lejsetad
Turning off default SMB and DLNA
Fri Nov 29, 2024 2:42 pm
I'm an owner of HAP ax3 device. I've connected a USB disk to the router. I share a few folders on that disk as SMB shares and I'm using one folder as a media share. However, there's one default samba share one media share that are both linked to the root of the disk. They are both marked as dynamic, so I cannot remove nor edit them. How do I turn them off? Thank you
mszru
Re: Turning off default SMB and DLNA
Fri Nov 29, 2024 5:12 pm
In Winbox open System => Disks => Settings and uncheck Auto SMB Share and Auto Media Share parameters.
or
In CLI run
/disk/settings/set auto-smb-sharing=no auto-media-sharing=no
lejsetad
Fri Nov 29, 2024 6:13 pm
Thanks for the tip, but it didn't help. I've also rebooted the router after disabling both, but nothing changed. Any ideas why?
Amm0
Fri Nov 29, 2024 7:36 pm
I would have thought that would have worked...
You can also be explicit to disable SMB:
/ip/smb/set enabled=no
(the default is "auto" AFAIK ... but I'd thought the /disk auto-smb-sharing=no mean auto in /ip/smb be =no)
Backward4964
Sat Dec 14, 2024 6:40 pm
I'm facing the same issue:
Set:
But I still have the whole usb2 shared by default while I would like to expose only usb2/share:
ip/smb/shares/print
0  X*  pub    pub         no
1    r share  usb2/share  no                  guest
2 D    usb2   usb2        no                  guest
ip/smb/print
enabled: yes
status: enabled
domain: MSHOME
comment: MikrotikSMB
interfaces: brg-lan
I'm hosting also 2 containers on that usb2 drive and would like to avoid exposing all the config files over SMB
Did you manage to find a solution to remove the whole usb drive from the SMB share and leave exposed only specific folders on the drive?
Amm0
Sun Dec 15, 2024 4:01 am
Set:
ip/smb/print
enabled: yes
status: enabled
domain: MSHOME
interfaces: brg-lan
Did you try /ip/smb/set enabled=no or /ip/smb/set enabled=auto ?
strobber
Sat Dec 21, 2024 3:22 pm
I have the same problem on my AX3 (7.16.2) - the default SMB share and DLNA server for the usb1 root are still accessible after disabling them in System->Disk->Settings. Has anyone finally solved this problem?
Backward4964
Mon Dec 23, 2024 4:03 pm
Set:
Yes tried all options:
- no -> SMB files are not accessible
- auto/yes -> enable SMB, but shares the whole USB drive.
Backward4964
Mon Dec 23, 2024 5:44 pm
A possible solution:
set
disk/set usb2 smb-sharing=no
(replace usb2) with the drive id that you want to disable. Then in the IP/SMB settings add only the folder you would want to share in Shares.
strobber
Thu Dec 26, 2024 12:15 am
set
This solution really works for me. Thanks a lot!
