bokili
RB411 upgrade or downgrade
Fri Feb 01, 2008 6:06 pm
We buy large quantity of RB411 and have few questions if somebody can help us:
1. Can this be upgraded to v3.2 and how as it came with version v3.0 rc12 ? We downloaded npk package for 3.2 version and it won't upgrade after reboot. Is there a different way for upgrading than in v2?
2. Can this RB411 work good with 2.9.50 version of Mikrotik RouterOS? I suppose in this case it will be no problem for downgrading ?
mrz
Re: RB411 upgrade or downgrade
Fri Feb 01, 2008 6:14 pm
1. Make sure you uploaded correct package. For RB400 routeros-mipsbe package should be used. Log should also have some entries about what went wrong during installation.
2. 411 is using new atheros cpu which is big endian, so 2.9 won't work on this board.
bokili
Fri Feb 01, 2008 6:36 pm
Thank you. Our administrator used mipsle and that is the reason why it didn't upgraded. Now it works..
RB411 have level 4 license. Will it always come with this version of ROS? RB133c have level 3
Gerard
Trainer
Trainer
Sat Feb 02, 2008 6:16 am
Level 4 is included with the first production batch. Future batches will include level 3. The same thing happened when the RB133c first came out.
-Gerard
Certified Mikrotik Trainer
Users browsing this forum: No registered users and 100 guests
