davidolaj
Android App Developer
Mon Jul 15, 2024 4:15 pm
Hello everyone,
Please, I need a software developer here who can help me build an MikroTik Android App that I can use to update my MikroTik Router user details only.
A small Android App like MikroTik Mobile App.
Please contact me via email (davidolaj @ gmail.com) if you can build the App.
abbio90
Re: Android App Developer
Sat Jul 20, 2024 3:55 pm
you can always create a skin that only allows you to access the user manager and modify or insert users
IslaMujeres
Mon Sep 23, 2024 1:51 pm
did you figure that out? Check out different platforms like Upwork and Fiverr; you might have better luck finding opportunities there. These sites offer a variety of freelance gigs that can help you gain experience and build your portfolio. Additionally, another effective approach is to focus on improving your skills continuously. There are plenty of free resources available that can help you along the way. For instance, CoreLangs here https://www.corelangs.org/js/string/split.html offers great tutorials on JavaScript, including essential functions like string manipulation. Understanding how to work with strings is crucial for web development, as it allows you to handle data more effectively. As you enhance your coding abilities, you’ll become more confident and capable of tackling different projects. Combining practical experience from platforms like Upwork or Fiverr with solid foundational knowledge will undoubtedly boost your chances of success. Keep pushing yourself, and remember that each step you take brings you closer to your goals
leestanton
Tue Sep 24, 2024 2:39 pm
You can consider reaching out to freelance platforms like Upwork or Fiverr to find a developer with experience in MikroTik API and Android development. You might also want to check the MikroTik forum for developers who specialize in similar projects. Good luck with your app!
anovojr
Thu Oct 17, 2024 1:06 pm
I recently had a similar experience when I needed to develop an app for my business. I worked with a company that built both my app and website, and they did an excellent job—quick turnaround and very professional. They also helped me with an SEO strategy, which made a big difference in getting more visibility online. If you’re building an app, it’s worth considering how SEO ties into the whole picture. It helped identify key areas to optimize my website, ensuring it was user-friendly and easy to find through search engines. I paid around $500 for this service, and it was a great investment in improving my site's performance.
For more details check https://pbb.lviv.ua/en/services/seo-and ... ite-audit/.
Users browsing this forum: No registered users and 2 guests
