manuschiller
Starting with 10Gbe at home - CRS304-4XG-IN as option?
Fri Feb 21, 2025 8:58 am
currently, I am very happy with my CRS326-24G-2S+RM. However, I'd like to upgrade some connections to faster speeds and thinking about how to extend the setup properly.
What I want:
  • mikrotik
  • connect the following devices with speeds >= 5Gbe: my 3 Accesspoints (currently WIFI 6 AX, but should be upgradable to WIFI 7), my NAS and my home-server.
  • 10GBASE-T (rj45), since the wirings in the house can not be easily changed
If I'd get the CRS304-4XG-IN, I could imagine the following setup:
  • CRS326-24G-2S+RM as main switch
  • CRS326 + Transceiver to SFP+ <-> NAS
  • CRS326 + Transceiver to SFP+ <-> CRS304-4XG-IN
  • CRS304-4XG-IN <-> 3 Access Points
but this way, I am missing one port for my home-server :(
Should I get two CRS304-4XG-IN (~360 €) - is there a better alternative without jumping in prices like upgrading to the CRS312-4C+8XG-RM?
elbob2002
Re: Starting with 10Gbe at home - CRS304-4XG-IN as option?
Fri Feb 21, 2025 9:41 am
I use a CRS309-1G-8S+ as my core switch.
It does have SFP+ ports but you can always use an RJ45 SFP+ converter. The only downside to that is that some of the cheaper ones might run hot.
mbovenka
Fri Feb 21, 2025 11:57 am
I have the same setup, and yes, 10GBASE-T does run hot. I used S+RJ10 modules and they ran to 100 degrees C in summer. I gave up in the end and pulled fiber (OM3 multimode) with 10GBASE-SR modules. Much cooler. But the OP does not have that luxury probably.
manuschiller
Sat Feb 22, 2025 10:45 am
unfortunately changing the wiring in the house is no option right now.
6-8 Ports + an SFP+ uplink (like a hypothetical CRS-304-6XG-2S-IN or CRS-304-8XG-2S-IN) would be a great fit for me right now.
The only thing that comes close is the CRS312-4C+8XG-RM, which is more than five years old.
Is it likely that mikrotik will introduce new 10g RJ45 devices in that range soon (like at MUM in March 2025)?
Or anything new in the 2.5GB entry level class?
magchiel
Sat Feb 22, 2025 12:42 pm
The CRS312 is I think still a very capable switch (I have one running as a core switch) and I wouldn't be hesitant buying it now if you need ports than the CRS304 offers AND you have a use case for L3HW. For just a mid-sized 10GbE-T L2 switch with SFP+ for stacking, I have more reservations on its value for money (although I admit the market isn't big, it seems >40% more expensive than some alternatives, at least here in Europe). Another thing to keep in mind in a domestic environment, is that the CRS312 is NOT a quiet switch.
Using a 10GbE-T SFP+ module here and there shouldn't be a problem, as long as you don't plan on filling up an entire switch with the 10GbE-T modules side-by-side. I use two 10GbE-T and two 1GbE-T in a CRS309 (like @elbob2002 above, I have one running as a core switch in another location) without a problem. Unfortunately, if you're running a copper-dominant infrastructure, with the added cost for modules it won't be much cheaper than the CRS312 (albeit more quiet).
Depending your home climate control, my concern would be having two 10GbE-T modules side-by-side in the CRS326 without some forced cooling during summer. So I'd opt for a solution where you can at least use a DAC or (if you need longer runs) optics for stacking the switches.
I don't know if all the equipment is in separate rooms and dependant on existing copper, but if your NAS and/or home server would allow swapping to SFP+ NICs, but that would make a better case for CRS309 as a core/aggregation switch, a 10GbE SFP+ module connected to the CRS304 for your access points and a DAC to stack the CRS309 with the CRS326 as an access switch to the rest of the cabled network.
Alternatively settle for 2.5Gbps for your access points through a CRS310-8G+2S+. Running one of those here as well as a leaf switch.
nereith
Sun Feb 23, 2025 7:56 am
I am using a CRS309 as my main switch. On hindsight, seems like it was a great decision.
-Supports L3 HW
-Supports newer 10GBaseT modules such as the Ubiquiti UACC-CM-RJ45-MG or Fibermall SFP-10G-TS80 (both Broadcom chipsets) which are more efficient than the Marvell chipsets (eg Mikrotik S+RJ10). Look for chipsets that support 10G @ 80m/100m instead of just 30m.
-Supports 2500BaseX - useful for modules like the MagicSFP 2.5G
-Flexibility to use DAC/Fiber
tryrtryrtryrt
Mon Feb 24, 2025 4:52 am
Before going with CRS304-4XG-IN instead of CRS309 study their offloading capabilities. CRS304 lacks a lot compared to CRS309, IMHO.
The main disadvantage of CRS309 compared to CRS304 if you intend to use it as more than a switch (i.e. lightweight containers maybe) is that it's ARM 32-bit instead of ARM64.
magchiel
Mon Feb 24, 2025 8:30 am
Forget containers in either of them. There just isn't enough storage, nor sufficient RAM for a Ramdisk.
