btebiplob
How to delete Dude servers old data?
Wed Jan 22, 2025 7:29 pm
Hello Tech people,
In our network we use dude for a long time and use SNMP for OLT and Switches so that every interfaces has long time data but we don't need that. In this time unable to clear.
Router Model: CCR1009-8G-1S-1S+
Amm0
Re: How to delete Dude servers old data?
Wed Jan 22, 2025 8:14 pm
IDK for sure it will remove old data... but in the "Settings" (on top tool bar), under "Charts", there are settings to control retention. By default, it's 10 years. Something to try at least....
But it does prune the data, so year back data should be pretty minimal in terms of storage relative to most disks. So I'm not sure it save that much space... But I guess if you really do have years back of the data, the Chart UI always require adjustment....
