miko
OSPF asynchronous routing with two channels
Tue Jul 23, 2024 10:02 am
There are 2 channels between the routers (GRE-tunnel).
1 router.
/routing ospf instance
add distribute-default=always-as-type-1 in-filter=ospf-in-gre name=ospf-gre out-filter=ospf-out-gre router-id=10.0.0.254
/routing ospf interface
add interface=gre-tunnel1 network-type=point-to-point
add cost=30 interface=gre-tunnel2 network-type=point-to-point
/routing ospf area
add area-id=1.1.1.1 default-cost=1 inject-summary-lsas=yes instance=ospf-gre name=area1 translator-role=translate-never type=nssa
2 router.
set [ find default=yes ] redistribute-connected=as-type-1 redistribute-static=as-type-1 router-id=10.0.0.251
/routing ospf area
add area-id=1.1.1.1 default-cost=1 inject-summary-lsas=yes name=area1 translator-role=translate-never type=nssa
When the connection is lost, a switch occurs, but when the connection is restored, router 2 switches but router 1 (ABR) does not.
I have never encountered channel reservation in OSPF before and I don’t understand why this behavior occurs.
miko
Re: OSPF asynchronous routing with two channels
Wed Jul 24, 2024 4:39 pm
Maybe someone will help, or someone will express their thoughts, at the moment it worked as it should, but I had to change the zone type to default.
It didn’t work in the NSSA zone. Problem with asymmetric routing with only default route. The rest of the networks worked correctly during distribution.
Users browsing this forum: No registered users and 5 guests
