kauedg
Filesystem forensic image
Sun Jan 19, 2025 6:19 pm
Is it possible to create a bit-by-bit image of a Mikrotik device and mount it on another OS, like Linux?
I need to perform a forensic analysis on a Mikrotik device, but I was unable to extract the filesystem from the flash storage.
Any technical articles por general guides on what to do/learn will be helpful. Thanks.
KKdPsLkxLzmA0
Re: Filesystem forensic image
Sun Jan 19, 2025 9:38 pm
I hope it isn't possible... I know some thieves across the street who try to do just that!
KKdPsLkxLzmA0
Sun Jan 19, 2025 10:58 pm
Aside from updating, what can be done to prevent someone from making such forensic bit-by-bit images and make sure there is plenty of variance?
optio
Sun Jan 19, 2025 11:09 pm
Generally by restricting physical access to device, using cabinets with locks, security guards on premises...
jaclaz
Sun Jan 19, 2025 11:19 pm
You can update as much as you want, if the hypothetical hacker interested in the secrets you store on your router has physical access to the device for enough time, It Is game over, physical extraction from a memory chip Is and will always be possible, as It uses exactly the same mechanisms that allow you to store and retrieve data on/from It.
Then, extracting from these data meaningful info may be easier or more difficult, but in theory It Is always possible.
kauedg
Wed Jan 22, 2025 12:13 am
I was able to dump the MTD devices contents, by PXE booting the device using a OpenWRT firmware using this guide: https://openwrt.org/toh/mikrotik/common. After running binwalk on each dump file, a SquashFS filesystem was found:
root@debian:/home/kauedg/Downloads/mtd# binwalk OpenWrt.mtd5.bin
DECIMAL       HEXADECIMAL     DESCRIPTION
20800         0x5140          Squashfs filesystem, little endian, version 4.0, compression:xz, size: 5570552 bytes, 587 inodes, blocksize: 262144 bytes, created: 2025-01-16 09:19:35
5606140       0x558AFC        xz compressed data
5668086       0x567CF6        xz compressed data
5670160       0x568510        xz compressed data
5672458       0x568E0A        xz compressed data
5673264       0x569130        xz compressed data
5677042       0x569FF2        xz compressed data
5679304       0x56A8C8        xz compressed data
5679718       0x56AA66        xz compressed data
5772539       0x5814FB        xz compressed data
5772643       0x581563        xz compressed data
7187594       0x6DAC8A        xz compressed data
7381067       0x70A04B        Neighborly text, "neighbor discovery-settings set discover-interface-list=LAN /tool mac-server set allowed-interface-list=LAN"
7382574       0x70A62E        Neighborly text, "neighbor discovery-settings set discover-interface-list=!dynamicc"
Then I tried unsquashing the filesystem but got stuck at these errors:
root@debian:/home/kauedg/Downloads/mtd# unsquashfs _OpenWrt.mtd5.bin.extracted/5140.squashfs
Lseek failed because Invalid argument
read_block: failed to read block @0x701000056100000
read_id_table: failed to read id table block
FATAL ERROR: File system corruption detected
I also unsquashing the filesystem from the RouterOS NPK image file used to flash the device and I was able to get a filesystem:
root@debian:/home/kauedg/Downloads/mtd# unsquashfs _routeros-7.17-smips.npk.extracted/1000.squashfs
Parallel unsquashfs: Using 8 processors
425 inodes (416 blocks) to write
created 393 files
created 162 directories
created 32 symlinks
created 0 devices
created 0 fifos
created 0 sockets
created 0 hardlinks
root@debian:/home/kauedg/Downloads/mtd# ll squashfs-root/
total 64K
drwxr-xr-x 16 root root 4.0K Jan 16 06:19 .
drwxr-xr-x  5 root root 4.0K Jan 21 19:09 ..
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 bin
drwxr-xr-x  8 root root 4.0K Jan 16 06:19 bndl
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 boot
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 dev
lrwxrwxrwx  1 root root   11 Jan 16 06:19 dude -> /flash/dude
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 etc
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 flash
drwxr-xr-x  3 root root 4.0K Jan 16 06:19 home
drwxr-xr-x  3 root root 4.0K Jan 16 06:19 lib
drwxr-xr-x  5 root root 4.0K Jan 16 06:19 nova
lrwxrwxrwx  1 root root    9 Jan 16 06:19 pckg -> /ram/pckg
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 proc
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 ram
lrwxrwxrwx  1 root root    9 Jan 16 06:19 rw -> /flash/rw
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 sbin
drwxr-xr-x  2 root root 4.0K Jan 16 06:19 sys
lrwxrwxrwx  1 root root    7 Jan 16 06:19 tmp -> /rw/tmp
drwxr-xr-x  5 root root 4.0K Jan 16 06:19 var
I'm looking for a way to unsquash the dumped filesystem without errors.
optio
Wed Jan 22, 2025 1:40 am
Try with extract binwalk command line option:
binwalk --run-as=root -e OpenWrt.mtd5.bin
This should extract any supported extractable data found in image including Squashfs.
jaclaz
Wed Jan 22, 2025 2:19 am
I think unsquash Is very "strict" and expects a "sound" filesystem and throws a fit even if minor issues are found.
I cannot remember if a tool for recovery/fix exists, something *like* dmde which Is excellent for other filesystems.
7-zip should be capable of reading a squashfs and in some cases It may be more tolerant.
There may be ways to decompress the single zlib blocks and then reassemble the stuff, but provided that It works, It can usually work for text contents and similar - given the nature of squashfs - fragmentation should not be and issue, but beginning and end of files, even using trid or file to detect signatures will required a lot of manuale work with a hex viewer/editor.
kauedg
Wed Jan 22, 2025 4:00 pm
Yes, that's exactly how I'm extracting the mtd's dump content. It creates a file named [XXXX].squashfs and tries to unsquash it automatically but it only gives an empty directory. When I try unsquashing it manually, I get the "Lseek failed because Invalid argument" error stated above.
kauedg
Wed Jan 22, 2025 4:08 pm
Using 7z was a great idea but no cigar
root@debian:/home/kauedg/Downloads/mtd# 7z l _OpenWrt.mtd5.bin.extracted/5140.squashfs
7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,64 bits,8 CPUs Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz (806EB),ASM,AES-NI)
Scanning the drive for archives:
1 file, 5570552 bytes (5440 KiB)
Listing archive: _OpenWrt.mtd5.bin.extracted/5140.squashfs
ERROR: _OpenWrt.mtd5.bin.extracted/5140.squashfs : opening : E_FAIL
Errors: 1
System ERROR:
E_FAIL
I found this OpenWRT forum post (https://forum.archive.openwrt.org/viewt ... p?id=67564) about using a tool named nand-dump-tool.py (https://github.com/Hitsxx/NandTool/blob ... mp-tool.py)to separate the OOB area but I'm still searching how to get the "ID code" parameter for a Mikrotik hAP lite (RB941-2nD)
optio
Wed Jan 22, 2025 4:53 pm
Could be that MT uses non-standard Squashfs for devices or it was not correctly dumped or fs is corrupted on flash. I know for sure that from CHR image Squashfs can be extracted with binwalk, done it many times.
kauedg
Wed Jan 22, 2025 4:58 pm
I dumped using both OpenWRT's MTD backup function and dd tool. Also dumped with dd the /etc/mtdXro and /etc/mtdblockX devices. All files with same sequential number are the same, so unless there's some gotcha on the acquisition itself, I believe their integrity is ok. Filesystem can't be corrupt on flash because I've freshly reflashed the device with Mikrotik's released RouterOS for the device, and, as I stated before, I dumped the filesystem from the npk file succesfully.
I'm following this https://fastcall.medium.com/dumping-fir ... 7e819199fd article regarding OOB, because I think it's causing the errors.
kauedg
Wed Jan 22, 2025 5:32 pm
[double post]
jaclaz
Wed Jan 22, 2025 6:40 pm
Nice find. :)
The related blog post:
https://www.j-michel.org/blog/2014/05/2 ... p-to-files
explains in detail how the oob/spare data works :) , and on the main page:
https://github.com/Hitsxx/NandTool/tree/master
it is clear that you can use oob and page size instead of chip ID (as it seems that there is no Winbond entry in the small program database of chips).
The "normal" mtd should have a way to show (detected/guessed) sizes. :?
The flash should be however a Winbond W25Q128JVSM, though finding the right values in the datasheet;
https://www.winbond.com/hq/product/code ... =W25Q128JV
seems not easy/immediate.
But with a hex viewer it should be identifiable.
kauedg
Wed Jan 22, 2025 8:01 pm
Nice find. :)
That's exactly the flash chip model. I got to the same datasheet as you did, but I'm inexperienced with flash chips. Could you help me identify the page and OOB size for this one?
I found this in the datasheet:
The W25Q128JV array is organized into 65,536 programmable pages of 256-bytes each
But I can't find a reference to OOB anywhere in it.
jaclaz
Wed Jan 22, 2025 9:13 pm
Neither can I, but again, with a hex viewer and a little patience it should be easy to identify the oob, see here another example:
https://redballoonsecurity.com/flash-dump/
optio
Wed Jan 22, 2025 9:28 pm
Some older topic https://forum.archive.openwrt.org/viewt ... p?id=70636, but here is stated 16-byte OOB but for different MTD model of same brand with same size.
Also as I see here https://openwrt.org/docs/techref/flash OpenWrt has nanddump which prints mtd info, like "Block size 131072, page size 2048, OOB size 64", also Nand-dump-tool.py should print OOB size according to this line from source code.
If you missed it from dump tool, try to dump again and see.
jaclaz
Thu Jan 23, 2025 11:08 am
Re-thinking about it, I believe you can also attempt "brute-forcing" the values.
It is not like there are tens or hundreds of possibilities, the single oob record cannot logically be smaller than 8 bytes, and more likely is either 16 or 32 bytes (i don't think that odd values or non multiples of 8 or 16 are used), grouped maybe in sets of 4 or 8.
The size of your dump in bytes, minus 65536*256= 16,777,216 is the total of oob space.
Let's say that your dump is 17,301,504.
The difference is 524,288.
That can be:
65,536x8 -> page size 256
32,768x16-> page size 512
16,384x32-> page size 1024
8,192x64-> page size 2048
4,096x128-> page size 4096
2,048x256-> page size 8192 <- improbable
Running that python script five or six times with these values (and with the parameter "guess" or double the times, once with "adjacent" and once with "separate") shouldn't take much time.
kauedg
Sat Feb 01, 2025 12:21 am
I was writing a long write-up on how I was troubleshooting the issue on the OOB but I found out something else was the problem. I downloaded the newest version available for squashfs-tools (https://github.com/plougher/squashfs-tools), compiled it with the tracing function enabled and fiddled around with the two squashfs files I dumped: the one from the RouterOS firmware npk file and the one I extracted from the device using nanddump, after flashing it.
I checked if the information about the files could be read
# ./unsquashfs -s ../../_routeros-7.17.1-smips.npk.extracted/1000.squashfs
squashfs: read_bytes: reading from position 0x0, bytes 96
Found a valid SQUASHFS 4:0 superblock on ../../_routeros-7.17.1-smips.npk.extracted/1000.squashfs.
Creation or last append time Thu Jan 30 08:26:56 2025
Filesystem size 5743084 bytes (5608.48 Kbytes / 5.48 Mbytes)
Compression xz
Block size 262144
Filesystem is exportable via NFS
Inodes are compressed
Data is compressed
Uids/Gids (Id table) are compressed
Fragments are compressed
Tailends are not packed into fragments
Xattrs are not stored
Duplicates are removed
Number of fragments 51
Number of inodes 593
Number of ids 1
squashfs: sBlk.s.inode_table_start 0x57706c
squashfs: sBlk.s.directory_table_start 0x57848e
squashfs: sBlk.s.fragment_table_start 0x579dac
squashfs: sBlk.s.lookup_table_start 0x57a1d6
squashfs: sBlk.s.id_table_start 0x57a1e4
squashfs: sBlk.s.xattr_id_table_start 0xffffffffffffffff
# ./unsquashfs -s ../../_mtd5.nanddump.bin.extracted/7534D0.squashfs
Found a valid SQUASHFS 4:0 superblock on ../../_mtd5.nanddump.bin.extracted/7534D0.squashfs.
Compression xz
Block size 262144
Data is compressed
Number of ids 1
The only difference was the filename
# diff <(./unsquashfs -s ../../_mtd5.nanddump.bin.extracted/7534D0.squashfs) <(./unsquashfs -s ../../_routeros-7.17.1-smips.npk.extracted/1000.squashfs)
2c2
< Found a valid SQUASHFS 4:0 superblock on ../../_mtd5.nanddump.bin.extracted/7534D0.squashfs.
This is the initial output from the npk file listing:
# ./unsquashfs -l ../../_routeros-7.17.1-smips.npk.extracted/1000.squashfs | head
squashfs: read_id_table: no_ids 1
squashfs: read_bytes: reading from position 0x57a1e4, bytes 8
squashfs: read_bytes: reading from position 0x57a1de, bytes 2
squashfs: read_block: block @0x57a1de, 4 uncompressed bytes
squashfs: read_bytes: reading from position 0x57a1e0, bytes 4
squashfs: read_bytes: reading from position 0x57a1d6, bytes 8
squashfs: read_fragment_table: 51 fragments, reading 1 fragment indexes from 0x579dac
squashfs: read_bytes: reading from position 0x579dac, bytes 8
squashfs: read_bytes: reading from position 0x579c1a, bytes 2
This is the full output for the mtd5 dumped file:
# ./unsquashfs -l ../../_mtd5.nanddump.bin.extracted/7534D0.squashfs
squashfs: read_bytes: reading from position 0xffffffffffffffff, bytes 2
read_block: failed to read block @0xffffffffffffffff
I manually checked the superblock section (96 bytes) and found out that the value 0xffffffffffffffff is in the "Xattr table" field, which the documentation (https://dr-emann.github.io/squashfs/squashfs.html) says
"The Xattr table, fragment table and export table are optional. If they are omitted from the archive, the respective fields indicating their position must be set to 0xFFFFFFFFFFFFFFFF (i.e. all bits set)."
Now let's compare both files' headers
# xxd -l 96 ../../_routeros-7.17.1-smips.npk.extracted/1000.squashfs
00000000: 6873 7173 5102 0000 0062 9b67 0000 0400  hsqsQ....b.g....
00000010: 3300 0000 0400 1200 c002 0100 0400 0000  3...............
00000020: 5c0b d810 0000 0000 eca1 5700 0000 0000  \.........W.....
00000030: e4a1 5700 0000 0000 ffff ffff ffff ffff  ..W.............
00000040: 6c70 5700 0000 0000 8e84 5700 0000 0000  lpW.......W.....
00000050: ac9d 5700 0000 0000 d6a1 5700 0000 0000  ..W.......W.....
# diff <(xxd -l 96 ../../_mtd5.nanddump.bin.extracted/7534D0.squashfs) <(xxd -l 96 ../../_routeros-7.17.1-smips.npk.extracted/1000.squashfs)
They are the same, right? When I try to unsquash the firmware's file, it runs without problems, but the absolutely same header, even with the -no-xattrs option, can't be read from the extracted file. I event checked the "flags" field and the bit for the option "Xattrs are stored uncompressed" was disabled and the bit for "There are no Xattrs in the archive was enabled"
# ./unsquashfs -l -no-xattrs ../../_mtd5.nanddump.bin.extracted/7534D0.squashfs
Is this a unsquashfs command bug or what?
jaclaz
Sat Feb 01, 2025 2:17 pm
No idea, but from what you posted it seems that in one case, just after reading at 0x57a1e4:
it "skips" to :
so the issue is probably in the 8 bytes @0x57a1e4.
optio
Sat Feb 01, 2025 5:44 pm
@kauedg Just by having same superbock in both images it doesn't mean that other data in image isn't corrupt.
By log it is corrupted inode table.
Analisis by trace log and source:
8 bytes for inode table positions are read and stored in id_index_table from position 0x57a1e4, call stack:
https://github.com/plougher/squashfs-to ... hfs.c#L659
https://github.com/plougher/squashfs-to ... h-4.c#L509
And it fails when reading table bytes by iterating positions, log call stack:
https://github.com/plougher/squashfs-to ... h-4.c#L530
https://github.com/plougher/squashfs-to ... hfs.c#L761
https://github.com/plougher/squashfs-to ... hfs.c#L665
https://github.com/plougher/squashfs-to ... hfs.c#L699
https://github.com/plougher/squashfs-to ... h-4.c#L527
By this, id_index_table is corrupt, since logged position is @0xffffffffffffffff (max unsigned long long) which is result of invalid value for its data type and such position in file is invalid (Lseek failed...). So as @jaclaz mentioned at 0x57a1e4 position 8 bytes are corrupt, where inode table positions are stored.
Did you strip correctly OOB data from image? Squashfs superblock is located in first 96 bytes and OOB data will not corrupt it if MTD page size is larger, which is.
kauedg
Mon Feb 03, 2025 12:26 am
Spoiler alert: I DID IT.
This is the short version, if someone wants a longer, detailed write-up, let me know and I'll post it here.
Step 1: Trim the beginning of the file, until 0x10000
# dd if=mtd5.nanddump.bin of=mtd5_trimmed bs=1 skip=65536
Step 2: I noticed there were 16 0xFF separators every 65520 bytes (OOB?). Remove it.
# ./nand-dump-tool.py -i dumps/mtd5_trimmed -o dumps/mtd5_step2 --page-size 65520 --oob-size 16 --save-oob dumps/mtd5_step2_oob --layout separate
Step 3: Remove OOB
# ./nand-dump-tool.py -i dumps/mtd5_step2 -o dumps/mtd5_step3 --page-size 1024 --oob-size 16 --save-oob dumps/mtd5_step3_oob --layout separate
Step 4: Fix offset to file's sections
0x57A1E4 - 0x5711e0 = 0x9000 (36864)
# dd if=/dev/zero bs=1 count=36864 | tr "\000" "\377" > mtd5_new
# dd if=mtd5_step3 bs=1 count=16321536 >> mtd5_new
Step 5: Execute the patched unsquashfs, with tracing enabled, ignoring the offset after reading the superblock
# ./unsquashfs -s -o 7681232 ../../mtd5_new
squashfs: READING...
squashfs: read_bytes: reading from position 0x7534d0, bytes 96
Found a valid SQUASHFS 4:0 superblock on ../../mtd5_new.
Compression xz
Block size 262144
Data is compressed
Number of ids 1
# ./unsquashfs -l -o 7533568 -ig -f ../../mtd5_new
squashfs-root
squashfs-root/bin
squashfs-root/bin/bash
squashfs-root/bin/catlog
squashfs-root/bin/gosh
squashfs-root/bin/login
squashfs-root/bin/pakp
squashfs-root/bin/sh
squashfs-root/bin/shell
squashfs-root/bndl
squashfs-root/bndl/advanced-tools
squashfs-root/bndl/advanced-tools/home
squashfs-root/bndl/advanced-tools/home/web
squashfs-root/bndl/advanced-tools/home/web/webfig
squashfs-root/bndl/advanced-tools/home/web/webfig/advtool-b6a18e54d46e.jg.gz
squashfs-root/bndl/advanced-tools/home/web/webfig/advtool.info
squashfs-root/bndl/advanced-tools/home/web/webfig/advtool.jg.gz
squashfs-root/bndl/advanced-tools/nova
squashfs-root/bndl/advanced-tools/nova/bin
squashfs-root/bndl/advanced-tools/nova/bin/ddns
squashfs-root/bndl/advanced-tools/nova/bin/fping
squashfs-root/bndl/advanced-tools/nova/bin/macscan
squashfs-root/bndl/advanced-tools/nova/bin/netwatch
squashfs-root/bndl/advanced-tools/nova/bin/pspeed
squashfs-root/bndl/advanced-tools/nova/bin/scanner
squashfs-root/bndl/advanced-tools/nova/bin/wakeonlan
squashfs-root/bndl/advanced-tools/nova/lib
squashfs-root/bndl/advanced-tools/nova/lib/console
squashfs-root/bndl/advanced-tools/nova/lib/console/1166016512.mem
squashfs-root/bndl/dhcp
squashfs-root/bndl/dhcp/home
squashfs-root/bndl/dhcp/home/web
squashfs-root/bndl/dhcp/home/web/webfig
squashfs-root/bndl/dhcp/home/web/webfig/dhcp-5540fe7f653a.jg.gz
squashfs-root/bndl/dhcp/home/web/webfig/dhcp.info
squashfs-root/bndl/dhcp/home/web/webfig/dhcp.jg.gz
squashfs-root/bndl/dhcp/lib
squashfs-root/bndl/dhcp/lib/libudhcp.so
squashfs-root/bndl/dhcp/nova
squashfs-root/bndl/dhcp/nova/bin
squashfs-root/bndl/dhcp/nova/bin/dhcp
squashfs-root/bndl/dhcp/nova/bin/dhcpclient
squashfs-root/bndl/dhcp/nova/lib
squashfs-root/bndl/dhcp/nova/lib/console
squashfs-root/bndl/dhcp/nova/lib/console/1128267776.mem
squashfs-root/bndl/hotspot
squashfs-root/bndl/hotspot/home
squashfs-root/bndl/hotspot/home/web
squashfs-root/bndl/hotspot/home/web/hotspot
squashfs-root/bndl/hotspot/home/web/hotspot/alogin.html
squashfs-root/bndl/hotspot/home/web/hotspot/api.json
squashfs-root/bndl/hotspot/home/web/hotspot/css
squashfs-root/bndl/hotspot/home/web/hotspot/css/style.css
squashfs-root/bndl/hotspot/home/web/hotspot/error.html
squashfs-root/bndl/hotspot/home/web/hotspot/errors.txt
squashfs-root/bndl/hotspot/home/web/hotspot/favicon.ico
squashfs-root/bndl/hotspot/home/web/hotspot/img
squashfs-root/bndl/hotspot/home/web/hotspot/img/password.svg
squashfs-root/bndl/hotspot/home/web/hotspot/img/user.svg
squashfs-root/bndl/hotspot/home/web/hotspot/login.html
squashfs-root/bndl/hotspot/home/web/hotspot/logout.html
squashfs-root/bndl/hotspot/home/web/hotspot/md5.js
squashfs-root/bndl/hotspot/home/web/hotspot/radvert.html
squashfs-root/bndl/hotspot/home/web/hotspot/redirect.html
squashfs-root/bndl/hotspot/home/web/hotspot/rlogin.html
squashfs-root/bndl/hotspot/home/web/hotspot/status.html
squashfs-root/bndl/hotspot/home/web/hotspot/xml
squashfs-root/bndl/hotspot/home/web/hotspot/xml/WISPAccessGatewayParam.xsd
squashfs-root/bndl/hotspot/home/web/hotspot/xml/alogin.html
squashfs-root/bndl/hotspot/home/web/hotspot/xml/error.html
squashfs-root/bndl/hotspot/home/web/hotspot/xml/flogout.html
squashfs-root/bndl/hotspot/home/web/hotspot/xml/login.html
squashfs-root/bndl/hotspot/home/web/hotspot/xml/logout.html
squashfs-root/bndl/hotspot/home/web/hotspot/xml/rlogin.html
squashfs-root/bndl/hotspot/home/web/webfig
squashfs-root/bndl/hotspot/home/web/webfig/hotspot-f1e2e1d4af99.jg.gz
squashfs-root/bndl/hotspot/home/web/webfig/hotspot.info
squashfs-root/bndl/hotspot/home/web/webfig/hotspot.jg.gz
squashfs-root/bndl/hotspot/lib
squashfs-root/bndl/hotspot/lib/modules
squashfs-root/bndl/hotspot/lib/modules/5.6.3
squashfs-root/bndl/hotspot/lib/modules/5.6.3/modules.dep.hotspot
squashfs-root/bndl/hotspot/lib/modules/5.6.3/net
squashfs-root/bndl/hotspot/lib/modules/5.6.3/net/ipv4
squashfs-root/bndl/hotspot/lib/modules/5.6.3/net/ipv4/unicl.ko
squashfs-root/bndl/hotspot/nova
squashfs-root/bndl/hotspot/nova/bin
squashfs-root/bndl/hotspot/nova/bin/hotspot
squashfs-root/bndl/hotspot/nova/etc
squashfs-root/bndl/hotspot/nova/etc/radius
squashfs-root/bndl/hotspot/nova/etc/radius/hotspot.x3
squashfs-root/bndl/hotspot/nova/lib
squashfs-root/bndl/hotspot/nova/lib/console
squashfs-root/bndl/hotspot/nova/lib/console/1132462080.mem
squashfs-root/bndl/ipv6
squashfs-root/bndl/ipv6/home
squashfs-root/bndl/ipv6/home/web
squashfs-root/bndl/ipv6/home/web/webfig
squashfs-root/bndl/ipv6/home/web/webfig/ipv6-b898739b568b.jg.gz
squashfs-root/bndl/ipv6/home/web/webfig/ipv6.info
squashfs-root/bndl/ipv6/home/web/webfig/ipv6.jg.gz
squashfs-root/bndl/ipv6/nova
squashfs-root/bndl/ipv6/nova/bin
squashfs-root/bndl/ipv6/nova/bin/ippool6
squashfs-root/bndl/ipv6/nova/bin/radvd
squashfs-root/bndl/ipv6/nova/lib
squashfs-root/bndl/ipv6/nova/lib/console
squashfs-root/bndl/ipv6/nova/lib/console/1212153856.mem
squashfs-root/bndl/ipv6/nova/lib/route
squashfs-root/bndl/ipv6/nova/lib/route/ipv6.rp
squashfs-root/bndl/ppp
squashfs-root/bndl/ppp/home
squashfs-root/bndl/ppp/home/web
squashfs-root/bndl/ppp/home/web/webfig
squashfs-root/bndl/ppp/home/web/webfig/ppp-0185abe62dd5.jg.gz
squashfs-root/bndl/ppp/home/web/webfig/ppp.info
squashfs-root/bndl/ppp/home/web/webfig/ppp.jg.gz
squashfs-root/bndl/ppp/lib
squashfs-root/bndl/ppp/lib/modules
squashfs-root/bndl/ppp/lib/modules/5.6.3
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp/ppp_async.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp/ppp_deflate.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp/ppp_generic.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp/ppp_mppe.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp/ppp_synctty.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp/pppoe.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/kernel/drivers/net/ppp/pppox.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/misc
squashfs-root/bndl/ppp/lib/modules/5.6.3/misc/ovpn.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/misc/pppoefp.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/misc/sstp.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/modules.dep.ppp
squashfs-root/bndl/ppp/lib/modules/5.6.3/net
squashfs-root/bndl/ppp/lib/modules/5.6.3/net/l2tp.ko
squashfs-root/bndl/ppp/lib/modules/5.6.3/net/pptp.ko
squashfs-root/bndl/ppp/nova
squashfs-root/bndl/ppp/nova/bin
squashfs-root/bndl/ppp/nova/bin/ppp
squashfs-root/bndl/ppp/nova/bin/ppp-worker
squashfs-root/bndl/ppp/nova/etc
squashfs-root/bndl/ppp/nova/etc/net-remote
squashfs-root/bndl/ppp/nova/etc/net-remote/ppp.x3
squashfs-root/bndl/ppp/nova/etc/radius
squashfs-root/bndl/ppp/nova/etc/radius/ppp.x3
squashfs-root/bndl/ppp/nova/lib
squashfs-root/bndl/ppp/nova/lib/console
squashfs-root/bndl/ppp/nova/lib/console/1090519040.mem
squashfs-root/bndl/ppp/nova/lib/profiler
squashfs-root/bndl/ppp/nova/lib/profiler/ppp.p
squashfs-root/bndl/security
squashfs-root/bndl/security/home
squashfs-root/bndl/security/home/web
squashfs-root/bndl/security/home/web/webfig
squashfs-root/bndl/security/home/web/webfig/secure-0a49065a769f.jg.gz
squashfs-root/bndl/security/home/web/webfig/secure.info
squashfs-root/bndl/security/home/web/webfig/secure.jg.gz
squashfs-root/bndl/security/lib
squashfs-root/bndl/security/lib/modules
squashfs-root/bndl/security/lib/modules/5.6.3
squashfs-root/bndl/security/lib/modules/5.6.3/kernel
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto/blowfish_common.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto/blowfish_generic.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto/camellia_generic.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto/chacha20poly1305.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto/echainiv.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto/twofish_common.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/crypto/twofish_generic.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net/ipv4
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net/ipv4/ah4.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net/ipv4/esp4.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net/key
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net/key/af_key.ko
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net/xfrm
squashfs-root/bndl/security/lib/modules/5.6.3/kernel/net/xfrm/xfrm_user.ko
squashfs-root/bndl/security/lib/modules/5.6.3/modules.dep.security
squashfs-root/bndl/security/nova
squashfs-root/bndl/security/nova/bin
squashfs-root/bndl/security/nova/bin/ipsec
squashfs-root/bndl/security/nova/bin/ipsec-worker
squashfs-root/bndl/security/nova/bin/ssh
squashfs-root/bndl/security/nova/bin/sshd
squashfs-root/bndl/security/nova/etc
squashfs-root/bndl/security/nova/etc/radius
squashfs-root/bndl/security/nova/etc/radius/security.x3
squashfs-root/bndl/security/nova/etc/services
squashfs-root/bndl/security/nova/etc/services/security.x3
squashfs-root/bndl/security/nova/lib
squashfs-root/bndl/security/nova/lib/console
squashfs-root/bndl/security/nova/lib/console/1077936128.mem
squashfs-root/boot
squashfs-root/dev
squashfs-root/dude
squashfs-root/etc
squashfs-root/etc/license
squashfs-root/etc/qca9531L-7.17.1.fwf
squashfs-root/etc/termcap
squashfs-root/flash
squashfs-root/home
squashfs-root/home/web
squashfs-root/home/web/assets
squashfs-root/home/web/assets/400.woff2
squashfs-root/home/web/assets/700.woff2
squashfs-root/home/web/assets/script-bd71a1293274.js
squashfs-root/home/web/assets/style-692511ab2675.css
squashfs-root/home/web/bth-files.html
squashfs-root/home/web/favicon.png
squashfs-root/home/web/favicon.svg
squashfs-root/home/web/graph.css
squashfs-root/home/web/help
squashfs-root/home/web/help/license.html
squashfs-root/home/web/index2.html
squashfs-root/home/web/license.txt
squashfs-root/home/web/logo.png
squashfs-root/home/web/mikrotik_logo.svg
squashfs-root/home/web/robots.txt
squashfs-root/home/web/webfig
squashfs-root/home/web/webfig/curve255-541e54a862be.js
squashfs-root/home/web/webfig/icons.info
squashfs-root/home/web/webfig/icons.png
squashfs-root/home/web/webfig/icons24.info
squashfs-root/home/web/webfig/icons24.png
squashfs-root/home/web/webfig/icons32.info
squashfs-root/home/web/webfig/icons32.png
squashfs-root/home/web/webfig/index.html
squashfs-root/home/web/webfig/list
squashfs-root/home/web/webfig/master-e24161e0bd73.js
squashfs-root/home/web/webfig/roteros-d7ce214a2753.jg.gz
squashfs-root/home/web/webfig/roteros.info
squashfs-root/home/web/webfig/roteros.jg.gz
squashfs-root/home/web/winbox
squashfs-root/lib
squashfs-root/lib/libc.so
squashfs-root/lib/libeap.so
squashfs-root/lib/libjson.so
squashfs-root/lib/librappsup.so
squashfs-root/lib/libubox.so
squashfs-root/lib/libuc++.so
squashfs-root/lib/libucrypto.so
squashfs-root/lib/libufiber.so
squashfs-root/lib/libuhttp.so
squashfs-root/lib/libumsg.so
squashfs-root/lib/liburadius.so
squashfs-root/lib/libuxml++.so
squashfs-root/lib/libwww.so
squashfs-root/lib/libxml.so
squashfs-root/lib/libz.so
squashfs-root/lib/modules
squashfs-root/lib/modules/5.6.3
squashfs-root/lib/modules/5.6.3/drivers
squashfs-root/lib/modules/5.6.3/drivers/char
squashfs-root/lib/modules/5.6.3/drivers/char/ar7100wdt.ko
squashfs-root/lib/modules/5.6.3/drivers/char/ticker.ko
squashfs-root/lib/modules/5.6.3/drivers/net
squashfs-root/lib/modules/5.6.3/drivers/net/ag7240.ko
squashfs-root/lib/modules/5.6.3/drivers/net/ath8327.ko
squashfs-root/lib/modules/5.6.3/drivers/net/aths16.ko
squashfs-root/lib/modules/5.6.3/drivers/net/imq.ko
squashfs-root/lib/modules/5.6.3/drivers/net/packet_hook.ko
squashfs-root/lib/modules/5.6.3/drivers/net/phy_helper.ko
squashfs-root/lib/modules/5.6.3/drivers/net/sram.ko
squashfs-root/lib/modules/5.6.3/drivers/net/switch.ko
squashfs-root/lib/modules/5.6.3/drivers/net/vxlan2.ko
squashfs-root/lib/modules/5.6.3/kernel
squashfs-root/lib/modules/5.6.3/kernel/arch
squashfs-root/lib/modules/5.6.3/kernel/arch/mips
squashfs-root/lib/modules/5.6.3/kernel/arch/mips/crypto
squashfs-root/lib/modules/5.6.3/kernel/arch/mips/crypto/chacha-mips.ko
squashfs-root/lib/modules/5.6.3/kernel/arch/mips/crypto/poly1305-mips.ko
squashfs-root/lib/modules/5.6.3/kernel/arch/mips/oprofile
squashfs-root/lib/modules/5.6.3/kernel/arch/mips/oprofile/oprofile.ko
squashfs-root/lib/modules/5.6.3/kernel/crypto
squashfs-root/lib/modules/5.6.3/kernel/crypto/arc4.ko
squashfs-root/lib/modules/5.6.3/kernel/crypto/des_generic.ko
squashfs-root/lib/modules/5.6.3/kernel/crypto/sha1_generic.ko
squashfs-root/lib/modules/5.6.3/kernel/crypto/sha512_generic.ko
squashfs-root/lib/modules/5.6.3/kernel/drivers
squashfs-root/lib/modules/5.6.3/kernel/drivers/net
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/bonding
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/bonding/bonding.ko
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/macvlan.ko
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/slip
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/slip/slhc.ko
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/vrf.ko
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/wireguard
squashfs-root/lib/modules/5.6.3/kernel/drivers/net/wireguard/wireguard.ko
squashfs-root/lib/modules/5.6.3/kernel/lib
squashfs-root/lib/modules/5.6.3/kernel/lib/crc-ccitt.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto/libarc4.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto/libblake2s-generic.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto/libblake2s.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto/libchacha20poly1305.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto/libcurve25519-generic.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto/libcurve25519.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/crypto/libdes.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/ts_bm.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/ts_kmp.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/zlib_deflate
squashfs-root/lib/modules/5.6.3/kernel/lib/zlib_deflate/zlib_deflate.ko
squashfs-root/lib/modules/5.6.3/kernel/lib/zlib_inflate
squashfs-root/lib/modules/5.6.3/kernel/lib/zlib_inflate/zlib_inflate.ko
squashfs-root/lib/modules/5.6.3/kernel/net
squashfs-root/lib/modules/5.6.3/kernel/net/8021q
squashfs-root/lib/modules/5.6.3/kernel/net/8021q/8021q.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_802_3.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_arp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_arpreply.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_dnat.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_ip.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_ip6.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_limit.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_mark.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_mark_m.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_pkttype.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_redirect.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_snat.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_stp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebt_vlan.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebtable_filter.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebtable_nat.ko
squashfs-root/lib/modules/5.6.3/kernel/net/bridge/netfilter/ebtables.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/ip_tunnel.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/ip_tables.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/ipt_REJECT.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/iptable_filter.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/iptable_mangle.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/iptable_nat.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/iptable_raw.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/nf_defrag_ipv4.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/nf_nat_h323.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/nf_nat_pptp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/netfilter/nf_reject_ipv4.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv4/udp_tunnel.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/ah6.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/esp6.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/ip6_udp_tunnel.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/ipv6.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6_tables.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6t_NPT.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6t_REJECT.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6t_eui64.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6t_ipv6header.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6table_filter.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6table_mangle.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6table_nat.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/ip6table_raw.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/nf_defrag_ipv6.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/netfilter/nf_reject_ipv6.ko
squashfs-root/lib/modules/5.6.3/kernel/net/ipv6/tunnel6.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_ftp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_h323.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_irc.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_netlink.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_pptp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_rtsp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_sip.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_conntrack_tftp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_nat.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_nat_ftp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_nat_irc.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_nat_rtsp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_nat_sip.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nf_nat_tftp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/nfnetlink.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/x_tables.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_CT.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_DSCP.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_HL.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_MASQUERADE.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_NETMAP.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_REDIRECT.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_TCPMSS.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_addrtype.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_connbytes.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_connmark.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_conntrack.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_dscp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_hashlimit.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_helper.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_hl.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_length.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_mac.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_mark.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_multiport.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_nat.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_physdev.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_policy.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_realm.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_statistic.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_string.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_tcpmss.ko
squashfs-root/lib/modules/5.6.3/kernel/net/netfilter/xt_tcpudp.ko
squashfs-root/lib/modules/5.6.3/kernel/net/sched
squashfs-root/lib/modules/5.6.3/kernel/net/sched/sch_cake.ko
squashfs-root/lib/modules/5.6.3/kernel/net/sched/sch_codel.ko
squashfs-root/lib/modules/5.6.3/kernel/net/sched/sch_fq_codel.ko
squashfs-root/lib/modules/5.6.3/kernel/net/sched/sch_htb.ko
squashfs-root/lib/modules/5.6.3/kernel/net/sched/sch_red.ko
squashfs-root/lib/modules/5.6.3/kernel/net/unix
squashfs-root/lib/modules/5.6.3/kernel/net/unix/unix.ko
squashfs-root/lib/modules/5.6.3/kernel/net/xfrm
squashfs-root/lib/modules/5.6.3/kernel/net/xfrm/xfrm_algo.ko
squashfs-root/lib/modules/5.6.3/misc
squashfs-root/lib/modules/5.6.3/misc/btest.ko
squashfs-root/lib/modules/5.6.3/misc/flash.ko
squashfs-root/lib/modules/5.6.3/misc/jiffies.ko
squashfs-root/lib/modules/5.6.3/misc/ledgroup.ko
squashfs-root/lib/modules/5.6.3/misc/logring.ko
squashfs-root/lib/modules/5.6.3/misc/mesh.ko
squashfs-root/lib/modules/5.6.3/misc/panics.ko
squashfs-root/lib/modules/5.6.3/misc/rb.ko
squashfs-root/lib/modules/5.6.3/misc/romon.ko
squashfs-root/lib/modules/5.6.3/misc/snif.ko
squashfs-root/lib/modules/5.6.3/misc/traffic_gen.ko
squashfs-root/lib/modules/5.6.3/misc/ulog.ko
squashfs-root/lib/modules/5.6.3/modules.dep.system
squashfs-root/lib/modules/5.6.3/net
squashfs-root/lib/modules/5.6.3/net/bridge
squashfs-root/lib/modules/5.6.3/net/bridge/bridge2.ko
squashfs-root/lib/modules/5.6.3/net/bridge/bridge2_netfilter.ko
squashfs-root/lib/modules/5.6.3/net/bridge/ebt_snif.ko
squashfs-root/lib/modules/5.6.3/net/bridge/ebt_ulog.ko
squashfs-root/lib/modules/5.6.3/net/ipv4
squashfs-root/lib/modules/5.6.3/net/ipv4/netfilter
squashfs-root/lib/modules/5.6.3/net/ipv4/netfilter/ipt_SAME.ko
squashfs-root/lib/modules/5.6.3/net/ipv4/netfilter/ipt_TARPIT.ko
squashfs-root/lib/modules/5.6.3/net/ipv4/netfilter/ipt_psd.ko
squashfs-root/lib/modules/5.6.3/net/ipv4/netfilter/ipt_snif.ko
squashfs-root/lib/modules/5.6.3/net/ipv4/netfilter/ipt_ulog.ko
squashfs-root/lib/modules/5.6.3/net/netfilter
squashfs-root/lib/modules/5.6.3/net/netfilter/nf_conntrack_ipv4.ko
squashfs-root/lib/modules/5.6.3/net/netfilter/nf_conntrack_ipv6.ko
squashfs-root/lib/modules/5.6.3/net/netfilter/xt_ein.ko
squashfs-root/lib/modules/5.6.3/net/netfilter/xt_layer7.ko
squashfs-root/lib/modules/5.6.3/net/netfilter/xt_misc.ko
squashfs-root/lib/modules/5.6.3/net/netfilter/xt_tls.ko
squashfs-root/lib/modules/5.6.3/net/sched
squashfs-root/lib/modules/5.6.3/net/sched/cls_fw.ko
squashfs-root/lib/modules/5.6.3/net/sched/cls_linear.ko
squashfs-root/lib/modules/5.6.3/net/sched/proto_agr.ko
squashfs-root/lib/modules/5.6.3/net/sched/sch_agr.ko
squashfs-root/lib/modules/5.6.3/net/sched/sch_pcq.ko
squashfs-root/lib/modules/5.6.3/net/sched/sch_sfq.ko
squashfs-root/lib/valgrind
squashfs-root/nova
squashfs-root/nova/bin
squashfs-root/nova/bin/agent
squashfs-root/nova/bin/arpd
squashfs-root/nova/bin/backup
squashfs-root/nova/bin/bridge2
squashfs-root/nova/bin/btest
squashfs-root/nova/bin/cerm
squashfs-root/nova/bin/cerm-worker
squashfs-root/nova/bin/cloud
squashfs-root/nova/bin/crossfig
squashfs-root/nova/bin/detnet
squashfs-root/nova/bin/discover
squashfs-root/nova/bin/email
squashfs-root/nova/bin/fileman
squashfs-root/nova/bin/ftpd
squashfs-root/nova/bin/graphing
squashfs-root/nova/bin/havecardbus
squashfs-root/nova/bin/igmpproxy
squashfs-root/nova/bin/installer
squashfs-root/nova/bin/ippool
squashfs-root/nova/bin/keyman
squashfs-root/nova/bin/kidcontrol
squashfs-root/nova/bin/led
squashfs-root/nova/bin/letsencrypt
squashfs-root/nova/bin/loader
squashfs-root/nova/bin/log
squashfs-root/nova/bin/login
squashfs-root/nova/bin/logmaker
squashfs-root/nova/bin/macping
squashfs-root/nova/bin/mactel
squashfs-root/nova/bin/mepty
squashfs-root/nova/bin/mesh
squashfs-root/nova/bin/mode
squashfs-root/nova/bin/modprobed
squashfs-root/nova/bin/moduler
squashfs-root/nova/bin/mproxy
squashfs-root/nova/bin/mtget
squashfs-root/nova/bin/natpmp
squashfs-root/nova/bin/net
squashfs-root/nova/bin/ntp
squashfs-root/nova/bin/panicsl
squashfs-root/nova/bin/parser
squashfs-root/nova/bin/ping
squashfs-root/nova/bin/portman
squashfs-root/nova/bin/profiler
squashfs-root/nova/bin/quickset
squashfs-root/nova/bin/radius
squashfs-root/nova/bin/resolver
squashfs-root/nova/bin/resolver_ctl
squashfs-root/nova/bin/romon
squashfs-root/nova/bin/route
squashfs-root/nova/bin/rtrace
squashfs-root/nova/bin/sermgr
squashfs-root/nova/bin/sertcp
squashfs-root/nova/bin/sniffer
squashfs-root/nova/bin/snmp
squashfs-root/nova/bin/socks
squashfs-root/nova/bin/ssld
squashfs-root/nova/bin/sstore
squashfs-root/nova/bin/sys2
squashfs-root/nova/bin/telnet
squashfs-root/nova/bin/telser
squashfs-root/nova/bin/tftpd
squashfs-root/nova/bin/traceroute
squashfs-root/nova/bin/trafficgen
squashfs-root/nova/bin/trafflow
squashfs-root/nova/bin/undo
squashfs-root/nova/bin/upnp
squashfs-root/nova/bin/user
squashfs-root/nova/bin/vrrp
squashfs-root/nova/bin/watchdog
squashfs-root/nova/bin/wproxy
squashfs-root/nova/bin/www
squashfs-root/nova/etc
squashfs-root/nova/etc/leds
squashfs-root/nova/etc/leds/system.x3
squashfs-root/nova/etc/lognames
squashfs-root/nova/etc/logo
squashfs-root/nova/etc/manual-url
squashfs-root/nova/etc/net-remote
squashfs-root/nova/etc/net-remote/system.x3
squashfs-root/nova/etc/pciinfo
squashfs-root/nova/etc/pciinfo/system.x3
squashfs-root/nova/etc/radius
squashfs-root/nova/etc/radius/system.x3
squashfs-root/nova/etc/services
squashfs-root/nova/etc/services/system.x3
squashfs-root/nova/etc/system_names
squashfs-root/nova/etc/system_names/system.x3
squashfs-root/nova/etc/upnp
squashfs-root/nova/etc/upnp/logo16.gif
squashfs-root/nova/etc/upnp/logo32.gif
squashfs-root/nova/etc/upnp/logo48.gif
squashfs-root/nova/etc/upnp/osinfo.xml
squashfs-root/nova/etc/upnp/wancommonifcfg.xml
squashfs-root/nova/etc/upnp/wanipconn.xml
squashfs-root/nova/etc/url
squashfs-root/nova/etc/user
squashfs-root/nova/etc/user/system.x3
squashfs-root/nova/etc/www
squashfs-root/nova/etc/www/system.x3
squashfs-root/nova/lib
squashfs-root/nova/lib/console
squashfs-root/nova/lib/console/1073741824.mem
squashfs-root/nova/lib/console/logo.txt
squashfs-root/nova/lib/console/sublogo.txt
squashfs-root/nova/lib/defconf
squashfs-root/nova/lib/defconf/defconf
squashfs-root/nova/lib/defconf/defconf-caps
squashfs-root/nova/lib/defconf/defconf-wps-sync
squashfs-root/nova/lib/defconf/get-custom-defconf
squashfs-root/nova/lib/profiler
squashfs-root/nova/lib/profiler/system.p
squashfs-root/nova/lib/xmlnames2
squashfs-root/nova/logs
squashfs-root/nova/store
squashfs-root/pckg
squashfs-root/proc
squashfs-root/ram
squashfs-root/rw
squashfs-root/sbin
squashfs-root/sbin/nandfix
squashfs-root/sbin/sysinit
squashfs-root/sys
squashfs-root/tmp
squashfs-root/var
squashfs-root/var/cm
squashfs-root/var/deinstall
squashfs-root/var/lock
squashfs-root/var/pckg
squashfs-root/var/pdb
squashfs-root/var/post
squashfs-root/var/run
squashfs-root/var/tmp
While extracting, the program threw some errors:
# ./unsquashfs -o 7533568 -ig -f ../../mtd5_new
430 inodes (423 blocks) to write
xz uncompress failed with error code 7
writer: failed to read/uncompress file squashfs-root/nova/lib/console/1073741824.mem
[===========================================================================================================================================================================|] 853/853 100%
created 398 files
created 163 directories
created 32 symlinks
created 0 devices
created 0 fifos
created 0 sockets
created 0 hardlinks
So I checked whether all the files matched the unsquashing output of the original npk file:
# tree squashfs-root > ../../mtd5_new.tree
# tree ../../_routeros-7.17.1-smips.npk.extracted/squashfs-root/ > ../../npk.tree
# diff --suppress-common-lines -y ../../npk.tree ../../mtd5_new.tree
../../_routeros-7.17.1-smips.npk.extracted/squashfs-root/     | squashfs-root
│   │   │   ├── 1073741824.mem                                <
164 directories, 429 files                                    | 164 directories, 428 files
The only issue was extracting the file /nova/lib/console/1073741824.mem, which I'm working on right now. I'll also try reproducing it on another dump file I have here.
Any help will be appreciated on extracting the /nova/lib/console/1073741824.mem file.
jaclaz
Mon Feb 03, 2025 1:47 am
So, there are two "layers".
1024+16=1040
63*1040=65520
65520+16=65536
Interesting.
It would make sense to have these extra 16 bytes at the end of a group of "sectors" to "get even" to a multiple of 1024, 64*1024=65536.
kauedg
Mon Feb 03, 2025 3:17 am
1024+16=1040
63*1040=65520
65520+16=65536
Interesting.
Later I'll check if the 0xff separators where introduced by the nanddump tool. I got another dump done with dd which doesn't have this. The steps above are only good for the dump I tried first, unfortunately. Now I'm trying to figure out where all the offsets come from, without knowing the value an address should have beforehand.
jaclaz
Mon Feb 03, 2025 2:54 pm
I don't know, but the math sounds similar to the way some of the enterprise SSD's or HD's drives are made (many of these are formatted with 520 or 528 bytes instead of the usual 512).
The actual "cell" (or sector group) size on the device should be anyway 4096 bytes or a multiple, and these drives can usually (with some spells and magic commands) be converted back to 512 bytes/sector, so some form of "slack" must exist, either 8 bytes every 32768 or 16 bytes every 65536. I believe.
kauedg
Mon Feb 03, 2025 11:32 pm
I checked using dd and it seems like the 0xFF bytes are present in the flash memory itself, repeat every 65520 bytes and are not a product of nanddump or whatever. Skipped to 131072 (0x20000) because before that it's all 0xFF, but 0xfff0 follows the same pattern.
# hexdump -s 131072 /dev/mtd5 | grep "ffff ffff ffff ffff ffff ffff ffff ffff"
002fff0 ffff ffff ffff ffff ffff ffff ffff ffff
003fff0 ffff ffff ffff ffff ffff ffff ffff ffff
0046ad0 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
0046b70 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
0046ba0 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
0046ee0 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
0046f80 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
0046fb0 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
00472f0 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
0047390 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
00473c0 ffff ffff ffff ffff ffff ffff ffff ffff		ignore this
004fff0 ffff ffff ffff ffff ffff ffff ffff ffff
005fff0 ffff ffff ffff ffff ffff ffff ffff ffff
006fff0 ffff ffff ffff ffff ffff ffff ffff ffff
007fff0 ffff ffff ffff ffff ffff ffff ffff ffff
008fff0 ffff ffff ffff ffff ffff ffff ffff ffff
009fff0 ffff ffff ffff ffff ffff ffff ffff ffff
00afff0 ffff ffff ffff ffff ffff ffff ffff ffff
00bfff0 ffff ffff ffff ffff ffff ffff ffff ffff
00cfff0 ffff ffff ffff ffff ffff ffff ffff ffff
00dfff0 ffff ffff ffff ffff ffff ffff ffff ffff
00efff0 ffff ffff ffff ffff ffff ffff ffff ffff
00ffff0 ffff ffff ffff ffff ffff ffff ffff ffff
010fff0 ffff ffff ffff ffff ffff ffff ffff ffff
011fff0 ffff ffff ffff ffff ffff ffff ffff ffff
012fff0 ffff ffff ffff ffff ffff ffff ffff ffff
013fff0 ffff ffff ffff ffff ffff ffff ffff ffff
014fff0 ffff ffff ffff ffff ffff ffff ffff ffff
015fff0 ffff ffff ffff ffff ffff ffff ffff ffff
016fff0 ffff ffff ffff ffff ffff ffff ffff ffff
017fff0 ffff ffff ffff ffff ffff ffff ffff ffff
018fff0 ffff ffff ffff ffff ffff ffff ffff ffff
[...] and so on
kauedg
Re: Filesystem forensic image  [SOLVED]
Fri Feb 21, 2025 10:34 pm
Finally, me and a coworker found out how to extract the files from the "firmware" mtd5 partition. The partition has a YAFFS1 filesystem, with 1024 pages and 16 bytes spare bytes and inside it there is a SquashFS filesystem.
First, the 0xFF padding that happens every 0x10000 bytes must be removed. It can be done using the attached script "parse.py" (obviously, remove the .txt extension).
Second, the filesystem must be extracted using the "yaffs.py" script, which is a version of the repo https://github.com/devttys0/yaffshiv/ with some corrections and tweaks. These were the parameters that worked well for RouterOS 6.49.9 and 7.17.1:
$ python3 yaffs.py -o -f mtd5.dd.bin_parsed.bin -p 1024 -s 16 --endianess=big --dir yaffs_output -D 2>output
Third, the SquashFS will be in a file named 'bootimage' and can be extracted using binwalk. Probably this is mounted as a read-only filesystem and the contents extracted in the previous step are read/writable.
Hope this helps anyone in the future.
$ tree yaffs_output
yaffs_output
├── boot
│   └── VERSION
├── bootimage
├── lost+found
│   ├── addrs.dat
│   ├── addrs.idx
│   ├── ca.dat
│   ├── ca.idx
│   ├── ca_issued.dat
│   ├── ca_issued.idx
│   ├── client.dat
│   ├── client.idx
│   ├── client_options.dat
│   ├── client_options.idx
│   ├── conf
│   ├── config.dat
│   ├── config.idx
│   ├── devices.dat
│   ├── devices.idx
│   ├── devlist.dat
│   ├── devlist.idx
│   ├── devlist-member.dat
│   ├── devlist-member.idx
│   ├── duid.dat
│   ├── duid.idx
│   ├── ebt-filter.dat
│   ├── ebt-filter.idx
│   ├── ebt-nat.dat
│   ├── ebt-nat.idx
│   ├── epoch.dat
│   ├── epoch.idx
│   ├── filter.dat
│   ├── filter.idx
│   ├── filterin.dat
│   ├── filterin.idx
│   ├── filterout.dat
│   ├── filterout.idx
│   ├── identity.dat
│   ├── identity.idx
│   ├── iface.dat
│   ├── iface.idx
│   ├── ifcfg.dat
│   ├── ifcfg.idx
│   ├── ipt6-filter.dat
│   ├── ipt6-filter.idx
│   ├── ipt6-mangle.dat
│   ├── ipt6-mangle.idx
│   ├── ipt6-raw.dat
│   ├── ipt6-raw.idx
│   ├── ipt-filter.dat
│   ├── ipt-filter.idx
│   ├── ipt-mangle.dat
│   ├── ipt-mangle.idx
│   ├── ipt-nat.dat
│   ├── ipt-nat.idx
│   ├── ipt-raw.dat
│   ├── ipt-raw.idx
│   ├── lease.dat
│   ├── lease.idx
│   ├── main.dat
│   ├── main.idx
│   ├── modecfg.dat
│   ├── modecfg.idx
│   ├── module.dat
│   ├── module.idx
│   ├── peer.dat
│   ├── peer.idx
│   ├── peer_proposal.dat
│   ├── peer_proposal.idx
│   ├── plists.dat
│   ├── plists.idx
│   ├── policy.dat
│   ├── policy_group.dat
│   ├── policy_group.idx
│   ├── policy.idx
│   ├── prefs
│   ├── profile.dat
│   ├── profile.idx
│   ├── queuetypes.dat
│   ├── queuetypes.idx
│   ├── raw.dat
│   ├── raw.idx
│   ├── ripkey.dat
│   ├── ripkey.idx
│   ├── routes.dat
│   ├── routes.idx
│   ├── rule.dat
│   ├── rule.idx
│   ├── sainfo.dat
│   ├── sainfo.idx
│   ├── scep_client.dat
│   ├── scep_client.idx
│   ├── server.dat
│   ├── server.idx
│   ├── simplequeues.dat
│   ├── simplequeues.idx
│   ├── srvprof.dat
│   ├── srvprof.idx
│   ├── static.dat
│   ├── static.idx
│   ├── store
│   │   ├── ifaces.dat
│   │   ├── ifaces.idx
│   │   ├── queues.dat
│   │   └── queues.idx
│   ├── subnet.dat
│   ├── subnet.idx
│   ├── switch-acl-entries.dat
│   ├── switch-acl-entries.idx
│   ├── switch-config.dat
│   ├── switch-config.idx
│   ├── switch-ports.dat
│   ├── switch-ports.idx
│   ├── template.dat
│   ├── template.idx
│   ├── user.dat
│   ├── user.idx
│   ├── user_settings.dat
│   ├── user_settings.idx
│   ├── webprefs
│   ├── wgip.dat
│   └── wgip.idx
├── rw
│   ├── cm
│   │   ├── cert
│   │   ├── crl
│   │   ├── hash_sha1
│   │   ├── key
│   │   └── seed
│   ├── DEFCONF
│   ├── DEFCONF_CONFIRM -> /rw/defconf-custom
│   ├── defconf-custom
│   ├── disk
│   │   └── skins
│   ├── logs
│   ├── pckg -> /rw/disk
│   ├── REBOOT
│   ├── RESET
│   ├── rnd_seed
│   ├── rosmode.msg
│   ├── startcount
│   ├── store
│   │   ├── accfg.dat
│   │   ├── accfg.idx
│   │   ├── bfd
│   │   ├── bridgeports.dat
│   │   ├── bridgeports.idx
│   │   ├── bserv.dat
│   │   ├── bserv.idx
│   │   ├── cchst2
│   │   ├── ccusq
│   │   ├── cerm.dat
│   │   ├── cerm.idx
│   │   ├── cert
│   │   ├── cfg.0000
│   │   ├── cfg.0004
│   │   ├── cloud.dat
│   │   ├── cloud.idx
│   │   ├── cmanifacecfg.dat
│   │   ├── cmanifacecfg.idx
│   │   ├── command
│   │   ├── detnet-settings.dat
│   │   ├── detnet-settings.idx
│   │   ├── dhcp
│   │   │   └── server
│   │   ├── echosave
│   │   ├── graphing
│   │   │   └── store
│   │   ├── group.dat
│   │   ├── group.idx
│   │   ├── hotspot
│   │   ├── ippool.dat
│   │   ├── ippool.idx
│   │   ├── ipsec
│   │   ├── l2tp
│   │   ├── led
│   │   ├── leds.dat
│   │   ├── leds.idx
│   │   ├── led_triggers.dat
│   │   ├── led_triggers.idx
│   │   ├── log-actions.dat
│   │   ├── log-actions.idx
│   │   ├── log-rules.dat
│   │   ├── log-rules.idx
│   │   ├── mactel-settings.dat
│   │   ├── mactel-settings.idx
│   │   ├── mode_button.dat
│   │   ├── mode_button.idx
│   │   ├── mpls
│   │   ├── mproxy-settings.dat
│   │   ├── mproxy-settings.idx
│   │   ├── net
│   │   ├── ntp.dat
│   │   ├── ntp.idx
│   │   ├── ovpn
│   │   ├── ppp
│   │   ├── pptp
│   │   ├── resolver
│   │   │   └── config.idx
│   │   ├── rip
│   │   ├── routing
│   │   ├── rps.dat
│   │   ├── rps.idx
│   │   ├── serial-login.dat
│   │   ├── serial-login.idx
│   │   ├── sermgr.dat
│   │   ├── sermgr.idx
│   │   ├── snmp-communities.dat
│   │   ├── snmp-communities.idx
│   │   ├── snmpd.dat
│   │   ├── snmpd.idx
│   │   ├── ssh
│   │   ├── ssh-forwarding.dat
│   │   ├── ssh-forwarding.idx
│   │   ├── sstp
│   │   ├── system.dat
│   │   ├── system.idx
│   │   ├── unicl
│   │   ├── user
│   │   ├── user.dat
│   │   ├── user.idx
│   │   ├── wirelessccl.dat
│   │   ├── wirelessccl.idx
│   │   ├── wirelessch.dat
│   │   ├── wirelessch.idx
│   │   ├── wireless.dat
│   │   ├── wireless.idx
│   │   ├── wirelessprofile.dat
│   │   ├── wirelessprofile.idx
│   │   ├── wlcacl.dat
│   │   ├── wlcacl.idx
│   │   ├── wlccfgrule.dat
│   │   ├── wlccfgrule.idx
│   │   ├── wtpcfg.dat
│   │   └── wtpcfg.idx
│   ├── tmp
│   └── vstore
├── SHOW_LICENSE
├── UPGRADEBOOTER
├── UPGRADED
└── var
    └── pdb
        ├── ipv6
        │   └── disabled
        ├── routeros-smips
        │   └── image -> /flash/bootimage
        └── system
47 directories, 202 files
jaclaz
Sat Feb 22, 2025 12:30 am
Happy you succeeded :D
