davidolaj
Public IP NAT Rule Issue
Sat Sep 21, 2024 11:36 pm
I want to assign one of my WAN IPs (public IPs) to my User and I have configured my Router as below but still not working;
NAT Rule
Chain: srcnat
src-address: 192.168.100.20 (private ip)
Action: netmap
To Addresses: 301.102.XX.20 (public ip)
Note! The 301.102.XX.20 already added to WAN-Ethernet in Address list.
The User WAN IP not change to the assigned Public IP.
How do I make the assigned Public IP work for the User?
Kanta
Re: Public IP NAT Rule Issue
Sat Sep 21, 2024 11:39 pm
use action src-nat, not netmap.
davidolaj
Sun Sep 22, 2024 12:01 am
Action changed to "src-nat" and still the same problem... user WAN IP not change to the 301.102.XX.20
Kanta
Sun Sep 22, 2024 12:05 am
ip 301.102.XX.20 is not a valid one, you can't change it to that. src-nat is the correct action, check the order of other nat rules and move the new one up on top.
davidolaj
Sun Sep 22, 2024 12:22 am
IP 301.102.XX.20 is just a sample here... I'm using valid public IP.
Yes, I understand that the rule is correct but is not working on my router, I don't understand what could be the problem.
Even the action netmap should work, if not the problem.
MikroTk Guru Guys, please help out!!
mkx
Sun Sep 22, 2024 9:27 am
What about order of NAT rules? They are evaluated from top to bottom, first one matching executes.
davidolaj
Sun Sep 22, 2024 2:25 pm
Attached images here are my settings...
The advertised network IP not route in the route list...
mkx
Mon Sep 23, 2024 8:19 am
You have two rules in srcnat chain. The screenshots don't show all the gory details, but ... masquerade rule is higher than "normal" src-nat rule. If masquerade rule selection rules match the packets which src-nat rule is supposed to act on, then masquerade rule will do it's job and src-nat rule won't get evaluated (and executed).
If you're unsure about it, create text export of NAT section, and copy-paste them here (execute /ip/firewall/nat/export to show NAT rules only in full detail).
davidolaj
Mon Sep 23, 2024 11:55 am
I moved the src-nat rule to top and now working perfectly.
Thanks.
