Mordraug
Wireguard no handshake on iOS
Sat Jul 13, 2024 8:35 pm
I created a simple wireguard configuration for 2 peers (Android phone and iPad) the Android phone works without an issue but the iPad doesn't even handshake. I used qr code to transfer configuration to both and they have same configuration other than ip and keys, I even added ipads configuration to my phone and it worked fine. Below is my config, it's mostly stock, I'm not sure if it can be an issue on the router side, sounds more like an ios problem but maybe I missed something.
add admin-mac=D4:01:C3:72:DA:8B auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
/interface wifi
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    configuration.mode=ap .ssid="The Promised LAN" disabled=no name=2ghz \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.mode=ap .ssid="The Promised LAN" disabled=no name=5ghz \
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=lan-pool ranges=192.168.1.100-192.168.1.200
add address-pool=lan-pool interface=bridge lease-time=1d name=lan-dhcp
/queue simple
add disabled=yes max-limit=40M/750M name=queue1 target=192.168.1.0/24
/queue type
add cake-diffserv=diffserv4 cake-flowmode=dual-srchost cake-nat=yes kind=cake \
    name=cake-upload
add cake-flowmode=dual-dsthost cake-nat=yes kind=cake name=cake-download
/queue tree
add bucket-size=0.01 max-limit=650M name=download packet-mark=no-mark parent=\
    bridge queue=cake-download
add bucket-size=0.01 max-limit=38M name=upload packet-mark=no-mark parent=\
    ether1 queue=cake-upload
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=5ghz internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=2ghz internal-path-cost=10 \
    path-cost=10
set udp-timeout=10s
/interface wireguard peers
add allowed-address=192.168.100.4/32 client-address=192.168.100.4/32 \
    client-endpoint=mord.dev interface=wireguard name=KrzysPixel private-key=\
    "<redacted>" public-key=\
    "6xJIhMljwYHM3VCe8qyvMd/HRFXROd7K8oTaZqe2xHc="
add allowed-address=192.168.100.3/32 client-address=192.168.100.3/32 \
    client-endpoint=mord.dev interface=wireguard name=iPad private-key=\
    "lixpcroM8JmU+LUo2MBqQLG5/QFdAfoPG5yZHWPU0Q4="
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
add address=192.168.100.1/24 interface=wireguard network=192.168.100.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.10 client-id=1:4:92:26:d9:4d:c0 mac-address=\
    04:92:26:D9:4D:C0 server=lan-dhcp
add address=192.168.1.2 client-id=\
    ff:dd:a9:fc:7:0:1:0:1:2d:6e:68:a:d8:3a:dd:a9:fc:7 mac-address=\
    D8:3A:DD:A9:FC:07 server=lan-dhcp
add address=192.168.1.3 client-id=1:e4:5f:1:1c:8c:9e mac-address=\
    E4:5F:01:1C:8C:9E server=lan-dhcp
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
/ip firewall address-list
add address=hgb09magzq5.sn.mynetname.net list="External ip"
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat dst-address=192.168.1.2 out-interface=\
    bridge protocol=tcp src-address=192.168.1.0/24
add action=dst-nat chain=dstnat comment=HTTP,HTTPS dst-address-list=\
    "External ip" dst-port=80,443 protocol=tcp to-addresses=192.168.1.2
/ip service
set www disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Warsaw
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Here's the client configuration that I exported:
[Interface]
PrivateKey = <redacted>
ListenPort = 51820
Address = 192.168.100.3/32
DNS = 8.8.8.8
[Peer]
PublicKey = D6u6AcSXwtppse/lc/JUzEp7aKATJvSacjHUAy3xLlA=
AllowedIPs = 192.168.1.0/24 <I tried with the default 0.0.0.0 too, no dice>
Endpoint = <public ip, I had my domain here and thought it might be the cause but apparently not>:13231
teleport
Re: Wireguard no handshake on iOS
Sat Jul 13, 2024 9:20 pm
where is your input firewall rule that accepts udp requests on wireguard port 13231?
also include wireguard interface in LAN interface list for seamless firewall navigation
Mordraug
Sat Jul 13, 2024 10:37 pm
I assume the
rule must be accepting it, since Android phone connects just fine from the internet.
Also I ran the sniffer to see what's going on and with phone there is a traffic on 13231 udp as expected, however for some reason iPad seems to only talk to google dns (8.8.8.8 ) and sends nothing on the 13231
MTNick
Sun Jul 14, 2024 7:01 am
Greetings. You're missing the wireguard interface from the interface member list. Missing the biggest part, the firewall rule in the input chain. Wireguard peers might need to be adjusted. Start with the first 2. Lastly, if you can't connect, adjust peers. Hope this helps
add interface=wireguard list=LAN
## Place after the input chain rule: "defconf: accept to local loopback (for CAPsMAN)"
add action=accept chain=input comment="allow wireguard handshake" dst-port=13231 protocol=udp
## Might need to adjust your peers.
add allowed-address=192.168.100.4/32 interface=wireguard name=KrzysPixel public-key="6xJIhMljwYHM3VCe8qyvMd/HRFXROd7K8oTaZqe2xHc="
llamajaja
Tue Jul 16, 2024 5:23 pm
Concur with previous posters.
If your android is connecting its using BTH not regular wireguard setting Which is only required if you dont have a public IP.
For client devices allowed IPs, you need either,
BOTH the subnet of wireguard and the subnet(s) you need to access { 192.168.100.0/24,192.168.1.0/24 }
OR
If you required internet then 0.0.0.0/0 which includes both items above! { 0.0.0.0/0 }
Recommend NOT to use BTH and as recommended
a. put in the input chain rule.
b. add wireguard to the LAN interface
c. change your NAT RULE TO:
add action=masquerade chain=srcnat comment=hairpin dst-address=192.168.1.0/24 src-address=192.168.1.0/24
As noted your Router wireguard allowed IPs should look like.
add allowed-address=192.168.100.4/32 interface=wireguard name=KrzysPixel public-key="#####"
add allowed-address=192.168.100.3/32 interface=wireguard name=ipad public-key="***"
DISABLE UPNP, it should NOT be required.
REMOVE All IPV6 firewall rules and lists if the IPV6 is disable.
Set to NONE:
/tool mac-server
set allowed-interface-list=NONE
Finally change your forward chain rules as follows:
REMOVE DEFAULT RULE AND REPLACE
With:
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
Users browsing this forum: No registered users and 27 guests
