mangust
How to remove log messages?
Wed Jan 16, 2008 2:58 pm
HI.
How to remove log messages that is stored on disk?
How to remove graf info that is stored on disk?
Is it possible to clear LOG window?
dawam
Trainer
Trainer
Re: How to remove log messages?
Wed Jan 16, 2008 6:07 pm
/system logging action
set memory memory-lines=1
set memory memory-lines=100
This is in the forum somewhere,
Look inside tool - > graphing menu
alternativi
Tue Feb 19, 2008 2:43 am
thank you very much my friend it worked..ByeBye
ahmedsaffar76
Sat Mar 08, 2008 11:22 pm
Hi ;
I think you should change your settings in tools -> graphing to not to store in the disk and later to store in the disk .
try this way .
for my self i will not erase it will it give me an idea about how is service level my isp and my client consumption to the internet which it at least push me fowrward to improve my internet .
:lol:
with best regards .
el berto
Tue May 24, 2011 11:38 am
What about erasing error log messages stored on disk?
Scripts shown before works correctly only if action=memory, but not if action=disk......
bunc1112
Thu Oct 27, 2011 12:47 am
Found a solution :)
script
add name="Clear Log" policy=ftp,reboot,read,write,policy,winbox,password,sniff \
source=\
"/system logging action\r\
\nset 1 disk-lines=1\r\
\nset 1 disk-lines=100"
where 1 is disk and it should be viewed if 1 or 0 is disk...in my MT 1 is disk and 0 is memory as seen below
/system logging action> print
Flags: * - default
# NAME TARGET REMOTE
0 * memory memory
1 * disk disk
2 * echo echo
3 * remote remote 0.0.0.0
or here is the code for memory or disk
set disk disk-lines=1
set disk disk-lines=100
javierc
Sat Aug 10, 2013 7:39 pm
Hola, muchas gracias por tu post, me ha sido de gran ayuda.
Me gustaría guardar el log de una semana, calculo que con unas 10000 líneas me valdría, pero no sé si esto saturaría la memoria del router, ¿sabéis cuál es un máximo razonable? He leído que el máximo eran 100, pero si le pones 10000 y luego haces print value-list el valor aparece.
Saludos
Users browsing this forum: bpwl, medi01, szt, tdw and 65 guests
