mkt974
R11e-LTE firmware update problem on RBM33G
Mon Aug 19, 2024 3:43 pm
Hello guys,
I have a problem with firmware upgrade of R11e-LTE module : with recent version of routerOS it's not possible to launch the update.
I use a new RBM33G on default configuration and new LTE modules for my test, the APN profile is configured and LTE module is in running state (IP address and routes provided by 4G operator).
Starting with with the factory firmware 6.48.6 I'm able to update a LTE module. Moving on routerOS 7.2 it's still possible to update a module.
But I've tried 7.10 and last 7.15.3 it's no longuer possible.
[admin@RouterOS] > interface lte firmware-upgrade lte1
installed: MikroTik_CP_2.160.000_v015
status: error: resolving error (6)
Does anyone know why I'm no longer able to update LTE firmware on newer router OS ?
mkt974
Re: R11e-LTE firmware update problem on RBM33G
Tue Aug 20, 2024 10:28 am
I've found my problem when creating the LTE APN I need to specify to use IPv4 in my case. It goes to auto after the router OS update hence my issue...
dreamlinker77
Wed Sep 11, 2024 3:14 pm
I'm going to install the same LTE module on the same routerboard (I ordered the module and I'm waiting for the shipment)
Actually I have 6.48.6 routerOS version but I need to upgrade to 7.15.3.
I have a question: Does the R11e-LTE work without any problem on your RBM33G with ros 7.15.3?
Thank you very much
krafg
Thu Sep 12, 2024 4:39 pm
It will works well. Tested on RBM33G and LtAP.
Regards.
dreamlinker77
Fri Sep 13, 2024 4:23 pm
Regards.
Thank you!
Users browsing this forum: No registered users and 6 guests
