predel
Kids control
Fri Oct 04, 2024 3:10 pm
I have a question about Kids-Control
I set the child's device hours
00:00:00-14:30:00 every day and it doesn't block my device, I have active access all the time. If I add 10:00:00-14:30:00 the device is blocked even during these hours. I made the settings using Winbox and my phone's seo. I'm doing something wrong, but I don't know what. With the second option from 10 to 14:30 there is an entry in the firewall rejected. Thanks for the help (version 6.49.17). Nice option and it would make it much easier for me to control the time spent on the computer by my children
mh45
Re: Kids control
Sun Oct 06, 2024 2:18 pm
Hi, I never used the functionality - so I'm not able to help you for that.
But does your Router has the correct local time? Did you set an NTP entry on "System" -> "NTP client" ?
Check the actual clock if timezone is recognized correctly: System -> Clock
predel
Re: Kids control
Mon Oct 07, 2024 11:04 am
Oh my, what is the function of the incorrect zone that is not automatically started and the time was 20, instead of 9 am. Thanks for your help
IslaMujeres
Re: Kids control
Wed Oct 09, 2024 12:50 am
When you set the time from 00:00:00-14:30:00 and it's not blocking the device as expected, the issue might be related to how the router interprets the time ranges. Setting it from 00:00:00 might create confusion in the router's system because it's often interpreted as the start of the day (midnight). I had conversation about that some time ago with the metro by tmobile , they helped me to understand this problem and solve it of course.
predel
Re: Kids control
Wed Oct 09, 2024 11:11 am
Yes, the problem was the time on the router, everything works. Thank you for your help
Users browsing this forum: No registered users and 13 guests
