scormar
KNOT modem firmware update
Thu Jun 06, 2024 5:41 pm
It appeared under a PPP interface using the NB/CAT-M modem the message
"Anewer version of modem firmware is available!"
Does anyone knows how to update it?
Actual ROS version 7.15
patrikg
Re: KNOT modem firmware update
Thu Jun 06, 2024 8:38 pm
In the Interfaces menu at the modem.
scormar
Fri Jun 07, 2024 10:20 am
Thanks for the answer, but the Knot has not a LTE interface.
It is a NB/CAT-M that is completely different from a LTE.
The Upgrade Firmware button is not present...
jaclaz
Fri Jun 07, 2024 11:28 am
There are commands in terminal, see:
viewtopic.php?t=206548
but I would ask official support before attempting using them, as there may be a definite procedure (like disabling the interface or not before attempting the upgrade) to follow.
