Amm0
Experiments with [:convert] for bits&bytes +CSV from /iot/...
Tue Oct 08, 2024 8:18 pm
Mikrotik recently add newer to/from= in the still new [:convert] function adding to/from =byte-array, =num, =bit-array-msb, =bit-array-lsb ... so I thought I'd provide an concrete example of using them. The =num is new in 7.17, but think the rest are in 7.16.
I have a few Dragino LHG65-E1 and KNOT LR9/LoRa in the unused toy box, so I brought them I play with IoT stack again. The sensor read temperature and humidity, but to read those you need to parse a "hex strings" (i.e. Base16 represented in ASCII string) like: CBE90A6D019D0109E97FFF, with Dragino's spec that describes what's in those 11 bytes in hexstring mean. Now how you'd the hexstring to need the function below in a longer discussion :lol: . But it currently comes from:
LoRa sensor --> KNOT LR9 --> old Eralng LoRa network server as /container --> a "hipster" MQTT broker as /container --> /iot/mqtt/subscription/on-message= script
Anyway in Mikrotik's tradition of dense/multilayered examples, here is one for [:convert] newer byte-array and bit-array-* & more like ... to=json options=json.pretty to see visualize RouterOS arrays:
convert bits and bytes example code
:global decodeDriago do={
    # input data
    :local bytes [:convert to=byte-array from=hex $1]
    # output parsed
    :local data {"_payloadByteArray"=$bytes}
    ## BATTERY - stores BOTH mV and status
    # size: 2 bytes - first 2 bits MSB are "status", next 14 bits are mV
    # docs suggest:
    #   BAT status = (0xCBA4cba4>>14) & 0xFF = 11b (00=bad ... 11=great)
    #   Battery Voltage = 0xCBF6&0x3FFF = 0x0BA4 = 2980mV
    # voltage: (ignoring first 2 bits)
    :local battRaw [:convert from=byte-array to=num [:pick $bytes 0 2]]
    :set ($data->"_battRaw") [:tonum $battRaw]
    :set ($data->"battMillivolts") ([:tonum $battRaw] & [:tonum "0x3FFF"])
    # status: (using new "to=bit-array-msb" to get 2 bits with status)
    :local bits [:convert $bytes to=bit-array-msb from=byte-array]
    :if (($bits->0) = 1 and ($bits->1) = 1) do={ :set ($data->"battStatus") "good" }
    :if (($bits->0) = 1 and ($bits->1) = 0) do={ :set ($data->"battStatus") "fair" }
    :if (($bits->0) = 0 and ($bits->1) = 1) do={ :set ($data->"battStatus") "low" }
    :if (($bits->0) = 0 and ($bits->1) = 0) do={ :set ($data->"battStatus") "EOL" }
    ## TEMP - internal, "centi-celsius" (C in 1/100th)
    # size: 2 bytes, MSB int
    :local intTempRaw [:convert from=byte-array to=num [:pick $bytes 2 4]]
    :set ($data->"_intTempRawC") $intTempRaw
    :set ($data->"intTempC") "$[:pick $intTempRaw 0 ([:len $intTempRaw]-2)].$[:pick $intTempRaw ([:len $intTempRaw]-2) [:len $intTempRaw]]"
    ## HUMIDITY - internal, "deci-percentage" (% in 1/10th)
    :local intHumRaw [:convert from=byte-array to=num [:pick $bytes 4 6]]
    :set ($data->"_intHumidityRaw") $intHumRaw
    :set ($data->"intHumidity") "$[:pick $intHumRaw 0 ([:len $intHumRaw]-1)].$[:pick $intHumRaw ([:len $intHumRaw]-1) [:len $intHumRaw]]"
    ## EXT SENSOR TYPE - connected external sensor
    # size: 1 bytes (docs have table)
    :local sensorTypeRaw ($bytes->6)
    :set ($data->"_sensorTypeRaw") $sensorTypeRaw
    :local sensorType [:toarray ""]
    :set ($sensorType->1) "temperature"
    :set ($sensorType->4) "interrupt"
    :set ($sensorType->5) "illumination"
    :set ($sensorType->6) "adc"
    :set ($sensorType->7) "counting-16bit"
    :set ($sensorType->8) "counting-32bit"
    :set ($sensorType->9) "temperature+datalog"
    :set ($data->"sensorType") ($sensorType->$sensorTypeRaw)
    ## EXT SENSOR - RAW undecoded
    # size: last 4 bytes MSB, sensor dependant
    :local extSensorData [:convert from=byte-array to=num [:pick $bytes 7 11]]
    :set ($data->"_sensorDataRaw") $extSensorData
    :set ($data->"_sensorDataHex") [:convert from=num to=hex $extSensorData]
    ## EXT SENSOR - parsed data based on type
    :if (($data->"sensorType") = "temperature") do={
        # size: 2 bytes MSB, starting at 7th (or 7, 0-based index)
        :local extTempRaw [:convert from=byte-array to=num [:pick $bytes 7 9]]
        :set ($data->"_extTempRawC") $extTempRaw
        :if ($extTempRaw != [:tonum "0x3FFF"]) do={
            :set ($data->"extTempC") "$[:pick $extTempRaw 0 ([:len $extTempRaw]-2)].$[:pick $extTempRaw ([:len $extTempRaw]-2) [:len $extTempRaw]]"
        } else={
            :set ($data->"sensorError") "disconnected"
    } else={
        ## OTHER SENSOR TYPES - NOT SUPPORTED
        :set ($data->"sensorError") "unsupported"
    ## STRIP "RAW" - if called with "debug=no"
    :if ($terse="yes") do={
        :foreach k,v in=$data do={
            :if ($k~"^_") do={:set ($data->$k)}
    ## OUTPUT
    :return $data
# output data to console
:put [$decodeDriago "CBE90A6D019D0109E97FFF"]
_battRaw=52201;_extTempRawC=2537;_intHumidityRaw=413;_intTempRawC=2669;_payloadByteArray=203;233;10;109;1;157;1;9;233;127;255;_sensorDataHex=09e97fff;_sensorDataRaw=166297599;_sensorTypeRaw=1;battMillivolts=3049;battStatus=good;extTempC=25.37;intHumidity=41.3;intTempC=26.69;sensorType=temperature
More usage examples, with "pretty" JSON output - to actually see what's been done...
# make it readable using new "json.pretty"
:global myDriagoData [$decodeDriago "CBE90A6D019D0109E97FFF"]
:put [:serialize to=json $myDriagoData options=json.pretty]
"_battRaw": 52201,
"_extTempRawC": 2537.000000,
"_intHumidityRaw": 413.000000,
"_intTempRawC": 2669.000000,
"_payloadByteArray": [
203,
233,
10,
109,
1,
157,
1,
9,
233,
127,
255
"_sensorDataHex": "09e97fff",
"_sensorDataRaw": 166297599.000000,
"_sensorTypeRaw": 1,
"battMillivolts": 3049,
"battStatus": "good",
"extTempC": 25.370000,
"intHumidity": 41.300000,
"intTempC": 26.690000,
"sensorType": "temperature"
... the function takes a "terse=yes" to not output the "raw" values to keep the output array cleaner (code for terse= also shows using function args & :foreach k,v as ".filter()" - in this multilayered scripting example):
# using "$decodeDriago terse=yes"
:put "... or using 'terse=yes' to not output raws ..."
:put [:serialize to=json [$decodeDriago "CBE90A6D019D0109E97FFF" terse="yes"] options=json.pretty]
Another subtle note here: check out the floating pointing the JSON output – that a feature of the [:convert to=json] that a RouterOS string like "41.3" becomes a float in JSON.
Finally, FWIW, Dragino has example code for JavaScript to use cloud LoRa like TTN — I'll include the TTN one below – just to show RouterOS <=> JavaScript comparison in one post:
function str_pad(byte){
var zero = '00';
var hex= byte.toString(16);
var tmp = 2-hex.length;
return zero.substr(0,tmp) + hex + " ";
function Decoder(bytes, port) {
var Ext= bytes[6]&0x0F;
var poll_message_status=(bytes[6]&0x40)>>6;
var Connect=(bytes[6]&0x80)>>7;
var decode = {};
if(Ext==0x09)
decode.TempC_DS=parseFloat(((bytes[0]<<24>>16 | bytes[1])/100).toFixed(2));
decode.Bat_status=bytes[4]>>6;
else
decode.BatV= ((bytes[0]<<8 | bytes[1]) & 0x3FFF)/1000;
decode.Bat_status=bytes[0]>>6;
if(Ext!=0x0f)
decode.TempC_SHT=parseFloat(((bytes[2]<<24>>16 | bytes[3])/100).toFixed(2));
decode.Hum_SHT=parseFloat((((bytes[4]<<8 | bytes[5])&0xFFF)/10).toFixed(1));
if(Connect=='1')
decode.No_connect="Sensor no connection";
if(Ext=='0')
decode.Ext_sensor ="No external sensor";
else if(Ext=='1')
decode.Ext_sensor ="Temperature Sensor";
decode.TempC_DS=parseFloat(((bytes[7]<<24>>16 | bytes[8])/100).toFixed(2));
else if(Ext=='4')
decode.Work_mode="Interrupt Sensor send";
decode.Exti_pin_level=bytes[7] ? "High":"Low";
decode.Exti_status=bytes[8] ? "True":"False";
else if(Ext=='5')
decode.Work_mode="Illumination Sensor";
decode.ILL_lx=bytes[7]<<8 | bytes[8];
else if(Ext=='6')
decode.Work_mode="ADC Sensor";
decode.ADC_V=(bytes[7]<<8 | bytes[8])/1000;
else if(Ext=='7')
decode.Work_mode="Interrupt Sensor count";
decode.Exit_count=bytes[7]<<8 | bytes[8];
else if(Ext=='8')
decode.Exit_count=bytes[7]<<24 | bytes[8]<<16 | bytes[9]<<8 | bytes[10];
else if(Ext=='9')
decode.Work_mode="DS18B20 & timestamp";
decode.Systimestamp=(bytes[7]<<24 | bytes[8]<<16 | bytes[9]<<8 | bytes[10] );
else if(Ext=='15')
decode.Work_mode="DS18B20ID";
decode.ID=str_pad(bytes[2])+str_pad(bytes[3])+str_pad(bytes[4])+str_pad(bytes[5])+str_pad(bytes[7])+str_pad(bytes[8])+str_pad(bytes[9])+str_pad(bytes[10]);
if(poll_message_status===0)
if(bytes.length==11)
return decode;
(now someone should be fired for JS code like that... but for comparison with RouterOS script, it's great )
There are some annoying quirks in scripting, but I do think the RouterOS version is more readable, especially with the [:convert]'s. But, IDK, thought?
Larsa
Re: Experiments with [:convert] for bits&bytes from /iot/...
Tue Oct 08, 2024 8:32 pm
These are really nice examples of various use cases, thank you! 😄
Amm0
Tue Oct 08, 2024 9:29 pm
And I guess to complete the 7.16/7.17 new scripting commands examples... While above shows new [:serialize to=json $myarray options=json.pretty] ... Mikrotik also added [:serialize]/[:deserialize] to CSV to RouterOS arrays – to me that actually more generically useful than byte-array things (but spreadsheets are less fun). And, it's be easy to miss in the release notes, since they talk about "DSV". But that because [:serialize]/[:deserialize] take a delimiter="\t" options to support things like TSV (tab-separated) or whatever. Adding the subtleties, from=dsv has a nice option=dsv.array which make a CSV work well with :foreach.
So to test my function, I downloaded a CSV file from the lorawan-server container in-between that contains the received LoRa frame. It's called "rxframes.csv" and copied to root of 7.17beta RouterOS. File has the format:
Dir,Time,Application,Location,DevAddr,MAC,U/L RSSI,U/L SNR,FCnt,Confirm,Port,Data
up,2024-10-08 10:40:20,test,,6263XXXX,31333XXXXC00XX00,-54,9.75,50,false,2,CBD308AA025101087F7FFF
up,2024-10-08 06:20:21,test,,6263XXX,31333XXXXC00XX00,-55,9.25,37,false,2,CBD5087502340108407FFF
So to get the temperature readings from the CSV (without a multi-hop voyage to MQTT on-message=) ... it could be 4-6 lines depending on what you're trying to do:
:global rxframes [:deserialize from=dsv delimiter=, options=dsv.array  [/file get rxframes.csv contents as-string]]
:global temps [:toarray ""]
:foreach k,v in=$rxframes do={
    :local tempC ([$decodeDriago ($v->"Data")]->"_intTempRawC")
    :if ($tempC > 0) do={:set $temps ($temps,$tempC) }
:put [:serialize to=dsv delimiter=" " $temps ]
2181 2292 2388 2537 2730 2742 2741 2738 2936 3040 2887 2936 2887 2963 2906 2881 2821 2812 2809 2707 2804 2726 2669 2781
since those 1/100th of C temperatures, "2707" is "27.07ºC"...
note... the space-separate output using :serialize to=dsv delimiter=" " & theoretically the CSV file could be download via /tool/fetch to server's HTTP API to avoid manual copy step here.
A more complete example using "CSV files" (aka DSV) with :serialize/:deserialize is here: viewtopic.php?t=211406&hilit=dsv#p1101608
Amm0
Re: Experiments with [:convert] for bits&bytes +CSV from /iot/...
Wed Oct 09, 2024 1:55 am
There is more code that wires up MQTT to logging, but since this was a text heavy post. The net result here is a log message with Unicode Emoji's
:global parseMqttJson do={
:local fn $decoder
:local msg [:deserialize from=json $1]
:set ($msg->"values") [$fn ($msg->"data")]
/log debug "mqtt sub $[:tostr $topic] got $[:tostr $msg]"
:return $msg
:global parseMqttTempHumSensor do={
:global decodeDriginoLht65Hex
:local msg [$parseMqttJson $1 decoder=$decodeDriginoLht65Hex topic=$topic]
:local extTemp ($msg->"values"->"extTempC")
:local hum ($msg->"values"->"intHumidity")
/log info "LHT65 \E2\84\96 $($msg->"devaddr"): \F0\9F\8C\A1 $extTemp\E2\84\83 \F0\9F\92\A6 $hum%"
:return $msg
:global onMqtt do={
[$parseMqttTempHumSensor $1 topic=$topic]
Amm0
Wed Oct 09, 2024 9:41 pm
Just to complete the visuals of the "bits&bytes", as parsed by [:convert]*, with some added /iot/mqtt/publish's, now the `mqttui` tool view looks nicer:
# publish each parsed value as new MQTT topic, using array key in topic with MQTT value matching array's value
:foreach k,v in=($msg->"values") do={
/iot/mqtt/publish broker=chirpito topic="weather/$($msg->"devaddr")/$k" qos=0 message="$[:tostr $v]"
* after LHT65 temp/hum tx/rx 900Mhz to KNOT, to a lorawan-server container on another RB1100, to nanomq MQTT container on same RB1100 ... to the /iot/mqtt/subscription on-message= that first load functions above from a /system/script (with dont-require-permissions=yes), and call the [$onMqtt $msgData topic=$msgTopic] that does the [:convert]/etc parsing ... and those function than MQTT publish the various [:convert]-parsed values in a new /weather MQTT topic — but no cloud, all RouterOS, except the LoRa temp sensor, and using /container. And, it generally works over past couple data... not 100% but I suspect my LoRa-specific config is wrong, but potentially a bug in bowels of Semtech UDP between RouterOS and lorawan-server.
excession
Thu Oct 17, 2024 11:44 pm
Wow, massive amount of useful work and great write-up. Thank you :)
