Saduff
WinBox v4 crashes router
Tue Sep 03, 2024 5:14 am
I cannot post a reply in the announcement thread, so making a new thread here.
As per the title, WinBox v4 is dangerous and can crash a router. So far, I've been able to reproduce it with one specific router model, the RB5009UPr+S+.
WinBox version: 4.0beta3
RouterOS version: 7.15
Router config:
# 2024-09-02 19:40:20 by RouterOS 7.15
# software id = KE3V-5H2I
# model = RB5009UPr+S+
# serial number = HFA09BQZDM7
add admin-mac=78:9A:18:A2:F0:8D auto-mac=no comment=defconf name=bridgeLocal port-cost-mode=short \
    vlan-filtering=yes
add bridge=bridgeLocal frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether1 internal-path-cost=10 path-cost=10 pvid=20
    interface=ether2 internal-path-cost=10 path-cost=10 pvid=20
    interface=ether3 internal-path-cost=10 path-cost=10 pvid=20
    interface=ether4 internal-path-cost=10 path-cost=10 pvid=20
    interface=ether5 internal-path-cost=10 path-cost=10 pvid=20
    interface=ether6 internal-path-cost=10 path-cost=10 pvid=20
    interface=ether7 internal-path-cost=10 path-cost=10 pvid=20
    interface=ether8 internal-path-cost=10 path-cost=10 pvid=20
add bridge=bridgeLocal interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ip settings
set ip-forward=no
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridgeLocal tagged=bridgeLocal,sfp-sfpplus1 vlan-ids=20
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set strong-crypto=yes
/system identity
set name="RB5009UPr"
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system routerboard settings
set auto-upgrade=yes
/tool romon
set enabled=yes
The computer running WinBox 4 is connected to the router's SFP+ port. The SFP module is a Mikrotik S-RJ01.
Steps to reproduce:
1. Create a new workspace
2. Connect to a CRS112-8P-4S switch
3. Open the following windows: Interfaces, Bridge, Switch→FDBs, Switch→VLAN
4. Connect to the RB5009UPr+S+
5. Change to the new workspace
6. Observe how in addition to the Interfaces and Bridge windows, empty Switch FDBs and Switch VLAN windows open
7. At this point, connection to the router is lost (WinBox might take some time to realize)
8. Try to ping or reconnect to the router, it won't work
Have to unplug the router's power cable to fix it.
If you try the same with WinBox v3 sessions and you open a session where the Switch windows were open, they do not open when connecting to the RB5009UPr and nothing happens. So this bug is unique to WinBox v4. Now I'm afraid to use WinBox v4.
za7
Re: WinBox v4 crashes router
Thu Sep 05, 2024 6:58 am
From reading your post I would assume you are using the Windows version of Winbox4 since you did not specify.
So are you using the Mac, Windows or Linux version of Winbox4?
Saduff
Thu Sep 05, 2024 9:24 am
For this issue, I did not think it relevant which OS WinBox is running on, but I guess there is a chance it could affect it. I'm running WinBox on Arch Linux.
It seems like the core issue would be in RouterOS, not WinBox, since WinBox is just client software and shouldn't be able to crash the router if ROS didn't have some kind of bug itself. It's just that WinBox 4 can trigger it while v3 couldn't.
boxybh
Tue Nov 05, 2024 9:03 am
i have seen this happen in ros7.16.1 i have a script run when i go to win box and turn off wan1 the script runs and turns of router of wan1 and then wan2 and then back, works fine, do it again it crashes while scripting when it runs and creates an support file, the /ip route get will not work.. restart it works and i sent this to mikrotik and they never responded.
Now i never keep www open so that i did was put another port for www and opened it and from there i tried the same thing with browser login , no crashes so far, wasted a week on this. its poor support by mikrotik i wonder they cant go to cisco level
