lordimac
login failure via winbox from mikrotik ip
Fri Jun 07, 2024 12:36 pm
I'm getting login failures for user "admin" around every minute from a ip address which belongs to the router itself.
login failure for user admin from 10.0.0.244 via winbox
Winbox service is restricted to our internal subnets.
Any idead what causing this?
baragoon
Re: login failure via winbox from mikrotik ip
Fri Jun 07, 2024 1:17 pm
dude?
lordimac
Fri Jun 07, 2024 2:14 pm
OMG, thank you, exactly.
godel0914
Tue May 13, 2025 7:32 am
I got the same issues, a lot of login failure for user admin from IP xxxx.yyyy.zzzz.wwww via winbox, since admin account was disabled,
i reenabled it but the error is the same, dude is enabled but login with another user account, does Dude needed to be login with admin?
May i know how you solve the annoying problem, please?
kris62
Mon Jun 09, 2025 5:18 am
I solved this problem by disable dude and no more login failure for user admin from xxx.xxx.xxx.xxx via winbox.
