EdPa
v7.18.2 [stable] is released!
Mon Feb 24, 2025 4:31 pm
RouterOS version 7.18 have been released in the "v7 stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.18.2 (2025-Mar-11 13:59):
*) console - fixed issue with file-name completion (introduced in v7.18);
*) container - fixed repository name handling to prevent redirect issues when basic authentication is used;
*) lte - additional fixes for eSIM management support;
*) lte - AT modems, improved redialing when modem lost connectivity without notifying host about APN status change;
*) netinstall - fixed socket reset (introduced in v7.18);
*) queue - fixed system failure when CAKE kind queue was configured but queue type definition does not exist anymore (introduced in v7.18);
*) wifi - improved stability for wifi interfaces;
*) winbox - improve graphing efficiency when communicating with WinBox;
What's new in 7.18.1 (2025-Feb-28 13:31):
*) bridge - improved stability in case of configuration error (introduced in v7.15);
*) bridge - show warning instead of causing error when using multicast MAC as admin-mac (introduced in v7.17);
*) cloud - fixed issues when BTH is toggled fast between enable/disable;
*) cloud - improved "BTH Files" web page design;
*) console - fixed issue with files when using scripts (introduced in v7.18);
*) console - improved file add/remove process stability;
*) dhcpv6-relay - clear saved routes on DHCP release;
*) dhcpv6-relay - show client address;
*) disk - add "sector-size" property in print detail;
*) disk - improved stability when formatting crypted partitions;
*) l3hw - remove VLAN tag before VXLAN encapsulation (fixes pvid behavior for bridged VXLAN);
*) lte - fixed modem recovery after firmware upgrade for R11e-LTE modem;
*) lte - fixed Router Advertisement processing issue for AT modems when an APN with "ip-type=ipv6" was configured;
*) ovpn - disable hardware accelerator for GCM on MMIPS CPUs (introduced in v7.18);
*) poe-out - fixed health showing 0V voltage when using PoE-in for RB960;
*) poe-out - upgraded firmware for 802.3at/bt PSE controlled boards (the update will cause brief power interruption to PoE-out interfaces);
*) route - show BGP session name instead of cache-id;
*) switch - improved stability when enabling IGMP snooping with VXLAN (introduced in v7.18);
*) system - improved internal "flash/" prefix handling for different file path related settings;
*) winbox - fixed missing SMB client on non-ROSE devices;
What's new in 7.18 (2025-Feb-24 10:47):
*) 60ghz - improved system stability;
*) bgp - fixed certain affinity options not working properly;
*) bgp - improved system stability when printing BGP advertisements;
*) bgp - make NO_ADVERTISE, NO_EXPORT, NO_PEER communities work;
*) bond - added transmit hash policies for encapsulated traffic;
*) bridge - added MLAG heartbeat property;
*) bridge - avoid duplicate VLAN entries with dynamic wifi VLANs;
*) bridge - do not reset MLAG peer port on heartbeat timeout (log warning instead);
*) bridge - fixed endless MAC update loop (introduced in v7.17);
*) bridge - fixed missing S flag on interface configuration changes;
*) bridge - improved stability when using MLAG with MSTP (introduced in v7.17);
*) bridge - improvements to MLAG host table updates;
*) bridge - process more DHCP message types (decline, NAK, inform);
*) bridge - removed controller-bridge (CB) and port-extender (PE) support;
*) bridge - show VXLAN remote-ip in host table;
*) btest - allow limiting access to server by IP address;
*) certificate - fixed localized text conversion to UTF-8 on certificate creation;
*) chr - fixed limited upgrades for expired instances;
*) chr/x86 - added network driver for Huawei SP570/580 NIC;
*) chr/x86 - fixed error message on bootup;
*) chr/x86 - fixed GRE issues with ice network driver;
*) chr/x86 - Realtek r8169 updated driver;
*) cloud - added "Back To Home Files" feature;
*) cloud,bth - use in-interface matcher for masquerade rule;
*) console - added dsv.remap to :serialize command to unpack array of maps from print as-value;
*) console - added file-name parameter to :serialize;
*) console - allow ISO timezone format in :totime command;
*) console - allow tab as dsv delimiter;
*) console - allow to toggle script error logging with "/console settings log-script-errors";
*) console - do not autocomplete arguments when match is both exact and ambiguous;
*) console - do not show numbering in print follow;
*) console - fixed "get" and "proplist" for certain settings;
*) console - fixed issue where ping command displays two lines at the same time;
*) console - fixed issue with disappearing global variable;
*) console - implement scriptable safe-mode commands and safe-mode handler;
*) console - improved hints;
*) console - log errors within scripts to the system log;
*) console - make non-pseudo terminals work with imports;
*) console - put !empty sentence when API query returns nothing;
*) console - renamed "back-to-home-users" to "back-to-home-user";
*) container - add default registry-url=https: //lscr.io;
*) container - allow HTTP redirects when accessing container registry;
*) container - allow specifying registry using remote-image property;
*) container - improved image arch choice;
*) container - use parent directory of container root-dir for unpack by default, so that container layer files are downloaded directly on target disk;
*) defconf - added IPv6 FastTrack configuration;
*) device-mode - do not allow changing CPU frequency if "routerboard" is not allowed by device mode (introduced in v7.17);
*) device-mode - fixed feature and mode update via power-reset on PPC devices;
*) dhcpv4-client - allow selecting to which routing tables add default route;
*) dhcpv4-client - fixed default option export output;
*) dhcpv4-server - fixed "active-mac-address" update when client has changed MAC address;
*) dhcpv4-server - fixed framed-route removal;
*) dhcpv4-server - fixed lease assigning when server address is not bind to server interface (introduced in v7.17);
*) dhcpv6-client - added "validate-server-duid" option;
*) dhcpv6-client - allow specifying custom DUID;
*) dhcpv6-client - do not run script on prefix renewal;
*) dhcpv6-relay - added option to create routes for bindings passing through relay;
*) dhcpv6-server - respond to client in case of RADIUS reject;
*) discovery - advertise IPv6 capabilities based on "Disable IPv6" global setting;
*) discovery - improved stability during configuration changes;
*) discovery - report actual PSE power-pair with LLDP;
*) discovery - use power-via-mdi-short LLDP TLV only on pse-type1 802.3af;
*) disk - add disk trim command (/disk format-drive diskx file-system=trim);
*) disk - allow to add swap space without container package;
*) disk - allow to set only type=raid devices as raid-master;
*) disk - cleanup raid members mountpoint, improve default name of file base block-device;
*) disk - do not allow adding device in raid when major settings mismatch in superblock and config;
*) disk - do not allow configuring empty slot as raid member;
*) disk - fix detecting disks on virtual machines;
*) disk - fixed removing device from raid while resyncing;
*) disk - fixed setting up dependent devices when file-based block-device becomes available;
*) disk - fixed showing free space on tmpfs (introduced in v7.17);
*) disk - improved stability;
*) disk - improved system stability when SMB interface list is used (introduced in v7.17);
*) disk - mount multi-device btrfs filesystems more reliably at startup;
*) disk - set non-empty fs label when formatting by default;
*) dns - do not show warning messages for DNS static entries when they are not needed;
*) ethernet - fixed issue with default-names for RB4011, RB1100Dx4, RB800 devices;
*) ethernet - fixed link-down on startup for ARM64 devices (introduced in v7.16);
*) ethernet - improved link speed reporting on 2.5G-baseT and 10Gbase-T ports;
*) fetch - added "http-max-redirect-count" parameter, allows to follow redirects;
*) fetch - do not require "content-length" or "transfer-encoding" for HTTP;
*) file - added "recursive" and "relative" parameters to "/file/print" for use in conjunction with "path" parameter;
*) file - allow printing specific directories via path parameter;
*) file - improved handling of filesystems with many files;
*) firewall - allow in-interface/in-bridge-port/in-bridge matching in postrouting chains;
*) firewall - fixed incorrectly inverted hotspot value configuration;
*) firewall - increased maximum connection tracking entry count based on device total RAM size;
*) hotspot - fixed an issue where extra "flash/" is added to html-directory for devices with flash folders (introduced in v7.17);
*) igmp-proxy - fixed multicast routing after upstream interface flaps (introduced in v7.17);
*) iot - added new "iot-bt-extra" package for ARM, ARM64 which enables use of USB Bluetooth adapters (LE 4.0+);
*) iot - improvements to LoRa logging and stability;
*) iot - limited MQTT payload size to 32 KB;
*) ip - added support for /31 address;
*) ippool - added pool usage statistics;
*) ipsec - added hardware acceleration support for hEX refresh;
*) ipsec - fixed chacha20 poly1305 proposal;
*) ipsec - fixed installed SAs update process when SAs are removed;
*) ipv6 - added ability to disable dynamic IPv6 LL address generation on non-VPN interfaces;
*) ipv6 - added FastTrack support;
*) ipv6 - added routing FastPath support (enabled by default);
*) ipv6 - added support for neighbor removal and static entries;
*) ipv6 - fixed configuration loss due to conflicting settings after upgrade (introduced in v7.17);
*) l2tp - added IPv6 FastPath support;
*) l3hw - added initial HW offloading for VXLAN on compatible switches;
*) l3hw - added neigh-dump-retries property;
*) l3hw - fixed /32 (IPv6 /128) route offloading when using interface as gateway;
*) l3hw - fixed partial route offloading for 98DX224S, 98DX226S, 98DX3236 switches;
*) l3hw - respect interface specifier (%) when matching a gateway;
*) log - added CEF format support for remote logging;
*) log - added option to select TCP or UDP for remote logging;
*) lte - added at-chat support for EC21EU;
*) lte - added basic support for Quectel RG255C-GL modem in "at+qcfg="usbnet",0" USB composition;
*) lte - added confirmation-code parameter for eSIM provisioning;
*) lte - added initial eSIM management support;
*) lte - fixed cases where the MBIM dialer could get stuck;
*) lte - fixed Huawei ME909s-120 support;
*) lte - fixed interface recovery in mixed multiapn setup for MBIM modems;
*) lte - fixed missing 5G info for "/interface lte print" command;
*) lte - fixed missing IPv6 prefix advertisement on renamed LTE interfaces;
*) lte - fixed prolonged reboots on Chateau 5G ax;
*) lte - fixed SIM slot initialization with multi-APN setups;
*) lte - improved automatic link recovery and modem redial functions;
*) lte - improved initialization for external USB modems;
*) lte - lte monitor, show CQI when modem reports it as 0 - undetectable, no RX/down-link resource block assigned to modem by provider;
*) lte - R11eL-EC200A-EU fixed online firmware upgrade and added support for firmware update from local file;
*) lte - R11eL-EC200A-EU improved failed connection handling and recovery;
*) lte - reduce modem initialization time for R11e-LTE-US;
*) lte - reduced SIM slot switchover time for modems with AT control channel (except R11e-LTE);
*) lte - removed nonexistent CQI reading for EC200A-EU modem;
*) net - added initial support for automatic multicast tunneling (AMT) interface;
*) netinstall - try to re-create socket if link status changes;
*) netinstall-cli - fixed DHCP magic cookie;
*) ospf - fixed DN bit not being set;
*) ospfv3 - fixed ignored metric for intra-area routes;
*) ovpn - added requirement for server name when exporting configuration;
*) ovpn - disable hardware accelerator for GCM on Alpine CPUs (introduced in v7.17);
*) ovpn-client - added 1000 character limit for password;
*) pimsm - fixed incorrect neighbor entry when using lo interface;
*) poe-out - added "power-pair" info to poe-out monitor (CLI only);
*) poe-out - added console hints;
*) poe-out - added new modes "forced-on-a" and "forced-on-bt" (CLI only);
*) port - improved handling of USB device plug/unplug events;
*) ppc - fixed HW encryption (introduced in v7.17);
*) ppp - add support for configuration of upload/download queue types in profile;
*) ppp - added support for random UDP source ports;
*) ppp - fixed setting loss when adding new ppp-client interface for BG77 modem from CLI;
*) ppp - properly cleanup failed inactive sessions on pppoe-server;
*) ptp - do not send packets on STP blocked ports;
*) ptp - improved system stability;
*) qos-hw - fixed global buffer limits for 98CX8410 switch;
*) queue - improved system stability when many simple queues are added (introduced in v7.17);
*) queue - improved system stability;
*) queue - prevent CAKE bandwidth config from potentially causing lost connectivity to a device;
*) resolver - fixed static FQDN resolving (introduced in v7.17);
*) rip - fixed visibility of added key-chains in interface-template;
*) rose-storage - add btrfs filesystem add-device/remove-device/replace-device/replace-cancel commands to add/remove/replace disks to/from a live filesystem;
*) rose-storage - add btrfs filesystem balance-start/cancel commands;
*) rose-storage - add btrfs filesystem scrub-start, scrub-cancel commands (CLI only);
*) rose-storage - add btrfs transfers, supports send/receive into/from file for transferring subvolumes across btrfs filesystems;
*) rose-storage - add support to add/remove btrfs subvolumes/snapshots;
*) rose-storage - added support for advanced btrfs features: multi-disk support, subvolumes, snapshots, subvolume send/receive, data/metadata profiles, compression, etc;
*) rose-storage - allow to separately mount any btrfs subvolumes;
*) rose-storage - fixes for btrfs server;
*) rose-storage - update rsync to 3.4.1;
*) rose-storage,ssh - support btrfs send/receive over ssh;
*) route - added /ip/route/check tool;
*) route - added subnet length validation on route add;
*) route - do not use disabled addresses when selecting routing id;
*) route - fixed busy loops (route lockups);
*) route - fixed incorrect H flag usage;
*) route - improved stability when polling static routes via SNMP;
*) route - properly resolve imported BGP VPN routes;
*) routerboot - disable packet switching during etherboot for hEX refresh ("/system routerboard upgrade" required);
*) routerboot - improved stability for IPQ8072 ("/system routerboard upgrade" required);
*) routing-filter - improved stability when using large address lists (>5000);
*) routing-filter - improved usage of quotes in filter rules;
*) sfp - fixed missing "1G-baseX" supported rate for NetMetal ac2 and hEX S devices;
*) sfp - improved linking with certain QSFP modules on CRS354 devices;
*) sfp - improved system stability with some GPON modules for CCR2004 and CCR2116 devices;
*) sfp,qsfp - improved initialization and linking;
*) smb - fixed connection issues with clients using older SMB versions (introduced in v7.17);
*) smb - fixes for SMB server;
*) smb - improved system stability;
*) snmp - added "mtxrAlarmSocketStatus" OID to MIKROTIK-MIB;
*) snmp - added disk serial number through description field;
*) snmp - sort disk list and assign correct disk types;
*) ssh - improved channel resumption after rekey and eof handling;
*) supout - added IPv6 settings section;
*) supout - added per CPU load information;
*) switch - allow entering IPv6 netmask for switch rules (CLI only);
*) switch - fixed dynamic switch rules created by dot1x server (introduced in v7.17);
*) switch - fixed issues with inactive hardware-offloaded bond ports;
*) switch - improved egress-rate on QSFP28 ports;
*) switch - improved system stability for CRS304 switch;
*) switch - improvements to certain switch operations (port disable, shaper and switch initialization);
*) system - added option to list and install available packages (after using "check-for-updates");
*) system - do not allow to install multiple wireless driver packages at the same time;
*) system - do not cause unnecessary sector writes on check-for-updates;
*) system - enable "ipv6" package on RouterOS v6 downgrade if IPv6 is enabled;
*) system - fixed a potential memory leak that occurred when resetting states after an error;
*) system - force time to be at least at package build time minus 1d;
*) system - improved HTTPS speed;
*) system - improved stability on busy systems;
*) system,arm - automatically increase boot part size on upgrade or netinstall (fixed upgrade failed due to a lack of space on kernel disk/partition);
*) tile - improved system stability;
*) traceroute - added "too many hops" error when max-hops are reached;
*) traceroute - limit max-hops maximum value to 255;
*) user - improved authentication procedure when RADIUS is not used;
*) vxlan - added disable option for VTEPs;
*) vxlan - added IPv6 FastPath support;
*) vxlan - added option to dynamically bridge interface and port settings (hw, pvid);
*) vxlan - added TTL property;
*) vxlan - changed default port to 4789;
*) vxlan - fixed unset for "group" and "interface" properties;
*) vxlan - replaced the "inherit" with "auto" option for dont-fragment property (new default);
*) webfig - added confirmation when quitting in Safe Mode;
*) webfig - do not reload form when failed to create new object;
*) webfig - fixed "TCP Flags" property when inverted flags are set in console;
*) webfig - fixed datetime setting under certain menus;
*) webfig - fixed displaying passwords;
*) webfig - fixed Switch/Ports menu not showing correctly;
*) webfig - hide certificate information in IP Services menu when not applicable;
*) webfig - remember expand/fold state;
*) wifi - added max-clients parameter;
*) wifi - avoid excessive re-transmission of SA Query action frames;
*) wifi - fix issue which made it possible for multiple concurrent WPA3 authentications to interfere with each other;
*) wifi - implement steering parameters to delay probe responses to clients in the 2.4GHz band;
*) wifi - log a warning when a client requests power save mode during association as this may prevent successful connection establishment;
*) wifi - re-word the "can't find PMKSA" log message to "no cached PMK";
*) wifi - try to authenticate client as non-FT client if it provides incomplete set of FT parameters;
*) wifi-qcom - fix reporting of radio minimum antenna gain for hAP ax^2;
*) wifi-qcom - prevent AP from transmitting broadcast data unencrypted during authentication of first client;
*) winbox - added "Copy to Provisioning" button under "WiFi/Radios" menu;
*) winbox - added "Last Logged In/Out" and "Times Matched" properties under "WiFi/Access List" menu;
*) winbox - added "Reset Alert" button under "IP/DHCP Server/Alerts" menu;
*) winbox - added L3HW Advanced and Monitor;
*) winbox - added missing options under "System/Disk" menu;
*) winbox - added TCP settings under "Tools/Traffic Generator/Packet Templates" menu;
*) winbox - do not show 0 Tx/Rx rate under "WiFi/Registration" menu when values are not known;
*) winbox - do not show LTE "Antenna Scan" button on devices that do not support it;
*) winbox - fixed locked input fields when creating new certificate template;
*) winbox - show LTE "CA Band" field only when CA info is available;
*) winbox - show warning messages for static DNS entries;
*) x86 - fixed "unsupported speed" warning;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
rextended
Re: v7.18 [stable] is released!
Mon Feb 24, 2025 4:43 pm
To add default IPv6 FastTrack when updating from ANY v7 previous version, just paste this into the terminal
(barring arbitrary changes to the default configuration already made).
New devices netinstalled with beta4 and later, or reset with default configuration on beta4 and later, are already ready.
enable default IPv6 FastTrack code
/ipv6 fire filter
remove [find where comment="defconf: fasttrack6"]
add chain=forward action=fasttrack-connection connection-state=established,related comment="defconf: fasttrack6"
:local idone [find where comment="defconf: fasttrack6"]
:local idtwo [find where comment="defconf: accept established,related,untracked" and chain=forward]
:put $idone
:put $idtwo
move $idone destination=$idtwo
For full default firewall rules:
viewtopic.php?p=1124805#p856824
maisondasilva
Mon Feb 24, 2025 4:53 pm
Great release Thank you Mikrotik Team
grusu
Mon Feb 24, 2025 5:02 pm
Regarding smb client: cli settings are in the main package but the settings do not appear in winbox unless you install rose-storage or try to copy an existing configuration.
oreggin
Mon Feb 24, 2025 5:38 pm
Do I see right some of RC2 chages are skipped?
$ diff -ruN 7.18rc2.sort 7.18.sort | grep -P '^[\-+]'
--- 7.18rc2.sort	2025-02-24 16:34:05.762863405 +0100
+++ 7.18.sort	2025-02-24 16:31:51.441714374 +0100
-*) fetch - fixed IPv6 handling in URL (introduced in v7.18beta2);
-*) file - fixed missing meta information from special files such as packages (introduced in v7.18beta2);
-*) file - hide store directories, such as container (introduced in v7.18beta2);
-*) lte - fixed R11eL-EC200A-EU modem RAT mode selection (introduced in v7.18beta2);
-*) lte - fix R11e-4G modem initialization (introduced in v7.18beta4);
-*) poe-out - added new modes "forced-on-a" and "forced-on-bt", where old "forced-on" mean "forced-on-bt" (CLI only);
+*) poe-out - added new modes "forced-on-a" and "forced-on-bt" (CLI only);
-*) poe-out - fixed invalid poe-in status detection for RB5009 (introduced in v7.18beta2);
-*) poe-out - fixed PoE-out not working on first boot after upgrade for CRS354 (introduced in v7.18beta2);
-*) qos-hw - fixed wred-threshold (introduced in v7.18beta2);
-*) wifi-qcom - fixed potentially lowered throughput for station interfaces if channel.width property is set (introduced in v7.18beta2);
-*) winbox - fixed usb power-reset bus selection for RB924iR-2nD-BT5&BG77 (introduced in v7.18beta2);
anav
Well, I'm glad you're working on it so hard.
+1 - I can just feel zerotrust cloudflare tunnel, in an options package, is right around the corner. ;-), and of course amnezia wireguard in an options package.
buset1974
Mon Feb 24, 2025 5:45 pm
I can't wait whatsnew in 7.19
eworm
I think they skipped everything introduced and fixed within the same development cycle.
strods
Mon Feb 24, 2025 5:53 pm
Stable release changelog has always been a list of changes since previous stable - bugs introduced and resolved within beta/rc are not in this list.
ech1965
Mon Feb 24, 2025 6:12 pm
Would be very useful to have this changelog present in the last post before locking the rc thread. I agree it should not pollute the main release topic.
rextended
Mon Feb 24, 2025 6:19 pm
As it should be.
infabo
Mon Feb 24, 2025 6:20 pm
This release cycle was short. Thank you Mikrotik! Can't wait to see IPv6 FastTrack in action.
Chaosphere64
Mon Feb 24, 2025 6:32 pm
1.) I keep getting the attached error message, even after numerous reboots. Why is that and how can I get rid of it?
2.) How is IPv6 fast tracking enabled?
pe1chl
Mon Feb 24, 2025 6:33 pm
It would be nice when new bugs introduced in a stable release would be added to the changelog (as a separate section) once they become known, so it is easier to watch for them in later releases to see if they have been fixed.
(and also to know beforehand that it is better to wait, e.g. when some functionality is critical for you)
nmt1900
Mon Feb 24, 2025 6:43 pm
It would be possible if Mikrotik had transparency level of any other vendor which is able to keep a record of known issues and would publish them as a part of release notes. Without that we have no way to know the real state of things what comes to development...
jfim88
Mon Feb 24, 2025 6:45 pm
Hope that 7.19 comes with a fix for SUP-152693 after several months of waiting (IPTV cuts/pixelations with Movistar Spain)
fischerdouglas
Mon Feb 24, 2025 6:58 pm
They've gone through all the bugs and broken features with a bulldozer.
That's it! Now they can release RDS with 7.18 as a factory default, meeting the pressure from the product and marketing teams.
Who knows, maybe after this they'll go back to focusing at least a little on Routing and Switching.
vivoras
Mon Feb 24, 2025 7:03 pm
After updating several devices, I see that this update automatically installs extra packages that were not installed on the router before the update?
holvoetn
Mon Feb 24, 2025 7:04 pm
Like ?
Coming from which version ?
If coming from pre-7.13, it's normal to see wireless appearing on crs devices ( normal as in: it shouldn't but it's consistent)
anav
Mon Feb 24, 2025 7:15 pm
holvoe, can you comment on the wifi changes, good bad ugly??
optio
With 16Mb flash device you can only watch new release notes and cry :)
$ stat --format="%n: %s" *
container-7.16.2-arm.npk: 98449
routeros-7.16.2-arm.npk: 11608772
wifi-qcom-ac-7.16.2-arm.npk: 2740369
= 14447590 bytes
container-7.18-arm.npk: 118929B
routeros-7.18-arm.npk: 12076474B
wifi-qcom-ac-7.18-arm.npk: 2744465B
= 14939868 bytes
14939868 - 14447590 = 492278 bytes (480.74 KiB)
Free space after 7.16.2 netinstall with imported config (not backup):
free-hdd-space: 396.0KiB
guipoletto
Mon Feb 24, 2025 7:16 pm
No, this is just spectacular bad communication from Mikrotik
In previous releases, "greyed" packages meant "the .npk is stored locally in flash, but not loaded at boot" (status = "disabled")
To remove them and free flash space, one would perform the action "uninstall"
from 7.18, all possible available packages are listed in greyed-out form, to be fetched "automagically" from "the clouds" if one selects "action=install"
It does not necessarily mean (as was once true), that there is a kludge of .npk 's in the local storage
vivoras
Mon Feb 24, 2025 7:26 pm
Thanks for the clarification. How do we know which packages are locally hosted and disabled? I have selected the greyed out packages and after uninstalling and restarting the router they have disappeared from the list. In The Dude they also appeared as installed (That's why I noticed the "error").
wrkq
Mon Feb 24, 2025 7:31 pm
Depends which packages you've seen.
The new feature from 7.18 it works like this:
* After reboot, the list of packages contains only what is installed.
* After you run the "check online for updates" option, it not only tells you if ROS can be upgraded, but downloads full list of package names and shows them grayed out with "XA" flags (disabled, available for download).
* If you try to enable one of those, it gets downloaded.
If you saw packages with just "X" disabled flag, not "XA", those were on-disk and disabled, and that normally doesn't happen.
(Mind, good chance Dude being barely-on-life-support can't show up the new flag.)
If you saw /enabled/ packages, then it matters what old version you've upgraded from; due to split/merge of some features between the main ROS package and external ones, upgrading across some specific versions installs extra packages to make sure the feature that was there before is still available.
Main example is the legacy "wireless" package showing up even on devices without wifi.
holvoetn
Mon Feb 24, 2025 7:36 pm
I am not seeing much difference but then again I am lucky enough not to have those problems with disconnects like some others do.
burnduck
Mon Feb 24, 2025 7:42 pm
IPv6 FastTrack has made a noticeable difference on my CCR2004!
When routing 6Gbps of traffic I'm seeing ~15% reduction in total CPU usage.
That's a significant free upgrade by my book!
DeGlucker
Mon Feb 24, 2025 7:50 pm
= 14447590 bytes
= 14939868 bytes
Looks like Mikrotik doesn't test their releases on 16MB devices at all. My hAP AC2 has 0MB free after update to ROS 7.18 and now Ican't even reboot it... Forced will go to do netinstall...
vivoras
Mon Feb 24, 2025 7:53 pm
Ok, I see how it works. So the only problem then is that Dude shows all the packages, both installed and "available" to install.
wrkq
Mon Feb 24, 2025 8:12 pm
Probably, but you should double-check if something weird shows up again.
Compare the listing in Dude and in Winbox/CLI, at least.
infabo
Mon Feb 24, 2025 8:45 pm
At least this change was already in 7.17 stable:
What is the logic behind changelog?
CGGXANNX
Long time Member
Long time Member
Mon Feb 24, 2025 8:52 pm
There was a bug in 7.17 where even with device-mode locking down RouterBOARD, people were able to change the CPU frequency once.
CGGXANNX
Long time Member
Long time Member
Mon Feb 24, 2025 9:00 pm
I am linking to my old posts in the 7.18 beta thread:
viewtopic.php?t=214071&start=300#p1125166
viewtopic.php?t=214071&start=300#p1125183
MikroTik does have the possibility to free up at least 565KB (38KB from the useless .woff2 font files) for those AC devices with 16MiB flash if they care.
oe5nip
Mon Feb 24, 2025 9:17 pm
Nice Install on 1100DX4 and RBD52G-5HacD2HnD+RBD53iG-5HacD2Hnd
infabo
I disagree, this bug was fixed in 7.17.2.
rextended
Mon Feb 24, 2025 9:30 pm
For enable default IPv6 FastTrack, do not suffice just manual/auto update/upgrade, defconf is not applied on already installed devices:
viewtopic.php?p=1128583#p1128583
ksoze
Mon Feb 24, 2025 9:32 pm
I upgraded one device and am now no longer able to acquire a DHCPv6 lease. On my other device (which has different firewall rules) I can, but I can't route for some reason. Perhaps there is a breaking config change I am unaware of with IPv6.
CGGXANNX
Long time Member
Long time Member
Mon Feb 24, 2025 9:48 pm
It has been like that since forever. The changelog of the stable c.d release contains changes since the previous a.b release. Version a.b might have additional patch versions a.b.x or a.b.y that already include the same fix, but the fix will still be listed in the changelog of c.d. Just look at https://mikrotik.com/download/changelogs. For example, let's me pick some random excepts:
* Both 7.17 and 7.16.2 have *) certificate - do not download CRL if there is not enough free RAM; among others.
* Both 7.14 and 7.13.4 have *) bridge - fixed MLAG connection after peer-link flap (introduced in v7.13);
pe1chl
I upgraded a CHR that is on a local network only (with free license), from version 7.18beta6.
After the reboot, 123MB more disk space is used than before. After another reboot, it falls back to 105MB more used.
After another reboot with internet access, it returns back to normal.
I have seen this before with the 7.18 betas but not every time. One time all my diskspace was used after running without internet access for a while.
szaboistvan007
Mon Feb 24, 2025 9:59 pm
My RB750Gr3 became unstable under 7.18, it rebooted quite frequently so I couldn't do much, not even troubleshoot, so I reverted to 7.17.2
I have opened a support case and attached the autosupout file
LonDat
Mon Feb 24, 2025 10:32 pm
Yes! Small think, but very helpful...thanks Mikrotik!
infabo
Mon Feb 24, 2025 10:48 pm
Thank you for pointing this out. I have noticed these "duplicates" before, but the one regarding the device-mode CPU fix particularly caught my attention, as I had already reported this bug to Mikrotik and tested the fix in version 7.17.2. Could someone clarify why identical changelog items are listed multiple times, especially within the same stable branch? Does this serve a specific purpose? This way of presenting changelogs can be confusing for users who are upgrading. For instance, someone concerned about device mode might think the fix is only in 7.18 and choose to upgrade unnecessarily, even though it was already resolved in 7.17.2.
infabo
Mon Feb 24, 2025 11:30 pm
Duplicates (already contained in 7.17.1 or 7.17.2):
wrkq
Mon Feb 24, 2025 11:59 pm
Kinda related to the discussion we had over there: viewtopic.php?t=215049
Short version:
* 7.17 released, developers start working on 7.18 dev/alpha/beta
* bug is discovered, fixed in 7.18 dev, fix is put in changelog of 7.18 as "fixed after 7.17"
* bug is decided to be important enough and easy-to-backport enough, it is backported into a hotfix for 7.17
* hotfix 7.17.2 released, including fix, so fix is put in a changelog
Think of the hotfix "third number" versions as branching to the sides of the main development train, so needing their own changelogs.
7.18.nothirdnumber comes after 7.17.nothirdnumber, not after 7.17.2.
Miyuki
Tue Feb 25, 2025 12:01 am
I have a problem, after updating to 7.18 voltage reporting shows 0V
At 7.17 it worked just right
[admin@MikroTik_Switch] > system/routerboard/print
routerboard: yes
board-name: hEX PoE
model: RB960PGS
revision: r2
serial-number: HD1086861FK
firmware-type: qca9550L
factory-firmware: 6.48.6
current-firmware: 7.18
upgrade-firmware: 7.18
[admin@MikroTik_Switch] > system/health/print
Columns: NAME, VALUE, TYPE
# NAME VALUE TYPE
0 voltage 0 V
1 temperature 61 C
Albirew
Tue Feb 25, 2025 1:27 am
mhh... i have an issue since 7.17, percent variables in branding maker doesn't transform anymore, leading my branded skins like this:
toxicfusion
Tue Feb 25, 2025 1:35 am
Since MikroTIk mods are now locking prior RC threads.
now that 7.17 is "stable". Will MikroTik return their focus on routing and switching? When will you all realize your identity as a company and become laser focused on software quality. Need to better align your focus and priorities - figure out what MikroTik' identity is. Become laser focused on producing quality software releases. The hardware isnt the problem - MikroTik has quite good hardware engineers [routing, switching] Wireless still needs work [cost cutting on sheilding and antenna designs].
Fork ROSE to separate project for a MikroTik NAS. Work on separating management, control-plane, processing. it's wild to see bug fixes for "ROSE" in v7.18 stable. This should be a separate package release and its own focus.
Why are you still bringing storage technology into RouterOS? Yeah, brb - I'll go convert my NAS to a router, and my Router to a NAS.
icosasupport
Tue Feb 25, 2025 1:37 am
I just upgraded to 7.18 and now it's stuck in a boot loop :( why?
I can't even hit DEL or Control+E :(
I feel as if the testing portion of releases is a bit lacking
RouterBOOT booter 7.18
CCR2116-12G-4S+
CPU frequency: 2000 MHz
  Memory size:  16 GiB
    NAND size: 128 MiB
Press Ctrl+E to enter etherboot mode
Press <delete> key within 2 seconds to enter setup..
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
stage2_loader v3.63.2
Memory repair completed within 226 uSecs
DDR ECC static poisoning address: (0x1e0000)
DDR ECC static poisoning address: (0x1e1100)
SPD I2C Address: 52, offset 0000(0)
DRAM ch 0: 8GB
SPD I2C Address: 53, offset 0000(0)
DRAM ch 1: 8GB
DRAM total size: 16GB
Executing next at 0x01000000!
agent_wakeup v3.53
infabo
Tue Feb 25, 2025 2:01 am
Short version:
This is a simplified explanation of how a Version Control System (VCS) works: you make a bugfix commit on the main branch and then cherry-pick that commit to the next patch-release branch. However, this is not the right way to write changelogs. I don't know of any software that writes changelogs like this. It doesn't make sense, especially for someone who reads the changelog in the stable branch in chronological order.
wrkq
Tue Feb 25, 2025 2:27 am
Would you be happier if instead of "What's new in 7.18 (2025-Feb-24 10:47):" the caption would say "Version 7.18 (2025-Feb-24 10:47). Changes since 7.17:" ?
icosasupport
Tue Feb 25, 2025 2:56 am
I got past the boot loop after some effort and power cycling :O
Did a fresh net install to 7.18 and formatted the hard drive. It boots with no config :)
First thing I noticed is that the PPP profile now needs a queue statement with 2 values.
Why break our configs with silliness like that?
ver 7.17.2 and below
add bridge=router-bridge bridge-port-vid=30 change-tcp-mss=yes name=private-encryption use-encryption=yes use-upnp=no [b]queue=default[/b]
ver 7.18
add bridge=router-bridge bridge-port-vid=30 change-tcp-mss=yes name=private-encryption use-encryption=yes use-upnp=no [b]queue=default/default[/b]
Second thing, this is what was probably causing the initial boot loop was enabling IGMP snooping. I tested it on the clean install and kernel panic!
add name=router-bridge comment="Site Master Bridge" frame-types=admit-only-vlan-tagged ingress-filtering=no port-cost-mode=short protocol-mode=none pvid=4094 igmp-snooping=yes
From the RIF log:
Feb/24/2025 17:35:19 system,error,critical router was rebooted without proper shutdown, probably kernel failure
So be careful out there if you're using IGMP snooping on v7.18
infabo
Tue Feb 25, 2025 3:14 am
No, that would just be window dressing. If I upgrade from 7.17.2 to 7.18, I want to see the changes at a glance - specifically compared to the exact previous stable version. I don’t want to have to extract every changelog line from multiple patch versions (e.g., 7.13 had 5 patch versions). As I mentioned earlier, changelogs are meant to be read chronologically. If I upgrade from, say, 7.14.2 to 7.18, I want to be able to read the changelog from 7.14.3 up to 7.18 in order, without constantly encountering repetitive or duplicate changelog entries.
This changelog item is in 7.17.1 changelog, but is not in 7.18 changelog. So it is either a fluke in changelog of 7.18 or it is not contained in 7.18 at all.
ipv6 - fixed an issue where bridge, IP, IPv6 and discovery settings were lost after upgrade due to conflicting IPv6 properties (introduced in v7.17);
It’s unlikely that anything about the changelog will change at this point. But now, back to the topic. Since this time the testing cycle was extremely short (just 1 week of RC phase), I’ll at least wait for 7.18.1 this time - if not 7.18.2.
mantouboji
Tue Feb 25, 2025 5:08 am
How to use IPv6 dhcp-relay? need some detail document, Thx.
julianho
Tue Feb 25, 2025 6:01 am
What does this fix?
Is it about using PPPOE-CLIENT with the cable port, causing intermittent UP/DOWN of all ports?
Wyz4k
Tue Feb 25, 2025 6:19 am
WARNING: Do not install this on RB450G or HAP AC2
Both has been repeatedly bricked, and even brick directly after restoring backup config onto freshly netinstalled 7.18
I am rolling back to 7.17.2 and will wait for the next release
loloski
Tue Feb 25, 2025 7:00 am
It's working on hapac2
xgalsax1
Tue Feb 25, 2025 7:47 am
I just had an odd crash on my RB5009 after I removed a Cake Queue Type that was assigned to a disabled rule in the Queue Tree, after removing the Queue Type the system crashed immediately. After that I couldn't boot the system anymore and NetInstall was necessary.
strods
Tue Feb 25, 2025 8:20 am
grusu, vivoras, pe1chl, Miyuki, Albirew, icosasupport - Thank you for your report, we will look into this!
Chaosphere64, ksoze, szaboistvan007, xgalsax1, Wyz4k - Please send supout file from your router to support@mikrotik.com
Everyone #1 - Please remember now and always - if you did find a bug, report it to the support@mikrotik.com. Send supout files and any other materials that might be useful. This is a user forum and even though we monitor version release topics, support@mikrotik.com would be the proper channel for reporting bugs. Especially when these topics so often go off-topic.
Everyone #2 - Please do not turn this version release topic again unrelated to the release itself and talking about how changelogs might be better, testing might be better, etc. Please open new forum topics for such discussions and let us keep these release topics related to RouterOS not management. If not for us, then at least for other colleagues users.
Everyone #3 - Each and every RouterOS release is well tested in countless setups, tests and different router models. However, routers are like levers with millions of possible setting combinations, and not just settings to make things even more interesting - router models, used algorithms, connected devices, etc. If you experience problems, then most likely the problem on your device appeared because "a combination of things" caused the issue. For example, a single specific network packet from some unusual/unpopular network client can call processes on the router which can not be simply simulated or predicted. This is how any software is developed - we do our best and after release find out about unpredicted edge cases. Please report these cases to support@mikrotik.com so we can improve as smoothly as possible. If you report them already within beta/rc stage, then we can address them before the stable release, but no lab in the world will be able to simulate everything.
Jotne
Tue Feb 25, 2025 8:22 am
I am glad MT has added CEF to the logging with UDP/TCP and ISO8601 time format, but it seem that this is the only changes and the logging mess do continue. viewtopic.php?t=124291
Repeatedly I asked for fixing the double name in beta and RC, still not fixed. It do add some unneeded bytes to all package.
How CEF message are created:
2025-02-25T06:38:34.986+0100 RB951-test
Cef version			CEF:0|
Device Vendor			MikroTik|
Device Product			RB951Ui-2HnD|
Device Version			7.18 (stable)|
Device Event Class ID		65|
Name				dns|
Severity			Unknown|
[Extension]			dvchost=RB951-test msg=serial\=5581045XXXX MikroTik: done query: #194 settings-win.data.microsoft.com. 51.104.136.2
2025-02-25T06:38:34.986+0100 RB951-test CEF:0|MikroTik|RB951Ui-2HnD|7.18 (stable)|65|dns|Unknown|dvchost=RB951-test msg=serial\=5581045XXXX MikroTik: done query: #194 settings-win.data.microsoft.com. 51.104.136.2
Look at this message:
2025-02-25T05:33:10.918+0000 RB951-Jobb CEF:0|MikroTik|RB951Ui-2HnD|7.18 (stable)|10|system,clock,critical,info|Very-High|dvchost=RB951-Jobb msg=serial\=5581045C386A MikroTik: ntp change time Feb/25/2025 05:33:10 \=> Feb/25/2025 05:33:32
Here Name field should be Clock or NTP.
What in the hell does critical,info mean.
1. This is severity field and should be in Severity place of the CEF message.
2. Is it Critical or Info, It can not be both.
Severity= Unknown for DNS is wrong, it should be Informational, not Unknown.
Lets hope 7.19 will get this correct.
matiss
Tue Feb 25, 2025 8:55 am
The %version% and %host% variables are deprecated and are no longer supported.
Sorry for the inconvenience caused.
https://help.mikrotik.com/docs/spaces/R ... 4/Branding
honzam
Tue Feb 25, 2025 9:00 am
Client (CubePRO) 7.12.1 -> upgrade to 7.18. Client does not boot
spippan
Long time Member
Long time Member
Tue Feb 25, 2025 9:08 am
thx. BFD in BGP now working again (as it did not work in 7.18beta4 - i don't know if it was addressed in b5, b6, rc1 or rc2)
sergejs
Tue Feb 25, 2025 9:09 am
Cef version			CEF:0|
Name				dns|
Severity			Unknown|
this message is taken from RouterOS logs and goes with tags, that are assigned to specific entry, that as well displayed at /log print.
Jotne
Tue Feb 25, 2025 9:21 am
It does not matter from where it comes from. For 10 years I have asked for cleaning up the log message from RouterOS. It will simplify use of SIEM tools like Splunk.
Default Severity:
Level	Severity	Keyword	Description
0	Emergency	emerg	System is unusable
1	Alert	alert	Action must be taken immediately
2	Critical	crit	Critical conditions
3	Error	err	Error conditions
4	Warning	warning	Warning conditions
5	Notice	notice	Normal but significant condition
6	Informational	info	Informational messages
7	Debug	debug	Debug-level messages
So when you are using Critical and Info in same message, how should you know if its a big problem, or just info?
Is there a list of all "Device Event Class ID"?
Here are some:
DeviceEventClassID	Name
73	bridge,stp
16	dhcp,info
65	dns
61	interface,info
9	script,info
10	system,info,account
81	wireguard,info
23	wireless,info
This should be if cleaned up:
73	bridge
16	dhcp
65	dns
61	interface
9	script
10	system
81	wireguard
23	wireless
Wyz4k
Tue Feb 25, 2025 9:22 am
How should I send a supout? The unit works fine and then after upgrading to 7.18 it no longer responds and needs to be netinstalled.
After netinstall to 7.18 if I restore the backup, it immediately fails again.
After netinstall to 7.17.2 and backup restore, it works without problems.
Do you want my backup file or a supout of it working on 7.17.2?
Jotne
Tue Feb 25, 2025 9:26 am
As far as I remember backup is only for same version, so you need to upgrade or do a import of config.
Try to upgrade from 7.17.2 to 7.18 instead of netinstal.
Or export config from 7.17.2 and import it to 7.18
strods
Tue Feb 25, 2025 9:38 am
Wyz4k - Yes, please generate backup file and send it to us. Add some static IP address to some specific and "unprotected" port on the router so after backup import we can access the router. Additionally add a new system user so you can share this - IP address, username, password and port on which we should be able to connect after backup import. Send this to support@mikrotik.com.
sergejs
Tue Feb 25, 2025 9:39 am
Default Severity:
Here are some:
73	bridge,stp
16	dhcp,info
65	dns
61	interface,info
9	script,info
81	wireguard,info
23	wireless,info
73	bridge
16	dhcp
65	dns
61	interface
9	script
10	system
81	wireguard
23	wireless
Thank you for the information. Yes, SIEM was not implemented in 7.18, and still RouterOS logging format is being sent by CEF.
strods
Tue Feb 25, 2025 9:40 am
Backups work between different version on the same device. However, for safety it is recommended to import backup on the same version as it was made for obvious reasons - what if some setting is deprecated, syntax has been changed, etc.
whatever
Tue Feb 25, 2025 9:55 am
Both has been repeatedly bricked,[...]
Not confirmed, hap ac2 upgrade was successful here.
Admittedly, there is not much free space left and only routeros and wifi-qcom-ac are installed, but the device did not brick:
> /system/resource/print
                   uptime: 1m26s
                  version: 7.18 (stable)
               build-time: 2025-02-24 08:47:02
         factory-software: 6.41.3
              free-memory: 157.4MiB
             total-memory: 256.0MiB
                      cpu: ARM
                cpu-count: 4
            cpu-frequency: 597MHz
                 cpu-load: 1%
           free-hdd-space: 268.0KiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 24
         write-sect-total: 1692350
        architecture-name: arm
               board-name: hAP ac^2
                 platform: MikroTik
> /system/package/print
Columns: NAME, VERSION, BUILD-TIME, SIZE
# NAME          VERSION  BUILD-TIME           SIZE
0 routeros      7.18     2025-02-24 08:47:02  11.5MiB
1 wifi-qcom-ac  7.18     2025-02-24 08:47:02  2680.1KiB
CGGXANNX
Long time Member
Long time Member
Tue Feb 25, 2025 9:58 am
My hAP ac² also went through the 7.18 betas, RCs, and final without issues. But it has no wifi packages installed and still has plenty of spaces.
Wyz4k
If the backups are incompatible it should warn that it is and simply reboot. Bricking is not an acceptable outcome.
I have emailed through the backup, a supout and the config files to support @ mikrotik . com
ips
Tue Feb 25, 2025 10:03 am
Is there any doc about this?
Edit: I've just seen the message in the RC thread:
/interface/wifi/steering/ 2g-probe-delay=yes
Babujnik
Tue Feb 25, 2025 10:20 am
pulling images from registry-url seems to not working:
/container> config/print
      ram-high: 128.0MiB
  registry-url: https://lscr.io
  2025-02-25 09:19:42 container,info,debug [cont] not ok registry auth response: 400
Kanzler
Tue Feb 25, 2025 10:40 am
@ips,
Example:
set 2g-probe-delay=yes steering1
strods
Tue Feb 25, 2025 10:41 am
Wyz4k - This is some misunderstanding. Backup might not work on another router, or another version - my answer was to reply to Jotne about assumption that backup works only on the same version as created on. It should not ever crash router. Your crash has nothing to do with backup, most likely, but the configuration combination with your router environment/network/processed traffic/etc.
Wyz4k
Tue Feb 25, 2025 10:55 am
Thanks strods. Understood.
asimko
Tue Feb 25, 2025 11:26 am
The CVE-2024-54772 (https://github.com/deauther890/CVE-2024-54772) is still functioning in 7.18, will it be fixed?
guipoletto
Tue Feb 25, 2025 11:31 am
This works only for manually setup neighbor groups
/interface/wifi/configuration/set [find] steering.2g-probe-delay=yes
should work for locally-managed, and automatic/dynamic peer-groups
infabo
Tue Feb 25, 2025 11:32 am
@asimko Look, this is fixed in 7.18: https://mikrotik.com/supportsec/cve-2024-54772
pe1chl
The issue is that the opening of another topic (even to add to the topic of feature suggestions) is a no-op.
When discussing things here, at least MikroTik employees are reading it and it may get in the back of their head to look at it some time.
When we open a new topic, only fellow users will reply to it and for sure nothing will happen.
You will probably say "then submit it as a ticket or mail to support" but some of these things really benefit from some discussion involving several users.
Please consider that. Maybe (I don't know if the used ticketing system supports that) allow some publicly visible tickets for feature requests or generic bug reports.
ID
Tue Feb 25, 2025 11:53 am
I never do. If i see an problem i'm coming here to aware users about problem. How do we know that version specific problems if everyone send problems to closed system? I'm not gonna jump and update my devices either for unnecessary things with new bugs. That's why we need open bug tracker. Thanks god that most of users reporting problems in forum thus we know most of it...
dynek
Tue Feb 25, 2025 11:59 am
Is it expected that containers created with digest (sha256) have the repo value ending in "latest" ?
I was not able to specify both the tag and the digest.
btw for those scripting stuff around containers, "tag" became "repo", haven't seen anything to that regard in the changelog and it broke my automations (consistency and updates).
Guntis
Tue Feb 25, 2025 12:02 pm
"is still functioning in 7.18, will it be fixed?" - is there a concrete reason for this claim? We have retested the issue and it is resolved. If it's purely from testing with GitHub PoC, it will return "Valid username!" even for non-existent ones, at least in 7.18.
noradtux
Why is this relevant? You don't have the WinBox port (or any management port) open on an untrusted network without at least address constraints, do you?
sch
Tue Feb 25, 2025 12:04 pm
      ram-high: 128.0MiB
Please write to support and add a supout.rif file.
infabo
Tue Feb 25, 2025 12:07 pm
The same reason you set a password.
holvoetn
Tue Feb 25, 2025 12:24 pm
Maybe I missed something somewhere but it looks like configuration.installation parameter (to set indoor/outdoor) is missing from Winbox for Wifi part.
Verified both Winbox3 and winbox4.
It is there in CLI.
It still shows in documentation so it should be there ?
leonardogyn
Tue Feb 25, 2025 12:42 pm
Got a RB750Gr3 that did not came back after update from v7.17.2 to v7.18. Will have to reach the unit for further analysis and trying to get it back online.
It was running only the core "routeros" package, no extra packages installed at all. It had hotspot enabled, which creates some files on the flash filesystem, but that's about 40-50k, not much difference on the storage usage anyway.
LordNikkon
Tue Feb 25, 2025 1:44 pm
I have to report that three of my RB760 (HexS) constantly rebooting. After checking terminal i saw that last reload was caused by kernel problem. On two routers i was able to log in (routers crashing after 1 minute) download 7.17.2 and force to downgrade. They are working now. Problem is device which is very far. I don't have enough time to copy image before crash.
FFS Mikrotik, how could you release ROS without proper testing on MMIPS based routers which you have in constant sell! Routers which crashed has simple configuration no additional software installed. ARM and ARM64 works fine.
Great! Thank you for giving me extra work! Thanks god we imiddiatly stopped upgrade when we saw that routers not starting up.
leonardogyn
Tue Feb 25, 2025 1:52 pm
UPDATE: the actual upgrade to v7.18 seems to have completed fine, router is online, however rebooting a few seconds after booting, and kept on this constant reboot loop. On a VERY quick troubleshoot, seems that disabling my OpenVPN management instance (OpenVPN client instance) restored the RB750Gr3 to its working condition, it's not rebooting anymore. Enabling the OpenVPN client instance makes the router crash a few seconds after VPN is established, no messages displayed on '/log print follow' however. It seems to be something OpenVPN-client related on my RB750Gr3s. This is absolutely confirmed to me here, disabling OpenVPN-client brings the RB750Gr3 to a working state again, no rebooting loops, with update to v7.18 being just fine (i mean, no crashes on the update itself, config migration seems OK). OpenVPN-client configuration is pretty simple:
/interface ovpn-client add certificate=cliente-<CERT-NAME> cipher=aes256-cbc connect-to=<VPNHOSTNAME> mac-address=FE:D1:A4:68:B2:B1 name=ovpn-management password=password port=11945 user=user
Already tried removing the ovpn-client and recreating, with the exact config above, and nothing changed, router reboots few seconds after VPN is established.
Reconnecting to the RB750Gr3 after a reboot shows a kernel failure warning:
2025-02-25 08:52:33 system,clock,critical,info ntp change time Feb/25/2025 08:51:55 => Feb/25/2025 08:52:33
2025-02-25 08:52:36 system,error,critical router was rebooted without proper shutdown, probably kernel failure
2025-02-25 08:52:37 system,error,critical kernel failure in previous boot
No coredumps or anything automatically generated on the filesystem to help further investigation :(
I have other models on exactly same configuration, all connecting to this OpenVPN management VPN, and none presented similar behavior. RB2011s, RB3011s, RB4011s, RB1100s, some CCRs This is happening on RB750Gr3 only (at least among the models I have and use)
accarda
Tue Feb 25, 2025 1:54 pm
Actually on my hEX-S I didn't have any issue after installing Ros 7.18, so as indicated in some post above, it's not a specific model issue, but the combination of your setup and situation.
zipiju
Tue Feb 25, 2025 2:17 pm
RBM33G dead after upgrade from I believe 7.13.x with no extra packages. Was used only as an ethernet to serial converter with very basic config on it.
leonardogyn
Tue Feb 25, 2025 2:25 pm
UPDATE: the actual upgrade to v7.18 seems to have completed fine, routers are online, however rebooting a few seconds after booting, and kept on this constant reboot loop. On a VERY quick troubleshoot, seems that disabling my OpenVPN management instance (OpenVPN client instance) restored the RB750Gr3 to its working condition, it's not rebooting anymore. Enabling the OpenVPN client instance makes the router crash a few seconds after VPN is established, no messages displayed on '/log print follow' however.
UPDATE 2: Tried setting up a fresh RB750Gr3 with the most basic setup as possible (a plain IP address on an ether interface, DNS and default route). As soon as configured a ovpn-client instance, it connects, disconnects a few seconds later and the router crashes and reboots. It seems to disconnect twice before the router fully crashing and rebooting. Look at the timestamps:
2025-02-25 09:18:21 ovpn,info ovpn-management: using encoding - AES-256-CBC/SHA1
2025-02-25 09:18:21 ovpn,info ovpn-management: connected
(10 seconds)
2025-02-25 09:18:31 ovpn,info ovpn-management: disconnected <peer disconnected>
2025-02-25 09:18:31 ovpn,info ovpn-management: terminating... - peer disconnected
2025-02-25 09:18:31 ovpn,info ovpn-management: initializing...
2025-02-25 09:18:31 ovpn,info ovpn-management: connecting...
2025-02-25 09:18:32 ovpn,info ovpn-management: using encoding - AES-256-CBC/SHA1
2025-02-25 09:18:32 ovpn,info ovpn-management: connected
(10 seconds)
2025-02-25 09:18:42 ovpn,info ovpn-management: disconnected <peer disconnected>
2025-02-25 09:18:42 ovpn,info ovpn-management: terminating... - peer disconnected
(and router crashes, reboots, and on next connection to it I can see:)
2025-02-25 11:33:33 system,error,critical kernel failure in previous boot
And despite the <peer disconnected> message, as previously stated, the very same configuration and VPN (server) instance is working fine for other models I also have: 2011s, 3011s, 4011s, some different CCR models, 1100s. Only the RB750Gr3 is having this behavior. OpenVPN server instance is running on a regular AlmaLinux Linux box, if that matters, and successfully serving different MK models on v7.18 with no problems but RB750Gr3s
leonardogyn
Tue Feb 25, 2025 2:32 pm
Are you, by any chance, running any OpenVPN instance on these routers? I'm facing problems clearly isolated, to me, to a openvpn client instance on the routers. Once disabled, everything works just fine!
LordNikkon
Tue Feb 25, 2025 2:54 pm
Yes i have OpenVPN set up. Problem is that i cant switch it off, because router is far away (like few thousand kilometer from me)
leonardogyn
Tue Feb 25, 2025 3:08 pm
It's fine ... this is just a second confirmation that problem occurs with some OpenVPN configuration/traffic in place. It just confirms my quick analysis here. Thanks!
leonardogyn
Tue Feb 25, 2025 3:15 pm
UPDATE 3: Actually it seems that as soon as some traffic hits the OpenVPN client instance, on the RB750Gr3, it crashes and reboots. On my previous test I wasn't trying to use the OpenVPN client instance, just had it connected. The 10 second interval I was seeing are likely the OpenVPN server heartbeats only. But with a ping to the IP that ovpn client instance interface will receive, as soon as it connects, RB750Gr3 crashes and reboots, it's just immediately.
Also tried netinstalling to the device, to really "clean" old updates gargage that might have been left behind, but no changes. As soon as traffic hits the ovpn client instance, RB750Gr3 crashes and reboots.
LordNikkon
Tue Feb 25, 2025 3:25 pm
i tried to connect to this router but it's reloading to fast and lag (250ms) is not helping. I need to configure new router and send it with older software.
Damm lazy Mikrotik. Great Release candidate checking...
On two routers in EU i was able to log in, quickly upload ROS 7.17.2 and execute commend "/system/package/downgrade". This save me in two sites. Last one is too far to make it in less then minute (also IPSEC tunnel is not start as fast like in EU). Thanks god i didn't upgrade all RB760 (50+).
Summary affected are all MMIPS CPU routers whcih has OpenVPN configured.
leonardogyn
Tue Feb 25, 2025 3:32 pm
I have disabled VPN access for my RB750Gr3 box that is having problems using iptables rules (my OpenVPN server instance is running on a regular linux). While the RB is not connecting to my management interface anymore and I have no management to it, at least it's running fine. Maybe, as a quick workaroung just to get things working, trying to block the VPN connection on your side might help. And when Mikrotik releases a fix for this, someone can grant you access via AnyDesk/TeamViewer from inside the network, and you can update them to v7.18.1 for example.
This is the approach I took here, RB750Gr3 is offline to my management VPN network, but at least working and serving its networks fine. This will give me at least time to breath and think.
rextended
Tue Feb 25, 2025 3:34 pm
@LordNikkon you can only cry on your own.
No matter who the vendor is, putting a newly released software into production without even testing it for a month is irresponsible.
blacksnow
Tue Feb 25, 2025 3:36 pm
Was thinking the exact same thing, not to mention installing it on devices you don't have local access to......
Jotne
Tue Feb 25, 2025 3:37 pm
So you did a remote upgrade on a router first day after a new release?
Here is what you should do:
Do not upgrade .0 version. Wait to at least .1
Do wait some weeks after a new release to upgrade to make sure no surprise are lurking in the shadows.
Read forum and see what other says.
Then upgrade a local router with same config as the remote and test it (if possible)
If all looks fine, do the upgrade, but only if its needed. Why fix some that is not broken.
blbeczech82
Tue Feb 25, 2025 3:39 pm
Thank you for adding rtl8125b-2.fw driver in extra-nic package!
I still hope for 8156, resp. r8152 for arm64 (x86 already added). Could you add?
teslasystems
Tue Feb 25, 2025 3:53 pm
Regarding remote logging. Currently, if a connection between a router and log server is lost for some period, all records appeared during this period are not transferred to the server. Please consider implementing some kind of "buffering" such records, so they can be automatically transferred, when connection restores.
labynko
Tue Feb 25, 2025 3:55 pm
I had problems booting via UEFI on two DELL PowerEdge R630 servers after upgrading RouterOS from 7.17.2 to 7.18.
I had to install 7.18 from ISO over it. Up until this version all upgrades were successful.
eworm
Tue Feb 25, 2025 4:07 pm
I think there is some kind of buffering already. But messages can not be kept infinitely to make sure a missing log server does not cause resource exhaustion on all network devices.
leonardogyn
Tue Feb 25, 2025 4:21 pm
When using UDP as transport, which I believe is the default, I don't believe it's typical for syslog exporting to buffer anything. With UDP, there's really no way of knowing server is online or not.
That will be clearly easier with TCP, which syslog supports. But to my experience, UDP is much more commonly used while exporting logs.
teslasystems
I don't see any buffering. If there is no connection, records are not transferred at all. I was testing it, just made a script, that adds a test log record periodically and disabled connection for a short period. All records, that appeared during no connection period, were not transferred.
Of course, there should be some limit for this buffer, same as 'Lines' parameter for memory type logging. Or, if such records are also logged with different types (memory, disk or whatever), they could be internally marked for transferring to save memory. But I think, it doesn't worth to complicate so much.
Yeah, but for UDP you could have an option to test its availability by pinging prior to sending. Stupid method probably, just an idea.
pe1chl
Tue Feb 25, 2025 4:29 pm
When you require that functionality, instead log to memory (as is default) and retrieve the logs using API from a remote system...
sinisa
Tue Feb 25, 2025 4:31 pm
It crashes only with AES-256-CBC. Works fine with AES-256-GCM.
Just fixed one 750gr3 HEX with same reboot problem (yes, it is set to auto-update when new version comes, it is not very important, but it is used every day so I get first impressions early. Also one of the few still on OpenVPN, I have moved most of the others to Wireguard).
leonardogyn
Tue Feb 25, 2025 4:35 pm
Good catch, I haven't tried ciphers and hash combinations. Actually this OpenVPN management server instance still runs on TCP, as RouterOS (at that time) didn't support UDP. Still using SHA1 for the same reason, it was the "best" supported option when I setup this instance and whole VPN management network. Might be a good time to analyze options and compatibility again.
mszru
Tue Feb 25, 2025 5:47 pm
"SA Query Timeout" problem renamed to "disconnected, not responding" is still there unfortunately. While in a Zoom meeting I got disconnected 3 times in a half hour. I use hAP ax3 and a laptop with Intel AX203 Wi-Fi card. I had WPA3 and Management Protection disabled since I first encountered the "SA Query..." error and decided to give it a try and enable it again in 7.18
 2025-02-25 15:46:10 wireless,info E4:B3:18:**:**:**@wifi10 reconnecting, signal strength -68
 2025-02-25 15:46:11 wireless,info 90:09:DF:**:**:**@wifi1 disconnected, not responding, signal strength -60
 2025-02-25 15:46:12 wireless,info 90:09:DF:**:**:**@wifi2 connected, signal strength -46
 2025-02-25 15:46:14 wireless,info E4:B3:18:**:**:**@wifi10 connected, signal strength -68
 2025-02-25 15:51:17 wireless,info 90:09:DF:**:**:**@wifi2 disconnected, not responding, signal strength -42
 2025-02-25 15:51:31 wireless,info 90:09:DF:**:**:**@wifi1 connected, signal strength -58
 2025-02-25 16:03:09 wireless,info E4:B3:18:**:**:**@wifi10 reconnecting, signal strength -69
 2025-02-25 16:03:10 wireless,info 90:09:DF:**:**:**@wifi1 disconnected, not responding, signal strength -56
 2025-02-25 16:03:12 wireless,info 90:09:DF:**:**:**@wifi2 connected, signal strength -49
 2025-02-25 16:03:17 wireless,info E4:B3:18:**:**:**@wifi10 connected, signal strength -73
 2025-02-25 16:08:17 wireless,info 90:09:DF:**:**:**@wifi2 disconnected, not responding, signal strength -42
 2025-02-25 16:08:17 wireless,info 90:09:DF:**:**:**@wifi2 connected, signal strength -46
 2025-02-25 16:13:27 wireless,info 90:09:DF:**:**:**@wifi2 disconnected, not responding, signal strength -44
 2025-02-25 16:13:42 wireless,info 90:09:DF:**:**:**@wifi1 connected, signal strength -59
Albirew
Tue Feb 25, 2025 8:03 pm
Thanks for the answer.
Is there still a way to get version number and host address from branding webpage without using rest API? maybe in /assets/script.js ?
(rest api requires login, hence my question for authless alternative usable in branded webpage)
chiem
Tue Feb 25, 2025 10:06 pm
Anyone seeing slightly strange ipv6 behavior in 7.18?
My ipv6 network has been on $prefix:0::/64 for years. After upgrading, it went to $prefix:2::/64. Then later I got a warning about something changing in neighbor discovery and it advised me to reboot. After that, it swapped back over to $prefix:0::/64.
Also, why don't I have any fast-path packets?
[admin@ccr2116] > /ipv6/settings/print
                    disable-ipv6: no
                         forward: yes
           multipath-hash-policy: l3
                accept-redirects: yes-if-forwarding-disabled
    accept-router-advertisements: yes-if-forwarding-disabled
      disable-link-local-address: no
  stale-neighbor-detect-interval: 30
          stale-neighbor-timeout: 60
            min-neighbor-entries: 4096
       soft-max-neighbor-entries: 8192
            max-neighbor-entries: 16384
                 allow-fast-path: yes
           ipv6-fast-path-active: yes
          ipv6-fast-path-packets: 0
            ipv6-fast-path-bytes: 0
           ipv6-fasttrack-active: yes
          ipv6-fasttrack-packets: 1862750
            ipv6-fasttrack-bytes: 2576286552
Doesn't the documentation say that if a packet is fast-tracked, it's also fast-pathed?
https://help.mikrotik.com/docs/spaces/R ... S-FastPath
CGGXANNX
Long time Member
Long time Member
Tue Feb 25, 2025 10:27 pm
The behavior with the incremented prefix was always there. If the interface (bridge, vlan, etc...) gets the address with the prefix from a pool, and you make any modifications to the interface (for instance toggling IGMP Snooping on the bridge interface or changing ARP mode on a VLAN interface), the current allocated prefix is released and a new prefix is retrieved from the pool to be used on the interface.
And if fasttrack is working correctly then it's normal that the fast path counters are all zeroes. If you see non-zero FP counters and zero FT counters, then Fasttrack was not enabled correctly.
eltikpad
Tue Feb 25, 2025 10:32 pm
@ chiem My understanding is that fast-path is only used if many conditions are met, one of which is no firewall filter rules.
My counters show similar 0 ipv6-fast-path-packets and bytes values.
chiem
Tue Feb 25, 2025 10:37 pm
But I didn't make any changes to the bridge. This is the first upgrade that came up with a different prefix. Well, I have to admit that I didn't check the address right after the upgrade, only after I noticed that ipv6 wasn't working. Perhaps the addition of the ipv6 firewall fasttrack rule changed it?
Good to know, thanks!
@eltikpad Thanks for confirming!
mikesaxl
ver 7.18
From the RIF log:
I am currenlty trying out ipv6 multicast. Is that supposed to work with ipv6 and a crs3xx switch? https://help.mikrotik.com/docs/spaces/R ... D+snooping says it should work and ipv6 should not interfere with ipv4 and ff02::1 is aways forwarded.
When I use vlans (the ipv4 querier is not a switch but a router with pimsm, else it is documented it will not work. currently there is no ipv6 querier, I think this is not implemented. pimv6 exists but a mld packet was never sent) neither ff02::1 is forwared reliably when igmp-snooping is enabled even tough mld-querier is none. Strangely bridge/mld populates SOME ipv6 groups, but there is no ff02::1 nor a ff02::2.
What would be helpful is being able to turn on multicast handling only for specific address families (so the switch does not even think to touch mac addresses beginning with 33:33) since this breaks ipv6 completly in a lan since the router advertisements dont come through. The only solution is disabling igmp-querier altogheter and live with multicast flooding
A very nice thing tough would be if optionally ff02::/16 would be treated like 224.0.0.0/24 (that is always forwarded) since heavy multicast should be on ff05::/16 since ff02:: is site local and thus not routable and usually used for low bandwidth neighbour discovery
Maggiore81
Trainer
Trainer
Tue Feb 25, 2025 10:56 pm
We had a 2116 that went into a boot loop. We were unable to recover it via netinstall older than 7.18
only 7.18 netinstall could recover it.
Rox169
Tue Feb 25, 2025 11:01 pm
is in 7.18 BUG?
I use DOH DNS with quad9. I also use adlist with StevenBlack from PiHole. Unfortunatelly this adlist block googleadservices. which is sometimes usefull. I tried to use DNS/static and also DNS/Forwarders but NOONE record unblock googleadservices..
Any help pleease?
pe1chl
Tue Feb 25, 2025 11:04 pm
There was a firmware change in 7.16 that of course may affect you only later when you do not update firmware every upgrade.
I had a CCR1009 go into a bootloop when I changed from 2 to 1 partitions (the first one being active) with 7.18beta4 to beta6 upgrade, and when trying to netinstall it things got only worse.
Serial terminal with Ctrl-E was required to recover it, but what if that was a device without serial port?
And of course the bootloop after changing partitions is a bug in itself.
WoZeR
Tue Feb 25, 2025 11:27 pm
Adding a queue with 7.18 on a CCR2004-1G-12S+2XS crashes the OS and boot loops the device. :(
I would avoid using this version, It is very unstable.
/queue type
add kind=pcq name=PCQ-Internet pcq-classifier=src-address
/queue simple
add dst=internet-sfp12 max-limit=950M/950M name=Internet-FairShare queue=\
PCQ-Internet/PCQ-Internet target="" total-queue=PCQ-Internet
dang21000
Tue Feb 25, 2025 11:35 pm
WebFIG : Please remove the default username in the login field ! And add dark mode too, like WB4
Jotne
Wed Feb 26, 2025 7:39 am
There are no buffer on logging, All logs that are generated at boot are not sent since there are no network up and running. Logs will only be tried sent once, and if that does not work, they are not sent (UDP/TCP).
braidiano
Wed Feb 26, 2025 7:41 am
if you set the /interface/pppoe-server/server set max-sessions=1 and for eg the pppoe-over-vlan-range=1-1000, only one pppo-client can connect at time, because "limit of maximum connections exceeded".
This is wrong, becase it have to take in account how many the sessions "for each inner vlan", and not the whole number of sessions on the outer vlan.
It work properly in the past if you set max-sessions=1 and have the pppo-server in a bridge and have 100 users.
strods
Wed Feb 26, 2025 8:09 am
The issue with OVPN service running on MMIPS devices with "hardware encryption" has been reproduced and fixed already. The fix will be available in the upcoming RouterOS releases.
nereith
Wed Feb 26, 2025 8:22 am
*) ovpn - disable hardware accelerator for GCM on Alpine CPUs (introduced in v7.17);
What's the reason for disabling GCM? What issue was it causing?
infabo
Wed Feb 26, 2025 9:06 am
pe1chl
Wed Feb 26, 2025 11:11 am
Yes, and it is not something that can be solved easily.
E.g. in our network the branch routers log to a syslog server in the main office, connected via tunnels and routed with BGP.
Due to the BGP bugs introduced in 7.16 it takes a minute for the routing to establish, so everything happening in the first minute is lost. That could be a lot.
Probably when someone is interested in the logs after boot, they should send a trigger message at boot (have a scheduled job at startup that checks if the connection to logserver is already up, or does a simple delay) and on the logserver have some action that recognizes this message and fires a program that contacts the router using API and retrieves the log from memory.
eworm
Wed Feb 26, 2025 11:22 am
Just checked for myself... The very first message I have on the log server for every device is:
system,info MikroTik: router rebooted by ssh:eworm@10.171.215.2/shutdown
I am pretty sure this is before wireguard connection is up, and also before OSPF established any routes. So there must be what ever kind of buffering, no?
Paternot
Wed Feb 26, 2025 11:33 am
Log servers are mostly passive. To me the best course of action would be to create a memory buffer (a small one, say 1MiB) and send log messages to it. In fact, we already have: it's the "log to memory option".
THEN the contents of this buffers that were marked to remote logging are sent - and only removed either wen successfully sent OR the buffer runs out of space.
Problem 1:
This won't work for logs servers using UDP for communication.
Problem 2:
Increases complexity on a system that should just work.
Possible workaround 1:
Set a job to be run ONLY after boot. It tries to send everything on memory that is marked with the "remote" option. This would take care of the UDP problem, would not need changes to the server and should "just work".
Problem 1 for this workaround:
Now we have several lines of log waiting for network. How do we check connectivity? A simple "fire and forget" UDP log server will not have this. We could ping it - but how do we make sure it's really working? How do we know the ping isn't going trough one secondary route, and the UDP would be blocked by the firewall on this one?
Possible workaround 2:
I had another idea, but just forgot. Early morning and all that. Ah, well.
nipfel
Wed Feb 26, 2025 11:35 am
I saw exactly the same on hap ac, 600 kb left after that. Even uninstalled packages came back after resetting the router and the reason Is I got locked by no rules. First rule in the FW filter list to filter incoming dhcp-offers disappeared somewhere. It was fine until I simplified some Address Lists (combined them) using WInBox.
They forgot to test again, I suppose.
UPD: Now router rejects offers from netinstall to flash long-term back. Nice piece of software.
pe1chl
Wed Feb 26, 2025 11:43 am
PLEASE PLEASE PLEASE study the matter before you claim that packages get installed.
Starting from 7.18, this list has both the packages that are installed, and those that are optional to install.
erlinden
Wed Feb 26, 2025 11:52 am
Besides marking for uninstall, was the device rebooted to complete uninstall @nipfel?
And did you create supout to inform support?
This is not really constructive.
Can't imagine people overseeing such a thing, can you?
pe1chl
Wed Feb 26, 2025 12:05 pm
Well, I have often commented that the changelog is inadequate and should be replaced with something that has more info, links to documentation, etc.
But when looking at the packages screen, I really do not see how someone could think that packages are installed that are not:
oskarsk
Wed Feb 26, 2025 12:09 pm
OVPN related issues are fixed, if you still have problems with this version, send us supout.
https://box.mikrotik.com/d/c2fc960065ed49b78214/
rextended
Wed Feb 26, 2025 12:10 pm
@oskarsk
WARNING: Are links for RouterOS 7.20_ab22!!!
I do not know if is done on purpose, skipping 7.18.x / 7.19
fischerdouglas
Wed Feb 26, 2025 12:13 pm
OK! That's it!
v7.18 "stable" published and with this: The pressures from product teams and marketing teams have already been met.
Now who knows, maybe they can put "renice -19" on everything related to routing and switching, and a "renice 19" on everything that is superfluous.
Let's pray.
pe1chl
Wed Feb 26, 2025 12:29 pm
Yes, that would be great!
But I fear that once the Rose Data Server really hits the street, we will see lots of requests for (in itself) reasonable requests around data server functionality.
(some of them in software not written by MikroTik but becoming their responsibility when used as part of such a product. e.g. I am using BTRFS myself on my home system, and I can tell it is a REAL PAIN when you are running RAID-1 and one of the disks goes offline. It is NOT like in a typical RAID-1 controller where you can just pull the disk and plug the same or another one back in)
leonardogyn
Re: v7.18 [stable] is released!
Wed Feb 26, 2025 12:31 pm
Great news, thanks for the quick fix on this one. Can we expect a v7.18.1 fixing this, or it will be published on v7.19 only, for example?
CHL
Wed Feb 26, 2025 12:57 pm
OVPN still in trouble here on RB4011GS+ / ARM. aes256cbc working fine, aes256gcm results in permanent disconnects as soon as data is transmitted.
rextended
Wed Feb 26, 2025 12:59 pm
Probably only on RouterOS 7.20_ab22+ (didn't you notice the shared files versions have, and my comment)?
cyrq
Wed Feb 26, 2025 1:07 pm
It's called branching...
leonardogyn
Wed Feb 26, 2025 1:18 pm
Tested ab23 and, in a quick lab test, and it solved connections issues for AES-256-CBC. I also tested AES-256-GCM and it worked just fine. Tested on RB750Gr3 only.
leonardogyn
Wed Feb 26, 2025 1:25 pm
Fore sure I noticed the filenames (v7.20) and your comments. I'm just looking for a kind of official answer on where to expect that fix to be published on a "stable" release.
teslasystems
Wed Feb 26, 2025 1:52 pm
Thanks for telling me obvious things... I was talking about changing this behavior.
fischerdouglas
Wed Feb 26, 2025 1:53 pm
Could you please do me a favor? Just to satisfy my curiosity.
/system/resource/usb/print
What kernel version appears there?
I remember reading something about AES-256-CBC in relation to the Linux Kernel starting to support this type of encryption. But I remember it being about FileSystem encryption, not network encryption.
I don't even know why I'm so curious about this, because even if it was network encryption, and they had changed something to support it, I'm almost certain that they wouldn't update the Kernel, but rather backport changes to the base Kernel they use.
But, hope is the last thing to die, right?
Many other requested features would be more easily achieved if there were a Kernel update.
leonardogyn
Wed Feb 26, 2025 2:00 pm
Sure!
[admin@MikroTik] > /system/resource/print
                   uptime: 43m35s
                  version: 7.20_ab23 (development)
               build-time: 2025-02-26 10:03:54
        architecture-name: mmips
               board-name: hEX
                 platform: MikroTik
[admin@MikroTik] > /system/resource/usb/print
Columns: DEVICE, VENDOR, NAME, SPEED
# DEVICE  VENDOR                NAME                  SPEED
0 1-0     Linux 5.6.3 xhci-hcd  xHCI Host Controller    480
1 2-0     Linux 5.6.3 xhci-hcd  xHCI Host Controller   5000
[admin@MikroTik] >
rextended
Wed Feb 26, 2025 2:02 pm
Just open the file with 7-zip or similar for see routeros-7.20_ab23-arm64.npk\lib\modules\5.6.3
LK7R
Wed Feb 26, 2025 2:20 pm
I have problem with hEX S device and RouterOS 7.18 too. In my case there is only ipsec in play, but it uses "aes-256 cbd" for Encr. too. As the router reboots it self after a while, i had to quickly downgrade to 7.17.2, will support.rif be of any use from router that has the problem, but is downgraded to 7.17.2?
davetickem
Wed Feb 26, 2025 2:22 pm
Same issue here on HexPoE - health stats in webui and cli show zero Volts. Worked with previous version.
Upgrade path - stable versions only 7.17.2 (working) direct to 7.18 (stable)
<snip>
mike7
Wed Feb 26, 2025 2:28 pm
*) container - allow HTTP redirects when accessing container registry;
*) container - allow specifying registry using remote-image property;
Starting from v7.18 can't use private HTTP registry without SSL. I've got
unexpected response from container registry: SSL: ssl: record overflow (6)
Looks like I can't specify access protocol (http or https) on remote-image property and protocol is ignored in registry-url config.
The only workaround is using tarball format (
leonardogyn
Wed Feb 26, 2025 2:47 pm
So maybe it's CBC encryption related, and not OpenVPN only. I have tested the test firmware ab23, provided on the link a few comments above, and at least to me, on OpenVPN, it solved the problem. It's not working as expected with AES-256-CBC and AES-256-GCM on my RB750Gr3s. It might worth trying the ab23 firmware to see it solved IPSec related problems as well.
Tenshinur
Wed Feb 26, 2025 3:00 pm
Mikrotik RB750Gr3
installed 7.17.2
Problems appeared after upgrading to 7.18.
The router starts normally. However, after some time (about 30 seconds) it disappears from the network and so on until the moment of manual restart.
During these 30 seconds, if you connect to it via Winbox, the router immediately reboots.
The ssh connection is normal and you can look at the logs, but again there is nothing about possible causes.
I reset all the settings and the router in the factory configuration loaded and works, but when deploying a backup, everything happens again.
I rolled back the version back to 7.17.2, deployed a backup, the router works without problems.
From this it follows that there are some changes that in the old configuration conflict with the new version. I do not think that this is "stable"
holvoetn
Wed Feb 26, 2025 3:04 pm
There should be an autosupout.rif after reboot.
Best to create ticket to support and include that file.
oreggin
Wed Feb 26, 2025 3:23 pm
Using BTRFS's RAID finctionality in enterprise environment is a kamikaze solution. I'm curious what solution they use if there is any RAID function in it. I hope it is battery backed HW RAID controller...
matiss
Wed Feb 26, 2025 3:36 pm
Host address you can find in address bar.
Unfortunately, version number is not available.
massinia
Wed Feb 26, 2025 4:51 pm
BTH File page loading is very slow, I think it's due to many files are not available for download...
const iconSrcDir = 'https://cdn.mt.lv/marketing/bth/folder.svg';
const iconSrcFile = 'https://cdn.mt.lv/marketing/bth/file.svg';
const iconMissing = 'https://cdn.mt.lv/marketing/bth/missing.svg';
S8T8
Wed Feb 26, 2025 5:24 pm
*) wifi - implement steering parameters to delay probe responses to clients in the 2.4GHz band
How does 2g-probe-delay practically work and when should be used?
msilcher
Wed Feb 26, 2025 5:45 pm
In regards to IPv6 fasttrack: I've enabled it based on suggestions but counters always show "0". This doesn't look normal to me. IPv4 counters works properly (as expected).
I'm on a hAP ax2 by the way and the device has been rebooted after enabling the feature.
CGGXANNX
Long time Member
Long time Member
Wed Feb 26, 2025 6:14 pm
If you have DHCP Snooping / IGMP Snooping turned on on the bridge, try to disable those features first. At least DHCP Snooping is confirmed by the updated documentation to cause fast-path to be non-working, which causes fasttrack to be useless on that bridge.
https://help.mikrotik.com/docs/spaces/R ... rfaceSetup
dhcp-snooping (yes | no; Default: no)
Enables or disables DHCP Snooping on the bridge.
Enabling the DHCP snooping feature will turn off bridge fast-path, which in turn affects the ability to fasttrack connections going over that bridge.
marcotmv
Wed Feb 26, 2025 6:18 pm
Doesn't Fasttrack have to come after the connection is established or related?
osc86
Wed Feb 26, 2025 6:27 pm
ehm.. no? putting it after the Established & Related Connections Rule would make it useless.
jsadler
7.18 - console - do not autocomplete arguments
Wed Feb 26, 2025 6:28 pm
I see in the 7.18 changelog the following came in...
>>>console - do not autocomplete arguments when match is both exact and ambiguous
I'm not sure if this is by design or not, but this is taking exact matches to the extreme - where a script triggered "/tool e-mail send file=filename" prior to 7.18 if the filename was an exact match but without the file extension the command would still succeed. On 7.18 the file= parameter must include the file extension for the command to succeed. Eg file=myexport would have worked previously, now it must by file=myexport.rsc - This isn't too much of a major but does mean that scripts that have been working this way for many years now need to be updated to use the exact filename, including extension.
It would be nice to have a configuration setting to enable changes in behaviour like this so that it can be left in the current state if a user wishes.
If this is by design then it isn't a bug, but it did catch us by surprise.
If this is not what Mikrotik intended with this change then it would be nice to see the functionality reverted.
Cheers,
Jono.
whatever
Wed Feb 26, 2025 7:32 pm
Speculation:
I assume it delays probe responses on 2g interfaces to ensure probe responses on 5g interfaces are faster. So when a client probes 2g and 5g simultaneously, it will receive a response from 5g first and will hopefully prefer the 5g network over the 2g network, even if the client does not implement 802.11v.
pe1chl
Wed Feb 26, 2025 9:12 pm
It is unclear if the RAID function uses Linux block-level RAID or the BTRFS balance profile "raid1".
Both have advantages and disadvantages. But the Linux block-level RAID is much easier to use for admins that just want to replace a failed disk without doing a full study of how BTRFS balance works... and why you cannot simply re-seat a disk when it goes offline.
Indeed that would be kamikaze when deployed in an environment where the personnel are used to HW RAID controllers...
rextended
Wed Feb 26, 2025 9:22 pm
WARNING: Installing 7.20_ab28 (on 7.18rc1) reset to "no" the device-mode flagging-enabled, traffic-gen, container, partitions, routerboard,
on my hAPax² that I have already set to "yes" on 7.18rc1
(OK, this topic is about 7.18, but 7.20_alpha_build28 is provided in this topic)
keywork
Wed Feb 26, 2025 10:18 pm
Upgraded my HEX S this morning without a hitch and got ipv6 fasttrack going. Hitting the line-rate of my 800Mbps plan now which is fantastic. Kudos to the MT staff for finally getting this across the line!
tom3f
Wed Feb 26, 2025 10:31 pm
On hap ac2 with routeros + wifi-qcom-ac it works just fine. Update from 7.17.2 was successful. But i can report only 172KiB od free hdd space. It is less and less with every update. Soon it will became big problem.
leah
Wed Feb 26, 2025 10:40 pm
I can see a massive increase in latency spikes and loss after upgrading to v7.18 on multiple CCR2004-1G-12S+2XS
nipfel
Wed Feb 26, 2025 10:47 pm
Yes rebooted. I will try again. I believe it will repro soon.
I also had 100% CPU usage because I decided to clear DF and IP options somewhere in prerouting. Additionally I managed to drop Martian Addresses and RFC1918 from/to WAN using AddressLists (And also one Turkish subnet who wanna be fonts cdn for me).
Maybe in that case saving or modifying fw filter rules may have such result. Who knows, who knows...
challado
Wed Feb 26, 2025 11:03 pm
<snip>
Same here. Voltage 0v and working OK on 7.17.
mozerd
Forum Veteran
Forum Veteran
Thu Feb 27, 2025 12:03 am
CCR1009 RoS v7.18 stable
under ipv6 neighbours list I'm getting a lot of 00:00:00:00:00:00 for Mac Addy .. these are all windows hosts that go into hybridization mode.
This does not happen under ipv4 for the very same hosts.
When I issue a directive like
ipv6/neighbor/remove [find mac-address=00:00:00:00:00:00 status=failed]
or
ipv6/neighbor/remove [find where mac-address=00:00:00:00:00:00 status=failed]
or
ipv6/neighbor/remove [find where interface=vlan100 mac-address=00:00:00:00:00:00 status=failed]
via Terminal nothing happens
BUT the following does work
[:foreach a in=[/ipv6/neighbor find where status=failed] do={:if ([/ipv6/neigh
bor get number=$a mac-address] = []) do={/ipv6/neighbor/remove numbers=$a}}]
leah
Thu Feb 27, 2025 12:51 am
Here is the proof: after downgrading to RouterOS 7.17.2 again, the problem is gone
toxicfusion
Thu Feb 27, 2025 1:02 am
This is what happens when MikroTik rushes a release to "Stable", they did this to themselves. Pushed it out the door so they could make the RDS hardware announcement. Lets hope RDS hardware doesnt ship with 7.18 lol.
MikroTik needs to answer and address. Focus needs to be on software QC, extended change logs and a known-issues section.
chiem
Thu Feb 27, 2025 3:59 am
Why would MikroTik need to release 7.18 to stable in order to announce the rds2216?
joshhboss
Thu Feb 27, 2025 5:01 am
Is VRRP having any issues with this release. That’s the only thing stopping me from moving up my main core network.
Read something about connection syncing
infabo
Thu Feb 27, 2025 8:46 am
Put email.backup in quotes.
file="email.backup"
eworm
Thu Feb 27, 2025 8:47 am
Does it help to put the file name in double quotes? Or add a little delay between the commands?
Other than that you should perhaps open a new topic. I can tell that scripting works just fine with this version.
chiem
Thu Feb 27, 2025 8:55 am
Should the ipv6 fasttrack support make it as fast as ipv4 now? On my ccr2116, 10gbps on ipv4 barely shows a 1% blip, if anything, on the cpu. But the same on ipv6 seems to show up to 250% total cpu usage spread across multiple cores.
All of the hw offload seems to be enabled:
[admin@ccr2116] > /interface/ethernet/switch/l3hw-settings/print
            autorestart: no
           fasttrack-hw: yes
                ipv6-hw: yes
    icmp-reply-on-error: yes
  hw-supports-fasttrack: yes
oskarsk
Thu Feb 27, 2025 9:09 am
This is fixed, please try
And please send us supout files to us so we can deal with issues faster.
elmomac
Thu Feb 27, 2025 9:53 am
            autorestart: no
           fasttrack-hw: yes
                ipv6-hw: yes
Seeing this too. I think it's due to the limitation still around how many IPv6 routes can be offloaded?
chiem
Thu Feb 27, 2025 10:16 am
Mine's not offloading any routes to hardware..
I notice that the /ip/firewall/filter rule for fasttrack has a hw-offload option, but not the corresponding ipv6 version.
fischerdouglas
Thu Feb 27, 2025 10:24 am
Unpublished!
Prophecy?
pe1chl
Thu Feb 27, 2025 10:55 am
Prophecy?
Well in the Newsletter #123 topic it already begins... "we want ZFS, not BTRFS".
sinisa
Thu Feb 27, 2025 11:10 am
Prophecy?
We DON'T WANT any FS on a ROUTER!
Please make this whole file-sharing cr*p optional on a ROUTER.
Thank you!
rextended
Thu Feb 27, 2025 11:13 am
No one is forcing you to use or buy that model, just ignore it.
merkkg
Thu Feb 27, 2025 11:19 am
Thank you!
You need install rose package so its already optional.... I don't see where issue is.
infabo
Thu Feb 27, 2025 11:40 am
sinisa said "file sharing". "*) cloud - added "Back To Home Files" feature;" is a feature in routeros main package. True, the storage features are part of rose extra package. Regarding the shoutout "We DON'T WANT any FS on a ROUTER!". Every device needs to support at least one file system for the root partition. So the thing of "we don't want any FS on a router" is impossible.
pe1chl
Thu Feb 27, 2025 11:42 am
Indeed it already is optional on the router, that is not the issue.
What most people worry about is that it takes away development resources from router functionality, e.g. BGP.
That is clearly demonstrated by the BGP problems introduced in 7.16 (and not present in 7.15) still not having been fixed in 7.18.
holvoetn
Thu Feb 27, 2025 12:41 pm
No it does not IMHO.
Different type of developers so there should be no conflict.
oreggin
Thu Feb 27, 2025 12:46 pm
I wish it were so, but experience shows that it isn't. If I open a ticket about dynamic routing or MPLS issue, it takes months to react. If I am the only one about this issue then there is not so big the problem is.
fischerdouglas
Thu Feb 27, 2025 1:49 pm
It's very unlikely that we'll see the following in v7.18.1, 7.19... And based on spoilers, not even for 7.20.
But can we dream about the following items?
  • A Kernel update?
    • Already targeting nftables
    • And as a bonus, better BTRFS support
  • Support for Hooks triggers and actions, for all types of events? Including:
    • Routing events
    • BNG events
    • Radius events
    • Firewall events
    • Interface events
  • Is it too much to ask for the possibility of inserting eBPF apps that can be used in Firewall rules?
  • And dreaming about a Commit / Commit-Confirmed / Dry-Run / Rollback... Can we dream about that?
pe1chl
Thu Feb 27, 2025 2:14 pm
There have been several people here complaining about the BGP issues, and I also opened a ticket half a year ago, but nothing happens.
Maybe there are no developers left for that part of the system?
There have been other times (also recently) when I reported a new issue in a new version, e.g. about PoE, and it was fixed within a couple of days.
SeppBlattered
Thu Feb 27, 2025 2:33 pm
and of course amnezia wireguard in an options package.
I guess nobody's replied because this is a terrible, terrible idea. Nobody wants Wireguard plus some proprietary Russian "improvements" on top running anywhere near their networks. Shipping this would be the end of Mikrotik.
An what potential benefits would it bring? If you think your Wireguard traffic is at risk of DPI monitoring or attacks, run a box on your local network to run Amnezia - at least in that example you can get rooted by the FSB and the rest of us will stay safe.
If you need support you can go to Telegram! I'm going to be chuckling about that one for some time!
philipwillemse
Thu Feb 27, 2025 3:01 pm
Howzit,
I wanted to check if anyone else has experienced this issue on their CCR2216 running v7.16.2. Every now and then, routing seems to stop working properly, and when I go to Routing → BGP, the display is completely blank and unresponsive.
If you’ve encountered this, did upgrading to the latest version resolve the issue?
Would appreciate any feedback!
Thanks,
Cha0s
Thu Feb 27, 2025 3:02 pm
The amount of money companies spend on developers is finite.
Wasting money on non-networking features, means that they don't put enough developers to fix networking bugs.
In other words, those developers that work on storage, could have been put to work on networking.
So IMHO as long as there are bugs and missing features in networking, working on non-networking features is a conflict.
It RouterOS after all. Not StorageOS.
holvoetn
Thu Feb 27, 2025 3:10 pm
I understand completely. Just wanted to point out there doesn't have to be a conflict from a personnel point of view.
Obviously other resources (like funding) can of course have an impact as well.
Since at its core Mikrotik is into networking, I can only assume (and that's an assumption from my side) that strategically required resources are available to tackle advanced networking stuff.
kreb
Thu Feb 27, 2025 3:40 pm
Anything changed regarding dhcpv6 server? anyone noticed a problem?
pe1chl
Thu Feb 27, 2025 4:47 pm
Please make a support ticket!
When the support tickets about BGP keep coming in, maybe someone at MikroTik realizes that they broke something in 7.16 and it needs to be fixed.
When you require it to be fixed quickly, downgrade to 7.15.3 (download from the archive).
philipwillemse
Thu Feb 27, 2025 4:49 pm
Thank you for the feedback, you had similar issues and when you downgraded to 7.15.3 the issue have gone away permanently?
pe1chl
Thu Feb 27, 2025 4:57 pm
I have all kinds of BGP issues that were introduced with 7.16, reported, but not yet fixed.
In version 7.15.x it worked much better. But I cannot downgrade because I require other fixes.
philipwillemse
Thu Feb 27, 2025 5:03 pm
Thank you for the feedback, I am going to wait for Mikrotik to respond before updating as it might introduce other issues and downgrading might not fix the issues that I am having where pings to a PPPoE client stops working and my frontend goes blank etc.
oreggin
Thu Feb 27, 2025 5:34 pm
Prophecy?
And there is a good reason for this. I using BTRFS only where there is no need FS level RAID or at most I using RAID0 for data and RAID1 for metadata if data loss is accepted. As I read correctly, NVMe disks connected directly to the PCIe fabric so there is no HW RAID controller in this pizza-box. I don't know ROSE storage solution, what kind of possibilities we have if we would like to use RAID like operation? BTRFS RAID is unfortunately a dead end however RAID0 or RAID1 us usable with some constraints, but if I need RAID5 or RAID6 for some reason, how could I do that without ZFS? For comparison, I have a NAS at home, with four 8TB disks in RAID5 setup. I was clingy for BTRFS for a long time till I started a scrub on it and it tells me it will take more than a week. I copied all data from that volume, recreate it with ZFS RAIDZ and copied all data back. Now, if I start a scrub, it take 9 hours on the same HW. Not to mention that ZFS is much more mature.
Paternot
Thu Feb 27, 2025 6:39 pm
I don't KNOW what ROSE uses, but I do know that the Linux kernel have support for software RAID (mdraid) for quite some time already. It's stable, it's mature and it's dependable. Can't say if they use it, but it's (would be?) an easy "turn key" solution.
pe1chl
Thu Feb 27, 2025 7:03 pm
Disadvantage of kernel RAID: when a single block error occurs the entire device is removed from the array and no longer updated. So when you have two disks in RAID-1 each with a block error at a different location, you lose all your data. BTRFS balance raid1 does not have that problem, it keeps both disks online and combines the good blocks from each of them, not losing any data.
Advantage of kernel RAID: you can remove a disk from a RAID-1 and replace it, or even put the same disk back, and it will automatically copy the data without much hassle. In BTRFS that is extremely difficult, because you cannot remove a disk from a 2-disk RAID-1, you first need to downgrade it to a SINGLE, then you can add or re-add the disk and convert it to RAID-1 again (which will copy the data). But when the system cannot read a block from the disk when copying over, you are in trouble, even though the block likely still exists on your "broken" disk.
In the scenario where a disk goes "soft" offline (which has happened to me twice now with one of the M.2 WD_BLACK SN850X devices in my home system), i.e. it becomes inaccessible but is not broken, an extremely dangerous situation occurs: when the system is rebooted and the disk comes back online, the filesystem is totally toast because one of the members has not been kept up-to-date for a while and there is NO WAY to tell BTRFS that you want to re-sync that device nor to not use it for a while. Only thing that is possible is: physically remove de M.2 that was down, boot the system from USB, mount the filesystem(s) with "-o degraded", convert the RAID1 on the remaining device to SINGLE, shutdown and put the M.2 in again, boot the system from USB, clear the partition then add the partition to the filesystem again and convert back from SINGLE to RAID1.
It is totally broken. There should be some sequence number on devices, when one of the devices in a RAID1 gets inaccessible, the number should be incremented on the other one, so that when the system boots with both again available the system knows which one is the more up-to-date and re-sync to the other. I think kernel RAID does that, but BTRFS raid for sure does not. That makes it unusable without a watchful eye. And it is also insane that it does not allow to remove an (inaccessible) disk from a configured RAID-1, bringing it effectively back to SINGLE. At least kernel RAID does allow that.
From what I understand the U.2 slots in the ROSE storage device are hot-swappable. That is a disaster waiting to happen with BTRFS.
sirbryan
Thu Feb 27, 2025 7:34 pm
@pe1chl, I have an idea. How many peers do your routers have?
I think some of the BGP bugs in 7.15.x and 7.16.x have to do with the number of peers, along with the proclivity for routes to come and go.
For example, my borders peer with five different upstream peers and three downstream peers, as well as with each other. Routes are coming and going as network conditions change both internally and across the world. Since all of them announce everything to each other, that's a lot of updates across 8-10 peers, and with 7.16.x I found many routes in the RIB didn't match what was actually happening ("stuck routes"). I'd eventually have to reboot the router because traffic would loop up or stall, or the router itself began to slow down.
With the internal routers, on 7.15.3, they were running into memory issues and randomly rebooting every week or so. Upgrading them to 7.16.2 solved that problem. Routes don't seem to get stuck, despite internal network changes (60GHz links going up and down, other random wireless drops). But then, each of those routers only has two peers: the route reflectors.
My route reflectors were also showing odd behavior on 7.16.x; once I moved them to 7.15.3, they've been pretty solid, and their memory utilization is holding at 280MB (they're CHR's with 1GB of RAM).
Bottom line is that 7.16.x with a low number of BGP peers seems to work fine, and 7.15.3 with lots of peers seems to work fine, but uses more memory than 7.16.x on small-memory routers/switches.
oreggin
Thu Feb 27, 2025 7:41 pm
As far as I can remember, I replaced a faulty disk in BTRFS only once, there is a replace function, there is no need to convert it to anything.
https://wiki.tnonline.net/w/Btrfs/Replacing_a_disk
pe1chl
Thu Feb 27, 2025 7:45 pm
But you cannot replace a disk with the same disk, that is the problem.
toxicfusion
Thu Feb 27, 2025 7:49 pm
[*]Rose Data Server Confluence page was published 1 hour ago.
I stand corrected and validated regarding the point I made surrounding the rush release of v7.18 in support of their RDS hardware announcement.
Also, BTRFS is dead, PITA to manage groups of disks. MikroTik, if you F(&*& listening...... implement OpenZFS instead of BTRFS....... This will be better received, more support and benefits.
MikroTik will also need to create a way, or within Winbox UI for the DISK MANAGEMENT. Functions of adding disks to RAID or if they instead goto ZFS.. create vdevs and zpool. Without proper disk management, this is DOA. .... what about blinking LED of disk for locating? If you want to be a NAS.. you need the features. DOA DOA
RouterOS == stick to routing.
StorageOS [ROSE] == focus on storage.
The idea of combining solutions is cool... but need to friggen up your game on software quality, this is bullshit mikrotik. Trying to do what Synology and QNAP has done for YEARS [DHCP server, AD, etc] on their NAS
What about AD/LDAP join for user management? Enterprise my ass.
Also, I concur with question of how they will prioritize the routing processing over storage, renice -19 is an idea. Or dedicate CPU resources to speciifc items. Similar to what Palo Alto does....
Larsa
Thu Feb 27, 2025 7:55 pm
n/a
nipfel
I managed to repro issue with locking.
There was default rule:
chain=input action=drop in-interface-list=!LAN log=no log-prefix=""
I was not able to log in to inbox thru input until I added another one exactly the same rule after that default.
Adding supout here. I believe that there is a hidden issue with defaults.
oreggin
Thu Feb 27, 2025 8:10 pm
Yes, it needs hotplug, but I dunno if it is supported in RDS. An enterprise storage has hotplug support, so crew can replace faulty disks on-the-fly.
Larsa
Thu Feb 27, 2025 8:14 pm
@oreggin; the Wiki describes a planned disk replacement, but @pe1chl ran into an unexpected failure. Since Btrfs RAID1 doesn’t have automatic resync, it might be unreliable when disks go offline (kernel RAID handles resyncing differently)
Beyond what @pe1chl mentioned, there are plenty of other risks that haven’t even been brought up in the forum. With no recovery or repair kits available and a lack of documentation, one might wonder if MT did any real risk assessment at all before choosing Btrfs and (IMO, prematurely) released the RDS2216.
Two essential questions MT must be able to answer:
- What happens if the Btrfs file system fails?
- How do you perform a full system backup?
Check this out: viewtopic.php?p=1129574#p1129574
sinisa
Thu Feb 27, 2025 8:34 pm
I think that you understood perfectly what I wanted to say.
Yes, I know that every device which works with files has to have a file system, but I don't want to worry about that, not even think about that, on a ROUTER (btw: what fs is used for ROS rootfs?). And by removing unnecessary things like fs modules MT could free precious space on 16MB devices (and there is plenty of them still being sold). I don't know how much space they consume on ARM(64), but on my x86_64 Linux RAID, brtfs, ext4, and smb server modules take more than 2MB zst-compressed, and 2 MB is plenty for a 16MB device. There are probably more things that could be removed/made optional on a ROUTER without hurting it's function.
And I also don't like to have on my router: BTH, Zerotier, nor any other "cloud" service that I don't control in full (but I understand that not everyone knows how to set up their own VPN). Now, ZT is optional, so that's fine, BTH is not configured, so hopefully not active...
infabo
Thu Feb 27, 2025 8:57 pm
btrfs is part of rose package. Dont worry. But there is ext4, fat32 and exfat support in routeros package AFAIK. Some devices have USB ports and some people want to use USB sticks. When not for SMB, then just for e.g. container storage and or log storage.
And btw, I think this controversial discussion should be continued over here: viewtopic.php?t=214539
Because once 7.19 shows up, this topic is going to be locked. All discussion lost.
antiqued4
Thu Feb 27, 2025 9:46 pm
On the subject just above BGP, on a CCR2216, with several Peers, I noticed a behavior, in versions above 7.15.3, currently on 7.17.2
It turns out that depending on what you change, do an update of routes something like that, you can notice in the LOG that the OSPF sessions all drop and come back, then the BGP sessions drop and come back, but the internet stops working, basically it appears that all the routes are "stuck", after a reboot everything goes back to normal, CPU is more or less at 36%.
I will check in the near future, with this version.
KiwiBloke
Thu Feb 27, 2025 9:49 pm
Client (CubePRO) 7.12.1 -> upgrade to 7.18. Client does not boot
I could be wrong, but I think you need to upgrade to 7.13 first, then to 7.18. There were some major changes to the way packages were handled requiring the step to 7.13 first. Maybe someone could correct me if I'm wrong.
elmemis
Thu Feb 27, 2025 11:36 pm
*) bgp - make NO_ADVERTISE, NO_EXPORT, NO_PEER communities work;
If you use
set/append bgp-communities no-export/no-advertise/no-peer
in filters, it does not work, and the filter stops processing the prefix.
eleven
Fri Feb 28, 2025 1:48 am
@oskarsk - Can I assume this fix will be part of 7.20 stable and not 7.19?
nishadul
Fri Feb 28, 2025 3:37 am
This script is not working, Please check
:global Var1
:global Var2
:set Var1 "$[/system routerboard get upgrade-firmware]"
:set Var2 "$[/system routerboard get current-firmware]"
:if ($Var1>$Var2) do={/system routerboard upgrade;
:delay 8s;
/system reboot;
leonardogyn
Fri Feb 28, 2025 3:50 am
Because of the problems with CBC encrypt with OpenVPN (and maybe other places) on the MMIPS platform, I have changed a management VPN network I have, used to manage a bunch of different models of MK routers, to now use AES-256-GCM instead of AES-256-CBC. While I know 7.20dev is already available here, I'm really not looking to run a test version on some production MK routers that are really serving some networks. To avoid that, changing my VPN network to GCM instead of CBC seemed to be the quick fix. And to the most part, it worked fine, VPNs are now fully established with v7.18 even on RB750Gr3s which presented the serious problem with CBC and v7.18.
However ... after changing that, I started noticing some errors coming exclusively from RB4011 routers, which seems to be the only model I use on the ARM32 platform. Example:
Feb 27 22:23:53 unifi openvpn[314096]: cliente-XXXXXX-01/177.xx.xx.xx:49625 AEAD Decrypt error: cipher final failed
And more than that, I started noticing some packet loss SPECIALLY with big packets and some fragmentation involved (RouterOS OpenVPN implementation don't hav all the MTU/fragment options OpenVPN offers to fine control that). For example, with the VPN established (using AES-256-GCM), and pinging from my VPN server host (a regular AlmaLinux box) to one RB4011 connected via this VPN instance, and forcing a packet size that will require some fragmentation (don't even need to be that big), I have severe packet loss:
[root@unifi openvpn-mikrotik]# ping 172.30.1.94 -s 1550 -c 50 -q -f
PING 172.30.1.94 (172.30.1.94) 1550(1578) bytes of data.
--- 172.30.1.94 ping statistics ---
50 packets transmitted, 36 received, 28% packet loss, time 646ms
50 packets transmitted, 37 received, 26% packet loss, time 652ms
(eventually, no loss occurs, but that seems to be really exception)
50 packets transmitted, 50 received, 0% packet loss, time 667ms
50 packets transmitted, 35 received, 30% packet loss, time 640ms
50 packets transmitted, 29 received, 42% packet loss, time 624ms
After changing my VPN server instance back again to AES-256-CBC, packet loss (and the "AEAD Decrypt error: cipher final failed" message) complete goes away, even with a much bigger packet size (used 30000 bytes on the next tests, much bigger than 1550 on the previous ones). And no packet loss at all, with AES-256-CBC
[root@unifi openvpn-mikrotik]# ping 172.30.1.94 -s 30000 -c 50 -q -f
PING 172.30.1.94 (172.30.1.94) 30000(30028) bytes of data.
50 packets transmitted, 50 received, 0% packet loss, time 611ms
50 packets transmitted, 50 received, 0% packet loss, time 730ms
50 packets transmitted, 50 received, 0% packet loss, time 685ms
While I don't have other ARM32 equipped MK routers, and the RB4011 is the only one on that platform I have available, it really seems there's still something wrong with GCM on this specific platform (or router model). All other platforms/models I have using this network, do not present the decrypt errors that I'm facing with RB4011s. I might have to test different models to see if some are also presenting packet loss, but at least no other model is presenting the "decrypt error" messages. I do have a CCR2004 (ARM64) available, will test on that platform by the morning, and will update here. Anyway, it really seems there's something still wrong with GCM on the ARM32 platform or, at least, on the RB4011s, as reported: lots of decrypt error messages AND a lot of packet loss, which completely go away while using CBC.
And while I'm reporting here on the v7.18 thread, I'm not really sure if the problem started on this version, as I was using CBC previously and changed because v7.18 introduced problem with that on MMIPS. Maybe this is not new and I'm just facing it now because of the change from CBC to GCM v7.18 kind of forced me to do.
leonardogyn
Fri Feb 28, 2025 4:26 am
UPDATE: updated one of the RB4011 routers "affected" by the decrypt errors/packet loss I just reported to v7.20ab37 (why not??), and nothing really changed. I'm still facing packet loss AND lots of decrypt error messages. Absolutely no changes, in regards of what I just reported, from v7.18 and v7.20ab37
Jotne
Fri Feb 28, 2025 8:16 am
:global Var1
:global Var2
:delay 8s;
/system reboot;
1. This has nothing to do with 7.18
2. Your error is that you are trying to test two string if one is larger than other. This is not numbers.
3. You do not need ; at end of scrip line. Only when you have multiple command at same line to separate them.
4. Why use global variable when you only set/used them in same script. Use local.
Cut and past this to terminal:
:local Var1
:local Var2
:delay 8s
:put "upgrade $Var1"
:put "current $Var2"
You will see this error:
Script Error: cannot compare if string is more than string
rextended
Fri Feb 28, 2025 10:03 am
The simplest, if you really like shooting yourself in the foot, is this:
viewtopic.php?t=214886#p1127217
infabo
Fri Feb 28, 2025 11:19 am
I hate to continue the discussion on this offtopic, but the referenced post shows how to update ROS - and not the routerboard firmware.
The simple solution for nishadul, who raised a completely non-7.18-related question here, is: use "!=" instead of ">". It is enough to know that version is different. And as a string comparison completely valid as well.
:if ($Var1 != $Var2) do
Jotne
Fri Feb 28, 2025 11:22 am
I did not post the solution, just pointed out what was wrong, to help the poster to try to figure out how to fix it and learn some from it ;)
rextended
Fri Feb 28, 2025 11:27 am
It's not the script that doesn't work, it's you who are unable to write it correctly.
I misread before, but just do this:
/system routerboard settings set auto-upgrade=yes
The routerboard does not auto-reboot to apply it (and not even in the previous script).
Just reboot the routerboard after each software update, since the "bios" is updated automatically.
pe1chl
Fri Feb 28, 2025 11:48 am
My main issues with BGP involve a network within a company with a headoffice and 4 branches.
Additional to that there are 2 test routers that act like branches.
Between the branches there are several kinds of tunnels: GRE/IPsec, GRE6/IPsec and L2TP/IPsec.
They form a partial mesh. Each site is a separate AS with private AS# so eBGP is in use.
The L2TP/IPsec tunnels are over LTE and should serve only as a backup in case the GREx/IPsec tunnels, that are over fiber or DSL, fail.
The main office has 14 BGP peers, the branch offices usually have 5 (3 to the main office and 2 to another branch).
Observations starting from 7.16 but still occurring in 7.18:
- the backup paths, that have a route filter that sets local preference 90, are often not stored in the route table at all. at first after boot they do appear, but after a while when the L2TP/IPsec tunnel has been down/up a couple of times, they no longer appear. BGP peer connection is up but prefixes show as 0. Only pref 100 routes are in the table after that. Problem: when the fixed internet connection fails, the routes to failover to the LTE are not in place.
- when the peer that is running over L2TP/IPsec disconnects (the LTE connections are disconnected by the provider every 8 hours so that happens regularly) in many cases other peers, over totally unrelated paths, disconnect at the same time and immediately re-connect.
- when a BGP peer has connected, it takes one "keepalive time" interval (default 60 seconds) before the routes are received by the connecting side. combined with the previous item that results in loss of routing for a minute.
These issues were not present in 7.15.3 so I would think it would be "easy" for the developers to look at what they changed in 7.16 and roll that back to correct the change.
The only specific answer I got on my ticket is that the developers are "aware of" the third item (the 1 minute delay) but it has still not been fixed.
As you can understand, when building a network that is supposed to be reliable and that was reliable before, I do not like it at all.
And we also cannot just go back to 7.15.3 because of another issue with the RB5009UPr+S+ branch routers that we use.
dang21000
Fri Feb 28, 2025 1:09 pm
Warning for people using this metrics exporter : https://github.com/akpw/mktxp/issues/229
Since 7.18, something is broken...
But the main question is why routeros don't provide it's own metrics endpoint...???
ACJM
Fri Feb 28, 2025 1:17 pm
What are you using for monitoring?
infabo
Fri Feb 28, 2025 1:37 pm
This is no mystery anymore. It is this change causing it:
*) console - put !empty sentence when API query returns nothing;
Wondering why this change is "console" and not "rest-api" or "www". But I dont want to start another Mikrotik changelog discussion. Maybe someone has the bigger picture an can explain why "console". Otherwise: it is what it is.
Larsa
Fri Feb 28, 2025 1:46 pm
I just realized I forgot to give a heads-up in this thread too, like I did in "v7.18rc [testing]":
Heads-up - breaking changes for management and monitoring:
wellyngtonsiqueira
Fri Feb 28, 2025 2:08 pm
After the update, openvpn is rebooting the rb on each external connection made. I went back to the normalized version 7.17.2.
Error log
RB750Gr3
itimo01
Fri Feb 28, 2025 2:13 pm
Error log
RB750Gr3
This hotfix is supposed to fix it:
pe1chl
Fri Feb 28, 2025 2:14 pm
Please read previous replies to a release thread before adding another.
wellyngtonsiqueira
Fri Feb 28, 2025 2:53 pm
Error log
RB750Gr3
Tks
hasmidzul
Fri Feb 28, 2025 3:35 pm
Do you guys have wifi disconnection on this 7.18?
sirbryan
Fri Feb 28, 2025 4:52 pm
This is the other thing that stands out to me. Some of my providers are set at lower preferences than others. But I don't use local pref internally.
utiker
Fri Feb 28, 2025 9:12 pm
I updated an ATL from 7.16 to 7.18. In general, everything seems to work as expected except this:
viewtopic.php?t=215194
dnwklin
Fri Feb 28, 2025 10:44 pm
On my RBM33G, Wireless module get disabled. I only have WIFI module enabled. My WIFI card is AC so I need wireless module. I tried multiple times to re-enable Wireless module without success. Any idea?
krafg
Fri Feb 28, 2025 11:16 pm
Upgraded all my devices without problems this time. All working well.
Regards.
t0mm13b
Sat Mar 01, 2025 11:48 am
Spotted difference when upgraded hap ax2 from v7.16.2 to v7.18, ran "beyond compare" on the resource scripts exported before and after upgrade
this was added in, however its not on winbox 4
/interface ovpn-server server add mac-address=AA:BB:CC:DD:EE:FF name=ovpn-server1
infabo
Sat Mar 01, 2025 2:08 pm
This ovpn server was explained several times. See 7.17 beta/rc/stable topics for more information.
deanMK
Sat Mar 01, 2025 3:00 pm
Will wait for 7.18.X that will sort it out this reported things.
gotsprings
Sat Mar 01, 2025 4:13 pm
Also have the voltage issue.
RB960PGS driven using POE from a CSS610-8P Shows Voltage of 0.0 Under Health.
Used a 60 watt POE injector and 960 still shows 0.0 For Voltage.
JanWerner
Sat Mar 01, 2025 7:39 pm
Upgrade broke CHR on Digital Ocean. Droplet won't start
AlexandruL
Sat Mar 01, 2025 8:04 pm
I have about 22 AP, I had some issues when running a mixed environment with CapsMAN and WiFi Capsman that were caused by using discovery interface instead of configuring the controller IP.
During the debugging I downgraded all the AP to 7.14.3 and everything worked perfectly.
The plan was to upgrade back to the newest version of RouterOS so I did, but 4 AP that were configured in an identical manner were no longer accessible after reboot. The only way to revive them was to netinstall, resetting only got them to etherboot mode.
The last 3 AP were hard to reach so I factory reset them and then did the upgrade, they all upgraded successfully.
labynko
Sat Mar 01, 2025 8:34 pm
Why doesn't the "Sync. Connection Tracking" option work for VRRP in version 7.18?
NaranKPatel
Sat Mar 01, 2025 8:42 pm
For me on 7.18 (on ccr1036) ipv6 neighbor in winbox disappears on reload? I think this maybe a bug? Possible some confusion since ipv4 and ipv6 neighbors appear to have the same title name in winbox window?
frankhe
Sat Mar 01, 2025 10:31 pm
Hi, I have a lot of issues with the new version 7.18 of RouterOS. The changes in the main navigation of the web interface and changes in which buttons appear on the right hand side is confusing and I notice that I move around less fast en less efficient compared to before. Things seems not to be displayed consistently. I am contemplating a downgrade back to version 7.16 if I remember correctly.
sirbryan
Sun Mar 02, 2025 4:37 am
*) chr/x86 - Realtek r8169 updated driver;
Does this include the Realtek 8126 updates to the 8169 driver, from kernel 6.12? I've got a couple of Realtek 5G M.2 NICs that show up in the PCI list, but the driver doesn't load for them.
manojlovicl
Sun Mar 02, 2025 11:38 am
hEX S in kernel panic reboot loop - I have reset router and re-applied configuration step-by-step and I found out that everything works until I enable OVPN Server - when I do that router starts to reboot (it comes online for 10-15 seconds - in this time I was able to make export of config :) )
loloski
Sun Mar 02, 2025 12:51 pm
/ip/ipsec/policy/set src-address=0.0.0.0/0 dst-address=0.0.0.0/0 numbers=0
CHR goes in limbo if you enable IPSEC policy with this parameter, we just stumble this accidentally during lab.
ahlvhin1985
Sun Mar 02, 2025 3:11 pm
When i upgrade my hap ax3 to v7.18 from v7.16.2, there is a problem on the hotspot/host between DHCP (H) and Dynamic (D). Now, everytime there a new connection on the hotspot, it always connect as Dynamic (D) that never happened on v7.16.2 or lower. Happens also on v7.17.X.
So, as of now, I currently downgrade it on v7.16.2 and went back to normal.
DJGlooM
Sun Mar 02, 2025 5:25 pm
Hey guys. VXLAN is broken\changed again with 7.18
I have vxlan bridged untagged on both sides and esxi with the same tagged vlan in the same bridge. After update couldn't reach VCenter VM to ESXi interface with the same vlan over vxlan. Had to enable local-proxy-arp on vlan interface of CCR.
nexusds
Sun Mar 02, 2025 6:19 pm
I opened a ticket for this. Try disable HW option in your interface and also confirm the ports are the new default if you are using VTEP.
JhnMtrx
Sun Mar 02, 2025 7:41 pm
Hello, since 7.18, there is no client activity listed in Kids Control in WinBox
elcano89
Mon Mar 03, 2025 1:17 am
*) l3hw - remove VLAN tag before VXLAN encapsulation (fixes pvid behavior for bridged VXLAN);
Just saw this fix in the beta 7.19 release
BBCWatcher
Mon Mar 03, 2025 6:49 am
I am linking to my old posts in the 7.18 beta thread:
viewtopic.php?t=214071&start=300#p1125166
viewtopic.php?t=214071&start=300#p1125183
MikroTik does have the possibility to free up at least 565KB (38KB from the useless .woff2 font files) for those AC devices with 16MiB flash if they care.
I'm also concerned about RouterOS 7.18+'s footprint on 16MB flash devices with the wifi-qcom-ac package. One of the objections raised is that having 3 "wifi-qcom" packages instead of 2 would be more complicated. It would be, but I don't think it's necessary. In fact, I think the current split could be made LESS complicated. Continue offering only 2 packages, but instead there'd be a "skinny" package called wifi-ipq401x and a "fat" package called wifi-qcom. The wifi-ipq401x package would include ONLY the drivers and firmware for IPQ4018 and IPQ4019 devices -- all that's needed but no more than what's needed for the 16MB flash devices. The new wifi-qcom would include everything that's in today's wifi-qcom-ac and wifi-qcom packages. Owners of >16MB flash IPQ401x devices such as the hAP ac3 could run either wifi-ipq401x or (new) wifi-qcom, as they prefer.
That's a short-term fix. In the medium-term it'd be nice to have a base "skinny" RouterOS package (with enough function to "get going") and to allow loading of cryptographically signed "secondary" packages from USB- and even network-attached storage. The onboard flash storage configuration would still strictly control whether any packages are loaded from "external" storage, and which packages. This sort of approach would probably make RouterOS easier to maintain and easier to test.
EdPa
Re: v7.18.1 [stable] is released!
Mon Mar 03, 2025 10:55 am
What's new in 7.18.1 (2025-Feb-28 13:31):
*) bridge - improved stability in case of configuration error (introduced in v7.15);
*) bridge - show warning instead of causing error when using multicast MAC as admin-mac (introduced in v7.17);
*) cloud - fixed issues when BTH is toggled fast between enable/disable;
*) cloud - improved "BTH Files" web page design;
*) console - fixed issue with files when using scripts (introduced in v7.18);
*) console - improved file add/remove process stability;
*) dhcpv6-relay - clear saved routes on DHCP release;
*) dhcpv6-relay - show client address;
*) disk - add "sector-size" property in print detail;
*) disk - improved stability when formatting crypted partitions;
*) lte - fixed modem recovery after firmware upgrade for R11e-LTE modem;
*) lte - fixed Router Advertisement processing issue for AT modems when an APN with "ip-type=ipv6" was configured;
*) ovpn - disable hardware accelerator for GCM on MMIPS CPUs (introduced in v7.18);
*) poe-out - fixed health showing 0V voltage when using PoE-in for RB960;
*) poe-out - upgraded firmware for 802.3at/bt PSE controlled boards (the update will cause brief power interruption to PoE-out interfaces);
*) route - show BGP session name instead of cache-id;
*) switch - improved stability when enabling IGMP snooping with VXLAN (introduced in v7.18);
*) system - improved internal "flash/" prefix handling for different file path related settings;
*) winbox - fixed missing SMB client on non-ROSE devices;
chrisfr
Mon Mar 03, 2025 11:03 am
Since we can remove the wifi pakage, i had add rose-storage and container on my crs305. The disk space was short, but i was ok.
After upgrade to 7.18, disk is full and my logs are flooded of error, and i can't uninstall container or rose-storage package (it does nothing when i try).
edit : try to upgrade to 18.1, but it hang at 80%
LordNikkon
Mon Mar 03, 2025 12:03 pm
On one hand OVPN issue with boot cycle was solved. Now what i see is that dowloading new IOS is very slow.
infabo
Mon Mar 03, 2025 12:04 pm
I kindly request documentation update for the following changelog item in the wifi docs (https://help.mikrotik.com/docs/spaces/R ... 59120/WiFi):
*) wifi - implement steering parameters to delay probe responses to clients in the 2.4GHz band;
Thank you!
infabo
Mon Mar 03, 2025 12:30 pm
Today was the day I thought, 7.18.1, now I can upgrade. But it did not upgrade:
 2025-03-03 11:22:21 system,error upgrade failed, free 13 kB of disk space
 2025-03-03 11:22:21 system,error GENERAL: upgrade failed, free 13 kB of disk space
Well yeah, before upgrade I checked system resources:
                  version: 7.17.2 (stable)
           free-hdd-space: 168.0KiB
          total-hdd-space: 16.0MiB
        architecture-name: arm
               board-name: D53G-5HacD2HnD
                 platform: MikroTik
Yeah, 168kib is not much. But again: yet another major release consuming more space. 7.14 was a disaster (space wise). 7.15 regained quite a lot of space. Since 7.16 decreasing space again. Now 7.18.1 - and my device can't upgrade. Leaves me puzzled.
Upgrading cap ac (dumb AP, wifi-qcom-ac in caps-mode with zero manual config) worked. But again, free space is less.
           free-hdd-space: 408.0KiB
               board-name: cAP ac
                 platform: MikroTik
                  version: 7.18.1 (stable)
           free-hdd-space: 292.0KiB
               board-name: cAP ac
                 platform: MikroTik
rextended
Mon Mar 03, 2025 12:55 pm
I could understand for the peripherals that were born with RouterOS v6,
but for a peripheral that was born with v7 (am I remembering wrong?)
they should make dedicated packages where useless drivers for all the other individual arm models are not put...
Have you tried if netinstall + .rsc does the magic?
infabo
Mon Mar 03, 2025 12:59 pm
Indeed. product-specific (or board-specific) packages not containing unused/useless drivers could probably regain some space.
AlexandruL
Mon Mar 03, 2025 1:01 pm
You could netinstall with keep old configuration, but as the fine manual says: The "Keep old configuration" process involves downloading the configuration database from the router, reinstalling the router (including disk formatting), and uploading the configuration files back to it. However, it's important to note that this process solely applies to the configuration itself and does not impact the files, including databases like the User Manager database, Dude database, and others.
Maybe it will clear some space.
rextended
Mon Mar 03, 2025 1:19 pm
He already knows it...
viewtopic.php?t=202945#p1045773
mkx
Mon Mar 03, 2025 2:25 pm
I can confirm that ROS 7.18.1 on ARM uses around 200kB more of flash storage than 7.17.2 ... on hAP ac2 with only base (routeros) package installed.
jlgonzalez
Mon Mar 03, 2025 2:33 pm
There is a bug with error reporting when executing scripts from a scheduler. If I run a script that contains a :return statement from the terminal, everything works correctly and no error is logged. However, if I run the same script from a scheduler, the script is also executed but an error appears on the log (executing script lte-recovery from scheduler failed, please check it manually).
This issue was addressed in version 7.17. However, it seems that it is not completely fixed. Have anyone also else experienced this?
PD: I know about *) console - allow to toggle script error logging with "/console settings log-script-errors"; and I don't see it as a clean solution!
rextended
Mon Mar 03, 2025 2:35 pm
@jlgonzalez
Don't pollute this topic unnecessarily, open a new one in Scripting for this thing and show the script.
ecylcje
Mon Mar 03, 2025 3:59 pm
Does anyone else have any issues with POE devices in 7.18.1?
My Pi zero POE Hat no longer functions, and only seems to advertise 10Mbps and connect with 10Mbps. No connection to the Pi Zero is possible with this connection. (No ping or ssh connections)
When I downgrade back again to 7.17.2, then it starts working again, advertising and connecting at 100Mbps.
I had the same issue with 7.16.2 and 7.17, but it seemed to be fixed with 7.17.1 and 7.17.2.
I have always upgraded the firmware post upgrade to 7.18.1, and it does seem to be related to this area, because I have to downgrade it to 7.17.2 to make things work as expected in this lower version.
Thanks,
Chris
faux
Mon Mar 03, 2025 5:06 pm
In good news our CCR2004 updated to 7.18.0 fine, including firmware. Also an RB4011 but that literally just has VLAN bridging right now.
The only funky config we have is a (still working) IKEv2 VPN using GCM, DoH to a custom gateway, and 38,146 ip firewall rules lol. All works perfect :)
rextended
Mon Mar 03, 2025 5:24 pm
38,146 only on firewall filter????......
wispmikrotik
Mon Mar 03, 2025 5:27 pm
They will be IP in IP >Firewall>Address-List. Otherwise, he'll be completely crazy xD
Regards,
rextended
Mon Mar 03, 2025 5:29 pm
Ahhhh, not rules, addresses.... 🙃
Effort for effort, put 7.18.1 instead of 7.18[nothing], it fixes more issues related to those written than it seems...
Maggiore81
Trainer
Trainer
Mon Mar 03, 2025 9:36 pm
@ chiem My understanding is that fast-path is only used if many conditions are met, one of which is no firewall filter rules.
My counters show similar 0 ipv6-fast-path-packets and bytes values.
Exactly... I have the checkbox enabled,
no firewall rules, nothing for ipv6, but counters are not going up.
nexusds
Mon Mar 03, 2025 11:09 pm
Doesnt work for me - nor in 7.18.1. still need to disable HW option in vlan
jef152
Re: v7.18.1 [stable] is released! Can't update CCR2116-12G-4S+
Mon Mar 03, 2025 11:55 pm
Just as an fyi for anyone here (I did create a support ticket, SUP-181012). I have a CCR2116-12G-4S+, with two partitions, each running 7.17.2 (they failover to the other if something breaks). When attempting to update to 7.18.1, via the Webfig, the system downloads the update, reboots and after about 5-8 minutes, it eventually reboots/fails over to the other partition. The steps I tried:
-Booted on partition 0 (7.17.2)
-Ran 'Download and Install ' in Packages
-System downloads and reboots.
-After the reboot, something fails and the system reboots again and fails over to partition 1
-On boot of the working partition 1 (7.17.2), partition 0 shows as being updated to 7.18,1. Log shows the following message:
'router was rebooted without proper shutdown, probably kernel failure'
I then copied the currently booted working partition 1 7.17.2 over to partition 0 as backup and attempted to update partition 1 to see if there was any difference, but same result.
Kentzo
Forum Veteran
Forum Veteran
Tue Mar 04, 2025 1:26 am
Major downgrade in wireless performance on hAP ac lite / RB952Ui-5ac2nD (7.18.1) over 2.4Ghz link as a station of hAP ax3 AP (7.17.2): x10 latency and frequent packet drops. Downgrade to 7.18 resolves the issue.
infabo
Tue Mar 04, 2025 1:33 am
                 platform: MikroTik
Just netinstalled this device. 7.18.1 is now running, but flash-space is tight.
           free-hdd-space: 44.0KiB
                 platform: MikroTik
And after a reboot I now see:
2025-03-04 00:39:54 system,error,critical could not save configuration changes, not enough storage space available.
2025-03-04 00:40:41 system,error,critical could not save configuration changes, not enough storage space available.
No space is left.
           free-hdd-space: 0
                 platform: MikroTik
Now, not even /system/reboot is possible. It times out.
/system/reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
TMS1
Tue Mar 04, 2025 1:58 am
On hAP AX^3 after the 7.17.2 -> 7.18.1 update of ROS and RouterBOARD cannot connect to wifi1 (that utilized local User manager as RADIUS server).
After enable debug log and investigated it deeper.
manager, debug !---> DEBUG: >>> DROP rx from [127.0.0.1]:34974, reason: unknown router IP
And yes the defined router disappeared.
 > /user-manager/router/print
Flags: X - disabled
Empty list.
Certificate is also missing from Settings of User Manager
 /user-manager> print
               enabled: yes
   authentication-port: 1812
       accounting-port: 1813
           certificate: none
          use-profiles: no
  require-message-auth: yes-access-request
No defined Users, no User Groups seems the whole User Manager has been reset to factory default.
Update:
Connection problem solved.
After redoing the configuration of User Manager by hand, and resyncing the Shared secret between /user-manager/router and RADIUS.
wifi1 works again.
Lesson learned:
It was a good decision to document what I did and store commands needed to reproduce my config in text files.
Another problem discovered: my files and directories are disappeared from internal storage.
The Pi-hole run in a container also lost it's configuration and the config could be restored partially using it's Teleporter feature.
Opened a SUP request.
pe1chl
Tue Mar 04, 2025 11:00 am
In such cases support will advise to connect a computer to the serial port and run a terminal application with logging.
There will be diagnostic output on the serial port that is sent before the system reboots, and is not available via the network.
(of course it isn't always that easy to do that... in the meantime I have a permanent serial cable between the router and a server so I can do this without physical visit)
pe1chl
Tue Mar 04, 2025 11:07 am
                 platform: MikroTik
It looks like your use-case is finished, and you need to either remain on a lower version or remove one of the packages.
It is only to be expected that when you have a 16MB device and you happen to find a set of packages that "just fit", over time you will get issues because the packages get larger as fixes and new features are added.
I have learned my lesson and I DON'T BUY any MikroTik devices that have 16MB flash anymore.
Of course it is a bit sour to have a "flagship home router" that is limited like this. That is likely why it is discontinued.
I know the feeling, I have another "flagship home router" the RB4011iGS+5HacQ2HnD which does not have a storage problem, but instead it has two different WiFi architectures and it does not support 2GHz once you install wifi-qcom.
So I do not recommend that one to others either...
infabo
Tue Mar 04, 2025 11:21 am
I wouldn’t buy a router with 16MB flash anymore either. However, when I purchased it in 2020, it was (to my knowledge) the first "native" v7-only RouterOS device, which one might have assumed would be a meaningful distinction.
That said, I’m not ready to retire the device just yet. I could free up some space by removing the container package, and I also have wifi-qcom-ac installed only as a fallback - allowing me to toggle the WiFi interface via the WPS button in case my CAP goes offline. But in practice, it’s functioning solely as an LTE router without wireless, so there’s still sufficient space for (some) future updates.
Nonetheless, it’s disappointing to see the base package consuming more and more flash without offering any noticeable benefits (at least for my use case).
bratislav
Tue Mar 04, 2025 11:42 am
                 platform: MikroTik
It seems to me that someone at MT forgot to compress few binaries in 7.18.1 ARM package like login, graphing, trafficgen etc. so they are now using much more of already pretty limited 16MB storage space...
Also 16MB devices just cannot support wifi-qcom-ac which is almost 1MB larger than old wireless package, not to mention OOM issues...
And adding new binaries, like 180kB sshfs, however nice doesn't help and makes entire routeros unusable on 16MB devices...
Probably the better long term solution to this would be to split huge monolithic routeros package into something essential and put some extra stuff like totally useless lcdstat (only RB3011 arm device has LCD as far as I now and even there LCD uses to much CPU to make any sense), wproxy, hotspot etc. into separate packages. It would require some additional effort on developers side to repackage and maintain but will avoid issues on consumer side which should be a good thing IMHO...
loloski
Tue Mar 04, 2025 12:02 pm
This storage woes will not happen in the first place if only mikrotik don't offer 16MB flash in their product they can pass on this to consumer they are just crazy and masochist for shooting themselves on the foot for making an extra effort to fix this storage woes without wiggle room and in the end nobody wins I hope someday they become pragmatic and make sane decision
infabo
Tue Mar 04, 2025 12:09 pm
16MB devices support it. Look at my free-space report to "cap ac". This little device is capable of running 7.18.1 and still has enough free space. But there is a clear trend.
11431552  routeros-7.13-arm.npk
11755104  routeros-7.14-arm.npk
11553008  routeros-7.15-arm.npk
11608756  routeros-7.16-arm.npk
11887342  routeros-7.17-arm.npk
12076474  routeros-7.18-arm.npk
12158782  routeros-7.19beta2-arm.npk
12171054  routeros-7.20_ab57-arm.npk
The "reboot" of Chateau LTE12 has now 32MB flash (instead of 16MB). With apparently the same board - just a different LTE modem. https://mikrotik.com/product/chateau_lte12_2025 Why now?
pe1chl
Tue Mar 04, 2025 12:12 pm
I think the newly introduced products where it can be expected that users have more than basic needs (i.e. excluding switches) are no longer released with 16MB of flash. But we can all agree it was a stupid move from the beginning.
Splitting stuff into packages introduces the issue that merely having a separate package introduces storage overhead as well, so the total of a base package and the options that are now included in the routeros package will be more than everything in a single package.
So that only solves a problem when the optional package is sufficiently "niche" and likely only to be used on devices with more than 16MB.
Support for LCD might fit well into that category.
infabo
Tue Mar 04, 2025 12:16 pm
What type of package manager introduces such a significant storage overhead? OpenWRT has been using "opkg" for years without issues. However, OpenWRT also provides board-specific builds - perhaps this is the key to addressing flash storage limitations on 16MB devices.
That being said, I have shared all relevant details. I reported the available free space on my devices running 7.18. Additionally, I performed two netinstalls on my Chateau LTE12: once to upgrade to 7.18.1 and again to downgrade to 7.17.2, as the lack of free space prevented a direct downgrade. I have gone through this and provided the necessary information. Others should be aware of potential storage constraints.
irrwitzer
Tue Mar 04, 2025 3:00 pm
I am not sure yet, what or why it's happening, but:
v7.18.1 partly breaks my IPv6 setup on CHR boxes.
I can't even ping their loopback IPv6 addresses, even though they are actively seen in the routing table and redistributed in OSPF.
This *might* just be some stupid firewalling that breaks because of a change between versions, but I don't see which.
After downgrading to v7.18.0 they are fine again.
The same does not happen on a LtAP, meaning physical MIPS device.
BUT this device does have a different config, so it might not be the platform, but the config that makes the difference.
Just wanted to quickly let you know as a warning, will dig deeper, when I have the time for it.
[Update 2025-03-05]: Upgraded again, router after router - could NOT reproduce this error, so maybe just bad timing... or bad luck. sorry for the false alarm!
BR,
Irrwitzer
leah
Re: v7.18 [stable] is released!
Tue Mar 04, 2025 3:57 pm
Ping Exporter:
https://github.com/czerwonk/ping_exporter
irrwitzer
Tue Mar 04, 2025 4:02 pm
Maybe you'll like SuperQ's Smokeping Prober https://github.com/SuperQ/smokeping_prober
pe1chl
Tue Mar 04, 2025 4:17 pm
After boot we get this message once: possible SYN flooding on tcp port 53
(I don't know at which version that started, but it was "recently")
DNS service is only allowed from the local networks, not from the internet. There are hundreds of clients on the network and "SYN flooding on tcp port 53" is a normal situation.
Now while I am debugging something else I see the router did not answer a TCP connection to port 53.
I presume the message is logged only once, but the issue re-occurs. This causes delays for the clients.
Please advise how we can avoid this situation.
Max concurrent TCP sessions is configured at 1000, that should be enough.
erlinden
Tue Mar 04, 2025 4:57 pm
How often does it reoccur, @pe1chl? I have seen this message a couple of times, haven't found the cause yet (other then that it is my work laptop). Doesn't bother me that much, most DNS requests are UDP.
pe1chl
Tue Mar 04, 2025 5:31 pm
It is logged exactly once after every reboot. But I think that is because there is some "one time only" flag in the code to avoid overflowing the log with messages like that.
However, I was watching a wireshark capture running on a PC that has "spurious delays when visiting websites" and I saw that it was connecting to port 53 on the router and got no response.
Then I tried a "telnet x.x.x.x 53" from my own system and got a connection, so it isn't blocking all connects, at least not indefinitely.
bajodel
Long time Member
Long time Member
Tue Mar 04, 2025 5:51 pm
I noticed the same: logged exactly once after every reboot.
I'd like to have more control/visibility over this as well.
CGGXANNX
Long time Member
Long time Member
Tue Mar 04, 2025 6:24 pm
I think the reason this has a high probability of appearing at reboot is because while the router is being rebooted, clients in the network are still firing DNS queries at it (everything requires address resolution and TTL are nowadays quite short). Normally the queries are made with UDP and are not affected by the TCP SYN flood detection. But because the router can't answer while being rebooted and the timeout for UDP DNS queries is very short, I think 1-5 seconds depending on the OS (Windows starts with one second https://learn.microsoft.com/en-us/troub ... n-timeouts), the clients will quickly retries a couple of times. After that, they normally switch to TCP 53 and issue the queries again, also with shorter timeout than other normal TCP connections (because DNS shouldn't hold back everything else for too long). If the router comes back online during this period, it sees a lot of simultaneous TCP connection attempts at port 53, temporarily blocks the port and writes the log message. After this point it can answer UDP DNS queries again and most queries succeed over UDP, which means the temporary blocking doesn't affect much.
If WinBox was the one issuing the reboot command, it too will repeatedly tries to reconnect to the WinBox port 8291 and sometime you may also see the flood message at reboot for 8291, and WinBox takes longer to reconnect (PC already has access to internet but is unable to login to WinBox for a few tens of seconds). Another port I could observe was 2828, apparently used by UPnP, although UPnP is disabled on my router.
pe1chl
Tue Mar 04, 2025 7:25 pm
I think the reason this has a high probability of appearing at reboot is because while the router is being rebooted, clients in the network are still firing DNS queries at it ...
Yes I think that could be part of the reason, but what I observe is that on our main office network where there is lots of equipment running 24h/day I see this message immediately after the reboot (and I considered the same thing as you), however on other locations I see the message when the people come in during the morning. E.g. this was logged after a scheduled reboot last night at 01:01 to update to 7.18.1:
2025-03-04T01:01:17+01:00 MikroTik HeadOffice possible SYN flooding on tcp port 53
2025-03-04T06:06:52+01:00 MikroTik Branch3 possible SYN flooding on tcp port 53
2025-03-04T08:24:20+01:00 MikroTik Branch4 possible SYN flooding on tcp port 53
2025-03-04T08:52:10+01:00 MikroTik Branch2 possible SYN flooding on tcp port 53
