alihaji
Ethernet Continuously goes up and down
Sat Jul 06, 2024 12:44 am
Hi
I have a PTP link with Base box as AP and LHG as Station, that was working till 1 week ago. Recently It has got into problem. When I was looking for the problem I noticed that when you send traffic to Station(LHG) through its wireless interface and the destination is the LHG itself everything is fine, but if the traffic goes through Ethernet Interface, Ethernet goes up and down continuously but the device is not rebooted and if you're connected to the device through wlan you will stay connected to the device. both interfaces are added to a bridge and no other configuration is set.
Do you think it's a problem by software or the device must be replaced?
I,ve tried reset configuration, netinstall, upgrading to last version, downgrading to some older version, replacing cable and PoE and adaptor.
Does Anyone has a solution ?
Thanks beforehand
rivnanet
Re: Ethernet Continuously goes up and down
Sun Aug 11, 2024 2:51 pm
We have same issue.
Users browsing this forum: Google [Bot], Huannv, McSee, raphaps and 16 guests
