 GHz.
Best Regards,
These are the things...
eNET1
Wed Apr 23, 2025 2:12 pm
Great news! It was obvious it was driver problem from the start, I hope it does not take another year for a fix.
robmaltsystems
Forum Veteran
Forum Veteran
Wed Apr 23, 2025 2:41 pm
Yes, that's good news as stability of 5GHz AX is one of those niggles that after a while starts to annoy. On my hAP ax2, I've configured a separate virtual network only on 2.4GHz and also not WPA2+WPA3 because I've got a couple of Android TV devices that simply won't work with that combo. The virtual network is configured with WPA/WPA2. Rock solid streaming.
Sddaw
Wed Apr 23, 2025 11:36 pm
Great and all but fingers crosed considering Qualcomm should give a slightest fun poking with a driver for 5 y/o or so chip.
ToTheFull
Thu Apr 24, 2025 12:16 pm
I have a very convoluted wifi config, but will try the 2.4g idea on a slave of another 2.4g master and see what gives.
Also why does adding a slave not get added to the bridge automatically, Is this normal Tik behaviour ?
tangent
Thu Apr 24, 2025 1:09 pm
Because that may be the wrong thing. For example
If ROS second-guessed you on this, it would be objectively wrong in this instance.
grzegorzb
Mon Apr 28, 2025 10:19 am
Apart from the AX networks, I also have a few on AC, and I have a question for you: does the issue also affect devices with the wifi-qcom-ac package installed? As a precaution, on devices where I have wifi-qcom-ac installed, I kept version 7.14.3, while on those without this package, my installations are running under version 7.12.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Apr 28, 2025 11:19 am
This caught me out the first few times and I assumed because that there were cases where adding it to bridge wouldn't be the right action. This is one of those cases where there is no truly right answer and the balance between being in total control and "wizard" like functionality. RouterOS philosophy is mainly the former which can be a surprise to relatively inexperienced users where they expect more automation.
TomUrlings
Re: hap ax3 random wireless disconnects
Fri May 02, 2025 1:39 am
Although not directed to me, I do want to share what I have installed here.
hAP AC^3 running wifi-qcom-ac 7.18.2 - no random disconnects observed
hAP AX^3 running wifi-qcom 7.14.3 - no random disconnects observed after downgrade to 7.14.3
Some remarks though, I am not running any 5GHz radio on the AC^3, just 2.4GHz. Also, most devices on the AC^3 are IOT devices that use up little bandwidth.
I have to find some time over the weekend to check if the newest 7.19 fixes the random disconnects on the AX^3.
Update: Within minutes of running 7.19rc1 the random disconnect occurred on two devices.
Groetjes,
Ruza
Sat May 10, 2025 9:37 pm
7.19rc2 does not solve the problem.
mikhailov
Sun May 11, 2025 3:59 pm
I wonder if you notice any CPU spikes right before the disconnects? I have AX^3 since Nov'2024 and after upgrading antenna with improving cooling I see wireless signal remains stable. Make sure antenna are connected well with pliers, because stock antenna's socket is cheap and flimsy.
If you can share system metrics that mktxp collects, that would help to see some trends whether wireless drop signals are load spike's related or not. Do you still see CPU load spike and wireless drops when WPA3 PSK is disabled?
abitfrosty
Tue May 13, 2025 11:31 pm
Great idea to check!
I've just lowered CPU freq to 864MHz and my temp tanked by 1 C. So far I have no random disconnects, will test overnight and see the log in the morning.
abitfrosty
Wed May 14, 2025 10:05 am
It didn't work. My situation might be due to neighbors.
Part of the log:
 2025-05-14 07:11:47 wireless,info 6C:29:90:A3:FE:98@wifi2 disconnected, connection lost, signal strength -42
 2025-05-14 07:11:49 wireless,info 6C:29:90:A4:04:C7@wifi2 disconnected, connection lost, signal strength -59
 2025-05-14 07:11:51 wireless,info 6C:29:90:A3:FE:98@wifi2 connected, signal strength -43
 2025-05-14 07:11:51 dhcp,info defconf deassigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:11:51 dhcp,info defconf assigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:11:53 wireless,info 6C:29:90:A4:04:C7@wifi2 connected, signal strength -58
 2025-05-14 07:11:53 dhcp,info defconf deassigned 192.168.88.236 for 6C:29:90:A4:04:C7 wiz_a404c7
 2025-05-14 07:11:53 dhcp,info defconf assigned 192.168.88.236 for 6C:29:90:A4:04:C7 wiz_a404c7
 2025-05-14 07:11:58 wireless,info 6C:29:90:A4:6C:13@wifi2 disconnected, connection lost, signal strength -44
 2025-05-14 07:12:05 wireless,info 6C:29:90:A4:6C:13@wifi2 connected, signal strength -44
 2025-05-14 07:12:05 dhcp,info defconf deassigned 192.168.88.246 for 6C:29:90:A4:6C:13 wiz_a46c13
 2025-05-14 07:12:05 dhcp,info defconf assigned 192.168.88.246 for 6C:29:90:A4:6C:13 wiz_a46c13
 2025-05-14 07:12:18 wireless,info 6C:29:90:A3:FE:98@wifi2 disconnected, connection lost, signal strength -42
 2025-05-14 07:12:23 wireless,info 6C:29:90:A4:6C:13@wifi2 disconnected, connection lost, signal strength -44
 2025-05-14 07:12:23 wireless,info 6C:29:90:A3:FE:98@wifi2 connected, signal strength -43
 2025-05-14 07:12:23 dhcp,info defconf deassigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:12:23 dhcp,info defconf assigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:12:27 wireless,info 6C:29:90:A4:6C:13@wifi2 connected, signal strength -45
 2025-05-14 07:12:27 dhcp,info defconf deassigned 192.168.88.246 for 6C:29:90:A4:6C:13 wiz_a46c13
 2025-05-14 07:12:27 dhcp,info defconf assigned 192.168.88.246 for 6C:29:90:A4:6C:13 wiz_a46c13
 2025-05-14 07:12:53 wireless,info 6C:29:90:A3:FE:98@wifi2 disconnected, connection lost, signal strength -42
 2025-05-14 07:12:58 wireless,info 6C:29:90:A3:FE:98@wifi2 connected, signal strength -43
 2025-05-14 07:12:58 dhcp,info defconf deassigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:12:58 dhcp,info defconf assigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:13:03 wireless,info 6C:29:90:A4:04:1E@wifi2 disconnected, connection lost, signal strength -43
 2025-05-14 07:13:07 wireless,info 6C:29:90:A4:04:1E@wifi2 connected, signal strength -45
 2025-05-14 07:13:07 dhcp,info defconf deassigned 192.168.88.250 for 6C:29:90:A4:04:1E wiz_a4041e
 2025-05-14 07:13:07 dhcp,info defconf assigned 192.168.88.250 for 6C:29:90:A4:04:1E wiz_a4041e
 2025-05-14 07:13:49 wireless,info 6C:29:90:A3:FE:98@wifi2 disconnected, connection lost, signal strength -42
 2025-05-14 07:13:53 wireless,info 6C:29:90:A3:FE:98@wifi2 connected, signal strength -43
 2025-05-14 07:13:53 dhcp,info defconf deassigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:13:53 dhcp,info defconf assigned 192.168.88.244 for 6C:29:90:A3:FE:98 wiz_a3fe98
 2025-05-14 07:13:58 wireless,info 6C:29:90:A4:04:1E@wifi2 disconnected, connection lost, signal strength -43
 2025-05-14 07:14:02 wireless,info 6C:29:90:A4:04:1E@wifi2 connected, signal strength -45
 2025-05-14 07:14:12 dhcp,info defconf deassigned 192.168.88.250 for 6C:29:90:A4:04:1E wiz_a4041e
 2025-05-14 07:14:12 dhcp,info defconf assigned 192.168.88.250 for 6C:29:90:A4:04:1E wiz_a4041e
 2025-05-14 07:14:16 wireless,info 6C:29:90:A4:04:C7@wifi2 disconnected, connection lost, signal strength -59
 2025-05-14 07:14:17 wireless,info 6C:29:90:A3:FE:98@wifi2 disconnected, connection lost, signal strength -42
 2025-05-14 07:14:20 wireless,info 6C:29:90:A4:04:C7@wifi2 connected, signal strength -59
 2025-05-14 07:14:20 dhcp,info defconf deassigned 192.168.88.236 for 6C:29:90:A4:04:C7 wiz_a404c7
 2025-05-14 07:14:20 dhcp,info defconf assigned 192.168.88.236 for 6C:29:90:A4:04:C7 wiz_a404c7
 2025-05-14 07:14:21 wireless,info 6C:29:90:A3:FE:98@wifi2 connected, signal strength -43
/interface/wifi/flat-snoop number=0 proplist=address,bss-address,ssid,frequency,signal,country
Flags: L - LOCALLY-ADMINISTERED-ADDRESS
Columns: ADDRESS, BSS-ADDRESS, SSID, FREQUENCY, SIGNAL, COUNTRY
  ADDRESS            BSS-ADDRESS        SSID                 FREQUENCY  SIGNAL  COUNTRY
                                                             2412MHz    -44
                                                             2417MHz    -64
                                                             2422MHz    -44
                                                             2427MHz    -39
                                                             2432MHz    -53
                                                             2437MHz    -74
                                                             2442MHz    -88
                                                             2447MHz    -71
                                                             2452MHz    -91
                                                             2457MHz    -76
                                                             2462MHz    -41
                                                             2467MHz    -35
                                                             2472MHz    -81
L 02:17:FC:B1:90:E5                     Redmi 13             2412MHz    -92
  04:BF:6D:97:0D:58                     Keenetic-6478        2462MHz    -97     RU[1]:2412-2472/20
L 06:78:BF:38:4B:DD                     Galaxy S24 641D      2437MHz    -79     RU/4[1]:2412-2472/23
  0C:37:47:8C:E5:EA                     RT-2.4GHz_WiFi_E5EA  2412MHz    -68     RU[1]:2412-2472/20
  10:A3:B8:20:23:D9                     RT-GPON-23D8         2432MHz    -81     RU[1]:2412-2472/20
  24:2F:D0:8F:99:0F                     Archer               2417MHz    -64                         (This doesn't show but it's 35db, this is my closest neighbour)
  28:DE:E5:24:BF:F8                     RT-GPON-BFF0         2462MHz    -94
  28:EE:52:73:26:15                     Anastasia            2462MHz    -92
  2C:05:47:3A:82:CA                     70mai_M300_82ca      2437MHz    -96
  2C:4D:54:B7:10:00                     Stranger_Wifi        2472MHz    -93     FR[1]:2412-2472/20
  2C:AB:00:E6:8B:64                     HUAWEI-9AIm          2437MHz    -80     #a[1]:2412-2484/30
  30:DE:4B:C2:A5:E4                     59                   2412MHz    -93     RU[1]:2412-2472/35
L 32:DE:4B:A2:A5:E4                                          2412MHz    -93     RU[1]:2412-2472/35
  38:2C:4A:8F:3A:60                     STROGANOV            2472MHz    -81     FR[1]:2412-2472/20
  44:27:F3:82:40:7A                     70mai_A810_407a      2417MHz    -92
  50:91:E3:5A:9B:C9                     TP-Link_9BC9         2442MHz    -88     RU[1]:2412-2472/35
  50:C7:BF:77:00:C9                     Freezer              2437MHz    -92
  50:FF:20:40:00:3D                     Serega.Vi            2437MHz    -91     RU/4[1]:2412-2472/20
  50:FF:20:42:44:A1                     Serega.Vi            2452MHz    -81     RU[1]:2412-2472/20
  50:FF:20:4C:5B:44                     Keenetic-0787        2452MHz    -97     RU[1]:2412-2472/20
  50:FF:20:51:CF:4D                     Goodnetwork 2.4      2452MHz    -93     RU[1]:2412-2472/20
  50:FF:20:AF:19:5D                     Keenetic-0219        2437MHz    -92     RU[1]:2412-2472/20
L 52:91:E3:2A:9B:C9                                          2442MHz    -88     RU[1]:2412-2472/35
L 52:FF:20:70:00:3D                                          2437MHz    -92     RU/4[1]:2412-2472/20
L 52:FF:20:71:CF:4D                                          2452MHz    -95     RU[1]:2412-2472/20
L 52:FF:20:72:44:A1                                          2452MHz    -91     RU[1]:2412-2472/20
L 52:FF:20:73:BF:5A                                          2437MHz    -93     RU[1]:2412-2472/20
L 52:FF:20:7C:5B:44                                          2452MHz    -96     RU[1]:2412-2472/20
L 52:FF:20:FF:19:5D                                          2437MHz    -93     RU[1]:2412-2472/20
  58:70:C6:D5:33:96                     YICarCam_d53396      2432MHz    -81
  58:8B:F3:65:F6:D8                     Keenetic-7809        2447MHz    -93     RU[1]:2412-2472/20
  5C:A6:E6:3C:52:CC                     TP-Link_52CC         2417MHz    -92
  5C:A6:E6:9D:6D:27                     Chikushka            2447MHz    -64     DE[1]:2412-2472/20
  5C:E9:31:93:DB:F0                     Shakira_2.4          2422MHz    -92
  60:83:E7:8F:3F:3B                     Afalina              2462MHz    -63                         (This doesn't show but it's 30db, this is my another closest neighbour)
  6C:5A:B0:97:8A:EC                     AirNet_8AEC_2.4G     2427MHz    -92
  74:FE:CE:CA:8F:BD                     AirNet_8FBD_2.4G     2422MHz    -92
  7C:A2:3E:2F:F3:3C                     WWW                  2412MHz    -92     #a[1]:2412-2484/30
L 7E:A6:E6:9D:6D:27                                          2447MHz    -65     DE[1]:2412-2472/20
  8C:90:2D:64:E6:F0                     Archer_EXT           2417MHz    -71
  98:25:4A:BE:71:1E                     TP-Link_7139         2437MHz    -92     DE/4[1]:2412-2472/30
  9C:9D:7E:86:0B:AB                     Danil2008            2417MHz    -92     RU[1]:2412-2472/16
  A4:A9:30:EB:C7:53                     30 sm                2412MHz    -93     CN[1]:2412-2472/27
  A8:63:7D:04:25:CB                     51                   2437MHz    -74                         (This doesn't show but it's 35db, this is my another closest neighbour)
  A8:63:7D:F5:B8:AA                     83                   2472MHz    -93     US[1]:2412-2472/20
I've got the dump of this scan if needed for detailed info.
As you can see my place is crowded with people who tuned their routers to illegal TX rates, I'm in Russia and these are the legal rates:
/interface/wifi/radio/reg-info country="Russia" number=0
  ranges: 2402-2482/20dBm/40MHz
          5170-5250/23dBm/160MHz
          5250-5330/23dBm/160MHz
          5490-5730/30dBm/160MHz
          5735-5835/30dBm/80MHz
This is my shared folder with logs: https://drive.google.com/drive/folders/ ... sp=sharing
flat configuration: https://docs.google.com/spreadsheets/d/ ... share_link
log dump: https://drive.google.com/file/d/1NAOI4t ... share_link
flat-snoop: https://drive.google.com/file/d/1tU2_K5 ... share_link
flat-snoop (detailed log dump): https://drive.google.com/file/d/1LCAO2R ... sp=sharing
Ievgen
Wed May 14, 2025 3:04 pm
had the same problem with hap ax3 and returned it to the store. They offer me a refund or to choose another one. Now I don't know what to do, I generally like the declared functionality of this particular model. As far as I understand, this is a factory problem, so there is a chance that it will be fixed centrally, but reading this forum I understand that nothing has been fixed for almost a year.
eNET1
Wed May 14, 2025 9:57 pm
I hear from friend of mine that newer routers come up with newer os factory pre-installed, and many customers are returning/complaining, some internet providers are using ax2/ax3 as their default device here, and even with this, Mikrotik is in no rush to fix that. It took almost a after a year for them to acknowledge, which is bad practice for customers, so I am also considering buying UDR7 and moving on, I wait another month for fix, and that’s it. Mikrotik is good for routing, but wifi is horrible.
infabo
Wed May 14, 2025 11:24 pm
A month is nothing in Mikrotik world.
itimo01
Thu May 15, 2025 12:42 am
Yes, i would like to replace pest with cholera please.
https://www.reddit.com/r/Ubiquiti/comme ... t3_18i1mwb
Kreotodr
Fri May 23, 2025 6:56 am
Hi everyone, colleagues!
How are things going with this issue after the release version of RoS 7.19 came out?
Rox169
Sat May 24, 2025 9:33 pm
I have also AX3 and AX2...I have zero issues with those wifi routers. You may have wong/broken batch. I had problem with AC2 there was problem that my old notebook had compatibility wifi hardware issue with AC2. I have many devices conected to AX3 and AX2 and zero problems.
ozone1864
Sun May 25, 2025 3:19 pm
Anyone tested 7.19 ?
robmaltsystems
Forum Veteran
Forum Veteran
Sun May 25, 2025 4:34 pm
I'm in several threads on associated topics and I'm sure on another somebody said they'd tested the RC1 and no difference. Might be getting muddled up though.
mikrotik4kvm3
Sun May 25, 2025 6:52 pm
There was a response earlier on this thread mentioning that RC1 was tested and still not fixed :( Check viewtopic.php?p=1144609#p1141070.
I honestly don't think we'll see a fix until we see a new firmware update for Wireless mentioned in a changelog again.
VadiKO
Mon May 26, 2025 8:34 pm
The problem is still not solved.
Sddaw
Mon May 26, 2025 10:47 pm
yep, same old "why is my zoom call interrupted all of a sudden" with 7.19.1
socketbox
Tue May 27, 2025 5:51 am
A very frustrating experience working through this issue of random disconnects and low transmit power on my hAP ax3. Had I only encountered this thread prior to reading through dozens of others, I might have downgraded to 7.14.3 earlier.
infabo
Tue May 27, 2025 9:31 am
Does it disconnect you from AP when these interruptions occur? Or see log entries on AP?
Sddaw
Wed May 28, 2025 12:15 am
it does, and i'm 3 meters from ap
that's my zoom call timeline down here
infabo
Wed May 28, 2025 12:30 am
With wap ax I occasionally see some of these log entries, but in my case it says disconnect because of positive signal 150+ or something (Mikrotik support already acknowledged and they are working together with Qualcomm on a fix). But usually I dont see any signs in log but still in MS Teams I get "hold on" in meeting every few minutes. very very annoying. I am not 100% if it is the wap ax because I cant compare with Ethernet. But now running cap ac and wifi-qcom-ac and I dont see these "hold on" timeouts. Maybe once in a 30min meeting - but thats probably because of my LTE connection that might be flaky as well.
robmaltsystems
Forum Veteran
Forum Veteran
Wed May 28, 2025 12:31 am
One immediate observation is why is the signal strength low so close to the router. -70dBm is a mid-level signal. Sorry if you've said this all before but what's the connecting client device? It's a real shame that Tx/Rx signal strength is missing and Tx Rate/Rx Rate detail is reduced in the new driver. Bit of a step backwards there :-(
Sddaw
Wed May 28, 2025 1:03 am
It's not low per se, it gets low during some (not every, and thats what drives me nuts) zoom calls. And I just don't use hap ax3 as my main router anymore, was hoping that 7.19 have fixed smth, so made a test. So goin back to wait for another version or two.
Kreotodr
Wed May 28, 2025 7:09 am
Hi everyone,
Has anyone tried the solution mentioned here?
https://it.hohenleitner.eu/blog/wifi-wa ... y-timeout/
How stable has it been in your experience?
sajgan
Wed May 28, 2025 9:49 am
Hi everyone,
this is over a year old - doesn't help.
kib0rg
Thu May 29, 2025 6:00 am
7.20beta2 bug still exists. That is so pathetic that is MikroTik's high-end home router cant be fixed for a year and literally unusable, but they still selling this router.
robmaltsystems
Forum Veteran
Forum Veteran
Thu May 29, 2025 11:53 am
I do sometimes wonder that because of the microscope that we're pointing at this issue that we're being too picky. But then again, we've got enough people mentioning "Dropped video conference calls" for this to be true. Brutally and sadly, if somebody asked me professionally whether I could recommend Mikrotik AX equipment for an office environment, I'd have to say no. Despite those who will peep up and say "Works fine for me". There are just too many smoking guns.
I've only been using Mikrotik professionally for about five years when I stumbled upon one of the low-end consumer Wi-Fi routers and went "Wow, this is powerful". But ever since, I've spent more time fixing and fiddling with the Wi-Fi side than any other manufacturer.
So please focus on this Mikrotik. The fact it's not fixed suggests to me that a) it's software issue in the driver that they're unable to fix as they're not in control, b) it's a software issue in the driver that the maintainers are also unable/unwilling to fix or c) it's a fundamental hardware bug in the chipset that can never be fixed.
In all three cases Mikrotik is highly exposed. Do other network manufacturers like Cisco, Netgear or UniFi rely on 3rd party drivers? If not, then Mikrotik need to bite the bullet and write their own. I know, a big undertaking but it's a big game. If it's a hardware problem then change chipset. Do they use a commonly used chipset for Wi-Fi? They use a bespoke Linux kernel so they're used to the low-level stuff.
pajapatak
Thu May 29, 2025 1:23 pm
same situation here, with hap ax2 - random disconnects of one client (notebook with Qualcomm Atheros QCA9377 wireless card).
7.14.3 - no disconnects,
>7.14.3 - random disconnects, which are more frequent when there is some traffic (teams calls, file transfer, etc). Last tested version 7.19
massinia
Thu May 29, 2025 1:33 pm
Just to understand... those who have disconnects have CAPsMAN configured?
My hAP ax3 is very stable...
eddieb
Thu May 29, 2025 1:55 pm
Please please please,
stop complaining on this forum and create support tickets as intended.
As long as there are not enough examples of problems, they can not fix anything.
And, as there are far more users without problems (like me, no disconnects at all !)
the users with problemd are a minority ... And without signaling to support@mikrotik.com nothing happens
ToTheFull
Thu May 29, 2025 3:24 pm
NO that isn't correct CAP AX + Hap AX2, but according to some, us none pro's are clueless apparently!
Ubiquiti shills again ?
robmaltsystems
Forum Veteran
Forum Veteran
Thu May 29, 2025 4:11 pm
May I humbly suggest that this will simply cause Mikrotik more work. They're well aware of the issue. A far better solution would be for them to have an issue tracker that we could feed into.
