rossigee
Feature Request: native JSON parsing function
Fri Jul 12, 2024 1:35 pm
Because everyone having to include huge swathes of unsupported third-party RouterOS functions to do such a common task is not a good look :)
I'm probably not the only one that would really appreciate first-class support for parsing JSON objects in RouterOS scripts.
Thanks, guys!
tdw
Re: Feature Request: native JSON parsing function  [SOLVED]
Fri Jul 12, 2024 4:19 pm
Mikrotik added :serialize and :deserialize commands in v7 which support JSON. I've not tested to see if it handles nested arrays.
Larsa
Sat Jul 13, 2024 1:46 am
Yes, it does. Look for @Amm0's detailed explanations and examples on the matter.
rossigee
Sat Jul 13, 2024 6:14 am
Brilliant! Thanks. Not sure why I didn't spot this in the docs earlier.
Amm0
Mon Jul 15, 2024 8:52 pm
I have an example of using :serialize/:deserialize with /tool/fetch for the pushover app's JSON API here:
viewtopic.php?t=136256#p1083224
The approach work for most JSON API with a change of the URL used inside the function and different array of data provided.
Users browsing this forum: No registered users and 10 guests
