And it's not because one has ARM it's necessarily "better"
As reference: Hex as same processor as RMB33G.
I 've used my device both with ROS6 an ROS7. It's not slower (not that I know and not in my setup).
There are even features in ROS7 (HW offloading etc) not possible before in ROS6.
But "upgrade" why ? Extra ports ? Extra processing power ?
If only processing, look at AX2, cheaper then L009 and a LOT more powerful. 5 ports instead of 3 on RBM33G.
Or AX3, a bit higher in price then L009 but even slightly better performance wise then AX2.
Extra ethernet ports can always be handled using a switch.
My view ...
