MUM Europe 2020
pokeman
Traffic priority
Thu Jan 03, 2008 3:56 pm
hello
how to priority 1 below ports rest of all traffic on low priority . how can i do this ???
tcp 80,443,1863,5100
udp 53
shielder
Re: Traffic priority
Thu Jan 03, 2008 4:23 pm
mangle the traffic, if you wish to do it on simple queue, mark the connection and packet that you wish on the prerouting chain, then set the packet marks on simple queue with priority that you wish.
pokeman
Sat Jan 05, 2008 12:13 pm
hello
this is is not working may be some mistake any body correct this
mangle rule
chain=forward action=mark-packet new-packet-mark=other passthrough=yes
chain=forward connection-mark=HTTP_Traffic action=mark-packet new-packet-mark=HTTP_Packet passthrough=no
chain=prerouting protocol=tcp dst-port=80 action=mark-connection new-connection-mark=HTTP_Traffic passthrough=yes
chain=prerouting protocol=tcp dst-port=443 action=mark-connection new-connection-mark=HTTP_Traffic passthrough=yes
simple queue
name="http-queue" dst-address=0.0.0.0/0 interface=all parent=none packet-marks=HTTP_Packet direction=both priority=> queue=default-small/default-small limit-at=0/0 max-limit=0/0 total-queue=default-small
name="other-queue" dst-address=0.0.0.0/0 interface=all parent=none packet-marks=other direction=both priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/0 total-queue=default-small
balimore
Forum Veteran
Forum Veteran
Sat Jan 05, 2008 1:08 pm
Hai fren,
yes, you can mangle first, than create queue tree and put highest priority [1]
regards
Hasbullah.com
pokeman
Tue Jan 08, 2008 9:30 am
hi Hasbullah
please read my pervious post i send my conf please correct this
butche
Trainer
Trainer
Tue Jan 08, 2008 9:37 am
Since you are using simple queues, you need to use prerouting to mark the packet. Also, you want to mark the connection first, THEN mark packet rules.
Look here to understand why: http://www.mikrotik.com/testdocs/ros/2.9/ip/flow.php
Butch Evans
Mikrotik Certified Trainer
Mikrotik Certified Consultant
BLOG: blog.butchevans.com
http://store.wispgear.net/
Users browsing this forum: MSN [Bot] and 79 guests
