Valerio5000
Auto Media Share USB not disable
Sun Jan 19, 2025 6:51 pm
I noticed perhaps a bug present in ROS 7.17. I don't know if the previous versions also suffer from it because only today I inserted a USB stick into my HEX. I inserted a 16GB USB stick formatted in Ext4 to use it with SMB and there are no particular problems. However, I noticed that the "Auto SMB Share" and "Auto Media Share" items were active, which I proceeded to deactivate and restart ROS. Despite this, I have a dynamic sharing of "usb1" that I cannot delete and under My Computer I always see the Media sharing (DLNA?). I also tried to restart the PC but nothing....Bug?
mszru
Re: Auto Media Share USB not disable
Sun Jan 19, 2025 8:42 pm
That didn't work in the previous stable version either. See the following topic: viewtopic.php?t=212920
Valerio5000
Tue Jan 21, 2025 5:45 pm
Dynamic sharing following the discussion you linked has actually disappeared but I still have the "Hex_MediaUSB" icon in My Computer of all clients in LAN....
mszru
Tue Jan 21, 2025 6:36 pm
Can you try similar command:
/disk/set usb1 media-sharing=no
Valerio5000
Wed Jan 22, 2025 3:41 pm
solved!
but have you reported it to MK support? Otherwise I create a ticket with them to inform them of this, it seems that these graphic settings do not work.
mszru
Wed Jan 22, 2025 4:02 pm
solved!
Glad it helped. No, I haven't reported it. Please create a ticket.
