M1ASR
Issue Port Forwarding UDP
Fri Jan 24, 2025 3:53 pm
Good afternoon,
I have created a dstnat port forward rule - port 4569 UDP from WAN to 192.168.0.45 on my router. I can see the UDP packet coming in, but it's not port forwarding to my LAN port.
I'm new to this router and haven't had issues with other routers,
Any pointers appreciated.
anav
Re: Issue Port Forwarding UDP
Fri Jan 24, 2025 6:04 pm
/export file=anynameyouwish (minus router serial number, any public WANIP information vpn keys etc.)
using notepad++ to open and edit and post here, and use the code tags above, on the same line as Bold and Underline the black square with white square brackets.
