safhdev
Can't Upgrade SWos out of SWos
Thu Oct 03, 2024 1:11 pm
Hello there,
Why its not possible to Upgrade the SWOS out of the swos gui?
Is there a way except from booting router os and upgrade to some nativ way on swos?
Kind regards,
safhdev
Re: Can't Upgrade SWos out of SWos
Thu Oct 03, 2024 1:18 pm
I also noticed that the reboot button also not working via gui. Is that known?
erlinden
Re: Can't Upgrade SWos out of SWos  [SOLVED]
Thu Oct 03, 2024 1:22 pm
Have you tried using a different browser (and/or in-private mode)?
What device are you referring to?
safhdev
Thu Oct 03, 2024 1:39 pm
This was the golden tip, I tried a different browser (Mozilla and then Edge) and in Edge it works.
Thank you very much!
erlinden
Thu Oct 03, 2024 1:45 pm
8) 8)
Sypher
Tue Nov 12, 2024 2:53 am
I've tried the Private/Incognito tab and my switch [CSS326-24G-2S+RM] still wouldn't upgrade, even thou it's going through the motions. And can't find the manual FW file on the download page on the website.
k6ccc
Tue Nov 12, 2024 4:34 pm
https://mikrotik.com/download
Expand the section for SwitchOS. Near the bottom of the list.
