EdPa
v6.49.17 [stable] is released!
Thu Aug 08, 2024 10:26 am
RouterOS version 6.49.17 has been released in the "v6 stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.49.17 (2024-Aug-07 14:47):
*) defconf - increased LTE interface wait time;
*) system - fixed an issue with duplicated package list when upgrading from separated to bundled package;
*) system - improved system stability for RBLDF-5nD;
What's new in 6.49.16 (2024-Jun-07 10:02):
(factory only release)
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
mojojojo
Re: v6.49.17 [stable] is released!
Fri Aug 09, 2024 2:01 pm
Took a couple old 6.49.15 systems to 6.49.17 with no apparent issues after 30 minutes, FWIW.
prawira
Tue Aug 13, 2024 11:41 am
hello,
how about #[SUP-92244]: The Dude limited to 5 concurrent clients ? has it solved ?
P
normis
Tue Aug 13, 2024 11:43 am
As it was already replied, please use v7
prawira
Mon Aug 19, 2024 7:36 am
hi normis,
it intended for mikrotik training class (espesially mtcna) where we put the dude server on main router (rb4011) but not all of students can open it from their pc / notebook as it's limited to max 5 users on the same time.
bommi
Mon Aug 19, 2024 8:04 am
Is the training material still on 6.49.x ?
Guscht
Mon Aug 19, 2024 9:35 am
I hope so, v7 is still far away from a production-ready replacement.
Jotne
Mon Aug 19, 2024 2:06 pm
Can you give a list of why its not production-ready?
fischerdouglas
Mon Aug 19, 2024 8:23 pm
Please make 6.49.17 Long-Term.
And please, create the Long-Term chain on v7 also.
This will help to avoid mimimis around "v7 is not production ready".
infabo
Mon Aug 19, 2024 9:04 pm
You can't please mimimis.
Guscht
Tue Aug 20, 2024 5:21 pm
I had to use PIM in a v7-device, it is so stable as a house of cards.
Every few days a "autosupout.rif" is generated, because something crashed internally.
The Multi-WAN Wireguard-route-selection was fixed only in last 7.15.3.
For easy setups, maybe, v7 is stabel enough. But the moment you use it for cases ROS is designed for. Heaven forbid! Is's years away from a long-term in my eyes... Look here: https://help.mikrotik.com/docs/display/ ... l+Overview so much red and yellow and you dream of a "long-term" :D
K0NCTANT1N
Tue Aug 20, 2024 6:20 pm
Da, da, da
prawira
Thu Aug 22, 2024 12:06 pm
hello,
if possible, please add the following features (security reasons) for users who log-in into router :
+ max active session on the same time for each apps; winbox, telnet, ssh, etc
+ automatic logged out if inactive during certain duration
thank you
marekm
Fri Aug 30, 2024 1:15 am
You still forgot my #[SUP-126246]: Winbox IPv6 ND reachable time units. Cosmetic bug (works correctly and the value is specified in seconds, only Winbox and Webfig show wrong units label "ms" instead of "s"), but introduced in 6.47.10 which itself was a long-term release.
Reported exactly one year ago, and the response was: "This has been fixed in RouterOS V7, in RouterOS V6 branches this won't be fixed as V6 updates will only include security fixes." (yeah, so the long-term 6.47.10 showing the wrong units was a security fix?)
I plan to stick with v6 for a long time on RB931/RB941-2nD (the cheap basic routers which I give to customers for free with the service, tired of supporting cheap crappy chinese routers), simply because of limited hardware resources.
Users browsing this forum: No registered users and 2 guests
