BOSS497
7.15.3 wifi-qcom-ac cap's slaves interfaces problem.
Sun Sep 08, 2024 6:09 pm
Hi,I have L009UiGS-RM as CAPSMAN Controller and some cAP ac with wifi-qcom-ac package. If I try to use same configuration like in https://help.mikrotik.com/docs/display/ ... Fi-CAPsMAN: all works fine, but if i try to provision one more slave configuration its working incorrectly. 3nd slave configuration create dynamic interface "wifixx" instead of use static interface that i created.
Please help me, i spent 4 hours on it and no luck. Only main and one slave interface provision working, main and 2 slaves not(
L009UiGS-RM
add admin-mac=78:9A:18:A3:F7:00 auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan-10-staff vlan-id=10
add interface=bridge name=vlan-20-guest vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=bridge name=MAIN vlan-id=10
add bridge=bridge name=GUEST vlan-id=20
add bridge=bridge client-isolation=yes disabled=no name=wifi-qcom-ac
add bridge=bridge disabled=no name=wifi-qcom-ac-noisolation
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=Security_MAIN
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=Security_GUEST
/interface wifi configuration
add datapath=MAIN name=MAIN security=Security_MAIN ssid=MAIN_Network
add datapath=GUEST name=GUEST security=Security_GUEST ssid=GUEST_Network
add datapath=wifi-qcom-ac-noisolation disabled=no name=tech-ac security=Security_MAIN ssid=Tech_Network
add datapath=wifi-qcom-ac-noisolation disabled=no name=staff-ac security=Security_GUEST ssid=STAFF_Network
add datapath=wifi-qcom-ac disabled=no name=guest-ac security=Security_GUEST security.ft=no .ft-over-ds=no \
    ssid=GUEST_Network
add name=staff ranges=172.16.102.2-172.16.102.254
add name=guest ranges=172.17.102.2-172.17.102.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=staff interface=vlan-10-staff name=staff
add address-pool=guest interface=vlan-20-guest name=guest
/port
set 0 name=serial0
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" disabled=yes disabled=yes name=\
    zt1 port=9993
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=ether8
/interface bridge vlan
add bridge=bridge tagged=ether1,bridge vlan-ids=20
add bridge=bridge tagged=ether1,bridge vlan-ids=10
add interface=ether7 list=WAN
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled master-configuration=MAIN slave-configurations=GUEST supported-bands=\
    5ghz-ax
    2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=tech-ac slave-configurations=\
    staff-ac,guest-ac supported-bands=5ghz-ac
    staff-ac,guest-ac supported-bands=2ghz-n
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=172.17.102.1/24 interface=vlan-20-guest network=172.17.102.0
add address=172.16.102.1/24 interface=vlan-10-staff network=172.16.102.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether7
add address=172.16.102.0/24 gateway=172.16.102.1
add address=172.17.102.0/24 gateway=172.17.102.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward dst-address=192.168.20.2 src-address=192.168.20.3
add action=accept chain=input comment="allow winbox remote access" dst-port=8291 in-interface-list=WAN \
    protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=\
    127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=\
    !dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=\
    WAN
/ip firewall raw
add action=drop chain=prerouting dst-address=192.168.20.0/24 src-address=192.168.20.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 \
    protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=\
    in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=\
    !LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=\
    icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=\
    in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" \
    in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=test
/system note
set show-at-login=no
/system package update
set channel=testing
/system routerboard settings
set auto-upgrade=yes enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
cAP ac
add admin-mac=74:4D:28:BD:7A:8D auto-mac=no comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged name=bridgeLocal vlan-filtering=yes
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
# managed by CAPsMAN
# mode: AP, SSID: Tech_Network, channel: 2472/n/eC
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp \
    disabled=no
# mode: AP, SSID: STAFF_Network
add configuration.mode=ap disabled=no mac-address=76:4D:28:BD:7A:8F \
    master-interface=wifi1 name=wifi1-vlan10-staff
add configuration.mode=ap disabled=no mac-address=76:4D:28:BD:7A:91 \
    master-interface=wifi1 name=wifi1-vlan20-guest
# mode: AP, SSID: Tech_Network, channel: 5500/ac/Ceee
set [ find default-name=wifi2 ] configuration.manager=capsman datapath=capdp \
    disabled=no
add configuration.mode=ap disabled=no mac-address=76:4D:28:BD:7A:90 \
    master-interface=wifi2 name=wifi2-vlan10-staff
# mode: AP, SSID: GUEST_Network
add configuration.mode=ap disabled=no mac-address=76:4D:28:BD:7A:92 \
    master-interface=wifi2 name=wifi2-vlan20-guest
add datapath=capdp disabled=no mac-address=76:4D:28:BD:7A:90 master-interface=\
    wifi1 name=wifi3
add datapath=capdp disabled=no mac-address=76:4D:28:BD:7A:91 master-interface=\
    wifi2 name=wifi4
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal interface=wifi1
add bridge=bridgeLocal interface=wifi1-vlan10-staff pvid=10
add bridge=bridgeLocal interface=wifi2
add bridge=bridgeLocal interface=wifi2-vlan10-staff pvid=10
add bridge=bridgeLocal interface=wifi1-vlan20-guest pvid=20
add bridge=bridgeLocal interface=wifi2-vlan20-guest pvid=20
add bridge=bridgeLocal tagged=ether1 untagged=\
    wifi1-vlan20-guest,wifi2-vlan20-guest vlan-ids=20
    wifi1-vlan10-staff,wifi2-vlan10-staff vlan-ids=10
/interface wifi cap
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp \
    slaves-static=yes
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/ip hotspot profile
/system clock
/system identity
set name=CAP2-test
/system note
BOSS497
Re: 7.15.3 wifi-qcom-ac cap's slaves interfaces problem.  [SOLVED]
Sun Sep 08, 2024 10:11 pm
Change provision rules to create enabled and manually change interface names and vlans id's on caps is the only way for now :(.
killersoft
Mon Sep 09, 2024 12:46 am
100% Pain in the A$$, this issue.
MT really needs to get onto fixing this.
I have a mix of ~20ac + 20ax units running under capsman(wireless + wifi )
Being able to bring all my units under 1(wifi) controller-window is what I want.
Its so close to working, even the ap's when I try this, i see in the bridge VLAN dynamically allocates properly, but no l2 pathway from client to bride/vlan..
It just complains in the contoller in red text!!
toxicfusion
Sat Sep 14, 2024 6:32 am
preach...... we're still software limited by Mikrotik with them using the newer qualcom drivers.
We had to roll back the AC access points - removing the wifi-qcom-ac package and revert back to wireless package. The qcom-ac was not stable in a production environment. Devices would not stay connected. Even with proper AP configuration with manual bridge / vlan configuration.
infabo
Sat Sep 14, 2024 11:02 am
100% agree. VLANs with wifi-qcom-ac and capsman makes capsman look like a complete useless dumb manager. Who needs a manager which is not capable of managing its caps? Idiotic. And then for all of a sudden, learning the hard way, you have to use "create enabled" instead of "create dynamic enabled" so wifi interfaces are not renamed on config change. But don't ever do a manual provision: then even your non-dynamic interfaces may get renamed and you screw up your whole manual config on your Caps. Configured by pain in the ass, destroyed in 1 second. It is really a shame for a commercial product.
Users browsing this forum: No registered users and 8 guests
