chap
Help to make an ISP with MT
Tue Jan 15, 2008 7:35 pm
Hi all,
I want to make an ISP. And want to give users to real ips. or some subnet blocks.
How can i do this? please help.
Thanks.
winagain
Re: Help to make an ISP with MT
Mon Jan 21, 2008 8:13 pm
Hi Chap,
I asked a Question similar to this one, did not quite get a streight answer.
Basically if you are using Userman PPPOE or Hotspot to authenticate your clients you can assign a pool of public addresses for those clients.
I currently use Private IP's but intend adding a group of public ip's with this meathod, but have as yet not tried it myself.
I also don't know about the NAT Masquerade rule, whether I should disable or leave active, but as some will still be natted it should be left in place.
Don't know if this will help you, but if you manage please post back, as I would like to know if it works!
gosha
Mon Jan 21, 2008 8:25 pm
Your question is no clear and very common. Please specify what exactly you want to do and someone will answer.
winagain
Mon Jan 21, 2008 9:17 pm
I know that I would like to have some clients PPPOE userman to be assigned public ip address, while others are still behind NAT.
I am sure that "Chap" is looking for a similar setup, or a setup totally on public ip address'
ashish
Long time Member
Long time Member
Tue Jan 22, 2008 5:23 am
Hi all,
Thanks.
Chap,
Just mail me your exact requirements. I will return you back with solutions.
pashish.patel@hotmail.com
- AP - ASHISH PATEL - 757 309 0236 -
bokili
Tue Jan 22, 2008 6:52 am
You can hire a lot of administrators which knows how that works. This is not solution which you can write in few sentences.
Here on forum you can find them : )
chap
Thu Jan 24, 2008 12:52 pm
Thanks all,
What i want to know is just routing. suppose i got (Where to buy public addresses i don't know) an ip block like 200.100.20.x/24.
Now i assign user a public ip (i.e, 200.100.20.3, 200.100.20.4....).
and my router(MT) is connected with a different ISP.
ISP --->My_Router (MT)---->Users
Should I use BGP or RIP Routing protocols to serve users? If so, then how?
Thanks.
leoktv
Trainer
Trainer
Fri Jan 25, 2008 3:40 pm
You dont need to use any dynamic routing for that. Not for the setup that you are showing. but if you are planing to have the subnet splited to alot of difrent client routers then i would use OSPF.
_________________
Leo De Geer, Mikrotik Certified Consultant/Trainer #TR0003, MTCNA, MTCRE, MTCWE, MTCTCE, MTCINE, MTCUME, MTCIPv6E MTCSE MTCASE MTCSWE & MikroTik Distributor
http://www.mikrotik.se
support[at]mikrotik.se
Office: +46 325 660 650
roc-noc.com
Forum Veteran
Forum Veteran
Sat Jan 26, 2008 5:51 am
Thanks all,
Thanks.
You get public IP numbers from your upstream Internet Provider (where you get your Internet feed).
You need to ask them for at least a Class C (/24). If they won't accommodate you then find another ISP that will.
When you get larger, you can buy them from your Regional Internet Registry.
http://www.nro.net/about/internet-registries.html
We use ARIN in the USA. There are size, usage, and connectivity requirements before you qualify to buy IP space from them.
Most start up ISPs are too small so the best place is from your ISP.
Start out with static routes and assign your public IP space dynamically or give static IPs for a higher price. You won't need to use BGP until you have more than one upstream ISP and both are willing and capable of feeding you BGP routes.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
Users browsing this forum: admiralchoy, Znevna and 67 guests
