netgus
Is it possible to modify the 403 error page?
Fri Jul 12, 2024 11:05 pm
Is it possible to modify the 403 error page received through the proxy?
Thank you
peterda
Re: Is it possible to modify the 403 error page?
Sat Jul 13, 2024 12:34 am
The 403 error page?
The proxy?
anav
Sat Jul 13, 2024 3:37 am
Concur, it should be error 404-1 or conversely error 402+1
netgus
Mon Jul 15, 2024 5:39 pm
The aim is not to send any information to the person trying to access the system. It's a reverse proxy. I can understand that on an internal network, this information could be used, but it would still be interesting to be able to modify the page.
Thanks for your help
rextended
Re: Is it possible to modify the 403 error page?  [SOLVED]
Wed Jul 17, 2024 4:23 pm
is error.html inside webproxy folder................
if the page do not exist, press Reset HTML.............
error.html code
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html><head><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>ERROR: $(status)</title></head>
<body><h2>ERROR: $(status)</h2>
<hr noshade size="1px"/>
$(if error)
<p>While trying to retrieve the URL <a href="$(url)">$(url)</a>:</p>
<ul><li><strong>$(error)</strong></li></ul>
$(endif)
<p>Your cache administrator is <a href="mailto:$(admin)">$(admin)</a>.
$(signature)
</body></html>
netgus
Wed Jul 17, 2024 5:13 pm
error.html code
$(if error)
$(endif)
$(signature)
</body></html>
Thanks for your help, it works.
Users browsing this forum: GoogleOther [Bot], KillerBG, rabbitkiller, Valerio5000 and 29 guests
