anav,
Thank you very much for your reply and your time
By the way, why do your allowed IP setting seem almost identical........... do you understand wireguard or just copied from somewhere...........
This is my first WG configuration in home lab, so I used some guide on YT. If I gave restrictions, e.g. on page 77.1
allowed addresses:
10.0.0.0/24
192.168.77.0/24
the ping wasn't even coming from the routers.
Only setting 0.0.0.0/0 resulted in any response.
Will look at both configs
So as to understand one MT gets a public IP directly
The other MT is connected behind the h router and gets a WANIP on the private LAN of the h router.
In the first case, yes (77.1)
eth1 = Public IP
bridge + vlan 77 = 192.168.77.1 as gate and main network
In the second case
H_LTE is the main router with the address 192.168.50.1
However, mikrotik on the bridge has the address set to 192.168.50.3. It does not receive addressing on the WAN port. It is simply part of the network behind H_LTE.
Regards,
Peter
77.1
# 2024-11-11 18:00:20 by RouterOS 7.16.1
# model = RB4011iGS+5HacQ2HnD
/caps-man channel
add band=5ghz-onlyac control-channel-width=20mhz name=ch_5180 \
skip-dfs-channels=no
add band=2ghz-g/n control-channel-width=20mhz name=ch_2422
add admin-mac=XX:XX:31:1F:XX:XX auto-mac=no comment=defconf name=bridge \
port-cost-mode=short vlan-filtering=yes
/interface wireless
# managed by CAPsMAN
# channel: 5785/20-eeCe/ac(27dBm)+5210/80(14dBm), SSID: MT_SSID, CAPsMAN forwarding
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\
20/40/80mhz-XXXX country=no_country_set distance=indoors frequency-mode=\
superchannel installation=indoor mode=ap-bridge name=wlan1_5ghz \
skip-dfs-channels=all ssid=ssidname1 wireless-protocol=802.11
# channel: 2442/20-eC/gn(27dBm), SSID: MT_SSID_2, CAPsMAN forwarding
set [ find default-name=wlan1 ] distance=indoors frequency=auto installation=\
indoor mode=ap-bridge name=wlan2_2ghz ssid=ssidname2 \
set [ find default-name=ether1 ] name=ether1_WAN
set [ find default-name=ether3 ] name=ether3_CAM_74
set [ find default-name=ether4 ] name=ether4_usffx_76
set [ find default-name=ether5 ] name=ether5_PVEnas_TAG
set [ find default-name=ether7 ] loop-protect=off
set [ find default-name=ether8 ] name=ether8_USG_TAG
set [ find default-name=ether9 ] name=ether9_TAG_77.2
set [ find default-name=ether10 ] name=ether10_POE_AP
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard
/interface vlan
add arp=proxy-arp interface=bridge name=vlan_74_CAM vlan-id=74
add arp=proxy-arp interface=bridge name=vlan_75_IOT vlan-id=75
add arp=proxy-arp interface=bridge loop-protect=off name=vlan_76_PVE vlan-id=\
76
add arp=proxy-arp interface=bridge name=vlan_77_LAN vlan-id=77
add arp=proxy-arp interface=bridge name=vlan_78_goscie vlan-id=78
add interface=bridge name=vlan_79_LAB vlan-id=79
add interface=bridge name=vlan_80_unifi0 vlan-id=80
add interface=bridge name=vlan_81_unifi1 vlan-id=81
add interface=bridge name=vlan_82_unifi2 vlan-id=82
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes name=dp_vlan_77_LAN \
vlan-id=77 vlan-mode=use-tag
add bridge=bridge client-to-client-forwarding=yes name=dp_vlan_78_GUEST \
vlan-id=78 vlan-mode=use-tag
add bridge=bridge client-to-client-forwarding=yes name=dp_vlan_74_CAM \
vlan-id=74 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security_77_LAN
add authentication-types=wpa2-psk encryption=aes-ccm name=security_78_GOSCIE
add authentication-types=wpa2-psk encryption=aes-ccm name=security_74_cam
/caps-man configuration
add channel=ch_5180 datapath=dp_vlan_77_LAN mode=ap name=cfg_vlan77_LAN_5GHZ \
security=security_77_LAN ssid=MT_1
add channel=ch_5180 datapath=dp_vlan_78_GUEST mode=ap name=\
cfg_vlan78_GUEST_5GHZ security=security_78_GOSCIE ssid=MT_2
add channel=ch_2422 datapath=dp_vlan_77_LAN mode=ap name=cfg_vlan77_LAN_2GHZ \
security=security_77_LAN ssid=MT_3
add channel=ch_2422 datapath=dp_vlan_78_GUEST mode=ap name=\
cfg_vlan78_GUEST_2GHZ security=security_78_GOSCIE ssid=MT_4
add channel=ch_2422 country=poland datapath=dp_vlan_74_CAM hide-ssid=yes \
mode=ap name=cfg_vlan74_CAM_2GHZ security=security_74_cam ssid=MT_5
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec policy group
add name=group-hq-branch
/ip ipsec profile
add dh-group=modp2048 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=\
aes-256 hash-algorithm=sha256 name=profile-b-c
/ip ipsec peer
add address=C.sn.mynetname.net exchange-mode=ike2 name=\
peer-C port=500 profile=profile-b-c
add disabled=yes exchange-mode=ike2 name=peer-b-sl passive=yes profile=\
profile-C
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=proposal-C \
pfs-group=modp2048
add name=pool_77_LAN ranges=192.168.77.50-192.168.77.100
add name=pool_76_PVE ranges=192.168.76.50-192.168.76.100
add name=pool_75_IOT ranges=192.168.75.50-192.168.75.100
add name=pool_78_GGOSCIE ranges=192.168.78.50-192.168.78.100
add name=pool_74_CAM ranges=192.168.74.50-192.168.74.100
add address-pool=default-dhcp disabled=yes interface=bridge lease-time=10m \
name=defconf
add address-pool=pool_77_LAN interface=vlan_77_LAN lease-time=1h name=\
dhcp_77_LAN
add address-pool=pool_75_IOT interface=vlan_75_IOT lease-time=1h name=\
dhcp_75_LAN
add address-pool=pool_76_PVE interface=vlan_76_PVE lease-time=1h name=\
dhcp_76_PVE
add address-pool=pool_78_GGOSCIE interface=vlan_78_goscie lease-time=1h name=\
dhcp_78_LAN
add address-pool=pool_74_CAM interface=vlan_74_CAM lease-time=1h name=\
dhcp_74_CAM
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add bridge=bridge bridge-learning=yes local-address=192.168.77.1 name=\
profile-ovpn remote-address=pool_77_LAN use-encryption=required use-ipv6=\
no
add local-address=192.168.77.1 name=profile-l2tp-forLTE remote-address=\
pool_77_LAN
add bridge-learning=yes local-address=192.168.222.1 name=profile-l2tp \
use-compression=yes use-encryption=required use-ipv6=no use-upnp=no
/snmp community
add addresses=192.168.7.13/32 name=community
/system logging action
set 0 memory-lines=1500
add name=remotebranch remote=192.168.76.61 target=remote
add name=remoteAlienVaultOSSIM remote=192.168.76.20 target=remote
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
disabled=yes disabled=yes name=zt1 port=9993
/zerotier interface
add allow-default=no allow-global=no allow-managed=yes disabled=no instance=\
zt1 name=zerotier1 network=ZTNUMBER
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled comment=rb4011_5ghz master-configuration=\
cfg_vlan77_LAN_5GHZ name-format=prefix-identity radio-mac=\
YY:YY:YY:1F:A1:YY slave-configurations=cfg_vlan78_GUEST_5GHZ
add action=create-dynamic-enabled comment=rb4011_2ghz master-configuration=\
cfg_vlan77_LAN_2GHZ name-format=prefix-identity radio-mac=\
YY:YY:YY:C4:YY:YY slave-configurations=\
cfg_vlan78_GUEST_2GHZ,cfg_vlan74_CAM_2GHZ
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3_CAM_74 internal-path-cost=\
10 path-cost=10 pvid=74
add bridge=bridge comment=defconf interface=ether4_usffx_76 \
internal-path-cost=10 path-cost=10 pvid=76
add bridge=bridge comment=defconf interface=ether5_PVEnas_TAG \
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
add bridge=bridge comment=defconf interface=ether8_USG_TAG \
internal-path-cost=10 path-cost=10 pvid=80
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=ether9_TAG_77.2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether10_POE_AP \
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=\
10 path-cost=10
add bridge=bridge comment=defconf interface=wlan1_5ghz internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wlan2_2ghz internal-path-cost=10 \
path-cost=10
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes use-ip-firewall-for-vlan=yes
set udp-timeout=10s
/interface bridge vlan
add bridge=bridge tagged=\
bridge,ether9_TAG_77.2,ether5_PVEnas_TAG,ether4_usffx_76 vlan-ids=77
add bridge=bridge tagged=bridge,ether9_TAG_77.2,ether5_PVEnas_TAG vlan-ids=78
add bridge=bridge tagged=bridge,ether9_TAG_77.2,ether10_POE_AP,ether6 \
vlan-ids=76
add bridge=bridge tagged=bridge,ether9_TAG_77.2,ether5_PVEnas_TAG vlan-ids=75
bridge,ether9_TAG_77.2,ether5_PVEnas_TAG,ether4_usffx_76 vlan-ids=74
add bridge=bridge tagged=bridge,ether9_TAG_77.2,ether5_PVEnas_TAG vlan-ids=79
bridge,ether9_TAG_77.2,ether5_PVEnas_TAG,ether4_usffx_76,ether6 vlan-ids=\
80
add bridge=bridge tagged="bridge,ether9_TAG_77.2,ether5_PVEnas_TAG,ether8_USG_\
TAG,ether10_POE_AP,ether4_usffx_76" vlan-ids=81
TAG,ether10_POE_AP,ether4_usffx_76" vlan-ids=82
TAG,ether10_POE_AP,ether4_usffx_76" vlan-ids=200
TAG,ether10_POE_AP,ether4_usffx_76" vlan-ids=201
TAG,ether10_POE_AP,ether4_usffx_76" vlan-ids=202
/interface l2tp-server server
set default-profile=profile-l2tp enabled=yes
add comment=defconf interface=ether1_WAN list=WAN
add comment=defconf interface=vlan_77_LAN list=LAN
add interface=wireguard list=LAN
/interface ovpn-server server
set auth=sha512 certificate=SERV-CERT-BRANCH cipher=aes256-gcm \
default-profile=profile-ovpn enabled=yes require-client-certificate=yes
/interface wireguard peers
add allowed-address=10.0.0.2/32 disabled=yes endpoint-address=\
A.sn.mynetname.net endpoint-port=13231 interface=wireguard \
is-responder=yes name=peer-c public-key=\
"KEY="
add allowed-address=10.0.0.0/24,192.168.77.0/24 endpoint-address=\
B.sn.mynetname.net interface=wireguard name=peer-sl \
persistent-keepalive=30s public-key=\
"KEY="
/interface wireless cap
set caps-man-addresses=127.0.0.1 discovery-interfaces=bridge enabled=yes \
interfaces=wlan1_5ghz,wlan2_2ghz
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
network=192.168.88.0
add address=192.168.77.1/24 interface=vlan_77_LAN network=192.168.77.0
add address=192.168.78.1/24 interface=vlan_78_goscie network=192.168.78.0
add address=192.168.75.1/24 interface=vlan_75_IOT network=192.168.75.0
add address=192.168.76.1/24 interface=vlan_76_PVE network=192.168.76.0
add address=192.168.74.1/24 interface=vlan_74_CAM network=192.168.74.0
add address=10.0.0.1/24 interface=wireguard network=10.0.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
/ip dhcp-server config
set store-leases-disk=1h
add address=192.168.74.0/24 dns-server=192.168.74.1,1.1.1.1,8.8.8.8 gateway=\
192.168.74.1
add address=192.168.75.0/24 dns-server=192.168.75.1,1.1.1.1,8.8.8.8 gateway=\
192.168.75.1
add address=192.168.76.0/24 dns-server=192.168.76.1,1.1.1.1,8.8.8.8 gateway=\
192.168.76.1
add address=192.168.77.0/24 dns-server=192.168.77.1,1.1.1.1,8.8.8.8 gateway=\
192.168.77.1
add address=192.168.78.0/24 dns-server=192.168.78.1,1.1.1.1,8.8.8.8 gateway=\
192.168.78.1
192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip firewall address-list
add address=d7160ca3a5e7.sn.mynetname.net list=my-cloud
add address=192.168.7.0/24 list=my_c_ips
add address=192.168.6.0/24 list=my_c_ips
add address=192.168.50.0/24 list=my_c_ips
add address=192.168.11.0/24 list=my_c_ips
add address=192.168.9.0/24 list=my_c_ips
add address=192.168.77.0/24 list=my_b_ips
add address=192.168.76.0/24 list=my_b_ips
add address=192.168.75.0/24 list=my_b_ips
add address=192.168.74.0/24 list=my_b_ips
add address=192.168.10.0/24 list=my_c_ips
add address=V.sn.mynetname.net list=my-cloud
add address=192.168.222.0/24 list=my_c_ips
add address=N.sn.mynetname.net comment=AX3-c list=my-cloud
add address=M.sn.mynetname.net comment=RB750_sl list=my-cloud
add action=accept chain=forward dst-address=192.168.77.0/24 src-address=\
192.168.7.0/24
add action=accept chain=input dst-address=192.168.77.0/24 src-address=\
192.168.7.0/24
add action=accept chain=input comment=WIREGUARD_ALLOW dst-port=13231 \
protocol=udp
add action=accept chain=forward comment=WIREGUARD_ALLOW disabled=yes \
dst-address=192.168.76.0/24 in-interface=wireguard
add action=accept chain=input comment=WIREGUARD_ALLOW dst-address=\
192.168.77.0/24 src-address=10.0.0.0/24
add action=drop chain=forward comment=WIREGUARD_BLOCK_INTERNAL_IP disabled=\
yes dst-address=192.168.76.0/24 src-address=10.0.0.0/24
192.168.50.0/24
192.168.50.0/24
add action=accept chain=input comment=WAN_PING_ALLOW in-interface-list=WAN \
protocol=icmp
add action=accept chain=input comment="OVPN - ALLOW PORTS" dst-port=1194 \
in-interface-list=WAN protocol=tcp
add action=drop chain=forward disabled=yes dst-address=SOMEIP \
in-interface=bridge src-address=192.168.80.100
add action=drop chain=forward dst-address=192.168.90.1 in-interface=\
vlan_80_unifi0 src-address=192.168.80.100
add action=accept chain=input comment=LIST_IPSEC_b-c dst-address-list=\
my_c_ips src-address-list=my_b_ips
add action=accept chain=forward comment=LIST_IPSEC_b-c dst-address-list=\
add action=accept chain=input comment=LIST_IPSEC_c-b dst-address-list=\
my_b_ips src-address-list=my_c_ips
add action=accept chain=forward comment=LIST_IPSEC_c-b dst-address-list=\
add action=accept chain=input comment="IPSEC - ALLOW PORTS" dst-port=\
1701,500,4500 protocol=udp
established,related,untracked
invalid
add action=accept chain=input in-interface-list=WAN src-address-list=my-cloud
add action=accept chain=input comment="OVPN - ALLOW to 77" dst-address=\
192.168.77.0/24 src-address=192.168.77.0/24
add action=accept chain=forward comment="OVPN - ALLOW to 77" disabled=yes \
dst-address=192.168.76.0/24 src-address=192.168.77.0/24
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
connection-state=invalid
add action=accept chain=srcnat comment=LIST_IPSEC_b-c dst-address-list=\
add action=accept chain=srcnat comment=LIST_IPSEC_b-c dst-address=\
10.0.0.0/24 src-address=192.168.77.0/24
add action=accept chain=srcnat comment=LIST_IPSEC_b-c disabled=yes \
dst-address=10.0.0.0/24 src-address=192.168.76.0/24
add action=masquerade chain=srcnat dst-address=192.168.50.0/24 out-interface=\
wireguard src-address=192.168.77.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip ipsec identity
add peer=peer-b-c policy-template-group=group-hq-branch
add peer=peer-b-sl policy-template-group=group-hq-branch
/ip ipsec policy
add dst-address=192.168.7.0/24 level=unique peer=peer-b-c proposal=\
proposal-b-c src-address=192.168.77.0/24 tunnel=yes
add dst-address=192.168.50.0/24 level=unique peer=peer-b-sl proposal=\
proposal-b-c src-address=192.168.90.0/24 tunnel=yes
proposal-b-c src-address=192.168.74.0/24 tunnel=yes
add dst-address=192.168.10.0/24 level=unique peer=peer-b-c proposal=\
add dst-address=192.168.11.0/24 level=unique peer=peer-b-c proposal=\
proposal-b-c src-address=192.168.75.0/24 tunnel=yes
proposal-b-c src-address=192.168.76.0/24 tunnel=yes
add dst-address=192.168.6.0/24 level=unique peer=peer-b-c proposal=\
add disabled=no dst-address=192.168.55.0/24 gateway=192.168.222.11 \
routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=192.168.50.0/24 gateway=wireguard \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=192.168.50.0/24 gateway=10.0.0.3 \
target-scope=10
/ip traffic-flow target
add dst-address=192.168.76.20
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=ovpn-pch-branch profile=profile-ovpn service=ovpn
add name=l2tp-slp profile=profile-l2tp remote-address=192.168.222.11 \
service=l2tp
add name=ovpn-ppp-branch profile=profile-ovpn service=ovpn
add name=ovpn-sl-b-branch profile=profile-ovpn service=ovpn
/snmp
set enabled=yes trap-community=pch-community trap-version=2
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=MT_4011
/system leds
add interface=wlan2_2ghz leds="wlan1_5ghz_signal1-led,wlan1_5ghz_signal2-led,w\
lan1_5ghz_signal3-led,wlan1_5ghz_signal4-led,wlan1_5ghz_signal5-led" \
type=wireless-signal-strength
add interface=wlan2_2ghz leds=wlan1_5ghz_tx-led type=interface-transmit
add interface=wlan2_2ghz leds=wlan1_5ghz_rx-led type=interface-receive
/system logging
add action=remotebranch topics=info
add action=remotebranch topics=critical
add action=remotebranch topics=critical,error,info
add action=remoteAlienVaultOSSIM topics=critical,error,info
add topics=ovpn
add prefix=WG_ topics=wireguard
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=ether1_WAN
50.1
# 2024-11-11 17:52:33 by RouterOS 7.16.1
# model = RB750
add name=bridge
add listen-port=13231 mtu=1420 name=wireguard1
add exclude=dynamic name=discover
/interface lte apn
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc
/ppp profile
add bridge-learning=yes name=profile-l2tp-to-A only-one=no use-compression=\
yes use-encryption=required use-upnp=no
/interface l2tp-client
add allow=mschap2 connect-to=A.sn.mynetname.net disabled=no name=\
l2tp-to-A profile=default use-ipsec=yes user=l2tpsl
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
set udp-timeout=10s
set discover-interface-list=discover
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=ether1 list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
set auth=sha1,md5
add allowed-address=0.0.0.0/0 endpoint-address=d43b0d121167.sn.mynetname.net \
endpoint-port=13231 interface=wireguard1 name=peer-wawa \
"KEY="
add address=192.168.50.3/24 interface=bridge network=192.168.50.0
add address=192.168.40.3/24 disabled=yes interface=bridge network=\
192.168.40.0
add address=10.0.0.3/24 interface=wireguard1 network=10.0.0.0
/ip cloud
/ip dhcp-client
# Interface not active
set allow-remote-requests=yes servers=192.168.50.1,192.168.40.1,1.1.1.1
add address=A.sn.mynetname.net list=my-cloud
add address=B.sn.mynetname.net list=my-cloud
add action=accept chain=srcnat dst-address=192.168.77.0/24 out-interface=\
wireguard1 src-address=192.168.50.0/24
add action=masquerade chain=srcnat out-interface=bridge
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec profile
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.50.1 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=192.168.76.0/24 gateway=10.0.0.1 \
add disabled=no dst-address=192.168.7.0/24 gateway=192.168.11.1 \
add disabled=no distance=1 dst-address=192.168.77.0/24 gateway=wireguard1 \
/ip service
set api disabled=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system identity
set name=MT_RB750
/system note
