Actually, you don't have to add a dedicated
/ip ipsec identity row per client device unless you want each of them to get an individual treatment.
I haven't tested that practically because I don't have a use case for that, but while acting as a responder, the IPsec stack of RouterOS should accept any certificate the initiator presents if it is signed by a root CA the RouterOS trusts. So if you set
remote-id to
ignore and
match-by to
remote-id, a single
should be sufficient for all the clients. The drawback is that with this setting, you would need to maintain a CRL to be able to deny access to individual client devices (lost or stolen).
Other than that, there is no tickbox that would make RouterOS dynamically create the identities from the list of certificates in a similar way like routes to connected subnets are created dynamically. But you can use a (relatively) simple script to create a list of certificates matching a certain set of conditions, and for each item on that list, check whether a matching row already exists in
/ip ipsec identity and if it doesn't, create it:
:foreach crt in=[/certificate find where issued ca=my-root-ca] do={
:if ([:len [/ip ipsec identity find where remote-certificate=$crt]] = 0) do={
/ip ipsec identity add remote-certificate=$crt peer=xyz ...
(not tested!)
