abiadha
RB951Ui-2HnD port Running (R- flag) without cable connected to it
Mon Nov 11, 2024 11:29 am
I have RB951 the ports keeps running without cable Ethernet cable connected to it.
I have using Netinstall but not sort it out. What to do to resolve the issue? Image
mkx
Re: RB951Ui-2HnD port Running (R- flag) without cable connected to it
Mon Nov 11, 2024 9:03 pm
Throw RB951 in trash can?
dang21000
Mon Nov 11, 2024 10:44 pm
try clean contact with alcohol... but maybe it's time to change
abiadha
Tue Nov 12, 2024 7:37 am
This is not possible as we have received new package that faced the same thing. Like 5pcs in box
jaclaz
Tue Nov 12, 2024 12:46 pm
Maybe new package, but from the looks of the one in the picture not new devices.
From the screenshot, ether4 transmits something but doesn't receive anything (and this could be - though I cannot imagine how - some false contact or the like mistaking an empty port for a connected one) but ether2 transmits AND receives *something*, which is not possible, the received packets should come from somewhere.
Post your full configuration of the device, following this:
viewtopic.php?t=203686#p1051720
Check also your log, there could be there something about the connections (link up or down) of the ports.
karlisi
Tue Nov 12, 2024 4:03 pm
I believe OP connected computer to ether2 in moment of screenshot, that's why there is tx/rx on it.
I had at least 2 devices with blown out ethernet ports, with the same symptoms. Switch chip itself was OK, only input transformer was damaged.
