mara
Container on arm
Tue Dec 24, 2024 11:13 am
Hi everyone,
I need your help. I’ve been trying for quite some time to get a container with Alpine running on an LTE device like the hAP ax lite or Chateau. I’m able to create the image, with or without an SSH server, and I can load and start the container. However, the container doesn’t stay in a running state—it stops after a few seconds.
What’s really frustrating is that I don’t see anything in the logs, even though I’ve enabled logging. My goal is to run a small SSH server and a web server. Since I can’t even get the base image to work, I’d greatly appreciate any support.
I’m using the Alpine base image with FROM arm32v7/alpine, which should match the architecture of the device—or am I mistaken here? :?
Any guidance or suggestions would be greatly appreciated!
Thanks in advance! :)
https://hub.docker.com/r/arm32v7/alpine/
holvoetn
Re: Container on arm
Tue Dec 24, 2024 11:16 am
Check this recent thread with exact the same environment.
It was about a Python environment.
viewtopic.php?t=213024
stevepat
Fri Jan 17, 2025 7:03 pm
I experienced the same but did not solve it: viewtopic.php?t=213873
