actomobile
DHCP Relay VS Bridge
Tue Feb 04, 2025 6:20 pm
I have a network setup with multiple buildings, each with its own router connected using fiber cable to the main router. Each router has its own DHCP server. I want to change it so that there is only one DHCP server in the main router, with dynamic VLAN assignment from RADIUS server.
To get users obtain IP address from the main DHCP server I can either use DHCP relay or I can just bridge all the interfaces and VLANs.
Which method works best in this case?
Which one is more secure?
I think using bridge is much simpler, but maybe there's a catch?
Please advise me on this. Thanks.
mkx
Re: DHCP Relay VS Bridge  [SOLVED]
Tue Feb 04, 2025 6:59 pm
If you can use one VLAN per building ... and bring them to main router, then this would give you most flexibility ... building routers would become switches (bridges).
With bridge there might be more traffic on the connection towards main router (broadcasts mainly) then with routed traffic. If capacity of that/those connection(s) is not a limiting factor, then I'd go with bridge solution.
actomobile
Wed Feb 05, 2025 5:37 am
I forgot to add that users will get dynamic VLAN assignemt from RADIUS server. So VLAN for user devices will be separated from access points, routers, etc.
mkx
Wed Feb 05, 2025 10:30 am
Which means that VLANs are in the mix already. IMO another point in favour of VLAN-enabled bridges (and against DHCP relay).
actomobile
Mon Feb 10, 2025 4:43 am
I see. Then I will use the bridge method. Thank you
