Greetings All,
A couple of days back, I upgraded to RouterOS (ROS) 7.16.1 (from 7.14.1). After the reboot I noticed that while IPv4 was working fine, ROS's dhcpv6 client was stuck at 'searching...'. I tried various combinations with and without 'accept RA' but nothing seems to make any difference.
To rule out (unlikely?) issues with my 7.14.1 saved config, I went with the default 'out-of-the-box' 7.16.1 configuration but see the same results. I have not made any other mods apart from enabling the dhcpv6 client (currently requesting just the prefix. Attempts to request both the prefix and address also give the same result).
A quick sniffer run on ether1 shows ROS's DHCPv6 'solicit' going out and an immediate (and seemingly proper) DHCPv6 'Advertise' response from Xfinity. I do not see subsequent 'Solicit' retransmits from ROS so I'm assuming it did 'see' this response. But then I do not see the expected DHCPv6 'Request' packet (the next step in the DHCPv6 handshake sequence) from ROS either and the DHCPv6 client status still stays at 'searching'.
The system log does not show any untoward messages or warnings either.
Am I missing/forgetting something basic at my end of did something change in 7.16.1? My topology and config details are at the end of this post.
Thanks!
/DN
My home network topology (typical and very plain vanilla):
Xfinity -> Netgear Nighthawk Cable Modem -> [ether1] Mikrotik (RB4011iGS+) [bridge] -> LAN
RouterOS: v7.16.1
RouterOS Config: 'out-of-the-box' default for v7.16.1 (with just the dhcpv6 client enabled on ether1)
Current IPv6 related config:
admin@XXXXXXXX] /ipv6> /ipv6 export
# 2024-11-03 13:51:09 by RouterOS 7.16.1
# software id = R9T3-B8SI
# model = RB4011iGS+
# serial number = XXXXXXXXXXXX
/ipv6 dhcp-client
add interface=ether1 pool-name=ipv6_pool request=address,prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
/ipv6 settings
set accept-router-advertisements=no
[admin@XXXXXXXX] /ipv6> /ipv6 address print
Flags: D - DYNAMIC; L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
# ADDRESS INTERFACE ADVERTISE
0 D ::1/128 lo no
1 DL fe80::xxxx:xxxx:fe03:9445/64 bridge no
2 DL fe80::xxxx:xxxx:fe03:9444/64 ether1 no
[admin@XXXXXXXX] /ipv6> dhcp-client print
Columns: INTERFACE, STATUS, REQUEST
# INTERFACE STATUS REQUEST
0 ether1 searching... address
prefix
