MUM Europe 2020
ram
smoothwal+ mikrotik problem help
Sat Jan 12, 2008 7:10 pm
I am WISP not so profecional in IT but I decided to use smoothwall as a wb proxy for cache and firewall an MT for hotspot and user mangement.. I geus many would say why though MT has a webproxy and firewall .... after I tried it I saw MT cache is not so effecient so I decided to use the following sugession
INTERNET GATWAY -------> SMOOTHWALL-------->MT------Wireless
the problem is that the system worked perfect but after a while say 2 hours the smoothwall dhcp stop responding and return after restart ... I thought that the problem is in the smoothwall but I tried smoothwall alone without a problem..
so what would you suggest,why the dhcp stops with MT..
and I don't know why there is a problem with a static IP assignment to the MT with smoothwall
anyway before that I tried a firewall box with cache called ETRI based upon KUBUNTU LINX and squid.. and the same problem happend with dhcp...
best regard
Antixx
Re: smoothwal+ mikrotik problem help
Sat Jan 12, 2008 8:02 pm
best regard
hi,
why dont you use squid? squid is the best choise for cache server... and you will satisfy
GuJack20
Trainer
Trainer
Sun Jan 13, 2008 2:03 am
It's strange that just the DHCP "just" stops working. Try to resetup it and check the Ip Pools.
Anyway...The best solution would be a CentOS Server with squid and cacti (for statistics)...and you'll have a reliable caching and monitoring.
--Do you remember that guy who gave up? Neither does anybody else!
ram
Sun Jan 13, 2008 11:38 am
I told you that I am not so profetional but any way I tried KUBUNTU with squid3 and webmin it was welly amazing evry thing was good except transperent proxy I tried many Iptable setting for transperent and also tproxy with no result evry thing worked except transperent proxy... when I used smoothwall transpernt proxy worked and cache also but it stops after a while and dhcp stop responding... knowning that smoothwall has built in squid 2.6... I would be so gratefull if U tell me the best choice and configueration for either squid box and MT... I will try CentOS if you have config please do help me ...
GuJack20
Trainer
Trainer
Mon Jan 14, 2008 12:12 am
You can read at http://www.howtoforge.com/howtos/linux/centos
I'm sure you'll find the way to do it, it just takes a little time and brain :)
Users browsing this forum: No registered users and 77 guests
