byteit101
OpenVPN disconnecting every 2-3 minutes with poll error
Sat Aug 10, 2024 12:15 am
I have two mikrotik devices, a CRS305 in one location with an OpenVPN server running in ethernet mode, and a hEX in a different location being an OpenVPN client. Both devices are upgraded to 7.15.2/3
What happens is that I set up the hEX client, it connects, and I can access resources. I close the UI, and 2-3 minutes later the CRS305 logs say "disconnected <poll error>". I can't access the resources anymore, and the CRS305 server shows it as disconnected, while the hEX client shows it as connected. I have to manually disable and re-enable the hEX client for it to work again for the next 2-3 minutes.
Interestingly, I also have a linux desktop with NetworkManager, and it correctly re-connects so I don't notice any outages from it.
I presume I have some timeouts set wrong, but my attempts have resulted in no change. What timeouts can I adjust to fix this issue?
Users browsing this forum: Anrox, GoogleOther [Bot], zhenyahacker and 47 guests
