Hi
For some reason VPN access on both my hAP AX2 and WAP LTE is not working any more for last week. Tried both L2TP (which was configured from quick set in WinBox) as well IKEV2/IPsec. Tried from both my Windows 11 machine as well Android phone and Ipad - is there maybed some IP cloud issues ongoing? Tried to upgrade then AX2 from 7.5.13 to 7.16, but nothing. I'm using VPN to remotley connect to router and check the status, nothing fancy...
When I tried to connect to either router and check logs, I don't see any entries when connections are attempted (before it was visible).
Thx
Ivan
