becs
SwOS version 2.17 released!
Tue Sep 03, 2024 2:42 pm
http://www.mikrotik.com/download
What's new in v2.17:
*) added support for CRS320-8P-8B-4S+;
*) added per-port Neighbor Discovery settings;
*) added Reset Counter settings for individual ports;
*) crs310g: fixed SFP module detection;
*) crs312: fixed possible packet forwarding issue for 2.5Gbps links;
*) crs312/326q/326xg/354: added MGMT port enable/disable setting;
*) crs312/326q/326xg/354: improve packet buffer allocation;
*) crs320p/328p: added LLDP power management support;
*) crs326q/354: fixed management Ethernet LEDs;
*) crs354: improved switch management performance;
*) fixed incorrect forwarding of reserved multicast;
*) fixed neighbor discovery from WinBox;
*) improved fan control based on temperature;
*) improved SwOS web interface stability;
To install SwOS v2.17 on CRS320-8P-8B-4S+ devices, upgrade RouterOS to the latest stable version (7.15.3) and use "/system swos upgrade" command.
Note. The new version is not released for the CSS106 models due to no changes to their specific firmware.
pbr3000
Re: SwOS version 2.17 released!
Wed Sep 04, 2024 4:52 am
Thank you! When will we be able to collect sfp signals with snmp?
spippan
Wed Sep 04, 2024 5:07 am
css610 host mac addresses per vlan? anytime soon?
holvoetn
Wed Sep 04, 2024 11:51 am
CSS610 uses SWOS Lite.
chechito
Thu Sep 05, 2024 7:49 am
Summary
SwOS Lite is an operating system designed specifically for the administration of MikroTik CSS610 series switch products. CSS610 series switches support only SwOS Lite operating system.
The main differences compared to CSS3xx series switches are:
unsupported Independent VLAN Learning;
unsupported VLAN mode "enabled";
unsupported ACL Rate limiting;
supported Port Egress Rate limiting
spippan
Fri Sep 06, 2024 12:40 am
a "no" then
storp
Fri Sep 06, 2024 10:22 am
Updated two CSS326-24G-2S+RM switches without any problems.
bpwl
Mon Sep 09, 2024 11:18 am
Been hit by the known upgrade issue ... lost access now to remote CSS106. Warning should stay in this forum.
2.17 disappeared for CSS106 ? NOW the site says : " version 2.16 for new RB260GS(CSS106-5G-1S), new RB260GSP(CSS106-1G-4P-1S)"
infabo
Mon Sep 09, 2024 1:05 pm
wfburton
Mon Sep 09, 2024 4:28 pm
Does it have a serial port? Try connecting witth a serial port and send the firmware to the router and update
bpwl
Mon Sep 09, 2024 11:08 pm
No serial port AFAIK. And no USB for Woobm serial.
Device is more than 1200km from here. (There are 21 of those there.)
I know that RB260 cannot make an IP outgoing connection (it does not do any IP routing, only responding on the same interface to the connecting MAC address).
So what you see about upgrade in the web server of the RB260GSP is actually your PC collecting it from the internet, and framing it in that web-page.
Once it worked (2.12->2.13) this year, then later it did not anymore. Now it failed again and the 2.17 is missing on the MT download website, but the upgrade page talked about 2.17.
The unresponsive "CSS106-1G-4P-1S" is on version "SwOS 2.7" coming from 2.12, according to the "IP Neighbors Discovery" of RouterOS, the only responding request.
Somebody local cut and restored the power on the network for me.
Will not try this again, until the power supply is on an IP controlled power plug (Sonoff style - Switch ON and OFF)
k6ccc
Fri Sep 13, 2024 9:34 pm
Updated three CSS326-24G-2S+ and one CRS326-24G-2S+ without issue.
As expected, no update available for my two CSS106 switches.
Users browsing this forum: eworm, jorgepft and 8 guests
